VW Passat B8 2017 Tweaks
hex.v2.belgium
Belgium
C?ID=293974
wanted to share the tweaks I'm doing to my Passat B8 2017 and perhaps get some new ones through this thread.
What have I done sofar:
These all work:
XDS Adjustment
Select Control unit 03 (ABS)
Adaptation
Select: Expanded Electronic Differential Lock
Changed from Standard to Strong
Fan Speed on Auto Mod
Select Control unit 08 (Air condition A/C)
Control unit Long Coding
Byte 11
Bit 6 Activate
Hill Start Assistant
Select Control unit 03 (ABS Brakes)
Adaptation
Select: Hill Start Assistant
Changed from Normal to Early
Dynamic Starting Assist (Auto Hold)
Adaptation
Select: Dynamic Starting Assist
Needle sweep
Select Control unit 17
Coding - Long Coding Helper
Byte1
Bit 0 enable
Comfort Blink Cycle
Select Control unit 09 (Central Electrics)
Security access
Access Code 31347
Adaptation
Changed from 3 to 4
(Valid values are 1-5)
+ you need to reset the light controls in your nav system:
CAR > Setup > Reset to factory settings > Reset individual settings > Light
Original Autoscan before adaptations:
Thursday,12,January,2017,07:48:29:43967
VCDS Version: 17.1.0.0 (x64)  HEX-V2 CB: 0.4334.4
Data version: 20170106 DS267.0
VIN: WVWZZZ3CZHE0******   License Plate:
Mileage: 4264km-2649mi   Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 42 44 52 55 5F 6C
          6D A5 BB BC CA
VIN: WVWZZZ3CZHE0*****   Mileage: 4264km-2649miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CRLB)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H23 1990
   Revision: B5H23---
   Coding: 011D003203641D083000
   Shop #: WSC 05311 115 00302
   ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
   ROD: EV_ECM20TDI01104L906026ET_002.rod
   VCID: 005A8A810A89B8F72FF-8054
   Part No SW: 0D9 300 042 M    HW: 02E 927 770 AS
   Component: DQ250-6F MQB  H54 5013
   Revision: 06454104    Serial number: TFK01609151507
   Shop #: WSC 05311 115 00073
   ROD: EV_TCMDQ250021.rod
   VCID: 2310E50DBB5F43EF12D-8076
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 62726000002035
   Coding: 0FEC6A8F34280B734777060641CA49F0562CD0E2608292713862F0F8C20202
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_035_VW48.rod
   VCID: 7BA0FD6D636FDB2F7AD-802E
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0419208479
   Coding: 0F2020070F
   VCID: 3C223E7126E11C17337-8068
   Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
   Component: GEB.F.Heckoef  H17 0812
   Serial number: ;8061479
14222592 - Databus
                    Reset counter: 119
                    Mileage: 3293 km
                    Date: 2016.12.29
                    Time: 14:00:12
   Part No SW: 5G0 907 044 BP    HW: 5G0 907 044 BP
   Revision: 00001K10
   Coding: 12020124202410011115500E0010182A
   ROD: EV_ACClimaBHBVW37X_004_VW48.rod
   VCID: 76B6EC59584D8647053-8022
          P1719 00 [008] - -
                    Reset counter: 128
                    Mileage: 3430 km
                    Date: 2017.01.01
                    Time: 01:22:48
                    Voltage terminal 30: 14.4 V
                    Auxiliary heater: in stages-Act.value: 2
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 032 0222
   Revision: --------    Serial number: 8658300916000O
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 015C8F850183B1FF201-8054
   Component: WWS    160908  042 0607
   Serial number:         160919141844
   Component: RLHS  042 0105
   Serial number: S6Y16M10D06H13M04S28
   Coding: 00A8EE
   Light switch:
   Serial number: 30 06 2016  10000744
589592 - Databus
          U1201 00 [008] - No Communications
                    Reset counter: 124
                    Mileage: 2085 km
                    Date: 2016.12.11
                    Time: 12:46:37
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183616266
   Coding: 0271161851
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000_009.rod
   VCID: 0D44A3B54DDBE59F549-8058
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Component: ACC BOSCH MQB H04 0194
   Coding: 320067C359FFC428949C8045
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 343216510EB1D457FB7-8060
1538 - Sensor for Automatic Distance Control
                    Reset counter: 135
                    Mileage: 3869 km
                    Date: 2017.01.07
                    Time: 16:46:39
                    Control Module temperature: 20 °C
                    Voltage terminal 15: 13.0 V
                    Velocity_vehicle_reference: 23.48 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.16 m/s²
1542 - Sensor for Automatic Distance Control
                    Reset counter: 135
                    Mileage: 3869 km
                    Date: 2017.01.07
                    Time: 16:46:40
                    Velocity_vehicle_reference: 23.28 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.09 m/s²
   Serial number: 20091641350260
   ROD: EV_DRCONTITEMIC.rod
   VCID: 382A226112D93037D7F-806C
   Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003STPKQNTV%
   Coding: 88CCC000000000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F58097D7777C70F565-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 709 16
   Serial number: 3576U000000ABC3DDD1+
   Subsystem 2 - Part No SW: -----------    HW: 454 001 709 16
   Serial number: 3586U00000048A884D1M
   Subsystem 3 - Part No SW: -----------    HW: 454 801 409 16
   Serial number: 3516R7606DD0C000000D
   Subsystem 4 - Part No SW: -----------    HW: 454 801 409 16
   Serial number: 3526R2D03DD0C000000D
   Subsystem 5 - Part No SW: -----------    HW: 454 802 609 16
   Serial number: 3556V11FABD0C000000R
   Part No SW: 3Q0 953 521 EJ    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0225
   Revision: FF034034    Serial number: 20161002500321
   Coding: 0410
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7CA2FE716661DC17737-8028
291104 - Temperature Sensor for Heated Steering Wheel
          B1455 01 [008] - Electrical Failure
                    Reset counter: 143
                    Mileage: 7 km
                    Date: 2016.11.10
                    Time: 15:55:58
                    Ubat 30 Voltage: 12.10 V
                    Internal error state: 0
                    LIN_Temp: 254
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 251
                    Slope: 134
                    kp: 13
                    OUT: 50
                    Temperatur Statisch: 30
                    Tsoll Wert 0: 39.00 °C
                    Tsoll Wert 1: 43.00 °C
                    Tsoll Wert 2: 47.00 °C
   Part No SW: 3G0 920 791 B    HW: 3G0 920 791 B
   Component: KOMBI         404 2153
   Coding: 07A409183F84000801886B011001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 280AF221C279A0B747F-807C
   Revision: --------    Serial number: 30091610521617
   Coding: 030300045F087300FB00025A9C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   Serial number: 29160001867260056381
   Coding: 2FFFFF
   Serial number: 75410803001610011156
   Analog clock:
   Component: Analoguhr  209 2002
   Serial number: 16000232837009
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BCDF453123A17FD01-8024
   Serial number: 300916EIT32753
   Coding: 003F1B20D000020000001000
   VCID: 43D0458D5B1F63EF72D-8016
   Coding: 8307
   Shop #: WSC 00015 115 00302
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2E38692CD5222721B-806E
   Serial number: 140916EID33177
   Coding: 003F1120DE00020000001000
   VCID: 42DE408944056AE779B-8016
   Component: AFS-ECU       H01 0120
   Coding: 039203004F210200
   Shop #: WSC 05311 000 08193
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   VCID: 3FD8497D37F7070F165-806A
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-HGH2.clb
   Part No SW: 3G0 035 042     HW: 3G0 035 042
   Component: MU-H-LN-EU    H51 0814
   Serial number: A749J0GB003186
   Coding: 02840201FF00000051110001000808101F0100E4012000009E
   VCID: 58EA82E1B299D03737F-800C
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL04BPP
   Subsystem 2 - Part No SW: V03 959 800 QQ    HW: -----------
   Component: ECE 2017  --- 0157
   Component: Gracenote2---  --- 1013
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-980-556.clb
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H09 0170
   Coding: 0184020162002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB_VW37.rod
   VCID: 77A8E15D5F47FF4F1E5-8022
Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 C    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0260
   Revision: --------    Serial number: 30936315800000
   Coding: 0228
   ASAM Dataset: EV_DeckLidCONTIAU736 001013
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0220
   Serial number: 05101611K10580
   Coding: 000408020000040100262344C050A10010000E300040
   ROD: EV_MFKBoschMQBB.rod
Address BB: Door Rear Drv (J388)       Labels: None
   Serial number: 031016EJ205557
   Coding: 000E11200100020000001000
   VCID: 45D45B95552B5DDF5C9-8010
Address BC: Door Rear Pass (J389)       Labels: None
   Serial number: 031016EJ14280B
Address CA: Sunroof (J245)       Labels: None
   Component: SAD_STG_1     013 0005
   Coding: 008040748202
   ROD: EV_SunRoofCONTIAU736_005.rod
   VCID: 3D2433753DFB151F049-8068
End----------(Elapsed Time: 02:01, VBatt start/end: 12.2V/12.2V)-----------
What does not work (yet):
Comfort Blink Cycle
Security access
Access Code 31347
Adaptation
I tracked down the Blink cycle to the following parameter:
ENG10577-ENG116587-Ausenlicht_Blinker-Komfortblinken Blinkzyklen
Here it does indicate the standard blink cycle: 3
Normally I should be able to change this between 1-5, but I cannot get this to work, blinking stays at 3x
Does the new value (something other than 3) stay in there?
Have you tried the "Soft Reset" option next to the [Do It] button?
hex.v2.belgium
Belgium
C?ID=293974
The new value does stay, did not try to do the "soft Reset"...
Will try...
TBAx
C?ID=287144
After setting the comfort blinking cycle via the adaptation you have to reset the light controls in your navigation system to default for the change to take effect. Simply de- and reactivating the comfort blinking is not enough.
The reason is, that comfort blinking is controlled by both, user setting (albeit not having an option for that), and the value in your BCM adaptation. Thus you need to overwrite the invisible user setting with the adaption value using the "reset to defaults" menu entry.
hex.v2.belgium
Belgium
C?ID=293974
Thanks, will try that this evening and update my above settings if successful.
So resetting the light controls in the navigation system is a menu item?
TBAx
C?ID=287144
Correct. It should be in there:
hex.v2.belgium
Belgium
C?ID=293974
Thanks TBAx,
that was indeed the trick to get the comfortblinking working!
Adapted the first post to reflect the update!
Next steps:
Active Lane Assist
This will be a difficult one to code, since a lot of modules are involved!
But I should have all required hardware to support...
(I have Dynamic Light Assist and Traffic Sign Recognition, so camera should be ok...)
Any other tips or tricks?
TBAx
C?ID=287144
All modules required are there, so it should be easy to activate. Notice that your Front Sensor (A5) is a MFK_B_MQB so the coding is a bit different from what you might find in the Internet - but only in that module.
hex.v2.belgium
Belgium
C?ID=293974
Hi TBAx, will try this weekend to code all the modules...
For the Front Sensor (A5) beeing a MFK_B_MQB, do you know what the difference is?
One thing I know is that there is a version limited to ~160km/h and another one that allows >200km/h
My car limits the cruisecontrol to 160km/h, so i assume belgium imports the lower-end version, as we even cannot choose.
Would this limit the capabilities of lane assist in any way?
golfi_vend
Tartu, Estonia
C?ID=195131
Does the front camera really limit the speed? I think what limits is the radar 13- Automatic Distance control.
welshkaiboy
H11-2H
look at my A5 scan on another post to see if it's of any help. I have lane assist from factory on Mk2 Tiguan
TBAx
C?ID=287144
Enabling of Lane Assist should work as follows (writing from memory, so no guarantee):
  • Coding > Byte 16 > enable Bit 3 and 7
When l look at Dana's scan of a Golf Alltrack here, some Adaptions have to be set:
  • IDE10870-Switch-on condition: lane depart. warn. > on (setting via menu)
  • IDE10871-System mode: lane depart. warn: > Steering wheel vibration not active
  • IDE10872-Warning intensity: lane depart. warning > Medium
  • IDE10407-Personalization of intervention moment at T. 15 on > Last setting
Remeber to enable adaption via SA displayed in VCDS. The other modules are the same as with other vehicles (Golf 7 etc).
I guess so. The Passat B8 uses a "midline" ACC sensor (MRRevo) in combination with the Front camera (which therefore has to be a MFK_B_MQB, as far as I understand). The speed limit is somewhere in those two modules I guess. However it's neither coding nor adaption, so might be parameters or even software version.
welshkaiboy
H11-2H
;SW:3Q0-980-654-F   HW:3Q0-980-654 ---  Frt Sens. Drv. Assist
;Component:MQB_B_MFK     H06 0220, Coding:0003070600000401000213448040A10094000E000020
;EV_MFKBoschMQBB,001001,EV_MFKBoschMQBB.rod
;Saturday,31,December,2016,16:47:40:09667
;VCDS Version: Release 16.8.4 (x64)  Data version: 20161129 DS267.0
;VCID: 3A55E97EBD7A5A92C7-806E
IDE00001-Production mode,Deactivating
IDE00820-ENG130919-Activating and deactivating all development messages-Activation_of_development_messages_EHR,not activated
IDE00820-ENG130920-Activating and deactivating all development messages-Activation_of_development_messages_HCA_lane,not activated
IDE00820-ENG130921-Activating and deactivating all development messages-Activation_of_development_messages_HCA_state,not activated
IDE00820-ENG130922-Activating and deactivating all development messages-Activation_of_development_messages_internal,not activated
IDE00820-ENG130916-Activating and deactivating all development messages-Activation_of_development_messages_lane,not activated
IDE00820-ENG130915-Activating and deactivating all development messages-Activation_of_development_messages_reserved,not activated
IDE00820-ENG130918-Activating and deactivating all development messages-Activation_of_development_messages_VZF/TSR,not activated
IDE00820-ENG130917-Activating and deactivating all development messages-Activation_of_development_messages_WLA,not activated
IDE02332-Deactivate production mode,0
IDE04160-Direct. stab. assist speed threshold during towing mode,300 km/h
IDE04733-Road sign detection fusion mode,Road sign fusion
IDE06425-Roller test bench mode: functional,not activated
IDE07358-Distance to calibration field,1500 mm
IDE07596-Personalization of lane dept. warning Cl. 15 on,Last setting
IDE09375-IDE05717-Axle offset-Front axle transverse position,1.00001 mm
IDE09375-IDE05718-Axle offset-Rear axle transverse position,5.96046e-006 mm
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,778 mm
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,772 mm
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,799 mm
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,793 mm
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2460 mm
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,742 mm
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1697 mm
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2460 mm
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-742 mm
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1697 mm
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2460 mm
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,742 mm
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,1103 mm
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2460 mm
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-742 mm
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,1103 mm
IDE10407-Personalization of intervention moment at T. 15 on,Last setting
IDE10870-Switch-on condition: lane depart. warn.,on (setting via menu)
IDE10871-System mode: lane depart. warn:,Steering wheel vibration not active
IDE10872-Warning intensity: lane depart. warning,Medium
IDE10873-BAP personalization,activated
IDE10924-MAS02479-Initial calibration: result-Yaw angle,-0.279 °
IDE10924-MAS05286-Initial calibration: result-Roll angle,-0.142 °
IDE10924-MAS05287-Initial calibration: result-Pitch angle,-0.144 °
IDE10924-MAS10678-Initial calibration: result-Camera height,1475 mm
ENG130776-ENG130840-Adaptation_tsr-Par_country_code_RSR,0
ENG130776-ENG130841-Adaptation_tsr-Par_country_code_VZF,0
ENG130776-ENG130838-Adaptation_tsr-Par_country_mode,automatic
ENG130776-ENG130839-Adaptation_tsr-Par_relevance_mode,Enabled
ENG120319-Mask_error_reactions_for_development,not activated
ENG107577-ENG107577-Masked_fault_classes-,255
ENG130777-standstill_mode,not activated
ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active,12.8
ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive,0
ENG130779-Xcp_interface,not activated
hex.v2.belgium
Belgium
C?ID=293974
Could you also post a full autoscan of your tiguan, then I can also start comparing the long coding for interesting delta's ;-)
TBAx
C?ID=287144
Can I help? Are you searching for the other changes that have to be made for LDW to work?
hex.v2.belgium
Belgium
C?ID=293974
Hey,
looking for some further adaptations (have not yet done the lane assist, on my todo list when I have a full day to implement and test)
I would like to enable the rear lights in DLR mode as in following video:
https://www.youtube.com/watch?v=hmn80BHFsi0
(the part at ~42sec with outer LED rings)
Any idea what to code?
TBAx
C?ID=287144
Not sure, which lights; should be something in line with Leuchte23 and Leuchte24. Just add the light function Tagfahrlicht/Daylight running lights and you are done. Should be very easy.
hex.v2.belgium
Belgium
C?ID=293974
Thanks for the pointer, seems Leuchte23 and Leuchte24 are the outer 'stripes' of the rear lights, not the rings.
See the youtube vid at ~50sec what I mean with outer stripes.
After some searching I found that the rear outer rings are enabled through Leuchte16 and Leuchte17
So added the lightfunction Daylight running lights to lightfunction D16 and D17 and it works! Thanks!
Cannot EDIT my first post anymore, so adding the changes in this post:
Rear lights outer LED rings as DRL
Security access
Access Code 31347
Adaptation
Leuchte16 - Lightfunction D16 change from non-active to Daylight running lights
Leuchte17 - Lightfunction D17 change from non-active to Daylight running lights
TBAx
C?ID=287144
I wasn't sure anyway :), but great you still found the correct adaptions!
