Results 1 to 10 of 16
Thread: Sharan (7N) BF/BE Automatic sliding door Basic Settings
    16.4905 S, 151.7375 W
    This procedure below was recently requested by a Ross-Tech customer, I would like to post it up here for some feedback.
    Let me know if this did work or if it did not work and where in the procedure was the issue.
    Thanks....
    drpeter
    Prerequisites:
    - The power windows must be adapted.
    - Factory mode must be deactivated.
    (Check Measuring Value Blocks - Factory Mode Adaptation)
    - No crash message can present in [Slid. Door Rear] controller
    (Check Measuring Value Blocks - Operation Mode)
    - Must display = "No crash message present"
    * Note: If a crash message is stored, proceed as follows:
    - Reset the sliding door control module by removing the sliding door controller fuse for at least 30 seconds. (See repair manual)
    - Then turn ignition on, and manually open and close the sliding door.
    - Then trun ignition off and on again.
    Reset Normalization
    Select: [BE-Slid. Door Rear Left] or [BF-Slid. Door Rear Right]
    Select: [Basic Settings-04]
    From the pull-down menu choose:
    [Resetting standardization] - Press [Start] - wait for "Finished Correctly", then Press [Stop]
    then
    [Resetting of all adaptation values] - Press [Start] - wait for "Finished Correctly", then Press [Stop]
    Next:
    - Open the sliding door via the switch in the middle of the console.
    - If the door is open, close the door via the switch in the middle of the console and then open the sliding door via the switch in the middle of the console.
    The basic setting of the sliding door should be complete.
  2. Likes Boki Ar, Uwe liked this post
  3. #2
    Jun 2014
    Quote Originally Posted by DrPeter View Post
    Thanks....
    drpeter
    Hi Drpeter I know old post but I needed to use the procedure today on U.K, spec Vw sharan 2012 63 Plate with O/S electric door fault. When the controller was unpluged and plugged in all functions for door is disabled and electric door switches flashing , also when you press the buttons to open the door there is no response. But after the procedure was preformed all function for sliding door working again after clearing all codes out.
    Thanks for posting it
  4. Likes Uwe liked this post
  5. #3
    Feb 2018
    Norway
    Hi, my Sharan 2011 have been exposed to some cold Norwegian winter days up in the mountain, and I do have exactly the same problem as Mr Galee. There seems to be nothing wrong, except that the lights are flashing, and the doors does not operate automatically. Both doors can be manually operated.
    I have just bought a HEX-V2, and must admit that I am a beginner when it comes to this type of work. Is this something I can fix myself?
    If yes, I would need a “step be step” procedure for beginners.
    I have hooked up the HEX-V2 to the car, OK, but is seems like the “Basic Settings” button for the doors are not active.
    Help will be very much appreciated :-)
  6. #4
    Quote Originally Posted by Svein Arne View Post
    Please post an Auto-Scan so people can see exactly how the vehicle is equipped, configured, and what (if any) faults are present.
    Feb 2018
    Norway
    Wednesday,14,February,2018,19:59:27:41746
    VCDS Version: 18.1.0.2 (x64) HEX-V2 CB: 0.4411.4
    Gateway Installation List: 7N0 907 530 D
    BE-Slid. Door Rear Left -- Status: Malfunction 0010
    BF-Slid. Door Rear Right -- Status: Malfunction 0010
    ^^^^ A valiant attempt. But that's only the Gateway Installation List, not the whole scan.
    Feb 2018
    Norway
    Sorry, I was a bit too quick :-)
    Hope this will do:
    Thursday,15,February,2018,16:53:30:41746
    VIN: WVWZZZ7NZBV038084   License Plate:
    Chassis Type: 7N-VW36 (7N0)
    Scan: 01 02 03 05 08 09 10 15 16 17 18 19 25 2B 2E 36 37 42 44 46
              4F 52 53 55 56 61 62 69 6C 6D 72 BE BF
    VIN: WVWZZZ7NZBV038084   Mileage: 143130km-88936miles
       Part No SW: 03L 906 018 HJ    HW: 03L 907 309 Q
       Component: R4 2.0l TDI   H24 9979
       Revision: 44H24---    Serial number:
       Coding: 001D003A043401080000
       Shop #: WSC 00790 218 00000
       ASAM Dataset: EV_ECM20TDI01103L906018HJ 003014
       ROD: EV_ECM20TDI01103L906018HJ.rod
       VCID: 79AF10BCC95363EF2FB-802C
    5523 - Engine Start Blocked by Immobilizer
              P1570 00 [032] - -
    4891 - EGR Valve (N18)
              P0403 00 [032] - Malfunction
       Part No SW: 02E 300 054 Q    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2602
       Revision: 06351113    Serial number: 00001104061021
       Shop #: WSC 00020 000 90108
       VCID: 241111C812D1CE072CD-8070
    Address 03: ABS Brakes        Labels: 7N0-614-109.clb
       Part No SW: 7N0 614 109 M    HW: 7N0 614 109 M
       Component: J104   C3 450M VDF6 0009
       Revision: --H07---    Serial number: 00000004054445
       Coding: 0031514
       Shop #: WSC 00020 790 00000
       VCID: 372BD684B347B59F99F-8062
       Part No SW: 5K0 959 434 B    HW: 5K0 959 434 A
       Revision: 00085000    Serial number: 0145182623
       Coding: 03100C
       Shop #: WSC 00020 999 00000
       ASAM Dataset: EV_KESSYPQ35G A02014
       VCID: 3431E188AEB15E87BCD-8060
              U1400 00 [008] - -
                        Reset counter: 26
                        Mileage: 143009 km
                        Date: 2018.02.06
                        Time: 16:30:26
       Part No SW: 5K0 907 044 G    HW: 5K0 907 044 G
       Component: Clima-Sharan  H11 0104
       Coding: 0000000109
       Shop #: WSC 16530 000 1048576
       VCID: 2F3BEEE447977D5FC1F-807A
       Slave 1:
       Subsystem 1 - Part No SW: 7N0 907 049 B    HW: 7N0 907 049 B
       Component: KBT-H  004 0102
       Serial number: 20110826000000035956
       Part No SW: 5K0 937 087 M    HW: 5K0 937 087 M
       Component: BCM PQ35 H    011 0048
       Revision: BE011001
       Coding: 40590A3B89251AC0500800C0740009E443551408676D2DF2E4808720A2C1
       VCID: 3FDBBEA497778DDF51F-806A
       Subsystem 1 - Part No SW: 7N1 955 119 A    HW: 7N1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS    110325  31  0032
       Serial number:         110416045925
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
       Component: RLFS  021 0022
       Serial number: Y11M04D04h18m30s47S1
       Coding: 0380BB
    01259 - Fuel Pump Relay (J17)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 242
                        Mileage: 143113 km
                        Date: 2012.07.01
                        Time: 00:00:07
                            Term 15 Off
                        Voltage: 12.40 V
    Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
       Part No SW: 3AA 919 475 D    HW: 3AA 919 475 A
       Component: PARKHILFE PLA H04 0007
       Revision: --------    Serial number: 20401109500158
       Coding: 31830D
       ASAM Dataset: EV_EPHVA2C000000000 001006
       ROD: EV_EPHVA2C000000000_001_VW36.rod
       VCID: 3C21C9A886E196C774D-8068
       Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
       Component: VW10Airbag018 H07 0013
       Serial number: 003GFP7921PH
       Coding: 003138
       ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
       ROD: EV_AirbaVW10TS6VW428.rod
       VCID: 3E25C3A090FD84D75A9-806A
       Subsystem 1 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.V  --- ---
       Serial number: 3493ETS602EB5E9139D5
       Subsystem 2 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.V  --- ---
       Serial number: 3503ETS60C3AFEF13DDF
       Subsystem 3 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.H  --- ---
       Serial number: 3513ETS60FE3BEA13DDE
       Subsystem 4 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.H  --- ---
       Serial number: 3523ETS60416DE6139DV
       Subsystem 5 - Part No SW: ---            HW: ---
       Component: F.Sens.Fahr  --- ---
       Serial number: 35540TS60239FF7139DS
       Part No SW: 5K0 953 501 BM    HW: 5K0 953 569 L
       Revision: FF010040    Serial number: 20110412301085
       Coding: 1112240000
       VCID: 76B51B80F84D0C97429-8022
       Coding: E30000
       Part No SW: 7N0 920 870 A    HW: 7N0 920 870 A
       Component: KOMBI         H20 0430
       Coding: 140F00
       VCID: 3039ED985AA962A7D85-8064
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 7N0 963 271 C
       Component: Zuheizer        051 2730
       Revision: 00051000    Serial number: 09022126000000
       Coding: 0000041
       VCID: 3431E188A2315E87BCD-8060
    00664 - Fuel gauge
                        Reset counter: 10
                        Mileage: 141845 km
                        Date: 2012.05.17
                        Time: 16:08:16
    01444 - Under-Voltage Shut-Off (Automatic)
                000 -  -  - Intermittent
                        Reset counter: 25
                        Mileage: 141873 km
                        Date: 2012.05.18
                        Time: 08:45:54
       Part No SW: 7N0 907 530 D    HW: 1K0 907 951
       Component: J533  Gateway H35 0614
       Revision:   H35       Serial number: 140411F1003003
       Coding: 468002
       VCID: 313FE89C51236BAFD7B-8064
       Component: IMMO          H20 0430
       Coding: 000007
       VCID: 6A8D3FF0BCF5D877D61-803E
    9456681 - Key
              B104C 29 [008] - Implausible Signal
                        Mileage: 138018 km
                        Date: 2017.09.29
                        Time: 12:28:54
    Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
       Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
       Component: ELV-PQ35      H20 0230
       Revision: 00000000    Serial number: 11000093727002
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2E05F3E0409D7457CA9-807A
       Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
       Component: SG EXT.PLAYER H13 0150
       Revision: A1001003    Serial number: 7669802245
       Coding: 020000
       VCID: 280905F862F92A67005-807C
                        Reset counter: 31
                        Mileage: 143137 km
                        Date: 2012.07.06
                        Time: 21:33:22
    Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
       Part No SW: 3C8 959 760 A    HW: 3C8 959 760 A
       Component: Sitzmemory    H05 2301
       Revision: 00H05000
       Coding: 000018
       Shop #: WSC 12336 024 394758
       VCID: 3333E294AB3F59BFA57-8066
                        Reset counter: 17
                        Mileage: 142202 km
                        Date: 2012.05.24
                        Time: 14:46:56
    00447 - Function Limitation due to Over-Voltage
                        Fault Status: 00100001
                        Reset counter: 249
                        Mileage: 141468 km
                        Date: 2012.05.17
                        Time: 10:33:52
       Part No SW: 3C0 035 279     HW: 3C0 035 279
       Component: RNS315        H05 0010
       Serial number: VWZAZ2L3328497
       Coding: 040004210400000000021000
       ASAM Dataset: EV_RNS315VWEUV1UDS A01005
       ROD: EV_RNS315VWEUV1UDS.rod
       VCID: 60995DD84AC99227085-8034
    Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
       Part No SW: 7N0 959 793 E    HW: 7N0 959 793 A
       Component: TSG FA        H04 0400
       Revision:             Serial number: 0000114798124
       Coding: 01153E20DE00411001
       VCID: 44D1B148FE91EE070CD-8010
       Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.325 0802
       Revision: 1AH03729    Serial number: 00110890064501
       Coding: 0000258
       VCID: 3B23CAB48F6F91FF7D7-806E
                        Reset counter: 26
                        Voltage: 0.30 V
                        Voltage: 6.30 V
                        Voltage: 2.60 V
                            Not Occup.
                            Not Occup.
       Component: EZE_2         H35 0614
       Coding: 050B0500
       VCID: 6FBB2EE487973D5F81F-803A
    Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
       Part No SW: 7N0 959 792 E    HW: 7N0 959 792 A
       Component: TSG BF        H04 0400
       Revision:             Serial number: 0000114406691
       VCID: 43D3B254FB9FE93F357-8016
       Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
       Component: J540 EPB4  VW-55183 0007
       Revision:   H18       Serial number: 00000000293362
       Coding: 0024067
       VCID: 3333E294A73F59BFA57-8066
       Part No SW: 5M0 907 357 D    HW: 5M0 907 357 D
       Component: AFS-Steuergeraet    0149
       Coding: 3555545
       VCID: 3537DC8CA94B478F8B3-8060
       Subsystem 1 - Part No: 1T0 941 329   Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    0001
       Coding: 00000054
       Subsystem 2 - Part No: 1T0 941 329   Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul r    0001
       Coding: 00000054
       Component: Batt.regelung H35 0614
       Coding: 030B185A
       VCID: 71BF289C91A32BAF97B-8024
       Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0150
       Serial number: 00000000009370326296
    Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
       Part No SW: 7N0 959 794 F    HW: 7N0 959 795 B
       Component: TSG HL        H03 0403
       Revision:             Serial number: 0000114599841
       Coding: 01007C200000411001
       Shop #: WSC 02196 002 1048576
       VCID: 46D5AB40C8ADDC17129-8012
    Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
       Part No SW: 7N0 907 383     HW: 7N0 907 383
       Component: Anhaenger     H09 0101
       Revision: 3I001002    Serial number: 00000147036450
       Coding: 410C040001000000
       VCID: 73B32294EBBF19BF657-8026
       Part No SW: 7N0 907 441     HW: 7N0 907 441
       Component: J772__Rearview      0020
       Revision: 00H09000    Serial number: 525 PA8J122137
       Coding: 0030011
       VCID: 6E8533E08C9D34578A9-803A
                        Reset counter: 26
                        Mileage: 143009 km
                        Date: 2012.06.29
                        Time: 16:30:18
                            Reverse OFF
                        Count: 3
       Part No SW: 7N0 959 107 B    HW: 7N0 959 107 A
       Component: HDSG-Modul    H11 0803
       Revision: 41011001    Serial number: 094100437
       Coding: 0733334003
       ASAM Dataset: EV_HDSGVW428 201133
       ROD: EV_HDSGVW428_VW36.rod
       VCID: 3635DB80B8CD4C97829-8062
    Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
       Component: TSG HR        H03 0403
       Revision:             Serial number: 0000114603887
    Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
       Part No SW: 7N0 959 244 B    HW: 7N0 959 244 B
       Component: Schiebetuer_l 005 2414
       Serial number: 11101216
       ASAM Dataset: EV_AST A03704
       ROD: EV_AST.rod
       VCID: 3829D5B8B2D9BAE7905-806C
    52496 - Motor for Rear Window Regulator
              B11EE 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 246
                        Mileage: 143137 km
                        Date: 2018.02.13
                        Time: 23:09:53
                        Voltage terminal 30: 14.7 V
                        Sliding_Door_Motor_Current: 0.0 A
                        Sliding_Door_Clutch_Current: 0 A
                        Sliding_Door_Locking_Pawl_Motor_Current: 0 A
                        Front button for automatic sliding door: not activated
                        Rear button for automatic sliding door: not activated
                        Installed on left side: Yes
                        Installed on right side: No
                        Pinch protection sensor: not activated
                        Latch_Ajar: operated
                        Latch_Pawl: operated
                        Sliding door indicator lamp: active
                        Sliding door indicator lamp 2: active
                        Activation: motor for automatic sliding door: not active
                        Automatic sliding door coupling motor activation: not active
                        Motor activation for enabling ratchet release: not active
                        Sliding_Door_Feedback_Motor_Opening: not active
                        Sliding_Door_Feedback_Motor_Closing: not active
                        Sliding_Door_Feedback_Locking_Pawl_Motor_Opening: not active
                        Sliding_Door_Feedback_Locking_Pawl_Motor_Reversing: not active
                        Sliding_Door_Feedback_Clutch_In: not active
                        Sliding_Door_Feedback_Clutch_Out: not active
                        Sliding_Door_Feedback_Indicator_Light_Front: active
                        Sliding_Door_Feedback_Indicator_Light_Rear: active
                        AD-Value clamping_Protection_Seal: 100
                        Position of automatic sliding door: 0
                        Status_Sliding_Door: latch secondary position
                        Play protection: motor for automatic sliding door: not active
                        Play protection: motor for enabling ratchet release: not active
                        Play protection: automatic sliding door coupling motor: not active
                        Status_Locking_Pawl_Motor: closed
                        Status_Clutch_Motor: closed
    Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
       Component: Schiebetuer_r 005 2414
       Serial number: 11101186
       ROD: EV_AST.rod
                        Reset counter: 0
                        Time: 00:00:00
                        Voltage terminal 30: 12.4 V
                        Installed on left side: No
                        Installed on right side: Yes
                        Latch_Ajar: not activated
                        Sliding door indicator lamp: not active
                        Sliding door indicator lamp 2: not active
                        Sliding_Door_Feedback_Indicator_Light_Front: not active
                        Sliding_Door_Feedback_Indicator_Light_Rear: not active
                        AD-Value clamping_Protection_Seal: 99
    End----------(Elapsed Time: 02:06, VBatt start/end: 14.8V/14.7V)-----------
  10. #8
    OK, now that we can see the details of the sliding door modules, I'm scratching my head as to why the Basic Settings button would not be active. The Basic Settings mentioned in Post #1 of this thread should be available.
  11. #9
    Feb 2018
    Norway
    This is how my screen looks (if the link is working)
  12. #10
    Feb 2018
    Norway
  13. Likes Uwe liked this post
