Hi.
I have MY2017 VW Tiguan 2.0TDI. When i try to change coding in some modules (i.e. 17, A5), i'm getting error message "Coding rejected. Error 00: Unknown (0x00)". I'm using latest VCDS and HEX-USB+CAN cable.
Is that a problem with my car or VCDS?
Autoscan:
Autoscan:
Monday,23,January,2017,12:01:11:36118
VCDS Version: 17.1.2.0 (x64)
Data version: 20170107 DS267.0
VIN: WVGZZZ5NZHW3xxxxx License Plate:
Mileage: 11527km-7162mi Repair Order:
Chassis Type 5N (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 65 6C 6D
A5 BB BC
VIN: WVGZZZ5NZHW3xxxxx Mileage: 11527km-7162miles
Address 01: Engine (J623-DFGA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 026 HQ HW: 04L 907 309 P
Component: R4 2.0l TDI H24 3022
Revision: B4H24---
Coding: 0119003203441D083000
ASAM Dataset: EV_ECM20TDI01104L906026HQ 004002
ROD: N/A
VCID: 000FCD889B8E1541E3-8054
No ASAM data for: "EV_ECM20TDI01104L906026HQ" (VW37)
Part No SW: 5Q0 614 517 BG HW: 5Q0 614 517 AC
Component: ESC H25 0407
Revision: 00000000 Serial number: 62066000000645
Coding: 0AEE929A34230B714778260062CB4950492CD0E2644692713460F008402202
VCID: 77FDA654CE4052F9D2-8022
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0413465051
Coding: 032C0C060F
VCID: 3C777978B7E6B1A1FF-8068
Address 08: Auto HVAC (E87) Labels: 3V0-907-044.clb
Part No SW: 5NA 907 044 K HW: 5NA 907 044 K
Component: AC Automat H35 4003
Revision: 20K08000 Serial number: 00000B00198565
Coding: 00120124202110011105100000101022
ASAM Dataset: EV_ACClimaPrehVW37X 002014
ROD: EV_ACClimaPrehVW37X_SK48.rod
VCID: 479D1694FE20E27962-8012
Subsystem 1 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 00000000000000000000
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001621803298
ROD: EV_BCMBOSCH_017.rod
VCID: 7F0D4E74E6706AB99A-802A
Subsystem 1 - Part No SW: 5NC 955 119 HW: 5NC 955 119 Labels: 1KX-955-119.CLB
Component: 326 RL 160722 033 0372
Serial number: 00000001607200302042
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S4Y16M08D17H13M08S45
Coding: 00A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY1620218R7
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000065788925
Address 10: Park/Steer Assist (J791) Labels: None
Part No SW: 3Q0 919 298 A HW: 3Q0 919 298
Component: PLA 3.0 12K H09 0021
Serial number: 000108167478070
Coding: 0331163841
ASAM Dataset: EV_EPHBO2CVW3260000 010016
ROD: N/A
VCID: 3B757A64B2E8B699F6-806E
No ASAM data for: "EV_EPHBO2CVW3260000" (VW37)
Address 13: Auto Dist. Reg (J428) Labels: 2Q0-907-572.clb
Part No SW: 2Q0 907 572 J HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0156
Coding: 2A00404358FF8728749C8065104085
ASAM Dataset: EV_ACCMRRCONTIVW376 001011
ROD: EV_ACCMRRCONTIVW376_VW37.rod
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0315
Serial number: 003TDR20TFF4
Coding: 98CCC0C00C0000005C5400CF008800000065
VCID: 102FFDC8CBEE65C173-8044
Subsystem 1 - Part No SW: ----------- HW: 480 000 508 16
Serial number: 357000000005C9155D1N
Subsystem 2 - Part No SW: ----------- HW: 480 000 508 16
Serial number: 35800000000956F08D1U
Subsystem 3 - Part No SW: ----------- HW: 480 401 708 16
Serial number: 3510001B52149AC566E9
Subsystem 4 - Part No SW: ----------- HW: 480 401 708 16
Serial number: 3520001B52149AC48786
Subsystem 5 - Part No SW: ----------- HW: 480 401 608 16
Component: FrontSensor_D 000 6149
Serial number: 3550001B32149AC334D3
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 808 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001A521CC84603A0
Subsystem 7 - Part No SW: ----------- HW: 480 400 808 16
Component: PedP_Sensor_P 000 6149
Serial number: 2290001B32205C33F44Z
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 400 808 16
Component: PedP_Sensor_C 000 6149
Serial number: 2300001A721CC843D34%
Subsystem 9 - Part No SW: ----------- HW: 480 003 007 16
Component: PedPSensor_D2 001 0887
Serial number: I0M0000000084C311D1/
Subsystem 10 - Part No SW: ----------- HW: 480 003 007 16
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000D1A095D17
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 3Q0 953 521 DM HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF035035 Serial number: 20160714500251
Coding: 0C00
ROD: EV_SMLSVALEOMQB.rod
VCID: 7EF3B370E17A63B191-802A
Part No SW: 5NA 920 791 A HW: 5NA 920 791 A
Component: KOMBI 405 2153
Coding: 27A401906E80000801886A071401000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009052
VCID: 4189088CD004DC49AC-8014
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
Component: GW MQB High 128 1265
Revision: -------- Serial number: 0005233015
Coding: 030100041F087300FB00025A080F00010001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 7CF7B978F76671A1BF-8028
Subsystem 2 - Part No SW: 5TA 959 442 B HW: 5TA 959 442 B
Component: E221__MFL-TAT H06 0023
Serial number: 2151600184600038AT2B
Coding: 2C0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 6008760904
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000157239011
ROD: EV_ELVMarquMQBB.rod
VCID: 71E9984CA0240CC91C-8024
Component: TSG FS 020 0041
Serial number: 030416ED317202
Coding: 003F1A20D001040000001000
VCID: 43850284CA18CE59BE-8016
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Coding: 1307
ROD: EV_SteerAssisMQB_013.rod
VCID: 45811C9CC42CF06990-8010
Component: TSG BFS 020 0041
Serial number: 040716EG30551A
Coding: 003F1020DE01040000001000
VCID: 428B0780D502C751B5-8016
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0051
Coding: 089E00104B210201
ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 043 D HW: 3G0 035 043
Component: MU-H-N-EU H51 0687
Serial number: A683H0GS037236
Coding: 02730601FF00000051110001000808001F0100E601200000DF
VCID: 1D3194FC0C3CD8A9E8-8048
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL033A4
Subsystem 2 - Part No SW: V03 959 800 QQ HW: -----------
Component: ECE 2017 --- 0157
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2--- --- 1013
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 40000000026622
ROD: EV_RDKBERU30_006.rod
VCID: 346751589FB679E137-8060
Address 6C: Back-up Cam. (J772) Labels: 5Q0-980-556.clb
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H09 0170
Coding: 0123060102002017000040
ROD: EV_CamSysRVRVCPANAMQBAB_VW37.rod
Address 6D: Trunk Elect. (J605) Labels: 5Q0-959-107.clb
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30844452600000
Coding: 0A08
ASAM Dataset: EV_DeckLidCONTIAU736 001012
VCID: 3F8D0E74A6F0AAB9DA-806A
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 F HW: 3Q0 980 654
Component: MQB_B_MFK H06 0220
Serial number: 10081611K10626
Coding: 000307060000040100022344C040410084000E200040
ROD: EV_MFKBoschMQBB.rod
VCID: 3A7B7F60BDD28F91ED-806E
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 070816BH70461B
Coding: 002A10200100040000001000
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 020 0041
Serial number: 220716BGJ0276A
End-------------------------(Elapsed Time: 04:50)--------------------------
