Seen a few probes and such, no active faults. Hopefully is good enough for a reference (y)
Friday,17,February,2017,17:24:26:11509
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 17.1.3.0 (x64) HEX-NET CB: 0.4334.4
Data version: 20170203 DS267.2
VIN: WVWZZZ3CZHE051219 License Plate:
Chassis Type: 3C (5QE)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 51 52 55 5F
6D 75 8C A9 BB BC C6
VIN: WVWZZZ3CZHE051219 Mileage: 7201km-4474miles
23-Brake Booster -- Status: Malfunction 0010
51-Electric Drive -- Status: Malfunction 0010
8C-Hybrid Battery -- Status: Malfunction 0010
BC-Door Rear Pass -- Status: Malfunction 0010
C6-Batt. Chrg. -- Status: Malfunction 0010
Address 01: Engine (J623-CUKC) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 023 AH HW: 04E 907 309 F
Component: 1.4l TFSI hy H22 2881
Revision: X3H22---
Coding: 011D0012632405083000
Shop #: WSC 05311 115 00305
ASAM Dataset: EV_ECM14TFS01104E906023AH 006004
ROD: EV_ECM14TFS01104E906023AH_006.rod
VCID: 6680540F994B387173-8033
11 Faults Found:
26468 - Terminal 15 Voltage
P151B 00 [032] - Implausible
Mileage: 6660 km
Date: 2017.02.12
Time: 17:38:47
Coolant temperature: 75 °C
Intake air temperature: 24 °C
Voltage terminal 30: 12.280 V
Unlearning counter according OBD: 32
Outside air temperature: 3 °C
Absolute intake pressure: 102 kPa abs
Engine torque: 0.0 Nm
Fuel level: 50.00 l
E-machine torque actual value: -0.3 Nm
Operating mode control expanded electrical driving: Correct result
Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 1
High-volt. battery: charge state: abs. value: 41.84 %
17167 - Databus
Mileage: 6660 km
Date: 2017.02.12
Time: 17:38:39
Voltage terminal 30: 12.260 V
Acceleration: 0.000 m/s²
Cruise Control System (CCS): status-Bit 0: 7
Cruise_control_shutoff_conditions_irreversible-Bit 0: 0
Cruise_control_shutoff_conditions_irreversible-Bit 8: 0
Cruise control system: temporary deactivation-Bit 0: 255
Cruise control switch actuation-Bit 0: 0
Cruise control switch actuation-Bit 8: 32
17158 - Databus
Mileage: 6238 km
Date: 2017.01.21
Time: 00:00:10
Coolant temperature: -6 °C
Intake air temperature: -6 °C
Voltage terminal 30: 9.240 V
Unlearning counter according OBD: 15
Cruise Control System (CCS): status-Bit 0: 6
Drivetrain coordinator: ACC fault status-Bit 0: 0
Drivetrain coordinator: ACC fault status-Bit 8: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 0: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 16: 128
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 24: 2
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 8: 136
Drivetrain coordinator: brake fault status-Bit 0: 5
15494 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [032] - -
Mileage: 6238 km
Date: 2017.01.25
Time: 11:29:20
Engine speed: 1592.50 /min
Normed load value: 19.2 %
Vehicle speed: 15 km/h
Coolant temperature: 78 °C
Intake air temperature: 18 °C
Voltage terminal 30: 14.960 V
Outside air temperature: -3 °C
Absolute intake pressure: 49 kPa abs
Engine torque: 34.3 Nm
Fuel level: 45.00 l
E-machine torque actual value: -22.5 Nm
Operating mode control expanded electrical driving: False result
Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 0
High-volt. battery: charge state: abs. value: 13.98 %
U0428 00 [032] - -
Mileage: 6238 km
Date: 2017.01.21
Time: 00:00:09
Voltage terminal 30: 9.740 V
Outside air temperature: -4 °C
Absolute intake pressure: 103 kPa abs
Fuel level: 45.00 l
E-machine torque actual value: 0.2 Nm
High-volt. battery: charge state: abs. value: 10.33 %
23005 - No Communications with Control Module for Access/Start Authorization
U100A 00 [032] - -
Mileage: 6660 km
Date: 2017.02.12
Time: 17:38:45
Fuel level: 50.00 l
18096 - Implausible Data Received from Instrument Panel Control Module
U0423 00 [032] - -
Fault Frequency: 44
Mileage: 6660 km
Date: 2017.02.12
Time: 17:37:16
4858 - Implausible Data Received from Body Control Module A (Central Electric 2)
U0431 00 [032] - -
Fault Frequency: 34
Mileage: 6660 km
Date: 2017.02.12
Time: 17:37:17
Intake air temperature: 23 °C
23806 - Implausible Data Received from Steering Column Control Module
U0429 00 [032] - -
Mileage: 6660 km
Date: 2017.02.12
Time: 17:38:45
Fuel level: 50.00 l
4459 - Implausible Data Received from Body Control Module A (Central Electric 2)
U0431 00 [032] - -
Fault Frequency: 34
Mileage: 6660 km
Date: 2017.02.12
Time: 17:37:17
27705 - Implausible Data Received from Driver's Door Control Module
U049A 00 [032] - -
Fault Frequency: 34
Mileage: 6660 km
Date: 2017.02.12
Time: 17:37:17
Outside air temperature: 1 °C
Fuel level: 50.00 l
Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
Part No SW: 0DD 300 045 T HW: 0DD 927 770 B
Component: GSG DQ400E H31 1124
Revision: 00031033 Serial number: TFK01606030023
Shop #: WSC 05311 115 00089
ASAM Dataset: EV_TCMDQ400021 001001
ROD: EV_TCMDQ400021.rod
VCID: 383CCA77837F7E8111-806D
19 Faults Found:
10779 - System Voltage
P0562 00 [040] - Too Low
Mileage: 6238 km
Date: 2017.01.21
Time: 00:00:11
Engine speed: 6.25 /min
Engine torque: -100 Nm
Vehicle speed: 35 km/h
Control Module temperature: 22 °C
CURRENT pressure: -9.5 bar
Clutch: primary stat: Driving
selected gear: GANG_5
Driving position: N
Accelerator position: 0.4 %
DTC memory status: 13824
32317 - Unknown Error Code
U04B5 00 [002] - -
10893 - Implausible Data Received from Battery Energy Control Module 2
U0413 00 [002] - -
60354 - ROD - Unknown Error Code
- 00 [002]
60355 - ROD - Unknown Error Code
- 00 [002]
60356 - ROD - Unknown Error Code
- 00 [002]
60357 - ROD - Unknown Error Code
- 00 [002]
60358 - ROD - Unknown Error Code
- 00 [002]
60359 - ROD - Unknown Error Code
- 00 [002]
60360 - ROD - Unknown Error Code
- 00 [002]
60361 - ROD - Unknown Error Code
- 00 [002]
60362 - ROD - Unknown Error Code
- 00 [002]
60363 - ROD - Unknown Error Code
- 00 [002]
60364 - ROD - Unknown Error Code
- 00 [002]
60365 - ROD - Unknown Error Code
- 00 [002]
60366 - ROD - Unknown Error Code
- 00 [002]
60367 - ROD - Unknown Error Code
- 00 [002]
60368 - ROD - Unknown Error Code
- 00 [002]
60369 - ROD - Unknown Error Code
- 00 [002]
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 614 517 BL HW: 5Q0 614 517 AH
Component: ESC H62 0855
Revision: 00000000 Serial number: 62026000001669
Coding: 0FEC408F3825236D4779060141CC49F0021CC4E26082927132A1F078C20202
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
ROD: EV_Brake1UDSContiMK100OMG_SK37.rod
VCID: 7CB41667F7C792A1B5-8029
0297 - Steering angle sensor
B1168 16 [032] - Voltage Too Low
Mileage: 6238 km
Date: 2017.01.21
Time: 00:00:09
16412 - Display for Tire Pressure Monitoring
C1146 02 [044] - Signal Failure
Mileage: 6238 km
Date: 2017.01.25
Time: 11:17:28
16413 - Display for Tire Pressure Monitoring
Mileage: 6238 km
Date: 2017.01.25
Time: 11:17:28
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 3Q0 959 435 D HW: 3Q0 959 435 D
Component: VWKESSYMQB 026 0811
Revision: 00026000 Serial number: 0412456226
Coding: 002F0F070F
VCID: 3B36D57BB2495599FC-806F
U1400 00 [008] - -
Reset counter: 144
Mileage: 6238 km
Date: 2017.01.05
Time: 04:10:26
133124 - Databus
Fault Frequency: 52
Reset counter: 162
Mileage: 6246 km
Date: 2017.01.25
Time: 12:48:26
12718085 - Databus
Fault Frequency: 19
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:34:21
12786202 - Databus
Fault Frequency: 7
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:37:16
12786210 - Databus
Fault Frequency: 24
Reset counter: 162
Mileage: 1048574 km
Time: 00:00:00
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5GE 907 044 AK HW: 5GE 907 044 AK
Component: Climatronic H04 1502
Revision: 00001K07
Coding: 1202100420011001081550000010182A
ROD: EV_ACClimaBHBVW37X_004_VW48.rod
VCID: 05427383840DD369DA-8051
Subsystem 3 - Part No SW: 3Q0 963 231 D HW: 3Q0 963 231 D
Component: J848 HV-PTC 200 0204
Serial number: -00102.9T.5B20340229
H02 0007
B10CD 00 [008] - -
Reset counter: 147
Mileage: 6238 km
Date: 2016.12.28
Time: 13:32:44
Voltage terminal 30: 11.4 V
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 086 BH HW: 5Q0 937 086 BH
Component: BCM PQ37BOSCH 032 0222
Revision: -------- Serial number: 865823071601A7
ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
ROD: EV_BCMBOSCH_017.rod
VCID: 014A67939025FF49E6-8055
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160713 042 0607
Serial number: 160727033500
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S4Y16M08D02H08M04S44
Coding: 00A8DD
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 J HW: 3G0 941 633 J
Component: E1 - LDS MQB H01 0032
Serial number: 02 06 2016 10000048
131586 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 144
Mileage: 6238 km
Date: 2017.01.21
Time: 00:00:12
528662 - Databus
Fault Frequency: 56
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:37:16
544790 - Databus
Fault Frequency: 27
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:38:34
529174 - Databus
Fault Frequency: 21
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:37:16
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: 000305183616204
Coding: 1271061051
ASAM Dataset: EV_EPHVA2CAU3700000 009017
ROD: EV_EPHVA2CAU3700000_009.rod
VCID: 0D524BA3DC7DAB2992-8059
13637426 - Databus
Reset counter: 144
Mileage: 6238 km
Date: 2017.01.21
Time: 00:00:13
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0194
Coding: 5200608151FFC428949C8045
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3424FE479F179AE13D-8061
2055 - Databus
Reset counter: 144
Mileage: 6238 km
Date: 2017.01.21
Time: 00:00:14
Control Module temperature: -1 °C
Voltage terminal 15: 14.1 V
2101 - Databus
Reset counter: 144
Mileage: 6238 km
Date: 2017.01.21
Time: 00:00:13
Voltage terminal 15: 13.6 V
0836 - Databus
Fault Frequency: 88
Reset counter: 166
Mileage: 6237 km
Date: 2016.12.19
Time: 09:56:25
Control Module temperature: 30 °C
Voltage terminal 15: 14.5 V
Status_ACC_System: ACC_Init
1086 - Databus
Fault Frequency: 45
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:37:16
Control Module temperature: 25 °C
Voltage terminal 15: 11.9 V
1389 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 144
Mileage: 6238 km
Date: 2017.01.21
Time: 00:00:10
Voltage terminal 15: 8.9 V
Part No SW: 5Q0 959 655 S HW: 5Q0 959 655 S
Component: AirbagVW20 010 0870
Serial number: 003MFR02BZWI
Coding: 88CCC000002000005C5400CF004800000065
Shop #: WSC 05314 000 00001
VCID: 50EC92D70BCFC6C139-8005
Subsystem 1 - Part No SW: ----------- HW: 480 002 207 16
Serial number: 357000000004EC6DFC16
Subsystem 2 - Part No SW: ----------- HW: 480 002 207 16
Serial number: 35800000000ECAC8AC19
Subsystem 3 - Part No SW: ----------- HW: 480 402 306 16
Serial number: 3510002A520F1951524R
Subsystem 4 - Part No SW: ----------- HW: 480 402 306 16
Serial number: 3520002BD20FC4C1D0EN
Subsystem 5 - Part No SW: ----------- HW: 480 402 306 16
Serial number: 3550002BD20FC4C32148
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 3Q0 953 521 DJ HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160803501224
Coding: 0410
Shop #: WSC 00015 115 00001
ROD: EV_SMLSVALEOMQB.rod
VCID: 7BB6157BF2C99599BC-802F
Part No SW: 3G0 920 754 B HW: 3G0 920 754 B
Component: KOMBI 304 8315
Coding: 07240B182BC0000801886B111201002000000000
VCID: 271E190B5EC1E17988-8073
13 Faults Found:
16776960 - Databus
Fault Frequency: 65
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:37:16
16776961 - Databus
Fault Frequency: 77
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:37:16
16776962 - Databus
Fault Frequency: 24
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:37:16
16776968 - Databus
Fault Frequency: 41
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:37:16
16776978 - Databus
Fault Frequency: 39
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:37:16
16776988 - Databus
Fault Frequency: 37
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:37:16
12858141 - Databus
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:35:33
12858136 - Databus
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:41:33
12858138 - Databus
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:35:33
12858137 - Databus
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:47:30
16776990 - Databus
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:38:46
16776992 - Databus
Fault Frequency: 33
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:37:16
12858145 - Databus
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:38:33
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 5QE 907 530 F HW: 5QE 907 530 A
Component: GW MQB EV 312 3265
Revision: -------- Serial number: 01071610520442
Coding: 020300172EF21000FB00526A5C1D00000001070100010000000300000000
ASAM Dataset: EV_GatewEVConti 013020
ROD: EV_GatewEVConti_013.rod
VCID: 49DABFB3E895F7097E-801D
Subsystem 1 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 29160001413930116284
Coding: 29FFFF
Subsystem 2 - Part No SW: 3Q0 915 181 B HW: 3Q0 915 181 B
Serial number: 0277770904
Analog clock:
Subsystem 3 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
8531970 - Quiescent Current
U1406 00 [008] - Too High
Fault Frequency: 24
Reset counter: 168
Mileage: 6238 km
Date: 2016.12.20
Time: 06:11:58
Supply voltage: Terminal 30: 12.0 V
Terminal 15: OFF
8526356 - Autonomous Post-Charging Active
P30F2 00 [008] - -
Fault Frequency: 14
Reset counter: 147
Mileage: 6238 km
Date: 2016.12.28
Time: 13:32:45
Supply voltage: Terminal 30: 11.4 V
Terminal 15: OFF
8526359 - Autonomous Post-Charging Play-Protection Active
P30F3 00 [008] - -
Fault Frequency: 15
Reset counter: 147
Mileage: 6238 km
Date: 2016.12.28
Time: 13:52:40
Supply voltage: Terminal 30: 13.1 V
Terminal 15: OFF
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5QE 909 059 E HW: 5QE 909 059 B
Component: EBKV H14 0200
Serial number: 085430010354
Coding: 05720100431900020002060500
Shop #: WSC 05311 115 00314
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004001
ROD: EV_BrakeBoostBoschMQBOMG_001_VW48.rod
Brake Assistance Sub:
Subsystem 1 - Part No SW: 5QE 909 057 C HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0152
Serial number: 05802861130716163655
173568 - Function Restricted due to Insufficient Voltage
U1400 00 [040] - -
Mileage: 6238 km
Date: 2017.01.21
Time: 00:00:09
87296 - Databus
U1121 00 [040] - Missing Message
Mileage: 6660 km
Date: 2017.02.12
Time: 17:37:17
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000163941014
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71AA3753A085EFC916-8025
13637381 - Databus
Fault Frequency: 38
Reset counter: 162
Mileage: 6660 km
Date: 2017.02.12
Time: 17:38:33
Result lock conditions: invalid
ESCL locked: No
ESCL unlocked: Yes
Lock sensor: not activated
Unlock sensor: operated
Error mode 1: not active
Error mode 2: not active
Clamp S: On
Clamp 15: On
Clamp 15 Status: valid
Remotestart: not active
Driver door: closed
Central locking locked external: unlocked
Central locking safed external: Vehicle not secured
Clamp Request: No
Request highside lock: No
HW highside lock: OFF
Highside unlock: No
Motor break: not active
Activation lowside unlock: OFF
Activation lowside lock: OFF
I2C overflow: No
I2C error pathflags: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C length failure: No
I2C error sda: No
I2C communication failure: i2c no comm failure
I2C state esp 10: i2c e2e failure
I2C cnd haco message: valid
Coco reset: No
Coco supply: On
Password IMS OK: Yes
Signature IMS OK: Yes
IMS responded: Yes
Positive authentification in current KL15 cycle: Yes
Lifestate: Immobilizer download obtained
Authentication valid (T1): No
State of authentication state machine: WFS_AUTH_INIT_e
Vehicle speed: 0.00 km/h
UBat internal: 11.5 V
UMotorBridge: 6.3 V
Lock condition engine speed: Condition met
Lock condition clamp S: Condition not met
Lock condition clamp 15: Condition not met
Lock condition E2E clamp status: Condition not met
Lock condition timeout clamp status: Condition met
Lock condition vehicle speed: Condition met
Lock condition E2E vehicle speed: Condition not met
Lock condition timeout vehicle speed: Condition met
Lock condition Mode1: Condition met
Lock condition drive readiness: Condition not met
Lock condition selector lever position parking: Condition met
Clamp enable ESCL: not enabled
Lock condition timeout distance pulse: Condition met
Lock condition E2E distance pulse: Condition not met
Lock condition difference distance pulse: Condition not met
13637383 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Fault Frequency: 27
Reset counter: 159
Mileage: 6246 km
Time: 00:00:00
ESCL locked: Yes
ESCL unlocked: No
Lock sensor: operated
Unlock sensor: not activated
Clamp S: OFF
Clamp 15: OFF
Driver door: closed
Clamp Request: Yes
Highside unlock: No
I2C overflow: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C error sda: No
I2C state esp 10: i2c timeout
Coco reset: No
Coco supply: On
Password IMS OK: No
Signature IMS OK: No
IMS responded: No
Positive authentification in current KL15 cycle: No
Vehicle speed: 655.35 km/h
UBat internal: 11.9 V
UMotorBridge: 6.5 V
Lock condition clamp S: Condition met
Lock condition clamp 15: Condition met
Lock condition vehicle speed: Condition not met
Lock condition timeout vehicle speed: Condition not met
Lock condition drive readiness: Condition met
Lock condition timeout distance pulse: Condition not met
Component: TSG FS 020 0041
Serial number: 120716EGA22453
Coding: 003F0F208000020000001000
VCID: 43C6AD9BCAB92D59B4-8017
65621 - Locking Module for Central Locking
B122F 29 [008] - Signal Implausible
Reset counter: 144
Mileage: 6238 km
Date: 2017.01.25
Time: 11:18:08
Address 44: Steering Assist (J500) Labels: 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000958285
Coding: 01010010005101
Shop #: WSC 00015 115 00305
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_SK37.rod
VCID: 3D32DB63AC5D5BA9C2-8069
5262656 - Steering Angle Sensor
B1168 F2 [008] - Not Initialized
Reset counter: 144
Mileage: 6238 km
Date: 2017.01.21
Time: 00:00:08
valid
Address 51: Electric Drive (J841) Labels: None
Part No SW: 3G0 907 080 C HW: 3G0 907 080 C
Component: LE Gen 3.3H09 0060
Revision: 00H09000
Coding: C0020000000000000000
ASAM Dataset: EV_DMCM12030113G0907080C 001015
ROD: EV_DMCM12030113G0907080B.rod
VCID: 2502130324CDF369BA-8071
31789 - System Voltage
P0562 00 [032] - Too Low
Mileage: 6238 km
Date: 2017.01.21
Time: 00:00:10
Voltage terminal 30: 8.802 V
Drive control condition: Standby
Drive control condition-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Drv Ctrl UBYTE: 2
Component: TSG BFS 020 0041
Serial number: 070716EG625047
Coding: 003F01208000020000001000
VCID: 42C8A89FD5A32451BF-8017
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0120
Coding: 039A00000F200200
Shop #: WSC 05311 000 08193
ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
VCID: 3FCEA16BA65149B9D0-806B
Subsystem 1 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0003
Coding: E02400
Subsystem 2 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H09 0003
Coding: E02400
Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0003
Coding: E02400
13706046 - Databus
Reset counter: 162
Mileage: 6358 km
Date: 2017.02.09
Time: 14:07:06
13706047 - Databus
Reset counter: 162
Mileage: 6358 km
Date: 2017.02.09
Time: 14:07:06
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 846 A HW: 3Q0 035 846 A
Component: MU-S-N-ER H30 0356
Serial number: VWZAZ2S0408575
Coding: 02840201FF0000005111000100080A001F0209C401200100CF
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 2F2EF12B7631B93940-807B
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H43 4064
Serial number: VWZ6Z9S2070744
Subsystem 2 - Part No SW: 3G0 919 866 S HW: -----------
Component: ECE1 2016/17 --- 0635
5688 - Control Head for Mulimedia System
B13C9 F2 [008] - On/Off Switch
Reset counter: 162
Mileage: 6652 km
Date: 2017.02.12
Time: 16:27:11
Voltage terminal 30: 14.9 V
Address 6D: Trunk Elect. (J605) Labels: 5Q0-959-107.clb
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30813994300000
Coding: 0200
ASAM Dataset: EV_DeckLidCONTIAU736 001012
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 284 C HW: 5QE 035 284 C
Component: OCULowMQBEU 012 0717
Coding: 0284720110829A0300F800000000
ROD: EV_OCULowMQB.rod
VCID: 44C4AE87CFB72A618D-8011
Address 8C: Hybrid Battery (J840) Labels: 5QE-915-227.clb
Part No SW: 3Q0 915 227 K HW: 3Q0 915 227 K
Component: K8C H05 0430
Serial number: 22071616010149
ASAM Dataset: EV_BECM09620213Q0915227K 002006
ROD: EV_BECM09620213Q0915227K.rod
VCID: 393ACF73B8756789EE-806D
Battery Junction Box:
Subsystem 1 - Part No SW: 3Q0 915 227 J HW: 3Q0 915 227 J
Component: A2 HVSMBJBECU H08 0410
Serial number: 00000027071616010109
Cell Module Controller 1:
Subsystem 2 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC1 H04 0430
Serial number: 16430ZKK311A01040562
Cell Module Controller 2:
Subsystem 3 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC2 H04 0430
Serial number: 16430ZKK311A01040347
Cell Module Controller 3:
Subsystem 4 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC3 H04 0430
Serial number: 16430ZKK311A01040466
Cell Module Controller 4:
Subsystem 5 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC4 H04 0430
Serial number: 16430ZKK311A01040373
Cell Module Controller 5:
Subsystem 6 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC5 H04 0430
Serial number: 16502ZKK311A01040038
Cell Module Controller 6:
Subsystem 7 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC6 H04 0430
Serial number: 16424ZKK311A01040525
Cell Module Controller 7:
Subsystem 8 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC7 H04 0430
Serial number: 16426ZKK311A01040862
Cell Module Controller 8:
Subsystem 9 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC8 H04 0430
Serial number: 16426ZKK311A01040781
28796 - 14V Power System Voltage
P0A8D 00 [032] - too Low
Mileage: 6238 km
Time: 00:00:00
Current of high-voltage / hybrid battery: Initializing
Voltage terminal 30: 8.250 V
28809 - System Voltage
Mileage: 6238 km
Time: 00:00:00
Voltage terminal 30C: 8.300 V
28558 - Invalid Data Received from Diagnostic Gateway Module
U0447 00 [032] - -
Fault Frequency: 192
Mileage: 6320 km
Date: 2017.02.06
Time: 11:35:50
Current of high-voltage / hybrid battery: -2.750 A
28559 - Invalid Data Received from Diagnostic Gateway Module
U0447 00 [032] - -
Fault Frequency: 16
Mileage: 6320 km
Date: 2017.02.06
Time: 11:35:38
Current of high-voltage / hybrid battery: -16.750 A
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 3G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0006
Serial number: 160713201272
ROD: EV_SoundActuaGen2AU64X_VW26.rod
VCID: 699A5F33885517095E-803D
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 200716EGD08931
Coding: 000E01200100020000001000
VCID: 45C2B383C48D13699A-8011
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 020 0041
Serial number: 200716EGD09201
B122D 29 [008] - Signal Implausible
Reset counter: 149
Mileage: 6307 km
Date: 2017.02.04
Time: 11:51:15
Address C6: Batt. Chrg. (J1050) Labels: None
Part No SW: 5QE 915 682 M HW: 5QE 915 682 M
Component: OBC KOSTAL H31 4006
Revision: -------- Serial number: 0607160G40002O
Coding: 115068222000
ASAM Dataset: EV_OBCSinglPhaseKLOMQB11P 004001
ROD: EV_OBCSinglPhaseKLOMQB11P.rod
VCID: 57FE69CB2E2191F9F8-8003
U1400 00 [008] - -
Reset counter: 144
Time: 00:00:00
13705540 - Databus
Reset counter: 170
Mileage: 6237 km
Date: 2016.12.19
Time: 10:03:01
End----------(Elapsed Time: 02:11, VBatt start/end: 13.2V/13.2V)-----------
