I installed a MFSW on my 2016 e-Golf. All of the volume/media buttons work perfectly without doing any coding...the backlights on all the buttons is working just fine too. But, I can't get the cruise control to work. I followed the instructions in the wiki and changed the MF Variant to "High"
I then logged into the ECM to activate the cruise control, but it caused a whole bunch of error lights in the dash. I reverted the coding and am looking for solutions.
I found a retrofit guide online that says I need to retrofit a wire in pin #5 of the steering module to the ECM (pin unknown for the e-Golf). I haven't pulled the cover on the steering wheel to check to see if that wire is installed yet. But, I'm more worried about the error I get in the current autoscan on Address 19: "Additional Installations Detected"
I'm assuming that there is some coding that I need to make on the CAN Gateway to tell the car that the MFSW is installed, but as you can see, there is no currently .clb file for that module so I can't play around to see if there are any bits I can turn on/off to make this functional.
Before I pull off the steering column trim to check for a wire in pin #5, can anyone provide any insight? If not, how can I get a wiring diagram to determine what pin in the ECM I should be connecting to?
Thanks!
Monday,02,January,2017,12:11:54:62764
VCDS Version: 16.8.4.1 (x64)
Data version: 20161128 DS267.0
VIN: WVWKP7AU0GW915498 License Plate:
Chassis Type: AU (5QE)
Scan: 01 03 05 08 09 15 16 17 19 23 2B 42 44 51 52 5F 75 8C BD C0
C6
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
C6-Batt. Chrg. -- Status: OK 0000
Address 01: Engine (J623-EAGA) Labels: 0EA-907-309-V1.clb
Part No SW: 0EA 906 016 C HW: 0EA 907 309 A
Component: E-Vehicle H23 8344
Revision: WMH23---
Coding: 000D0012000400007000
ASAM Dataset: EV_VCU00XXX0110EA906016C 002006
ROD: EV_VCU00XXX0110EA906016C_002.rod
VCID: 2F66306576E8603A63-807A
Part No SW: 5Q0 614 517 BL HW: 5Q0 614 517 AH
Component: ESC H62 0855
Revision: 00000000 Serial number: 62136000000253
Coding: 01FA40A12C212171857B020981CB2980023484A14081943200810058C24203
ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
ROD: EV_Brake1UDSContiMK100OMG_SK37.rod
VCID: 7CFCD729F71E4BA296-8028
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0414570884
Coding: 032C0C
VCID: 3B7E1435B2908C9ADF-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5GE 907 044 AG HW: 5GE 907 044 AG
Component: Climatronic H04 1501
Revision: 00001K07
Coding: 00022200200110000405000200111822
ROD: EV_ACClimaBHBVW37X_005_VW37.rod
VCID: 0102A6DD90FC264AC5-8054
Subsystem 3 - Part No SW: 12E 963 231 G HW: 12E 963 231 G
Component: J848 HV-PTC H09 0208
Serial number: LM162183003810000145
H02
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 085 BK HW: 5Q0 937 085 AE
Component: BCM MQBAB MNA H24 0175
Serial number: 01061621400376
Coding: 00011866434182E169EC4000001407201800000000000000000000000000
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: 030EACD58AE0345AD7-8056
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160803 043 0551
Serial number: 160810055005
Coding: 0E4DFD
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S4Y16M08D23H20M21S03
Coding: 00A8DD
Component: AirbagVW20 010 0830
Serial number: 003GCR05MTL6
Coding: 8CCCFC00002000005000001AC24800000065
VCID: 479678C5FE58D87A4B-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000005LI5NW
Coding: 303230
Subsystem 2 - Part No SW: ----------- HW: 480 002 608 16
Serial number: 35700000000702BC0E1J
Subsystem 3 - Part No SW: ----------- HW: 480 002 508 16
Serial number: 3580000000070959FD1W
Subsystem 4 - Part No SW: ----------- HW: 480 400 408 16
Serial number: 3510002AF2095062F2E5
Subsystem 5 - Part No SW: ----------- HW: 480 400 408 16
Serial number: 3520002BF2095064F12$
Subsystem 6 - Part No SW: ----------- HW: 480 402 907 16
Serial number: 3550002C5209506381D-
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 907 16
Serial number: 3560002C12095062C12P
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 HM HW: 5Q0 953 549 E
Revision: -------- Serial number: 01081604220986
Coding: 0610
ROD: EV_SMLSKLOMQB_SK48.rod
VCID: 0814BBF9B3C6170282-805C
Address 17: Instruments (J285) Labels: None
Part No SW: 5GE 920 855 B HW: 5GE 920 855 B
Component: KOMBI 304 8315
Coding: 0B34181A2380CF05020828001700032000000000
VCID: 408463D9DB76EF428A-8014
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 5QE 907 530 F HW: 5QE 907 530 A
Component: GW MQB EV 312 3265
Revision: -------- Serial number: 06081610520579
Coding: 0200001706F81000FB001200081D00000001050100030000000300000000
ASAM Dataset: EV_GatewEVConti 013020
ROD: EV_GatewEVConti_013.rod
VCID: 49927EFDE84C2E0A5D-801C
Subsystem 1 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 0960401004
67072 - Local Databus
U1125 00 [009] - Additional Installations Detected
Reset counter: 11
Mileage: 558 km
Date: 2017.01.02
Time: 11:54:08
Supply voltage: Terminal 30: 13.2 V
Terminal 15: On
8782090 - Cruise Control Switch
B1154 96 [009] - Component internal failure
Fault Frequency: 14
Reset counter: 11
Mileage: 558 km
Date: 2017.01.02
Time: 11:54:08
Terminal 15: On
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5QE 909 059 E HW: 5QE 909 059 B
Component: EBKV H14 0200
Serial number: 085430010969
Coding: 01720100321A02030002000500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004001
ROD: EV_BrakeBoostBoschMQBOMG_001_VW37.rod
VCID: 50A453990B161FC21A-8004
Brake Assistance Sub:
Subsystem 1 - Part No SW: 5QE 909 057 C HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0152
Serial number: 05802861150716203840
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000133921006
Coding: 7900000000000000
ROD: EV_ELVMarquMQB_SK25.rod
VCID: 346C3F099FCE43E21E-8060
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 210516EEK17302
Coding: 003013208000040000000000
VCID: 418266DDD07CE64A85-8014
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000010975092
Coding: 111000
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 129 1072
Coding: C102
ROD: EV_SteerAssisMQB_013.rod
VCID: 458A72CDC454CA6AB9-8010
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5QE 907 080 G HW: 5QE 907 080 G
Component: VW370E2615020 H08 2480
Revision: 00H08000
Coding: 40020000000000000000
ASAM Dataset: EV_DMCM09550115QE907080G 001022
ROD: N/A
VCID: 4A9041F1ED4A251254-801E
No ASAM data for: "EV_DMCM09550115QE907080G" (VW37)
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 090716EG817423
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000011012231
Coding: 091000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 844 A HW: 3Q0 035 844 A
Component: MU-S-S-US 710 0751
Coding: 02737000FF00000051220001001808009F0105D40120010002
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 2D5A2A6D7CE4122A51-8078
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H53 1031
Serial number: VWZ8Z9SJW00SHG
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02737002C2829A017FFE06000000
ROD: EV_OCULowMQB.rod
VCID: 438E6CD5CA60F45A97-8016
Address 8C: Hybrid Battery (J840) Labels: 5QE-915-227.clb
Part No SW: 5QE 915 227 M HW: 5QE 915 227 H
Component: K8C H13 0722
Serial number: VWADGHU006
ASAM Dataset: EV_BECM08820215QE915227M 003016
ROD: EV_BECM08820215QE915227H.rod
VCID: 52A05991051A6DD22C-8006
Address BD: Hi Volt. Batt. Charg. (J966) Labels: Redir Fail!
Part No SW: 5QE 915 022 L HW: 12E 915 022 C
Component: LMSG H10 1084
Serial number: 01131062650167
Coding: 4A4914040400
ASAM Dataset: EV_HVChargManagVWMQB 002002
ROD: EV_HVChargManagVWMQB_002.rod
Address C0: Act. for Ext. Noise (----) Labels: None
Part No SW: 5QE 035 335 M HW: 5QE 035 335 B
Component: E_SOUND_SG H10 0223
Serial number: EN163119430000
Coding: 04
ASAM Dataset: EV_ENoiseS1NNVW3707 007015
ROD: EV_ENoiseS1NNVW3707_006.rod
VCID: 4B9E44F5E2303C1A6F-801E
Address C6: Batt. Chrg. (J1050) Labels: 5QE-915-681.clb
Part No SW: 5QE 915 681 B HW: 5QE 915 681 B
Component: OBC Delta-ES H52 1560
ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
ROD: EV_OBCTwoPhaseDT2VW3707.rod
End-------------------------(Elapsed Time: 04:18)--------------------------
Thanks!
