Results 1 to 4 of 4
Thread: P202A code and recall 23T3.....Are they connected...
    Feb 2016
    Canada
    Hello all, I came to this forum to see if P202A code is related to 23T3 recall...here is my scan.
    Address 01: Engine (J623-CKRA) Labels: 03L-906-012-CKR.clb
    Part No SW: 03L 906 012 BP HW: 03L 907 309 S
    Component: R4 2,0L EDC H21 7445
    Revision: 71H21--- Serial number: 00000000000000
    Coding: 001D0012842400008000
    Shop #: WSC 46153 001 1048576
    ASAM Dataset: EV_ECM20TDI01103L906012BP 004009
    ROD: EV_ECM20TDI01103L906012BP.rod
    VCID: 73E5E1A7DA20DCD9EE-8026
    9655 - Control Circuit for Reductant Tank Heating
    P202A 00 [175] - Open Circuit
    Mileage: 194780 km
    Date: 2017.01.31
    Time: 14:39:33
    Engine speed: 979.00 /min
    Normed load value: 48.2 %
    Coolant temperature: 62 C
    Intake air temperature: 20 C
    Voltage terminal 30: 13.880 V
    Outside air temperature: -2.0 C
    Pressure sensor for reducing agent: measured pressure: 5002 hPa
    Sensor for reducing agent fill level: fill level: 77.14 %
    Sensor for reducing agent tank temperature: temperature: -2.8 C
    Reducing agent pump: activation: 11.48 %
    Readiness: 1 1 0 0 0
    this problem started after I started using a carwash at a place that has "Under-Carriage Blast"
    the code returns within one hour of resetting, almost always at re-start ups or shortly after, now I keep BT Torque adaptor plugged in, so I can reset it on the fly, easier than VCDS.
    I read some posts online, but none addresses this question directly, the recall language is rather vague, so
    A)is this connected to the 23T3 recall?
    B) and/or what connector 23T3 refers to, and the circuits that carried by this "Connector" (the 23T3 refers to.
    Thank You
  2. Likes tncrom liked this post
  3. #2
    Jan 2017
    Iowa, USA
    Wondering if you ever got this answered? I have a p202a as of today and very interested in the answer if you might have it.
    Thanks,
    Chris
    Feb 2016
    Canada
    Quote Originally Posted by tncrom View Post
    Thanks,
    Chris
    No, other than the obvious where the sensor monitors the level of Nox while the adblu is there to reduce it, I do not know if they they both use the same connector, or not.
    I am in Canada so to me it is not a deal breaker, as I plan to opt for the Buyback offer, coming in a couple of months, and the code will have no baring on the value.
    Jan 2017
    Iowa, USA
    Thanks for the reply back. Since my original post, I confirmed the P202A with the dealer, and it is covered under the ADBLUE extension warranty. That was good news. Wish you well on your return.
    Chris
  6. Likes Uwe liked this post
