Hi everyone. I looked at the other thread in here about the tail light retrofit, but it did not really help much with this car. It currently has a euro headlight switch, LED tail lights and no bulb out codes. We picked ROW GTI from the drop down menu.
The problem is that we had to disconnect the wiring for the rear fog light as it was on all the time. Any ideas what is needed to make the rear fog function normally?
Thanks for any help!
Here is the autoscan that we did before changing the coding to ROW:
Chassis Type: AJ (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 37 42 44 46 52 56 65 77
VIN: WVWED7AJ6AW421150
1C-Position Sensing -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Not registered 0011
Address 01: Engine (CBF) Labels: 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AL HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0030
Revision: E3H23--- Serial number:
Coding: 0403010818070160
VCID: 70EF274963D3659E6B7-8025
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 015 - - Intermittent
Fault Status: 00101111
Date: 2047.15.31
Time: 31:63:63
Load: 0.0 %
Temperature: 32.0°C
Temperature: 29.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.811 V
001674 - ECM Power Relay Load Circuit: (J271)
P068A - 000 - De-Energized Performance Too Early - Intermittent
Date: 2047.15.31
Time: 31:63:63
Load: 0.0 %
Temperature: 24.0°C
Temperature: 24.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 10.795 V
001378 - System Voltage
P0562 - 000 - Too Low
Mileage: 84439 km
Date: 2047.14.06
Time: 00:01:28
Load: 0.0 %
Speed: 255.0 km/h
Temperature: 36.0°C
Temperature: 33.0°C
Voltage: 7.366 V
050217 - Implausible Data Received from Steering Column Control Module
U0429 - 000 - - Intermittent
Mileage: 84439 km
Date: 2047.14.06
Time: 00:00:21
RPM: 1623 /min
Load: 12.5 %
Temperature: 33.0°C
Temperature: 30.0°C
Voltage: 10.668 V
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B600C492400FB880C06E992190041300800
VCID: 78FF1F69CBA33DDEA37-802D
Reset counter: 46
Mileage: 84439 km
Date: 2047.14.06
Time: 15:17:05
Count: 7
Count: 3
Count: 28672
Count: 128
Count: 27904
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ROD: EV_ClimaBasis_SE36.rod
VCID: 75E1165DD4B140B6B81-8020
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: BCM PQ35 H+ 103 0576
Revision: 00103 AF
Coding: 6D180A1A90272A0480080081600005C441012186434D8D60648020200000
Shop #: WSC 23320 444 13807
VCID: 3561D65D9C3100B6781-8060
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 03051 23 0512
Coding: 009795
01800 - Light Switch (E1)
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 46
Mileage: 84439 km
Date: 2047.14.08
Time: 00:35:59
Term 15 On
Voltage: 12.95 V
Term 50 On
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 46
Mileage: 84439 km
Date: 2047.14.08
Time: 00:36:03
Term 15 On
Voltage: 12.80 V
Term 50 On
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R009RB7
Coding: 00003031
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3979DA6DB829E4D69C9-806C
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--000558RN00
Serial number: 3572MSME75044352ZZZN
Crash sensor for side airbag; passenger side:
Serial number: 3582MSME33233353ZZZJ
Crash sensor for side airbag; rear driver side:
Serial number: 3512QSME3E3E5B2FZZZF
Crash sensor for side airbag; rear passenger side:
Serial number: 3522QSME12515E2CZZZY
Serial number: 35527SME394F5721ZZZM
Crash sensor for front airbag; passenger side:
Serial number: 35627SME24507721ZZZ5
13635840 - Supply voltage
Reset counter: 86
Mileage: 84439 km
Date: 2047.14.06
Time: 15:17:36
9483264 - Seat Occupied Recognition
B10B4 00 [008] - Function Restriction due to Undervoltage
Reset counter: 86
Mileage: 84439 km
Date: 2047.14.06
Time: 15:16:52
9483008 - Seat Occupied Recognition
B10B3 00 [008] - Function Restriction due to Implausible Message(s)
Reset counter: 85
Mileage: 84437 km
Date: 2047.14.05
Time: 17:19:00
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000532
VCID: 78FF1F690BA33DDEA37-802D
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Coding: 00000130
00532 - Supply Voltage B+
Part No SW: 5K6 920 970 H HW: 5K6 920 970 H
Component: KOMBI H03 0305
Coding: 270F00
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
Reset counter: 86
Mileage: 84439 km
Date: 2047.14.06
Time: 15:18:19
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 040510F1022366
Coding: E9801F07001612000000
VCID: 69D94A2D400994562C9-803C
Mileage: 72165 km
Date: 2040.14.05
Time: 01:22:24
Reset counter: 86
Mileage: 84439 km
Date: 2047.14.06
Time: 00:51:50
00484 - Vehicle Position Recognition Control Module (J603)
Reset counter: 166
Mileage: 72165 km
Date: 2040.14.05
Time: 01:22:28
Component: IMMO H03 0305
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EADBB5210D0F1F4EA53-80BF
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Revision: A1001003 Serial number: 7668000486
VCID: 2643011151977B2EC1B-8073
Reset counter: 86
Mileage: 84439 km
Date: 2047.14.06
Time: 15:16:37
Reset counter: 86
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 HW: 1K0 035 274
Component: RNS315-NAR H03 0007
Serial number: VWZAZ2K8404220
Coding: 040500210100000000001000
ASAM Dataset: EV_RNS315VWNARV1UDS A01005
ROD: EV_RNS315VWNARV1UDS.rod
VCID: E1C9D20DF0395C16749-80B4
1048578 - Supply voltage
Reset counter: 86
Mileage: 84439 km
Date: 2047.14.06
Time: 15:18:19
1048580 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 86
Mileage: 84439 km
Date: 2047.14.06
Time: 15:16:42
1048669 - Tuner for Satelite Radio
B11CF 53 [009] - Deactivated
Reset counter: 166
Mileage: 72165 km
Date: 2040.14.05
Time: 01:23:01
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2137
Coding: 0001076
VCID: 3365E84552451E86565-8066
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
VCID: 3169E24DA8592C96249-8064
01316 - ABS Control Module
Fault Status: 00101101
Reset counter: 85
Mileage: 84437 km
Date: 2047.14.05
Time: 17:18:45
Voltage: 13.63 V
DU
Temperature: 26.0°C
RPM: 1229 /min
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Component: Tuer-SG 009 2111
Coding: 0001076
VCID: 326BED41AD5F178E5D3-8067
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
Component: RDK 103 0521
Coding: 018705
02214 - Tire Pressure Warning
Date: 2064.00.00
Time: 00:00:00
Text: 3452857663
Pressure: 0.00 bar
Pressure: 2.60 bar
Temperature: 52.4°C
Text: 00
Address 77: Telephone (J738) Labels: 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000A07750093
Coding: 412100
VCID: 2A5BF521458F5F4EE53-807F
Reset counter: 86
Mileage: 84439 km
Date: 2047.14.06
Time: 15:16:48
Reset counter: 86
Mileage: 84439 km
Date: 2047.14.06
Time: 15:17:48
