I got an "Ignition Lock Defective" error and the car is as described above. After a quick scan I have found an error in the module 5 (Acc/Start Auth.) and the result is presented bellow. I managed to compare with previous results and there is a modification on WSC number. Could that be the issue? I've changed already the ignition device and same situation. Any suggestion is welcome. Thank you.
Good scan 31.01.17:
Good scan 31.01.17:
Removed. Data from pirate copies of VCDS is not welcome here.
