Audi A6 C6 2,7l TDI CR engine CANA DPF regeneration login needed
MartinsX
Riga, Latvia
C?ID=268515
As by title of thread I need some help to determine correct login to start DPF service regeneration.
When this car was brought to me, engine was jerking and stalls time by time. Problems with fuel supply system solved, glow plugs replaced, only fault code left for engine is restricted DPF. It's clear, that normal regeneration was not possible while fuel system was not working correctly. Now it is repaired and I want to start service regeneration. Unfortunately there is no label file for this engine. Search in Wiki redirects to older 2,7 and 3,0l TDI engines, but login 10016 is not accepted by ECU.
First scan before repairs:
Wednesday,01,February,2017,16:51:38:32442
VCDS Version: 16.8.4.2
Data version: 20161129 DS267.0
VIN: WAUZZZ4F19N053478   License Plate:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 34 42 46 4F 52 53 55 56 5C 5F
          62 6D 72 76
VIN: WAUZZZ4F19N053478   Mileage: 200770km-124752miles
34-Level Control -- Status: Sporadic communication error 1000
5C-Lane Maintain. -- Status: Malfunction 0010
Address 01: Engine (CAN)       Labels: Redir Fail!
   Part No SW: 4F7 910 401 K    HW: 4F0 907 401 E
   Component: 2.7TDI EDC17G000CG  0090
   Revision: 16H01---    Serial number:
   Coding: 010D002C02070128
   Shop #: WSC 43915 123 98995
   VCID: 2B556D938A7B8A1A4C-807E
8 Faults Found:
               P0087 - 005 - Too Low - Intermittent - MIL ON
                    Fault Status: 10100101
                    Fault Frequency: 160
                    Mileage: 199719 km
                    Date: 2016.12.29
                    Time: 18:05:21
                    RPM: 756 /min
                    Speed: 6.7 km/h
                    Inj. Quantity: 13.0 mg/str
                    Temperature: 22.5°C
                    Pressure: 120.7 bar
                    (no units): 5.0
                    Bin. Bits: 00110100
009263 - Diesel Particulate Filter (Bank 1)
               P242F - 000 - Restricted/Clogged
                    Mileage: 199548 km
                    Date: 2016.12.22
                    Time: 10:54:27
                    (no units): 13.5
                    (no units): 12.0
                    Mileage: 60 km
                    Time: 0.00 s
                    (no units): 2.0
001650 - Cylinder 2 Glow Plug Circuit (Q11)
               P0672 - 000 - Electrical Fault
                    Mileage: 199548 km
                    Date: 2016.12.22
                    Time: 10:54:38
                    RPM: 924 /min
                    Voltage: 12.39 V
                    Temperature: 5.4°C
                    Lambda: 22.7 %
                    Temperature: 3.6°C
001651 - Cylinder 3 Glow Plug Circuit (Q12)
               P0673 - 000 - Electrical Fault
                    Mileage: 199548 km
                    Date: 2016.12.22
                    Time: 10:54:38
                    RPM: 924 /min
                    Voltage: 12.39 V
                    Temperature: 5.4°C
                    Lambda: 22.7 %
                    Temperature: 3.6°C
               P0087 - 003 - Too Low - Intermittent
                    Fault Status: 00100011
                    Fault Frequency: 23
                    Mileage: 200623 km
                    Date: 2017.01.27
                    Time: 15:50:17
                    RPM: 525 /min
                    Inj. Quantity: 29.0 mg/str
                    Temperature: 15.3°C
                    Pressure: 99.4 bar
                    (no units): 5.0
                    Bin. Bits: 00110100
               P0087 - 004 - Too Low - Intermittent
                    Fault Frequency: 9
                    Mileage: 200400 km
                    Date: 2017.01.16
                    Time: 15:30:48
                    RPM: 525 /min
                    Temperature: 14.4°C
                    Pressure: 106.5 bar
                    (no units): 5.0
                    Bin. Bits: 00110100
               P0087 - 001 - Too Low - Intermittent
                    Fault Status: 00100001
                    Mileage: 200385 km
                    Date: 2017.01.16
                    Time: 12:30:07
                    RPM: 588 /min
                    Pressure: 411.8 bar
                    Temperature: 12.6°C
                    Pressure: 99.4 bar
                    (no units): 16.0
                    Bin. Bits: 00110100
               P0087 - 014 - Too Low - Intermittent
                    Fault Status: 00101110
                    Mileage: 200524 km
                    Date: 2017.01.23
                    Time: 21:59:01
                    RPM: 630 /min
                    Pressure: 624.8 bar
                    Temperature: 9.9°C
                    Pressure: 113.6 bar
                    (no units): 4.0
                    Bin. Bits: 00110100
Readiness: 1 3 0 0 0
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 4F5 910 157 H    HW: 01J 927 156 JG
   Component: V30 0AN 2.7lTDI RdW 0010
   Revision: --H06---    Serial number: 00000000000308
   Shop #: WSC 04926 001 00001
   VCID: 2E536487B969FF326B-807A
   Part No SW: 4F0 910 517 AK    HW: 4F0 614 517 AT
   Component: ESP8 front      H03 0060
   Coding: 0016776
   Shop #: WSC 02145 785 00200
   VCID: 6DD1A38B74EF442A12-8038
01310 - Level Control System Control Module (J197)
                    Reset counter: 185
                    Mileage: 200691 km
                    Date: 2017.01.31
                    Time: 13:34:17
                    Hex Value: 0x0F00
                    Hex Value: 0x4002
                    Hex Value: 0x0013
                    Hex Value: 0x2AB2
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601292979
   Coding: 0000131
   VCID: 25419BABEC9FBC6A9A-8070
   Subsystem 1 - Part No: 4F0 910 132 E
   Component: FBSAUDIC6 IDG   H01 0040
   Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Component: KLIMABETAETIGUNGH30 0080
   Revision: 00000074    Serial number: 00000000619723
   Coding: 0000278
   VCID: 1D31B34BC4CF74AAC2-8048
00739 - Coolant Circulation Pump (V50)
                    Reset counter: 174
                    Mileage: 200176 km
                    Date: 2017.01.12
                    Time: 16:17:24
                    Temperature: 18.0°C
   Part No SW: 4F0 910 279 N    HW: 4F0 907 279
   Component: ILM Fahrer      H22 0320
   Coding: 0013121
   Shop #: WSC 02335 785 00200
   VCID: 346776EF5745D5E21D-8060
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00150573
   Shop #: WSC 02335
Address 15: Airbags (J234)       Labels: 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 L    HW: 4F0 959 655 E
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003CH0048269
   Coding: 30314236303630303031554A304C34463053
   Shop #: WSC 02323 785 00200
   ROD: EV_Airba10AURB4.rod
   VCID: 306F7AFF6B5DE9C279-8064
   Serial number: 3574SRB400008BBD313A
   Serial number: 3584SRB400008B844A7D
   Serial number: 35152RB402N7V8VGU4C7
   Serial number: 35252RB402R7V8VGO471
   Serial number: 3554NRB400004B16570U
   Serial number: 3564NRB400004ABFFD9V
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90055090750281
   Coding: 0022022
   VCID: 275D91A39693AE7AA8-8072
   Component: E0221           H01 0030
Address 17: Instruments (J285)       Labels: 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 901 J    HW: 4F0 920 901 J
   Component: KOMBIINSTR.   H06 0135
   Revision: 00100000    Serial number: ADR404H39
   Coding: 0F52100502010008000000
   Shop #: WSC 02391 823 56573
   VCID: 2959979B4087980ABE-807C
                    Fault Frequency: 81
                    Reset counter: 185
                    Mileage: 196808 km
                    Date: 2016.11.02
                    Time: 13:27:14
Address 19: CAN Gateway (J533)       Labels: 4F0-907-468.clb
   Part No SW: 4F0 907 468 L    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0025
   Revision: 4MA90025    Serial number: 2500M0931280B5
   Coding: 000303
   VCID: 387F42DF8B2D318231-806C
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140470700
                    Fault Frequency: 81
                    Reset counter: 185
                    Mileage: 196808 km
                    Date: 2016.11.02
                    Time: 13:27:14
                    Bin. Bits:    00111
                    Voltage: 10.80 V
                    Count: 7
                    Bin. Bits:     1011
                    Time: 0.00 s
Address 34: Level Control        Labels: None
   Part No SW: 4F0 910 553 C    HW: 4F0 907 553 A
   Component: J197 LUFTFEDER  H17 0030
   Serial number: 00871000619300
   Coding: 0000110
   VCID: 244786AFE7A545628D-8070
Address 42: Door Elect, Driver (J386)       Labels: 4F0-959-793.clb
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000100883070
   Coding: 011F02204040410001
   VCID: 46833C27F1D95772B3-8012
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 K    HW: 4F0 907 289 K
   Component: Komfortgeraet   H27 0220
   Revision: 02200027    Serial number: 01175523450000
   Coding: 3547781
   VCID: 326B70F7AD51DBD20F-8066
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000366379
   Coding: 0001013
   VCID: 5EB3F44789492FB29B-800A
Address 52: Door Elect, Pass. (J387)       Labels: 4F0-959-792.clb
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000100870171
   VCID: 45813B2BCCDF5C6ABA-8010
                    Fault Frequency: 213
                    Reset counter: 147
                    Mileage: 194722 km
                    Date: 2016.09.20
                    Time: 13:13:51
00447 - Function Limitation due to Over-Voltage
            000 -  -  - Intermittent
                    Reset counter: 181
                    Mileage: 200571 km
                    Date: 2017.01.24
                    Time: 14:58:28
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000531
   VCID: 21498FBBF8B7504AE6-8074
   Part No: 8P0 907 357 H
   Coding: 0000004
   Shop #: WSC 02325 785 00200
   VCID: 3F8D29C36E0306BAF0-806A
                    Fault Frequency: 9
                    Reset counter: 185
   Part No SW: 4F0 035 056 J    HW: 4F0 035 056
   Component: Radio U STD   H45 0052
   Revision: AB001007    Serial number: 342C1097589775
   Coding: 010003020100000000
   VCID: 275D91A35693AE7AA8-8072
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 4E0 910 217 C    HW: 4E0 907 217 C
   Component: J759  LDW       H07 0070
   Revision: 00H07018    Serial number: 8002093310004E
   Coding: 0001003
   VCID: 204F8ABFF3BD5942E9-8074
                    Fault Frequency: 80
                    Reset counter: 185
                    Mileage: 196808 km
                    Date: 2016.11.02
                    Time: 13:27:14
   Part No SW: 4E0 035 646 C    HW: 4E0 035 646
   Component: B-B-ER        H51 0109
   Revision: --------    Serial number: 348CR097522702
   Coding: 010000010002D3CD09000305EF6300030201
   Shop #: WSC 00766 400 97608
   VCID: 244786AF27A545628D-8070
   Subsystem 1 - Part No SW: 4L0 919 604     HW: 4L0 919 604
   Component: DU6 Basic  H43 0306
   Serial number: 9355CK091018361
   Subsystem 2 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 M
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001281733
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000100871891
   Coding: 010E00204040220001
   VCID: 43852533C2EB625A94-8016
                    Fault Frequency: 46
                    Reset counter: 146
                    Mileage: 198980 km
                    Date: 2016.12.12
                    Time: 13:47:08
Address 6D: Trunk Elect.        Labels: Redir Fail!
   Part No SW: 4F9 910 591     HW: 4F9 827 851 G
   Component: ValeoHeckdeckel H29 0410
   Revision: --H29001    Serial number: E5030000B
   Shop #: WSC 64998 123 181942
   VCID: 6CD7AE8F4FF54D2205-8038
   Subsystem 1 - Part No: 4F9 910 592
   Subsystem 3 - Serial number: RD25.03.09--H29001001B0086?
   Subsystem 4 - Serial number: 1B0086?
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000100851175
                    Reset counter: 181
                    Mileage: 200571 km
                    Date: 2017.01.24
                    Time: 14:58:28
   Part No SW: 4L0 910 283 B    HW: 4L0 919 283 B
   Component: Parkhilfe 4-Kan H02 0500
   Revision: 00H02000    Serial number: 12330907801328
   Coding: 0001016
   VCID: 2959979B8087980ABE-807C
End-------------------------(Elapsed Time: 03:30)--------------------------
Latest scan after fuel system repaired and glow plugs replaced:
Tuesday,07,February,2017,19:01:03:32442
VCDS Version: 17.1.2.1
Data version: 20170131 DS267.1
          62 6D 72 76
Address 01: Engine (CAN)       Labels: None
   VCID: 2B556D938A7B8A1967-807E
                    Mileage: 200772 km
                    Date: 2017.02.07
                    Time: 18:33:48
                    (no units): 14.0
                    (no units): 26.5
                    Mileage: 260 km
                    Time: 0.00 s
                    (no units): 9.0
   VCID: 2E536487B969FF3140-807A
   Coding: 0016776
   VCID: 6DD1A38B74EF442939-8038
                    Reset counter: 187
                    Mileage: 200771 km
                    Date: 2017.02.06
                    Time: 17:08:23
                    Hex Value: 0x0000
                    Hex Value: 0x4082
                    Hex Value: 0x0013
                    Hex Value: 0x2AB1
                    Hex Value: 0x00FF
   Coding: 0000131
   Coding: 0000278
   VCID: 1D31B34BC4CF74A9E9-8048
   Coding: 0013121
   VCID: 346776EF5745D5E136-8060
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00150573
   Shop #: WSC 02335
   VCID: 306F7AFF6B5DE9C152-8064
   Coding: 0022022
   VCID: 275D91A39693AE7983-8072
   VCID: 2959979B4087980995-807C
                    Reset counter: 187
                    Mileage: 200771 km
                    Date: 2017.02.06
                    Time: 15:12:23
Address 19: CAN Gateway (J533)       Labels: User\4F0-907-468.clb
   Coding: 000303
   VCID: 387F42DF8B2D31811A-806C
                    Reset counter: 187
                    Mileage: 200771 km
                    Date: 2017.02.06
                    Time: 15:12:22
                    Bin. Bits:    01111
                    Voltage: 13.30 V
                    Count: 7
                    Bin. Bits:     1011
                    Time: 0.00 s
   Coding: 0000110
   VCID: 244786AFE7A54561A6-8070
   VCID: 46833C27F1D9577198-8012
   Coding: 3547781
   VCID: 326B70F7AD51DBD124-8066
   Coding: 0001013
   VCID: 5EB3F44789492FB1B0-800A
   VCID: 45813B2BCCDF5C6991-8010
                    Reset counter: 147
                    Mileage: 200771 km
                    Date: 2017.02.06
                    Time: 14:14:30
   Revision: --H05---
   Coding: 0000531
   VCID: 21498FBBF8B75049CD-8074
   Coding: 0000004
   VCID: 3F8D29C36E0306B9DB-806A
                    Reset counter: 187
                    Mileage: 200776 km
                    Date: 2017.02.06
                    Time: 15:12:21
   VCID: 275D91A35693AE7983-8072
   Coding: 0001003
   VCID: 204F8ABFF3BD5941C2-8074
                    Reset counter: 187
                    Mileage: 200771 km
                    Date: 2017.02.06
                    Time: 15:12:22
   VCID: 244786AF27A54561A6-8070
   VCID: 43852533C2EB6259BF-8016
                    Reset counter: 147
                    Mileage: 200771 km
                    Date: 2017.02.06
                    Time: 14:14:30
   VCID: 6CD7AE8F4FF54D212E-8038
   Subsystem 3 - Serial number: RD25.03.09--H29001001B0086я
   Subsystem 4 - Serial number: 1B0086я
Address 76: Park Assist        Labels: User\4Fx-910-283.lbl
   Coding: 0001016
   VCID: 2959979B8087980995-807C
End-------------------------(Elapsed Time: 03:25)--------------------------
MartinsX
Riga, Latvia
C?ID=268515
Thanks, Dana!
SA 27971 was accepted by ECU. After some times trying I managed how to start DPF regeneration in basic settings channel 226. Some dance with brake and accelerator pedals needed, too :D Unfortunately regeneration ends with message 1.0 Abort 33.0 twice. What does it mean? No faults stored in ECU. Fault
                    Mileage: 200772 km
                    Date: 2017.02.07
                    Time: 18:33:48
                    (no units): 14.0
                    (no units): 26.5
                    Mileage: 260 km
                    Time: 0.00 s
                    (no units): 9.0
disappeared from ECU, too. But DPF warning in IPC stays on.
Dana
Western PA, USA
NEtech
C?ID=56995
Can you post controller map data from engine at idle.
MartinsX
Riga, Latvia
C?ID=268515
I have maps at state engine off/ignition on available at the moment. Those are logged before any repairs. Tomorrow I'll try Dana's suggestion and make new maps with engine at idle. P.S We have 10 pm here already, car left at workshop, I'm at home. Early for me, but sometimes have to take my time with family, too. ;)
MVB's:
;SW:4F7-910-401-K   HW:4F0-907-401-E ---  Engine
;Component:2.7TDI EDC17G000CG  0090, Coding:010D002C02070128
;Wednesday,01,February,2017,17:29:37:32442
;VCDS Version: Release 16.8.4  Data version: 20161129 DS267.0
;VCID: 2B556D938A7B8A1A4C-807E
Group,Field 1,Data type,Field 2,Data type,Field 3,Data type,Field 4,Data type,
1,0 /min,RPM,0.0 mg/str,Inj. Quantity,7.1 bar,Pressure,38.7°C,Temperature,
2,0 /min,RPM,0.0 %,Load, 0 01  0,Bin. Bits,38.7°C,Temperature,
3,0 /min,RPM,1192.6 mg/str,Mass Air / Rev.,0.0 mg/str,Mass Air / Rev.,99.6 %,Duty Cycle,
4,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.00 ms,Time,7.1 bar,Pressure,
5,0 /min,RPM,0.0 mg/str,Inj. Quantity,1.0,(no units),38.7°C,Temperature,
6,0.0 km/h,Speed,00101100,Bin. Bits,0.0 km/h,Speed,10000001,Bin. Bits,
7,26.1°C,Temperature,43.2°C,Temperature,17.1°C,Temperature,38.7°C,Temperature,
8,0 /min,RPM,0.0 Nm,Torque,420.0 Nm,Torque,799.5 Nm,Torque,
9,0 /min,RPM,-1280.0 Nm,Torque,799.5 Nm,Torque,0.0 Nm,Torque,
10,0.0 mg/str,Mass Air / Rev.,1020.0 mbar,Absolute Pres.,1020.0 mbar,Absolute Pres.,0.0 %,Load,
11,0 /min,RPM,989.4 mbar,Absolute Pres.,1020.0 mbar,Absolute Pres.,0.0 %,Duty Cycle,
12,01010000,Bin. Bits,0.00 s,Time,11.78 V,Voltage,38.7°C,Temperature,
13,0.00 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity, , ,
14,0.00 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity, , ,
15,0 /min,RPM,-195.0 Nm,Torque,0.00 l/h,Fuel Consump.,0.0 Nm,Torque,
16,0.0,(no units),00000001,Bin. Bits,0.0,(no units),0.0 %,Lambda,
18,0 /min,RPM,26.1°C,Temperature,0.0,(no units), , ,
19,0 /min,RPM,313.65,(no units),0.0 bar,Pressure,832.0,(no units),
20,0 /min,RPM,298.2 bar,Pressure,7.1 bar,Pressure,7.8 %,Lambda,
21,0 /min,RPM,298.2 bar,Pressure,7.1 bar,Pressure,15.6 %,Lambda,
22,0 /min,RPM,00000100,Bin. Bits,00000000,Bin. Bits,00110100,Bin. Bits,
23,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.00 ms,Time,3.0,(no units),
24,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.00 ms,Time,7.1 bar,Pressure,
25,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.00 ms,Time,7.1 bar,Pressure,
26,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.00 ms,Time,7.1 bar,Pressure,
28,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.00 ms,Time,7.1 bar,Pressure,
29,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.00 ms,Time,7.1 bar,Pressure,
30,0.740 V,Voltage,0.360 V,Voltage, 0 01  0,Bin. Bits,0.0 %,Load,
31,1507,Voltage,
32,0 /min,RPM,1.0,(no units),607.1 °,Angle,691.8 °,Angle,
33,0 /min,RPM,88.5°C,Temperature,1.00,(no units),1.00,(no units),
34,0 /min,RPM,0.0 %,Lambda,-0.8 %,Lambda,0.0 %,Lambda,
35,0 /min,RPM,1192.6 mg/str,Mass Air / Rev.,0.0 mg/str,Mass Air / Rev.,94.5 %,Duty Cycle,
36,0 /min,RPM,7.8 %,Lambda,0.0 %,Lambda,0.0 %,Lambda,
37,0 /min,RPM,9.4 %,Lambda,0.8 %,Lambda,0.0 %,Lambda,
38,0 /min,RPM,99.6 %,Duty Cycle,-0.8 %,Lambda,0.0 %,Lambda,
39,0 /min,RPM,0.0 mg/str,Mass Air / Rev.,17.1°C,Temperature,4.7 %,Lambda,
40,0 /min,RPM,0.0 %,Lambda,0.0 %,Lambda,4.7 %,Lambda,
41,4.7,Ohms,0.000 V,Voltage,0.1 %,Lambda,1.0,(no units),
42,0.1 %,Lambda,2.4 %,Lambda,3.300 V,Voltage,25.40,(no units),
43,0.0,(no units),12.6°C,Temperature,1030.2 mbar,Absolute Pres.,0.000 V,Voltage,
44,0 /min,RPM,11001000,Bin. Bits,0.0,(no units),0.0,(no units),
45,38.7°C,Temperature,0.0 %,Duty Cycle,9.4 %,Lambda,9.4 %,Lambda,
46,12.6°C,Temperature,19.8°C,Temperature,00000001,Bin. Bits,00000001,Bin. Bits,
47,89.1°C,Temperature,38.7°C,Temperature,95.5 %,Duty Cycle,9.4 %,Lambda,
48,0 /min,RPM,0 /min,RPM,       0,Bin. Bits,1270.0 Nm,Torque,
51,0 /min,RPM,0 /min,RPM,1.0,(no units), , ,
52,0 /min,RPM,0.0,(no units),0.0,(no units), , ,
53,00000000,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,00000100,Bin. Bits,
57,0 /min,RPM,0.0 km/h,Speed,100.6 %,Duty Cycle,100.6 %,Duty Cycle,
58,0 /min,RPM,0.0 km/h,Speed,100.6 %,Duty Cycle,100.6 %,Duty Cycle,
59,0 /min,RPM,-195.0 Nm,Torque,42.9 Nm,Torque,0.0 Nm,Torque,
60,42.9 Nm,Torque,-46.8 Nm,Torque,0.0 Nm,Torque,0.0,(no units),
61,0 /min,RPM,43.2°C,Temperature,37.0,(no units),64.77,(no units),
62,0 /min,RPM,0.0 mg/str,Inj. Quantity,0.0,(no units),0.0,(no units),
70,71.0,(no units),71.0,(no units),72.0,(no units), , ,
71,11111111,Bin. Bits,00111111,Bin. Bits, , , , ,
72,32.0 ms,Time Corr.,7.0 ms,Time Corr.,7.0 ms,Time Corr., , ,
73,43.0 ms,Time Corr.,18.0 ms,Time Corr.,12.0 ms,Time Corr., , ,
74,45.0 ms,Time Corr.,8.0 ms,Time Corr.,9.0 ms,Time Corr., , ,
75,48.0 ms,Time Corr.,11.0 ms,Time Corr.,12.0 ms,Time Corr., , ,
76,26.0 ms,Time Corr.,11.0 ms,Time Corr.,12.0 ms,Time Corr., , ,
77,29.0 ms,Time Corr.,13.0 ms,Time Corr.,16.0 ms,Time Corr., , ,
80,BPG-810 11.03.09 16H01--- 1235 0521, ,
81,WAUZZZ4F19N053478                <>     , ,
82,9436112343915 26.04.11 <>  <>   <>  <>  , ,
85,200770 km,Mileage,0.0,(no units),3265.0,(no units),10864.0,(no units),
86,11111111,Bin. Bits,11111111,Bin. Bits,11111111,Bin. Bits,11111111,Bin. Bits,
87,11111111,Bin. Bits,11111111,Bin. Bits,11111111,Bin. Bits, , ,
89,00000000,Bin. Bits,00001110,Bin. Bits,10000000,Bin. Bits,00000000,Bin. Bits,
90,0 /min,RPM,0.0 mg/str,Inj. Quantity,1192.6 mg/str,Mass Air / Rev.,00000000,Bin. Bits,
91,127.0,(no units),-128.0,(no units),1192.6 mg/str,Mass Air / Rev.,120.0,(no units),
93,00000000,Bin. Bits,1.89,(no units),0.0,(no units),0.0,(no units),
94,00000000,Bin. Bits, , , , , , ,
95,       0,Bin. Bits, 001   1,Bin. Bits,01011110,Bin. Bits,      10,Bin. Bits,
96,       0,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,11.78 V,Voltage,
97,-6 mbar,Pressure,-6 mbar,Pressure, , , , ,
98,38.7°C,Temperature,33.3°C,Temperature,       0,Bin. Bits,53.1°C,Temperature,
99,0 /min,RPM,849.6°C,Temperature,41.3°C,Temperature,224.2°C,Temperature,
100,0 /min,RPM,41.3°C,Temperature,0.0,(no units),       0,Bin. Bits,
101,00000000,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,00000001,Bin. Bits,
102,35.4°C,Temperature,41.3°C,Temperature,-6 mbar,Pressure,-6 mbar,Pressure,
103,00000001,Bin. Bits,00010000,Bin. Bits,     000,Bin. Bits,      00,Bin. Bits,
104,0.35,(no units),14.5,(no units),10.0,(no units),260 km,Mileage,
105,0.0,(no units),3.0,(no units),8.0,(no units),23.0 l,Tank Cont.,
106,00000000,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,
107,49.0,(no units),30.0,(no units),20.0,(no units),0.0,(no units),
110, , ,00000110,Bin. Bits,0.0 km/h,Speed, , ,
111,0 /min,RPM,0.0 km/h,Speed,0.00,(no units),0.0,(no units),
112,0.00,(no units),-700.0 Nm,Torque,-1280.0 Nm,Torque,0.0 Nm,Torque,
113,00000110,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,
114,255.0,(no units),255.0,(no units),0.00,(no units),0.00,(no units),
120,0.0 %,Lambda,0.0 %,Lambda,00000010,Bin. Bits,0.620 V,Voltage,
121,1.6 %,Lambda,13.3 %,Lambda,00000000,Bin. Bits,0.240 V,Voltage,
122,10.2 %,Lambda,9.4 %,Lambda,00000100,Bin. Bits,0.720 V,Voltage,
123, , ,00000100,Bin. Bits,00000010,Bin. Bits,3.960 V,Voltage,
124, , , , ,00000000,Bin. Bits, , ,
125,Transm. 1, ,ABS 1, ,Instruments 1, ,Airbag 1, ,
126,HVAC 1, , , , , , , ,
127, , , , ,El.Ign.Lock 1, ,St. Wheel 1, ,
128,Gateway 1, , , ,Steer. ang. 1, ,Park Brake 1, ,
133,1.00,(no units),1.00,(no units),1.00,(no units),1.00,(no units),
135,84.3 %,Load,29.7°C,Temperature,70.2°C,Temperature, , ,
148,11001101,Bin. Bits,00001100,Bin. Bits,00010000,Bin. Bits,00000000,Bin. Bits,
149,2016 /min,RPM,-1.18 mg/str,Inj. Quantity,20.0 mg/str,Inj. Quantity, , ,
166,1.02,(no units),1.00,(no units),1.05,(no units),1.01,(no units),
167,1.00,(no units),1.01,(no units), , , , ,
200,0.0,(no units),0.0,(no units),0.0,(no units), , ,
201,0.0,(no units),0.0,(no units),0.0,(no units), , ,
202,0 /min,RPM,0.0,(no units),0.0,(no units),0.0,(no units),
203,00000000,Bin. Bits,00000000,Bin. Bits,0.14,(no units),0.0 Nm,Torque,
204,-260.0 Nm,Torque,0.0 Nm,Torque,00000000,Bin. Bits, , ,
205,100.0,(no units),0.00,(no units), , , , ,
206,00000000,Bin. Bits,1250 km,Mileage,00000000,Bin. Bits, , ,
207,1.04,(no units), , , , , , ,
218, , ,0 km,Mileage,0.0,(no units),0.0,(no units),
219,-277.3°C,Temperature,-277.3°C,Temperature,0.0 km/h,Speed,0.0 km/h,Speed,
220,0.0,(no units), , , , , , ,
225,0.0,(no units),0.0,(no units),0.0,(no units),0.0,(no units),
226,0.0,(no units), , ,0.0,(no units),0.0,(no units),
227,0.0,(no units),0.0,(no units),0.0,(no units),0.0,(no units),
228,0.0,(no units),0.0,(no units),0.0,(no units),0.0,(no units),
229, , , , ,0.0,(no units),0.0,(no units),
230,0.0,(no units),0.0,(no units),0.0,(no units),0.0,(no units),
231,0.00,(no units),0.00,(no units),0.00,(no units),0.00,(no units),
232,20 km,Mileage,0.0,(no units),0.0,(no units),0.0,(no units),
233,1050 /min,RPM,0 /min,RPM,0 /min,RPM,29.1 km/h,Speed,
234,182.9°C,Temperature,-277.3°C,Temperature,28.0,(no units),0.0,(no units),
235,-0.01,(no units),-0.01,(no units),0.06,(no units),0.00,(no units),
236,0.00,(no units),0.0,(no units),0.0,(no units),0.0,(no units),
237,0.0,(no units),0.0,(no units),0.0,(no units), , ,
Adaptions:
;Wednesday,01,February,2017,17:30:11:32442
Channel,,Field 1,Field 2,Field 3,Field 4,
01,0, , , , ,
02,,ERROR:,Channel 02,Not,Available,
03,10000, , , , ,
04,,ERROR:,Channel 04,Not,Available,
05,50, , , , ,
06,20,0 /min, , , ,
07,,ERROR:,Channel 07,Not,Available,
08,30, , , , ,
09,,ERROR:,Channel 09,Not,Available,
10,,ERROR:,Channel 10,Not,Available,
11,,ERROR:,Channel 11,Not,Available,
12,,ERROR:,Channel 12,Not,Available,
13,,ERROR:,Security,access,required,
14,0, , , , ,
15,,ERROR:,Channel 15,Not,Available,
16,,ERROR:,Channel 16,Not,Available,
17,,ERROR:,Channel 17,Not,Available,
18,,ERROR:,Channel 18,Not,Available,
19,0,00000000,1250 km,00000000, ,
20,,ERROR:,Channel 20,Not,Available,
21,,ERROR:,Channel 21,Not,Available,
22,1, , , , ,
23,0,0.0, , , ,
24,,ERROR:,Channel 24,Not,Available,
25,,ERROR:,Channel 25,Not,Available,
26,,ERROR:,Channel 26,Not,Available,
27,,ERROR:,Channel 27,Not,Available,
28,,ERROR:,Channel 28,Not,Available,
29,,ERROR:,Channel 29,Not,Available,
30,,ERROR:,Channel 30,Not,Available,
31,,ERROR:,Channel 31,Not,Available,
32,,ERROR:,Channel 32,Not,Available,
33,,ERROR:,Channel 33,Not,Available,
34,,ERROR:,Channel 34,Not,Available,
35,,ERROR:,Channel 35,Not,Available,
36,,ERROR:,Channel 36,Not,Available,
37,,ERROR:,Channel 37,Not,Available,
38,,ERROR:,Channel 38,Not,Available,
39,,ERROR:,Channel 39,Not,Available,
40,,ERROR:,Channel 40,Not,Available,
41,,ERROR:,Channel 41,Not,Available,
42,,ERROR:,Channel 42,Not,Available,
43,,ERROR:,Channel 43,Not,Available,
44,,ERROR:,Channel 44,Not,Available,
45,,ERROR:,Channel 45,Not,Available,
46,,ERROR:,Channel 46,Not,Available,
47,,ERROR:,Channel 47,Not,Available,
48,,ERROR:,Channel 48,Not,Available,
49,,ERROR:,Channel 49,Not,Available,
50,,ERROR:,Security,access,required,
51,,ERROR:,Channel 51,Not,Available,
52,,ERROR:,Channel 52,Not,Available,
53,,ERROR:,Channel 53,Not,Available,
54,,ERROR:,Channel 54,Not,Available,
55,,ERROR:,Channel 55,Not,Available,
56,,ERROR:,Channel 56,Not,Available,
57,,ERROR:,Channel 57,Not,Available,
58,,ERROR:,Channel 58,Not,Available,
59,,ERROR:,Channel 59,Not,Available,
60,,ERROR:,Channel 60,Not,Available,
61,,ERROR:,Channel 61,Not,Available,
62,,ERROR:,Channel 62,Not,Available,
63,,ERROR:,Channel 63,Not,Available,
64,,ERROR:,Channel 64,Not,Available,
65,,ERROR:,Channel 65,Not,Available,
66,,ERROR:,Channel 66,Not,Available,
67,,ERROR:,Channel 67,Not,Available,
68,,ERROR:,Channel 68,Not,Available,
69,,ERROR:,Channel 69,Not,Available,
70,,ERROR:,Channel 70,Not,Available,
71,AZ8X7NI, , , , ,
72,DS13KWI, , , , ,
73,AZ1EBSI, , , , ,
74,8SHR8NH, , , , ,
75,BSIPDAH, , , , ,
76,A1ICD1H, , , , ,
77,,ERROR:,Channel 77,Not,Available,
78,,ERROR:,Channel 78,Not,Available,
79,,ERROR:,Channel 79,Not,Available,
80,,ERROR:,Channel 80,Not,Available,
81,0, , , , ,
82,0, , , , ,
83,0, , , , ,
84,,ERROR:,Channel 84,Not,Available,
85,,ERROR:,Channel 85,Not,Available,
86,,ERROR:,Channel 86,Not,Available,
87,,ERROR:,Channel 87,Not,Available,
88,,ERROR:,Channel 88,Not,Available,
89,,ERROR:,Channel 89,Not,Available,
90,,ERROR:,Channel 90,Not,Available,
91,4, , , , ,
92,,ERROR:,Channel 92,Not,Available,
93,,ERROR:,Channel 93,Not,Available,
94,,ERROR:,Channel 94,Not,Available,
95,,ERROR:,Channel 95,Not,Available,
96,,ERROR:,Channel 96,Not,Available,
97,,ERROR:,Channel 97,Not,Available,
98,,ERROR:,Channel 98,Not,Available,
99,0, , , , ,
100,,ERROR:,Channel 100,Not,Available,
101,,ERROR:,Channel 101,Not,Available,
102,,ERROR:,Channel 102,Not,Available,
103,,ERROR:,Channel 103,Not,Available,
104,,ERROR:,Channel 104,Not,Available,
105,,ERROR:,Channel 105,Not,Available,
106,,ERROR:,Channel 106,Not,Available,
107,,ERROR:,Channel 107,Not,Available,
108,,ERROR:,Channel 108,Not,Available,
109,,ERROR:,Channel 109,Not,Available,
110,,ERROR:,Channel 110,Not,Available,
111,,ERROR:,Channel 111,Not,Available,
112,,ERROR:,Channel 112,Not,Available,
113,,ERROR:,Channel 113,Not,Available,
114,,ERROR:,Channel 114,Not,Available,
115,,ERROR:,Channel 115,Not,Available,
116,,ERROR:,Channel 116,Not,Available,
117,0, , , , ,
118,,ERROR:,Channel 118,Not,Available,
119,,ERROR:,Channel 119,Not,Available,
120,,ERROR:,Channel 120,Not,Available,
121,,ERROR:,Channel 121,Not,Available,
122,,ERROR:,Channel 122,Not,Available,
123,,ERROR:,Channel 123,Not,Available,
124,,ERROR:,Channel 124,Not,Available,
125,,ERROR:,Channel 125,Not,Available,
126,,ERROR:,Channel 126,Not,Available,
127,,ERROR:,Channel 127,Not,Available,
128,,ERROR:,Security,access,required,
129,,ERROR:,Security,access,required,
130,,ERROR:,Security,access,required,
131,,ERROR:,Security,access,required,
132,,ERROR:,Security,access,required,
133,,ERROR:,Security,access,required,
134,,ERROR:,Security,access,required,
135,,ERROR:,Security,access,required,
136,,ERROR:,Security,access,required,
137,,ERROR:,Security,access,required,
138,,ERROR:,Security,access,required,
139,,ERROR:,Security,access,required,
140,,ERROR:,Security,access,required,
141,,ERROR:,Security,access,required,
142,,ERROR:,Security,access,required,
143,,ERROR:,Security,access,required,
144,,ERROR:,Security,access,required,
145,,ERROR:,Security,access,required,
146,,ERROR:,Security,access,required,
147,,ERROR:,Security,access,required,
148,,ERROR:,Security,access,required,
149,,ERROR:,Security,access,required,
150,,ERROR:,Security,access,required,
151,,ERROR:,Security,access,required,
152,,ERROR:,Security,access,required,
153,,ERROR:,Security,access,required,
154,,ERROR:,Security,access,required,
155,,ERROR:,Security,access,required,
156,,ERROR:,Security,access,required,
157,,ERROR:,Security,access,required,
158,,ERROR:,Security,access,required,
159,,ERROR:,Security,access,required,
160,,ERROR:,Security,access,required,
161,,ERROR:,Security,access,required,
162,,ERROR:,Security,access,required,
163,,ERROR:,Security,access,required,
164,,ERROR:,Security,access,required,
165,,ERROR:,Security,access,required,
166,,ERROR:,Security,access,required,
167,,ERROR:,Security,access,required,
168,,ERROR:,Security,access,required,
169,,ERROR:,Security,access,required,
170,,ERROR:,Security,access,required,
171,,ERROR:,Security,access,required,
172,,ERROR:,Security,access,required,
173,,ERROR:,Security,access,required,
174,,ERROR:,Security,access,required,
175,,ERROR:,Security,access,required,
176,,ERROR:,Security,access,required,
177,,ERROR:,Security,access,required,
178,,ERROR:,Security,access,required,
179,,ERROR:,Security,access,required,
180,,ERROR:,Security,access,required,
181,,ERROR:,Security,access,required,
182,,ERROR:,Security,access,required,
183,,ERROR:,Security,access,required,
184,,ERROR:,Channel 184,Not,Available,
185,,ERROR:,Channel 185,Not,Available,
186,,ERROR:,Channel 186,Not,Available,
187,,ERROR:,Channel 187,Not,Available,
188,,ERROR:,Channel 188,Not,Available,
189,,ERROR:,Channel 189,Not,Available,
190,,ERROR:,Channel 190,Not,Available,
191,,ERROR:,Security,access,required,
192,,ERROR:,Security,access,required,
193,,ERROR:,Security,access,required,
194,,ERROR:,Security,access,required,
195,,ERROR:,Security,access,required,
196,,ERROR:,Security,access,required,
197,,ERROR:,Security,access,required,
198,,ERROR:,Security,access,required,
199,,ERROR:,Security,access,required,
200,,ERROR:,Security,access,required,
201,,ERROR:,Channel 201,Not,Available,
202,,ERROR:,Security,access,required,
203,,ERROR:,Security,access,required,
204,,ERROR:,Security,access,required,
205,,ERROR:,Security,access,required,
206,,ERROR:,Security,access,required,
207,,ERROR:,Security,access,required,
208,,ERROR:,Security,access,required,
209,,ERROR:,Security,access,required,
210,,ERROR:,Security,access,required,
211,,ERROR:,Security,access,required,
212,,ERROR:,Security,access,required,
213,,ERROR:,Security,access,required,
214,,ERROR:,Security,access,required,
215,,ERROR:,Security,access,required,
216,,ERROR:,Security,access,required,
217,,ERROR:,Security,access,required,
218,,ERROR:,Channel 218,Not,Available,
219,,ERROR:,Security,access,required,
220,,ERROR:,Security,access,required,
221,,ERROR:,Security,access,required,
222,,ERROR:,Security,access,required,
223,,ERROR:,Security,access,required,
224,,ERROR:,Security,access,required,
225,,ERROR:,Security,access,required,
226,,ERROR:,Security,access,required,
227,,ERROR:,Security,access,required,
228,,ERROR:,Security,access,required,
229,,ERROR:,Security,access,required,
230,,ERROR:,Security,access,required,
231,,ERROR:,Security,access,required,
232,,ERROR:,Security,access,required,
233,,ERROR:,Security,access,required,
234,,ERROR:,Security,access,required,
235,,ERROR:,Security,access,required,
236,,ERROR:,Security,access,required,
237,,ERROR:,Security,access,required,
238,,ERROR:,Security,access,required,
239,,ERROR:,Security,access,required,
240,,ERROR:,Security,access,required,
241,,ERROR:,Security,access,required,
242,,ERROR:,Security,access,required,
243,,ERROR:,Security,access,required,
244,,ERROR:,Security,access,required,
245,,ERROR:,Security,access,required,
246,,ERROR:,Security,access,required,
247,,ERROR:,Security,access,required,
248,,ERROR:,Security,access,required,
249,,ERROR:,Security,access,required,
250,,ERROR:,Security,access,required,
251,,ERROR:,Security,access,required,
252,,ERROR:,Security,access,required,
253,,ERROR:,Security,access,required,
254,,ERROR:,Security,access,required,
255,,ERROR:,Security,access,required,
NEtech
C?ID=56995
Maybe you can check G450 diff.pressure sensor at different ref. pressures, see MWB 102.3
With ign. the sensor and sensor offset both show -6.0 mbar.
A little strange data:
104, 0.35 (Ash), 14.5 (Soot calc.), 10.0 (Soot meas.), 260 km (Mileage since last regen.)
MartinsX
Riga, Latvia
C?ID=268515
In any case it would be useful to check and recalibrate G450. Only some special, unknown for me, procedure and login or SA needed for it, again.
Do You know any non-English version of label file exist for this engine? Probably it should exist and probably in German version, if VCDS shows Redir Fail. Maybe you know file name for it? I can't find any when searching by partnumber of ECU.
jonixins
Latvia
C?ID=151647
I have had some of cars with similar ECU's to full advanced DPF delete procedure, when even Audi dealer could not get car working with perfect DPF etc.
MartinsX
Riga, Latvia
C?ID=268515
I know, and You will be asked for help, if I will not find any way how to make it work as it should work originally ;)
MartinsX
Riga, Latvia
C?ID=268515
Some couple more attempts start regeneration stationary ended with the same 1.0 Abort 33.0 once and 1.0 Error 57.0 second time.
MVB's with engine warmed up and running at idle:
;Wednesday,08,February,2017,10:46:08:32442
;VCDS Version: Release 17.1.2  Data version: 20170131 DS267.1
;VCID: 2B556D938A7B8A1967-807E
1,777 /min,RPM,6.0 mg/str,Inj. Quantity,298.2 bar,Pressure,81.0°C,Temperature,
2,777 /min,RPM,0.0 %,Load, 0 01  0,Bin. Bits,81.0°C,Temperature,
3,777 /min,RPM,329.0 mg/str,Mass Air / Rev.,329.0 mg/str,Mass Air / Rev.,99.6 %,Duty Cycle,
4,777 /min,RPM,1.2 °BTDC,Ign. Timing,0.44 ms,Time,298.2 bar,Pressure,
5,777 /min,RPM,40.0 mg/str,Inj. Quantity,48.0,(no units),81.0°C,Temperature,
7,19.8°C,Temperature,75.6°C,Temperature,28.8°C,Temperature,81.0°C,Temperature,
8,777 /min,RPM,0.0 Nm,Torque,420.0 Nm,Torque,171.6 Nm,Torque,
9,777 /min,RPM,-1280.0 Nm,Torque,799.5 Nm,Torque,171.6 Nm,Torque,
10,334.9 mg/str,Mass Air / Rev.,1040.4 mbar,Absolute Pres.,1071.0 mbar,Absolute Pres.,0.0 %,Load,
11,777 /min,RPM,989.4 mbar,Absolute Pres.,1071.0 mbar,Absolute Pres.,99.6 %,Duty Cycle,
12,11111111,Bin. Bits,1.98 s,Time,14.44 V,Voltage,81.0°C,Temperature,
13,-0.75 mg/str,Inj. Quantity,0.05 mg/str,Inj. Quantity,0.19 mg/str,Inj. Quantity, , ,
14,0.05 mg/str,Inj. Quantity,0.14 mg/str,Inj. Quantity,0.24 mg/str,Inj. Quantity, , ,
15,777 /min,RPM,66.3 Nm,Torque,0.93 l/h,Fuel Consump.,0.0 Nm,Torque,
18,777 /min,RPM,19.8°C,Temperature,5.0,(no units), , ,
19,777 /min,RPM,0.00,(no units),482.8 bar,Pressure,120.0,(no units),
20,777 /min,RPM,298.2 bar,Pressure,298.2 bar,Pressure,22.7 %,Lambda,
21,777 /min,RPM,298.2 bar,Pressure,298.2 bar,Pressure,44.5 %,Lambda,
22,777 /min,RPM,00110111,Bin. Bits,00110100,Bin. Bits,00110111,Bin. Bits,
23,777 /min,RPM,1.2 °BTDC,Ign. Timing,0.44 ms,Time,5.0,(no units),
24,777 /min,RPM,0.0 °BTDC,Ign. Timing,0.00 ms,Time,298.2 bar,Pressure,
25,777 /min,RPM,15.9 °BTDC,Ign. Timing,0.28 ms,Time,305.3 bar,Pressure,
26,777 /min,RPM,8.8 °BTDC,Ign. Timing,0.26 ms,Time,298.2 bar,Pressure,
28,777 /min,RPM,0.0 °BTDC,Ign. Timing,0.10 ms,Time,298.2 bar,Pressure,
29,777 /min,RPM,0.0 °BTDC,Ign. Timing,0.00 ms,Time,298.2 bar,Pressure,
31,1507,Voltage,
32,777 /min,RPM,48.0,(no units),607.1 °,Angle,691.8 °,Angle,
33,777 /min,RPM,159.3°C,Temperature,1.00,(no units),1.00,(no units),
34,777 /min,RPM,99.2 %,Lambda,99.2 %,Lambda,0.0 %,Lambda,
35,777 /min,RPM,329.0 mg/str,Mass Air / Rev.,323.1 mg/str,Mass Air / Rev.,4.7 %,Duty Cycle,
36,777 /min,RPM,94.5 %,Lambda,0.0 %,Lambda,0.0 %,Lambda,
37,777 /min,RPM,94.5 %,Lambda,94.5 %,Lambda,-24.2 %,Lambda,
38,777 /min,RPM,99.6 %,Duty Cycle,-0.8 %,Lambda,12.5 %,Lambda,
39,777 /min,RPM,329.0 mg/str,Mass Air / Rev.,28.8°C,Temperature,78.1 %,Lambda,
40,777 /min,RPM,78.1 %,Lambda,78.1 %,Lambda,78.1 %,Lambda,
41,5.8,Ohms,0.000 V,Voltage,0.1 %,Lambda,1.0,(no units),
42,0.1 %,Lambda,37.9 %,Lambda,1.000 V,Voltage,3.39,(no units),
43,0.0,(no units),-1.8°C,Temperature,1060.8 mbar,Absolute Pres.,0.920 V,Voltage,
44,777 /min,RPM,10001000,Bin. Bits,0.0,(no units),0.0,(no units),
45,81.0°C,Temperature,0.0 %,Duty Cycle,9.4 %,Lambda,9.4 %,Lambda,
46,-1.8°C,Temperature,19.8°C,Temperature,00000000,Bin. Bits,00000000,Bin. Bits,
47,89.1°C,Temperature,81.0°C,Temperature,19.7 %,Duty Cycle,9.4 %,Lambda,
48,777 /min,RPM,0 /min,RPM,       0,Bin. Bits,1270.0 Nm,Torque,
51,777 /min,RPM,392 /min,RPM,48.0,(no units), , ,
52,777 /min,RPM,0.0,(no units),0.0,(no units), , ,
57,777 /min,RPM,0.0 km/h,Speed,0.0 %,Duty Cycle,0.0 %,Duty Cycle,
58,777 /min,RPM,0.0 km/h,Speed,0.0 %,Duty Cycle,0.0 %,Duty Cycle,
59,777 /min,RPM,66.3 Nm,Torque,54.6 Nm,Torque,3.9 Nm,Torque,
60,54.6 Nm,Torque,-46.8 Nm,Torque,23.4 Nm,Torque,433.5,(no units),
61,777 /min,RPM,75.6°C,Temperature,36.0,(no units),64.77,(no units),
62,777 /min,RPM,6.0 mg/str,Inj. Quantity,39.0,(no units),0.0,(no units),
85,200770 km,Mileage,0.0,(no units),3265.0,(no units),10874.0,(no units),
90,777 /min,RPM,6.0 mg/str,Inj. Quantity,329.0 mg/str,Mass Air / Rev.,00000000,Bin. Bits,
91,127.0,(no units),-128.0,(no units),329.0 mg/str,Mass Air / Rev.,-1.0,(no units),
93,00000000,Bin. Bits,1.60,(no units),44.0,(no units),56.0,(no units),
95,       0,Bin. Bits, 001   1,Bin. Bits,00001100,Bin. Bits,      10,Bin. Bits,
96,       0,Bin. Bits,00000000,Bin. Bits,00000001,Bin. Bits,14.36 V,Voltage,
97,0 mbar,Pressure,0 mbar,Pressure, , , , ,
98,81.0°C,Temperature,67.5°C,Temperature,       0,Bin. Bits,76.7°C,Temperature,
99,777 /min,RPM,849.6°C,Temperature,129.8°C,Temperature,224.2°C,Temperature,
100,777 /min,RPM,123.9°C,Temperature,0.0,(no units),       0,Bin. Bits,
102,141.6°C,Temperature,129.8°C,Temperature,6 mbar,Pressure,0 mbar,Pressure,
103,00000010,Bin. Bits,00011100,Bin. Bits,     000,Bin. Bits,      00,Bin. Bits,
104,0.35,(no units),28.5,(no units),21.5,(no units),260 km,Mileage,
105,1.0,(no units),8.0,(no units),12.0,(no units),27.0 l,Tank Cont.,
107,49.0,(no units),30.0,(no units),20.0,(no units),47.0,(no units),
111,777 /min,RPM,0.0 km/h,Speed,0.00,(no units),0.0,(no units),
120,0.0 %,Lambda,0.0 %,Lambda,00000010,Bin. Bits,4.260 V,Voltage,
122,12.5 %,Lambda,8.6 %,Lambda,00000100,Bin. Bits,4.200 V,Voltage,
123, , ,01110110,Bin. Bits,00001010,Bin. Bits,3.940 V,Voltage,
135,84.3 %,Load,28.8°C,Temperature,70.2°C,Temperature, , ,
149,651 /min,RPM,0.00 mg/str,Inj. Quantity,40.0 mg/str,Inj. Quantity, , ,
200,6.0,(no units),9.0,(no units),9.0,(no units), , ,
201,9.0,(no units),8.0,(no units),11.0,(no units), , ,
202,777 /min,RPM,1.0,(no units),1.0,(no units),0.0,(no units),
203,01010001,Bin. Bits,00000000,Bin. Bits,0.14,(no units),0.0 Nm,Torque,
231,0.10,(no units),0.00,(no units),0.43,(no units),0.00,(no units),
233,966 /min,RPM,0 /min,RPM,0 /min,RPM,20.2 km/h,Speed,
234,141.6°C,Temperature,-277.3°C,Temperature,46.0,(no units),0.0,(no units),
235,-0.01,(no units),-0.01,(no units),0.05,(no units),0.00,(no units),
NEtech
C?ID=56995
Is that like this MWB
226.2 = 1
226.4 = 33
It could be interesting to know what values in MWB 101 (and maybe 106) is, after regeneration error.
Have you tried while driving, as Dana mentioned ?
MartinsX
Riga, Latvia
C?ID=268515
When login entered and process starts it shows like:
226.1 = some temperature (probably one of exhaust T sensors)
226.2 = some another temperature (probably another one of exhaust T sensors)
226.3 = 0.0
226.4 = 10000100
When process stops, it shows (several times):
226.1 = 1.0
226.2 = Abort
226.3 = 33.0
226.4 =
And once:
226.1 = 1.0
226.2 = ERROR
226.3 = 57.0
226.4 =
Will try regen in drive mode soon.
Dana
Western PA, USA
I believe Coding-II/Login 30605 = Exhaust Gas Differential Pressure Sensor (G450) Adaptation applies. After the Login make sure to turn the ignition off for 30 seconds and recheck MVBs. If that code is refused or doesn't change MVB data I can dig deeper to see if this uses Adp instead.
We do not have that file in German or English (REDIRECT,059-907-401-CAN.CLB,4F7-910-401-K ; CANA (4F)) but I can make sure we have this on the to-do list.
Internal ref: FS#1297
MartinsX
Riga, Latvia
C?ID=268515
Login 30605 is not accepted, error 11.
SA 12233 is accepted and it allows to see Long Adp ch 13. It shows 0. What should I do with it? Change to 1?
NEtech
C?ID=56995
I believe it is done at channel 83, enter 0001
Yes.
I am not sure if it done at idle, but I would guess so.
Then,
  • Driving min. 15-20 minutes
  • Min. 50 km/h
  • Engine rpm higher as 2500 min-1
NEtech
C?ID=56995
Sorry, Long adaptation, in my terminology, Basic Settings is MWB (if we are not talking UDS) :)
MartinsX
Riga, Latvia
C?ID=268515
Value 1 is accepted in Long Adp Ch 83, but it didn't make any changes in MVB 102.
Value 1 is accepted in Long Adp Ch 13, too, but nothing noticable changes at DPF related MVB's nor at idle nor during testdrive.
Car is returned to customer right now, he will come back next week to continue with door lock repairs, then I'll have some more possibilities to investigate DPF issue. DPF is not restricted/clogged definitely, no any noticable driveability problems.
Latest autoscan:
Thursday,09,February,2017,16:14:56:32442
          62 6D 72 76
VIN: WAUZZZ4F19N053478   Mileage: 200790km-124765miles
   Coding: 0016776
                    Reset counter: 191
                    Mileage: 200796 km
                    Date: 2017.02.09
                    Time: 09:46:39
                    Hex Value: 0x0000
                    Hex Value: 0x40A2
                    Hex Value: 0x0013
                    Hex Value: 0x2A8D
                    Hex Value: 0x00FF
   Coding: 0000131
   VCID: 25419BABEC9FBC69B1-8070
   Coding: 0000278
   Coding: 0013121
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00150573
   Shop #: WSC 02335
   Coding: 0022022
                    Fault Frequency: 36
                    Reset counter: 190
                    Mileage: 200772 km
                    Date: 2017.02.08
                    Time: 09:12:49
   Coding: 000303
                    Fault Frequency: 36
                    Reset counter: 190
                    Mileage: 200772 km
                    Date: 2017.02.08
                    Time: 09:12:49
                    Bin. Bits:    01111
                    Voltage: 13.20 V
                    Count: 7
                    Bin. Bits:     1011
                    Time: 0.00 s
   Coding: 0000110
   Coding: 3547781
   Coding: 0001013
                    Reset counter: 148
                    Mileage: 200772 km
                    Date: 2017.02.07
                    Time: 19:13:21
   Revision: --H05---
   Coding: 0000531
   Coding: 0000004
                    Fault Frequency: 36
                    Reset counter: 190
                    Mileage: 200776 km
                    Date: 2017.02.08
                    Time: 09:12:48
   Coding: 0001003
                    Fault Frequency: 36
                    Reset counter: 190
                    Mileage: 200772 km
                    Date: 2017.02.08
                    Time: 09:12:49
                    Reset counter: 148
                    Mileage: 200772 km
                    Date: 2017.02.07
                    Time: 19:13:21
   Coding: 0001016
End-------------------------(Elapsed Time: 03:24)--------------------------
P.S. After all different things tried now it is possible to clear DPF fault code, it comes back after some ignition cycles. DPF warning symbol in IPC sometimes is present, and sometimes not. Before it was not possible to clear fault.
jonixins
Latvia
C?ID=151647
Client should try using some petrol additives which increase dpf temperature. There also might be temperature increase defect.
