I have a 2008 a3 tdi 138. To cut a long story short I have replaced the engine as last owner damaged the old unit. All sensors and ancillaries are from the old unit. I have now purchased VCDS in order to get to the bottom of this. Any help would be appreciated Thanks Jamie
VCDS Version: 17.1.2.0 (x64) HEX-V2 CB: 0.4334.4
Data version: 20170107 DS267.0
Ross-Tech: Home
VIN: WAUZZZ8P89A033321 License Plate:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56
VIN: WAUZZZ8P89A033321 Mileage: 103700km-64436miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BQ HW: 03L 906 022 BQ
Component: R4 2,0L EDC G000SG 3066
Revision: 13H01--- Serial number: AUX7Z0H7FNF0A4
Coding: 0000072
Shop #: WSC 14557 551 00000
VCID: 75B4EBA6B9C7E51F0E5-8020
008214 - Intake Manifold Flap Position Sensor (Bank 1)
P2016 - 000 - Short to Ground
Mileage: 103700 km
Time: 31:63:63
Lambda: 6.3 %
Lambda: 3.2 %
Voltage: 0.228 V
Bin. Bits: 00000000
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal - Intermittent
Mileage: 103700 km
Date: 2016.07.19
Time: 00:00:04
Lambda: 6.3 %
Lambda: 3.2 %
Voltage: 0.228 V
Bin. Bits: 00000000
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 13424012092500FDC80E02E6901A00823800
Shop #: WSC 06314 000 00000
VCID: 74B2D6A2BEBDFC1739B-8020
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH09 0100
Revision: 000378 Serial number: 8P0820043BG
VCID: 72BED0BAC8A9F2272B7-8026
00532 - Supply Voltage B+
Reset counter: 182
Mileage: 103700 km
Date: 2016.04.09
Time: 21:09:54
Voltage: 9.10 V
Reset counter: 182
Reset counter: 142
Mileage: 103700 km
Date: 2016.08.01
Time: 03:05:12
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008732809
Coding: 118A0F07A0141380EF00000A4F00000000084E0564060003002000000000
Shop #: WSC 06314 000 08192
VCID: 48CA52529EB528F7A53-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 142
Voltage: 10.20 V
Reset counter: 142
Voltage: 10.25 V
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142413039303030384A55305238503053
ROD: EV_Airba10AURB4.rod
VCID: 49CC5756893FD1FFBAD-801C
Serial number: 34928RB400003F4D1AE%
Serial number: 35028RB400003FD4992T
Serial number: 35128RB400003F4CC1CY
Serial number: 35228RB400003FD3043H
Serial number: 35547RB40000407C638K
Serial number: 35647RB40000407C650F
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002042
VCID: 41DC4F76BD8F19BF62D-8014
Component: E0221 H02 0030
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H18 0830
Revision: D0H18006 Serial number: 2247H006005091
Coding: 0004428
Shop #: WSC 01215 210 175981
VCID: 392C2796D55F417F2AD-806C
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K0880908BC
Coding: E9811F061002020101
VCID: 35342BA6F947A51FCE5-8060
Revision: D0H18006 Serial number: AUX7Z0H7FNF0A4
16346 - Control Module - ROM Error
014 - Defective
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000564
VCID: 43D0457EA7930BAF701-8016
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 233 2301
Revision: 00H15000
VCID: 2A0E08DA20F9FAE7537-807E
000 - - - MIL ON
Fault Status: 11100000
Mileage: 103700 km
Date: 2016.07.19
Time: 01:10:18
Battery Volts: 12.0 V
DD
Temperature: 13.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D2D8505489AC637
Part No SW: 8P3 035 382 D HW: 8P3 035 382 D
Component: AB2 SUBWOOFERBOXH30 0160
Revision: 00006 Serial number: 30659850248431
VCID: 343216A2F23DBC17F9B-8060
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000564
VCID: 44D24662A29D0C9749B-8010
Part No: 8P0 907 357 J
Component: Dynamische LWR H01 0020
Coding: 0000013
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H03 0270
Revision: 00H03000 Serial number: AUZ1Z3H8947049
Coding: 0330211
VCID: 3FD8498ECB7B6F4F149-806A
00857 - CD Changer Unit (R41)
Reset counter: 142
Mileage: 103700 km
Date: 2016.08.01
Time: 03:06:42
