Results 1 to 10 of 14
Thread: RLS Sensor gel pad
    Feb 2017
    RLS Sensor gel pad
    Hi All,
    Can anyone advise me where I will get a gel pad for the windscreen RLS Sensor on my Passat B7 please, is a genuine gel pad from VW the best route?
    Thanks in advance
    andrew
    16.4905° S, 151.7375° W
    Hi there...
    - Have not seen or found any replacement gel I would trust, so I would use the 'repair kit for rain sensor / housing upper part with silicone pad', part number [1K0-998-559]
    - Hope this helps,
    drpeter
  3. Likes Drew, Sebastian, Dana, Uwe liked this post
    Feb 2017
    Hi DrPeter
    Ive ordered the "repair kit" from my local VW Dealer should be ready for collection on Tuesday, have you had any experience fitting the repair kitThanks in advance Drew.
    Feb 2017
    New,genuine gel pad fitted, same problem, even with the box ticked the RLS says it's inactive.
    Anyone any ideas
    Cheers Drew
    Hi Drew ...
    - Sorry ... a little late here in my response,
    - Yes I have installed the repair kit before, as you may have seen, pretty straight forward, just make sure the surfaces are nice and clean before installation.
    Anyone any ideas
    When you can, could you post up a complete vehicle Auto-Scan, that way we can see the whole picture (controller info, fault codes, coding, etc)
    Thanks,
    drpeter
  7. Likes Drew, Uwe liked this post
    Feb 2017
    Hi DrPeter,
    first attempt at posting an Auto Scan, hope its correct.
    thanks for taking the time to help.
    Best regards Andrew.
    Saturday,18,March,2017,10:54:35:47792
    VCDS Version: 17.1.3.0  HEX-V2 CB: 0.4334.4
    Data version: 20170220 DS267.3
    VIN: WVWZZZ3CZDE119832   License Plate: NS55 RAS
    Mileage: 69560km-43222mi   Repair Order:
    Chassis Type: 3C (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 4F 52 53 56
              61 62 65 72
    VIN: WVWZZZ3CZDE119832   Mileage: 69560km-43222miles
    08-Auto HVAC -- Status: Sporadic communication error 1000
    46-Central Conv. -- Status: Sporadic communication error 1000
    Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 NB    HW: 03L 907 309 AE
       Component: R4 2,0L EDC   H28 4013
       Revision: 41H28---    Serial number: 00000000000000
       Coding: 00190012042701080000
       Shop #: WSC 00015 115 00000
       ASAM Dataset: EV_ECM20TDI01103L906018NB 003004
       ROD: EV_ECM20TDI01103L906018NA.rod
       VCID: 77AA196D5F46EFBF1C3-8022
       Part No SW: 3AA 614 109 AK    HW: 3AA 614 109 AK
       Component: J104   C2 450M V434 0055
       Revision: --H07---    Serial number: 00000006573603
       Coding: 0789262
       Shop #: WSC 05311 000 00000
       VCID: 76B4146954CC96B7075-8022
       Part No SW: 3AA 907 044 AG    HW: 3AA 907 044 AG
       Component: Climatronic   H03 0303
       Revision: 00001K02
       Coding: 0014004803
       VCID: 75B61365454A9DAF0EF-8020
    Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
       Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
       Component: BCM PQ47 H++  421 0465
       Revision: BD421001
       Coding: 0008000000000000049800805400816403510088426D85606480C7200041
       Shop #: WSC 05311 123 12345
       VCID: 41DEB7B54182610F627-8014
       Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 31011  26  0612
       Coding: 00B795
       Component: RLS 310113 05  54  0403
       Coding: E72B28
    00834 - Signal for Activation of Heated Rear Window
                        Fault Status: 00101001
                        Reset counter: 92
                        Mileage: 69568 km
                        Date: 2017.03.18
                        Time: 10:28:10
                            Term 15 Off
                        Voltage: 12.20 V
    Address 10: Park/Steer Assist (J446)       Labels: 3AE-919-475.clb
       Part No SW: 3AE 919 475 C    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0018
       Revision: --------    Serial number: 28261303102648
       Coding: 108005
       ASAM Dataset: EV_EPHVA18VW47X0000 001006
       ROD: EV_EPHVA18VW4280000.rod
       VCID: 3FDAB14D37F617FF143-806A
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__108 VW10 HI   2118
       Revision: 25018000    Serial number: 003L7P2GQRKI
       Coding: 0012344
       VCID: 7CA006416AE0CCE7711-8028
       Subsystem 1 - Serial number: 6332MTS621860213
       Subsystem 2 - Serial number: 6342MTS643060213
       Subsystem 3 - Serial number: 6351HTS6798GPBKJ
       Subsystem 4 - Serial number: 6361HTS6JM2CPBKJ
    Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
       Part No SW: 3C9 953 501 BN    HW: 5K0 953 569 AB
       Revision: FF010041    Serial number: 20130205101497
       Coding: 1182250000
       VCID: 76B41469584C96B7075-8022
       Coding: E20000
    Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
       Part No SW: 3AA 920 970 L    HW: 3AA 920 970 L
       Coding: 451F00
       Shop #: WSC 05314 115 00000
       VCID: 3C20C64126E00CE7311-8068
    12674816 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 92
                        Mileage: 69568 km
                        Date: 2017.03.18
                        Time: 10:30:37
    13631488 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 92
                        Mileage: 69568 km
                        Date: 2017.03.18
                        Time: 10:30:38
       Part No SW: 7N0 907 530 AJ    HW: 7N0 907 530 AJ
       Component: J533  Gateway H51 1634
       Revision:   H51       Serial number: 180113F2001228
       Coding: 462007
       Shop #: WSC 05314 000 00000
       VCID: 78A81A5152D8E0C7159-802C
                        Fault Status: 00110100
                        Reset counter: 92
                        Mileage: 69568 km
                        Date: 2017.03.18
                        Time: 10:30:38
                        Reset counter: 92
                        Mileage: 69568 km
                        Date: 2017.03.18
                        Time: 10:30:39
                        Reset counter: 92
                        Mileage: 69568 km
                        Date: 2017.03.18
                        Time: 10:30:16
       Part No SW: 0BS 907 554 C    HW: 0BS 907 554 C
       Component: Haldex 4Motion      4016
       Coding: 0000005
       VCID: 46D4A4A964AC4637575-8012
       Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
       Component:    IMMO         043 0404
       VCID: 3828DA511E5820C7D59-806C
       Component: SG EXT.PLAYER H19 0550
       Revision: A1001003    Serial number: 7664273541
       Coding: 020100
       VCID: 2A0CF019DCF4825753D-807E
       Part No SW: 3C8 035 279 B    HW: 3C8 035 279 B
       Component: RNS315-EU   H59 0319
       Serial number: VWZAZ2M5552656
       Coding: 040004010400110000019002
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 2A0CF019DC74825753D-807E
       Component: EUR_W_V4  0050
       Component: TUER-SG FT    002 0534
       Revision: 12110009    Serial number: 0006469125
       Coding: 0202B7
       Shop #: WSC 05311 115 00000
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 3536D36505CADDAFCEF-8060
       Slave Driver:
       Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0503
       Serial number: 00000003333255
       Coding: 010290
    68098 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 92
                        Mileage: 69568 km
                        Date: 2017.03.18
                        Time: 10:30:38
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 196    3305
       Revision: 00H22000
       VCID: 372AD96D13462FBFDC3-8062
       Component:    KSG PQ47 ELV 043 0638
       Coding: 0191020052830E76340494157C085FCE105C04
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AJ
       Component: EZE_2         H51 1634
       Coding: 00000008
       VCID: 6FBA210D2796A77FC43-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0004
       Component: TUER-SG BT    002 0534
       Revision: 14110009    Serial number: 0006485514
       Coding: 0202B6
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: 3634D46918CCD6B7C75-8062
       Slave Passenger:
       Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0503
       Serial number: 00000003338574
       Coding: 010290
              U1111 00 [008] - -
                        Reset counter: 92
                        Mileage: 69568 km
                        Date: 2017.03.18
                        Time: 10:30:38
       Revision:   H19       Serial number: 00000000767965
       Coding: 0022167
       VCID: 3634D469144CD6B7C75-8062
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AJ
       Component: Batt.regelung H51 1634
       Coding: 030F1859
       VCID: 71BE277531A2B18FD27-8024
       Component: J367-BDM  H07 0180
       Serial number: 00000000001491005380
       Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
       Component: RDKBERU30     H09 0010
       Serial number: 10000000194635
       ASAM Dataset: EV_RDKBERU30 003012
       ROD: EV_RDKBERU30_003.rod
    End----------(Elapsed Time: 01:33, VBatt start/end: 12.3V/12.3V)-----------
    Magdeburg, Germany
    Drew, where did that RLS came from? Brand new part? Please recode the RLS to 032B28 and let us know if that addresses the issue.
    Sort of related, while it was "deactivated" - did the wiper work with normal intervals or not at all?
  10. Likes Drew liked this post
  11. #8
    Feb 2017
    Hi Sebastian,
    I'll recode in the morning and yes the intermittent function works, as do the 4 speed settings, I'm I right in thinking if I untick the box though it says rain Sensor inactive because it's not ticked it means it's active if that makes sense or should it say rain Sensor active.
    The gel pad was a brand new part supplied by my local VW Main dealer.
    Thanks for your help I'll post results in the morning
  12. #9
    Feb 2017
    Hi Sebastian,
    Changed coding this morning as suggested,still no change, attached is an Auto Scan taken after the changes.
    thanks again for your input
    cheers Andrew
    Sunday,19,March,2017,11:28:37:47792
              61 62 65 72
    VIN: WVWZZZ3CZDE119832   Mileage: 69590km-43241miles
       Component: J104   C2 450M V435 0055
       Coding: 0789262
       Revision: 00001K02
       Coding: 0014004803
       Revision: BD421001
       Coding: 00B795
       Coding: 032B28
       Coding: 108005
       Coding: 0012344
       Coding: 1182250000
       Coding: E20000
       Coding: 451F00
       Coding: 462007
       Coding: 0000005
       Coding: 020100
       Coding: 0202B7
       Slave Driver:
       Coding: 010290
       Revision: 00H22000
       Coding: 00000008
       Coding: 0202B6
       Slave Passenger:
       Coding: 010290
    131842 - Switch for Rear Window Regulator
              B11F2 29 [008] - Signal Implausible
                        Reset counter: 93
                        Mileage: 69578 km
                        Date: 2017.03.18
                        Time: 11:25:30
       Coding: 0022167
       Coding: 030F1859
    End----------(Elapsed Time: 01:32, VBatt start/end: 14.8V/14.7V)-----------
  13. #10
    Magdeburg, Germany
    Drew, I had asked this earlier - the sensor itself, was that new or used? Why did you need a new gel pad in the first place? Did you retrofit / change anything in the car? Did you install a new/different windscreen?
  14. Likes Drew liked this post
