T5 GP AUTO TWIN SLIDING DOORS REDIR FILES
Danners74
C?ID=273244
Just a bit more info for you all at Ross-Tech. Had repaired two rear electric auto sliding doors. Scan showed some Redir files on the control units. Hoping this info will be of use for future codings for perhaps auto open half way?
Regards Danners, heres the scan....the faults are all before the repair,as i replaced lower door runners and upper ones with the hall sensors both sides.
Wednesday,15,February,2017,11:25:59:44004
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
Dealer/Shop Name: Victoria Volkswagen.
Workshop Code: 210 01843 000002
VIN: WV2ZZZ7HZBH063641   License Plate:
Mileage: 118750km-73787mi   Repair Order:
                Address 0D: Slide Door, Left       Labels: Redir Fail!
Control Module Part Number: 7E0 959 243 D
  Component and/or Version: Schiebetuer-SG  407 0328
           Software Coding:
            Work Shop Code: WSC 02756 790 00000
                      VCID: 3068AD8BA388B7C159-8064
02356 - Data Transfer to Sliding Door
Wednesday,15,February,2017,11:27:49:44004
Chassis Type: 7H (6N0)
Scan: 01 02 03 04 08 09 0D 10 15 17 19 25 37 56 77 78 0B
VIN: WV2ZZZ7HZBH063641   Mileage: 118750km-73787miles
0D-Slide Door, Left -- Status: Malfunction 0010
78-Slide Door, Right -- Status: Malfunction 0010
Address 01: Engine (J623-CFCA)       Labels: 03L-906-022-CFC.clb
   Part No SW: 03L 906 022 JD    HW: 03L 907 309 H
   Component: R4 2,0L EDC   X34 9112
   Revision: 22X34---    Serial number: 00000000000000
   Coding: 01254012232400080000
   Shop #: WSC 66565 257 00032
   ASAM Dataset: EV_ECM20BTD01103L906022JD 002012
   ROD: EV_ECM20BTD01103L906022JD_002.rod
   VCID: 70E86D8BAB08F7C119-8024
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0BT 300 045 J    HW: 0BH 927 711 C
   Component: DSG DQ500-7F  H04 1408
   Revision: 00H04V01
   ROD: EV_TCMDQ500021_VW41.rod
   VCID: 3C7089BBB7C043A1F5-8068
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 G    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0105
   Revision: 00H43001
   Coding: 108764AD09AA089826A89075AA5F16
   Shop #: WSC 02756 790 49152
   VCID: 36649B9381EC99F103-8062
Address 08: Auto HVAC (J255)       Labels: 7E5-907-040.clb
   Part No SW: 7E5 907 040 N    HW: 7E5 907 040 N
   Component: ClimatronicT5 H11 0304
   Coding: 0004000102
   Shop #: WSC 02757 790 50316
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimatronicT5.rod
   VCID: 3362A2879A9E8CD924-8066
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
   Component: Heckbedienung  H10 0202
   Serial number: BHB-0010311100010113
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 087 F    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0230
   Revision: BO047001    Serial number: 0396 301100837
   Coding: A0B2793A0E612413932888107C2B8FD40080410F60844000300003000000
   Shop #: WSC 02756 790 00000
   VCID: 377A969786E660F918-8062
   Component: RLS 291010 05  54  0403
   Coding: 03302E
   Subsystem 2 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  003 3311
   Coding: 050000
   Subsystem 3 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  003 3311
   Coding: 040000
   Subsystem 4 - Part No: 7E1 951 171
   Subsystem 5 - Part No: 1K0 951 605 C
   Subsystem 6 - Part No: 7E1 951 171
   Subsystem 7 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Serial number: 40000000000000204984
   Coding: E20000
03303 - Response Closing Status of Rear Left Door
                    Reset counter: 207
                    Mileage: 116167 km
                    Date: 2011.04.10
                    Time: 08:06:09
03304 - Response Closing Status of Rear Right Door
                    Reset counter: 207
                    Mileage: 116167 km
                    Date: 2011.04.10
                    Time: 08:06:09
   Part No: 7E0 959 243 D
   Component: Schiebetuer-SG  407 0328
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 C    HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H11 0011
   Revision: --------    Serial number: 47431028902083
   Coding: 108101
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K A01004
   ROD: EV_VW75XParkAssis8K_VN75.rod
   VCID: 326CA783658485D12F-8066
   Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
   Component: VW10Airbag00P H06 0013
   Revision: --------    Serial number: 003HM000JBSE
   Coding: 000000000000000000000000000000003050
   Shop #: WSC 02754 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 36649B9389EC99F103-8062
   Serial number: 3495ZRB404P6PGAKGPM9
   Serial number: 3505ZRB404R6PGAKE9EK
   Part No SW: 7E0 920 980 C    HW: 7E0 920 980 C
   Component: KOMBI         H04 0206
   Coding: 460F00
   ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
   VCID: 2B52BAE742AED4196C-807E
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 042300
   VCID: 70E86D8BA308F7C119-8024
                    Reset counter: 160
                    Mileage: 116045 km
                    Date: 2011.04.05
                    Time: 14:38:26
   Component: IMMO          H04 0206
   VCID: 6ADC7FE38DD40D1157-803E
   Part No SW: 3C0 035 279     HW: 3C0 035 279
   Component: RNS315        H03 0007
   Serial number: VWZAZ2K8305453
   Coding: 000004310400000000051000
   ASAM Dataset: EV_RNS315VWEUV1UDS A01005
   ROD: EV_RNS315VWEUV1UDS.rod
   VCID: 60C81DCB7BE8474189-8034
1048659 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 160
                    Mileage: 116045 km
                    Date: 2016.11.12
                    Time: 14:38:03
Address 77: Telephone
Address 78: Slide Door, Right        Labels: Redir Fail!
End-------------------------(Elapsed Time: 03:53)--------------------------
Dana
Western PA, USA
Hi Danners74,
If you ran control module maps please send them to us via e-mail with a link to this thread. If you haven't and the vehicle is still at the shop please try the Type #1 procedure.
Thanks,
Dana
Danners74
C?ID=273244
email to whom and what address please Dana?
Regards
Support@.... would be best.
Lez78
C?ID=74086
Hi! I have the same problem... but it come and goes... did you sorted out ?
RowBot
England
C?ID=23016
I have the same fault code, it does not link to the error. I have taken the control module out, exposed the PCB all components look good. Put it back in and it works. However this evening the same fault has appeared. This is bugging me, short of exposing all the wiring to do end to end tests and individual electronic component tests, has anyone fault the root cause to the DFC? Or a hint.
Ta
Row
RowBot
England
C?ID=23016
Hi Lez,
Have you tried anything to rectify the issue?
