Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 56
Thread: RCD330
  1. #21
    Mar 2015
    Australia
    Quote Originally Posted by sasha View Post
    I've tried to remove the Telephone 77 module from CAN Gateway listing however once removed CAN gateway complains it hasn't been programmed correctly.. Is this the right way to disable the Telephone 77 module so there is just one bluetooth working in the car?
    @uwe, is there any help available with programming the rcd330 stereo?
    If you want to disable your existing Bluetooth module just unplug it.
    If it was factory fitted it will be under your driver's seat.
    If it was retrofitted it could be shoved in behind the climatronics panel.
    My guess would be there MAY be some way of disabling the BT functionality in the head unit but you'd have to find an adaption channel or coding byte to do so.
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|DAB RNS|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0
  2. Likes Dana liked this post
  3. #22
    Address 56: Radio (J503) Labels: None
    Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
    Component: Radio 534 5314
    Revision: -------- Serial number: VWZZZ4R6219226
    Coding: 16000400040005
    Shop #: WSC 00078 790 00217
    VCID: 4682D36EF199C27193-8013
    Sebastian may have coding info for that unit but I do not. It should redirect to 5M0-035-1xx-56.CLB but that's the RCD-510 coding chart which does not have telephone inactive documented like the RNS-315/310 units. Although this is a complete guess, please try enabling Byte 3, bit 5 to see if the Telephone Transceiver/Bluetooth (Internal) inactive per the 1K0-035-27x-37.CLB coding file applies.
    That would change the current coding from 16000400040005 -to- 16000420040005
    If that's accepted, and providing you haven't unplugged the #77 module already, please repeat the function tests, maps and scan when 77 is still present in the CAN Gateway list.
  4. Likes Uwe liked this post
  5. #23
    Jan 2016
    @johannvisser, the coding value for the transporter is correct. Keep in mind, the unit was never available in that model, so I am not surprised that it won't display the proper car outline.
    @atgw, yes - as stated earlier this year.
    Well, I can confirm what blade3562 states above, as I just installed my RCD330 and confirmed that there are no labels in the long coding helper. Sebastian - is there something I'm missing? I'm running the latest copy of VCDS
  6. #24
    Quote Originally Posted by atgw View Post
    You aren't missing anything. Looks like we have 6RD-035-187 and 6RD-035-187-A redirecting but B+ are not on the list as far as I can tell. I'll make sure Sebastian is aware of this if he doesn't already have something ready to go for our upcoming Beta. At the present time Beta 17.6.0 is available here
    http://www.ross-tech.com/vcds/download/beta/current.php
    .. but we plan on having another Beta version (with new labels, etc) available after testing. I cannot provide you with an exact date but I don't think it would be any later than the end of July.
    Edit: Created FS#1427
  7. #25
    Jan 2016
    Great, thank you.
  8. Likes Dana liked this post
  9. #26
    Verified VCDS User Blade3562's Avatar
    May 2017
    Any update on the 6RD 035 187 B functionality? Just checked for updates and I have the latest software. Hoping to figure out this MFSW problem.
  10. #27
    Magdeburg, Germany
    Make sure to use the Beta.
  11. #28
    Jan 2016
    I used the 17.7 beta yesterday to try to code my 6RD-035-187-B for Dynaudio but had no luck.
    I managed to change the byte for Treble Speaker Monitoring to deactivated to stop the Errors here. But I received an Error 31 Out of range when trying to change one or both of the Sound System correction to Dynaudio and the Speaker Channels to 'sound system (active speakers)'
    I have a value in WSC but no joy.
  12. #29
    Magdeburg, Germany
    What makes you think that RCD330 supports Dynaudio? I don't think it was ever offered with that option or even intended to be used with that, therefor it's not surprising that the coding option in question isn't supported (hence rejected).
  13. Likes Uwe liked this post
  14. #30
    Jan 2016
    Well, my apologies for not being an expert. I thought options were only displayed if they could be coded.
    Thanks for your help.
