Results 1 to 10 of 15
Thread: The Best Way to Perform a Parasitic Draw Test
    Not actually VCDS related, but the question comes up with some regularity, and it's difficult to explain in words, so I'm going to leave this here:
    ETA: Bentley Publishers also has a TSB that explains this here, which Jef posted way back in 2014.
    Oct 2014
    Arandjelovac, Serbia
    You can find this chart here.
  3. Likes DV52, D-Dub, Uwe, jyoung8607, Zenerdiode liked this post
    May 2014
    ^^^^^ Very good video (IMO), but just a note of caution - professionals (like the folk @ RT and Charles-the humble mechanic) correctly invest in good test equipment because it makes commercial sense to do so.What this means is that when these types of videos are made, there is an implicit assumption that what the meter reads is actually correct - and in most videos, the reading is correct (to the accuracy of the meter)
    However unless Joe-average is an enthusiast, he/she generally has less financial justification when choosing which multi-meter to buy. But this notwithstanding, Joe-average generally has the same unshakable degree of confidence in the reading shown on the meter screen and on lots (most?) domestic multi-meters this confidence is misplaced .
    The particular issue when "domestic" multi-meters are used for parasitic leakage analysis is that the test numbers are usually very small and this exacerbates the meter inaccuracy issue (which is further complicated by the noisy electrical environment in which the test is performed). This reading inaccuracy (@ small volt-drop numbers) makes the current draw number from the reference table in the video somewhat fungible (in my bitter experience)!
    So, if I may interpose a further point of complication to an otherwise excellent video - certainly do all the multi-meter tests shown in the video as a precursor to measuring the volt-drop across the fuse, but consider also that multi-meters sometimes tell deliberate lies (it's not their fault)! Even if your preliminary multi-meter tests are successful - just because the meter screen says 3 milli-volts, doesn't mean that the volt-drop is actually 3 milli-volts!
    VW Golf MkVII (103TSI) my13
  5. Likes Dana, Bruce, Boki Ar liked this post
    Oct 2014
    ^ Exactly, which is why we should always remember to compare the measured value with the table. ;-)
    Near Philadelphia, PA, USA
    Don, I could not agree more. Can't tell you how many times in my career a technician working with me gave me a reading number just because the meter said so... And then when I shorted the leads together - where the meter should read 0volts - I showed that the meter had an inaccuracy.
    Bad leads can change your numbers guys. Bad meters can change your numbers. Your meter itself should be checked regularly if you are going to do millivolt measurements.
    Voltage drop tests can be a help but be skeptical of results... Learn your gear and know what it can/cannot do for you. Practice doing voltage drop tests on known good systems before you have the confidence that on a screwed up system, the measurement you take is the Gold standard of measurements. It likely is not!
    Oh, and one more thing - the shorter the leads to the meter - the more likely the measurement will be accurate.
    Have fun out there!
  8. Likes Boki Ar liked this post
  9. #6
    TL;DR: Don't use a $15 multimeter from Harbor Freight for this.
  10. Likes NZDubNurd, PetrolDave liked this post
  11. #7
    What are you talking about, for a while they were free with any purchase
  12. Likes NZDubNurd, Santos, Uwe liked this post
  13. #8
    The Bentley Publishers link in this thread is still good: http://forums.ross-tech.com/showthre...teway-vehicles
    Uwe, do you have any objections to slipping that under your video?
  14. Likes Uwe liked this post
  15. #9
    Jul 2015
    Kent, UK
    This technique is all very well but not all fuses have the connectors exposed for external measurement with a meter.
    If you look at the video, most of the small fuses at the top don't have the external contacts although there are some pink ones that do.
    Certainly, in my A8, ALL the small fuses on both sides of the dash don't have the contacts for measurement.
    Julian
  16. #10
    Quote Originally Posted by JulianHicks View Post
    If one does run into this issue, then I think the correct solution would be to buy new fuses with test ports. Fuses are pretty cheap. The ones without test fuses are still good, toss them into an empty Altoids tin for later use.
    Jef
  17. Likes JulianHicks, jyoung8607, Uwe liked this post
