VW Passat B8 2017 Tweaks
   #81
@DRI@N
Romania
C?ID=317777
@Dana .
Where to find :
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal
In adaptation of RAIN & LIGHT SENSOR or BCM ???
Thanks .
   #82
It's in the BCM.
Use the Search/Filter box on the Adaptations screen.
@DRI@N
Romania
C?ID=317777
Hy,
Yesterday I tried to activate Daytime Running Light on the LED from the interior (near to the front grille) on my EU Passat B8 with FULL LED HEADLAMP .
I tried to adapt this channels on BCM :
left side
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 from Daytime running lights first version to the Daytime running lights second version but after adaptation the drl function light goes off .
and channel
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 from not active to the both versions of Daytime running lights but after adaptation the left side head lamp do nothing .
right side
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 from Daytime running lights first version to the Daytime running lights second version but after adaptation the drl function light goes off .
and channel
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 from not active to the both versions of Daytime running lights but after adaptation the left side head lamp do nothing .
Now my questions are :
Above mentioned channels are correct for what I try to do ?
Or I need to make the adaptation on headlight ??
Thanks.
   #84
Papa Leguas
Brazil
C?ID=307965
Hi Everyone,
I have Passat Highline 2017 B8.
I would like enable Ambient Color (10 diferents colors) in my MMI and my Cockpit.
I tried the process on Passat B8 2018 and was ok! But 2017 not is ok, because the MMI is not the same.
Someone can help me about this?
Best regards and tks.
   #85
TBAx
C?ID=287144
Where are you stuck? What is the problem you are confronted with?
   #86
@DRI@N
Romania
C?ID=317777
Hi Everyone,
Today I tried to activate RAIN CLOSING on my 2015 Passat B8 after this information :
Select Central Electrics 09
Security access 16
Access code 31347
Adaptation 10
(14) Access control 2-rain closure
or
(14) Zugriffskontrolle 2-Regenschliessen auswählen
Set new value to PERMANENT
(26) Access control 2-menu control Select rain closure
or
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen auswählen
Set new value to ACTIVE
Select LONG CODING HELPER
Select RLS (rain and light sensor)
Byte 0
Activate bit 1
Activate bit 2
But unfortunately I don't find Zugriffskontrolle 2-Regenschliessen auswählen or Access control 2 - Regenschliessen auswählen !!!
In my adaptation Channels I have, Access control 2 with only this two chanel :
Regenschliessen_art
Regenschliessen_ein_aus
Anybody know how to activate RAIN CLOSING for door window and sunroof ???
Thanks.
   #87
TBAx
C?ID=287144
Doesn't work, if your car has an RLHS. Only RLFS can do it.
   #88
@DRI@N
Romania
C?ID=317777
Ok, I understood .
But please tell me what this sensor looks like or what code it has?
Because this codding was accepted :
Byte 0
Activate bit 1
Activate bit 2
without problems !
   #89
TBAx
C?ID=287144
Those are the sensors. The lower one (with less "blue dots") is the RLHS, the one above the RLFS.
Both do accept the coding but one of them will simply not behave accordingly.
   #90
@DRI@N
Romania
C?ID=317777
Ok, thanks.
But if I buy and change only the windshield sensor is it necessary to make electrical changes ?
What is part number code are the RLFS ?
Thanks .
   #91
TBAx
C?ID=287144
Afaik you can simply switch them. Recoding is necessary but that's it. Part number is "5Q0 955 547" without an index.
   #92
@DRI@N
Romania
C?ID=317777
@TBAx ,
Hy,
I found HUMIDITY SENSOR but with code 5K7955547 .
Is good this code for PASSAT B8 ?
Thanks .
   #93
TBAx
C?ID=287144
The 5K7 module comes from an Up. Since the platform is somewhat different from the MQB, which the Passat is based on, I somewhat doubt this one will work correctly.
   #94
jrhenrique
BR
C?ID=245657
gabriel:I hope that I'm not stealing my knowledeable colleague's thunder! I think that my contribution to your question is consistent with both Uwe's and hazdez16's replies, but it consolidates the adaptation channels into a single list.
After you select the desired settings for these channels, you will need to complete an in-car procedure HERE
I tried all the procedures but only the beep happens! No horn!
Even try to select only one of the following at a time and both
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn
Still no horn!
Any suggestions?
   #95
DV52
C?ID=194404
^^^^ I developed the tweak for those vehicles that weren't fitted with a siren. It sounds like your car is fitted with an anti-theft system. AFAIK, the tweak can't be used for changing the acknowledgement from a siren to the car horn (or vice-a-versa)
   #96
PaulTulcea
Romania
C?ID=399032
VW Passat B8 - some teweks I would liek to enable
VW Passat B8 2016 (or 2017?), 2.0 TDI 150HP
VIN: WVWZZZ3CZHE078335
(Only enabled some features through VCDS: 01 - Refueling Gasoline Amount, 02 - Horn on closing and opening the car and 03 - Comfort Blink Cycle (changed from 3 to 5).)
"VCDS" COMPLETE Auto-Scan
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F
VIN: WVWZZZ3CZHE078335   Mileage: 176371km-109591miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H23 1990
   Revision: B5H23---
   Coding: 011D003203641D083000
   Shop #: WSC 05311 115 00319
   ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
   ROD: EV_ECM20TDI01104L906026ES_002_VW48.rod
   VCID: 005986A2FA8174EB532-8054
   Part No SW: 0D9 300 042 M    HW: 02E 927 770 AS
   Component: DQ250-6F MQB  H54 5013
   Revision: 06454104    Serial number: TFK01609082199
   Shop #: WSC 05311 115 00084
   ROD: EV_TCMDQ250021.rod
   VCID: 2313E92E4B578FF36E0-8076
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 62626000001467
   Coding: 0EEC6A8F34270B74477A060341C84970562CD0E2608292713862F078C20202
   Shop #: WSC 00015 115 00001
   VCID: 7BA3F14E93671733060-802E
   Part No SW: 3Q0 959 435 D    HW: 3Q0 959 435 D
   Component: VWKESSYMQB    026 0811
   Revision: 00026000    Serial number: 0417407871
   Coding: 002F0F070F
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3B23314ED3E7D733460-806E
          U1400 00 [008] - -
                    Fault Frequency: 16
                    Reset counter: 6
                    Mileage: 175671 km
                    Date: 2020.03.18
                    Time: 10:32:49
                    ZAT_pressed: OFF
                    Control Module Voltage: 8.443 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 157.5 /min
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 5G0 907 044 BP    HW: 5G0 907 044 BP
   Revision: 00001K10
   Coding: 11020104202110011015500000101822
   VCID: 76B5E07AA8454A5B79E-8022
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [008] - -
          [PTC-Reduzierung durch BCM]
                    Reset counter: 252
                    Mileage: 175817 km
                    Date: 2020.03.23
                    Time: 08:31:13
                    Voltage terminal 30: 14.6 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 1
                    Auxiliary heater: in stages-Act.val.: 1
          P1719 00 [008] - -
          [PTC-Reduzierung durch MSG]
                    Reset counter: 232
                    Mileage: 175807 km
                    Date: 2020.03.22
                    Time: 18:02:35
                    Voltage terminal 30: 14.4 V
                    Auxiliary heater: in stages-Act.val.: 0
   Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 032 0222
   Revision: --------    Serial number: 8658190916008P
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 015F83A6F18B7DE35CC-8054
   Component: WWS    160901  042 0607
   Serial number:         160908192821
   Component: RLHS  042 0105
   Serial number: S5Y16M09D22H21M03S30
   Coding: 00A8DD
   Light switch:
   Serial number: 25 06 2016  10000768
6 Faults Found:
131586 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten >]
550677 - Databus
          [TSG_HBFS_01 Datenbus fehlende Botschaft]
589592 - Databus
          U1201 00 [008] - No Communications
          [CAN Keine Kommunikation]
                    Fault Frequency: 7
                    Reset counter: 3
                    Mileage: 172246 km
                    Date: 2019.09.15
                    Time: 11:22:41
787212 - Windshield Washer Pump
          B1261 01 [008] - Electrical Failure
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
204546 - Remote key 2
          B147A 18 [008] - Current Too Low
                    Reset counter: 40
                    Mileage: 60059 km
                    Date: 2017.11.20
                    Time: 08:17:04
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183616252
   Coding: 0271061851
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 0D47AF96BDD32983284-8058
   Component: ACC BOSCH MQB H04 0194
   Coding: 3200670359FFC428949C8045
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 34311A72FEB9184B87A-8060
   Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003STPJZ9CSG
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5B055E877F0B132A8-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 609 16
   Serial number: 3576U0000001C2A4ED1M
   Subsystem 2 - Part No SW: -----------    HW: 454 000 109 16
   Serial number: 3586U000000F2818AD1O
   Subsystem 3 - Part No SW: -----------    HW: 454 800 909 16
   Serial number: 3516RFB5C2E0C000000R
   Subsystem 4 - Part No SW: -----------    HW: 454 800 809 16
   Serial number: 3526RE00D980C000000D
   Subsystem 5 - Part No SW: -----------    HW: 454 800 609 16
   Serial number: 3556V5ED6D00C000000R
   Part No SW: 3Q0 953 521 CS    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20160920100674
   Coding: 0010
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 035389AEEB976FF34E0-8056
   Part No SW: 3G0 920 791 B    HW: 3G0 920 791 B
   Component: KOMBI         404 2153
   Coding: 07A401182F80000801886B011001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 2809FE0232716CAB3B2-807C
   Revision: --------    Serial number: 12091610520017
   Coding: 030300045F087300FB0002581C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CA1F2529669100B0FA-8028
   Serial number: 29160001847210056373
   Coding: 2CFFFF
   Serial number: 75410803001609126496
   Analog clock:
   Component: Analoguhr  209 2002
   Serial number: 16000227917015
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD366C12B6D63ACC-8024
   Serial number: 080816EH709114
   Coding: 00350B20D000020000001000
   VCID: 43D349AEAB17AFF30E0-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000004585498
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0001055654
   Coding: 01010010005000
   Shop #: WSC 00015 115 00319
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   VCID: 3D273F56CDF3D903784-8068
   Serial number: 270716EGQ28591
   Coding: 00350120DE00020000001000
   VCID: 42DD4CAAB40DA6FB056-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000004589425
   Coding: 090000
   Coding: 03DA000009010000
   Shop #: WSC 05311 000 00001
   VCID: 75B7E776B5434143704-8020
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 3G0 035 043 D    HW: 3G0 035 043
   Component: MU-H-N-EU     H51 0814
   Serial number: A683I0GB041511
   Coding: 02840101FF00000051110001000808001F0100E401200000DF
   VCID: 1D67DFD66D33B903584-8048
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL03WVE
   Subsystem 2 - Part No SW: V03 959 806 FN    HW: -----------
   Component: ECE 2020  --- 0184
   Component: Gracenote2---  --- 1013
0513 - Rear Right Treble Speaker
          B1068 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 1: Unterbrechung]
                    Reset counter: 78
                    Mileage: 51725 km
                    Date: 2017.10.10
                    Time: 14:34:09
                    Voltage terminal 30: 12.4 V
1561 - predictive route data
          B1630 02 [009] - Signal Failure
                    Reset counter: 145
                    Mileage: 72418 km
                    Date: 2018.02.07
                    Time: 18:29:25
                    Voltage terminal 30: 13.5 V
End----------(Elapsed Time: 01:45, VBatt start/end: 14.7V/14.4V)-----------
No repairs were done to the car since I have it (Feb 2020) and I do not have the history of the car repairs :mad:
I would like to know if the following are possible:
1. All windows to be closed when I lock the car - not by long pressing the lock button.
2. Know how to check if my device has protection or not;
3. If Playing youtube is possible
4. If Video in Motion can be enabled, without involving a VW dealer
5. Is there a way to have somewhere in the DiscoverPro unit displayed the Voltage of battery? It would be very usefull, at least for me
6. Sport HMI - can this be activated it is not present for my unit under Supported/Installed codes - without involving a VW dealer?
7. When coming home, the "Coming Home / Leaving Home" does not work. When leaving home (and unlocking the car) the lights do power on.
