Results 11 to 20 of 30
Thread: Finally joined (with Mk.2 Tiguan)
    Dec 2016
    Uwe,
    Any concern over the errors seen, should I contact the dealer? No functional issues detected whilst driving.
    Do you need anymore information from me for the new MK2 VW Tiguan?
  2. #12
    Quote Originally Posted by welshkaiboy View Post
    IMO, no. Dealers don't want to chase spurious faulty codes that have no functional symptoms.
    Nothing I can think of at the moment, but I'll leave the question open for others to chime in.
  3. #13
    Dec 2016
    OK no problem, any idea when you might have the 09 SA code?
    Thank in advance
  4. #14
    09 looks like a fairly normal MQB module. Have you tried 31347 ?
  5. #15
    Dec 2016
    Yes it doesn't work.
  6. #16
    Dec 2016
    http://forums.ross-tech.com/showthre...ll=1#post80863
    Can't answer in the OP's thread but the same behaviour that I was describing above.
  7. #17
    Nov 2016
    Poland
    @Uwe, check his autoscan. He has 09 Coding included - in oposite to my two Tiguans scan and other from DV52.
    The problem is, welshkaiboy can't access his module using known SA code (31347), but we can.
    Do you have any details about differences between modules? They're different in letters after par number.
  8. #18
    Nov 2016
    Poland
    SA code working (empty coding string on autoscan):
    5Q0 937 084 CF
    5Q0 937 084 CG
    SA code not working (included coding in autoscan):
    5Q0 937 084 BP
    welshkaiboy VIN suggest 2016, my both 2017 - but one of my Tiguans was delivered 08/2016.
  9. #19
    Dec 2016
    As in PM, car is May 2016 one of the first dealer demonstrators.
  10. #20
    Dec 2016
    Updated scan using latest Beta. Engine error now recognised (not in latest release). Going in for oil service on Saturday so have asked them to ensure car is scanned and module software updated to latest as this car was on of the first MK2 demo's so not so sure all software is final. Is it a real engine error? ACC sensor is a known issue and new version of sensor available. Alarm has never been right since I had the car.
    Tuesday,23,May,2017,18:58:24:09667
    VCDS Version: 17.4.2.3 (x64)
    Data version: 20170505 DS270.4
    Mileage: 13075km-8124mi   Repair Order:
    Chassis Type: 5N (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F A5
    Address 01: Engine (J623-DFGA)       Labels: 04L-907-309-V1.clb
       Part No SW: 04L 906 026 EE    HW: 04L 907 309 M
       Component: R4 2.0l TDI   H23 2100
       Revision: B4H23---
       Coding: 0119001203251D082000
       ASAM Dataset: EV_ECM20TDI01104L906026EE 001003
       ROD: EV_ECM20TDI01104L906026HS_001_VW37.rod
       VCID: 71C70E52A08CD9CFF3-8024
    28991 - No Communications with NOX Sensor 1
              U029D 00 [032] - -
       Part No SW: 5Q0 614 517 BG    HW: 5Q0 614 517 AC
       Component: ESC           H25 0407
       Revision: 00000000    Serial number: 60986000000722
       Coding: 0AEE929A34210B6D477B260462C64950492CD0E2644692713060F078C02202
       VCID: 77D3304ACEE887FF3D-8022
    Address 08: Auto HVAC (E87)       Labels: None
       Part No SW: 5NC 907 044     HW: 5NC 907 044
       Component: AC Automat    H34 3902
       Revision: 20K07000    Serial number: 00000B00101230
       Coding: 00120104202110011105104C00101102
       ASAM Dataset: EV_ACClimaPrehVW37X 002013
       ROD: EV_ACClimaPrehVW37X_002_VW37.rod
       VCID: 7EDD256EE1D2B6B77E-802A
       Subsystem 1 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
       Component: E265KlimaHeck  H02 0201
       Serial number: 00000000000000000000
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
       Part No SW: 5Q0 937 084 BP    HW: 5Q0 937 084 BP
       Component: BCM MQBAB M+  H32 0212
       Serial number: 00021524300004
       Coding: 03000946C24102FB0BA44080B11407081080000000000000000000000000
       ASAM Dataset: EV_BCMMQB 016001
       ROD: EV_BCMBOSCH_016_VW37.rod
       VCID: 0733408ABE08F77F4D-8052
       Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
       Component: 326 RL 160318  033 0372
       Serial number: 00000001603160301622
       Component: RLHS  037 0059
       Serial number: S3Y16M04D21H21M04S13
       Coding: 06A8DD
       Serial number: 000000000ZY160322AA5
       Serial number: 00000000000065024289
    Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
       Part No SW: 3Q0 919 294     HW: 3Q0 919 294
       Component: PDC 8 Kanal   H07 0152
       Serial number: 002203167478020
       Coding: 0071051001
       ASAM Dataset: EV_EPHBO18VW3260000 007013
       ROD: EV_EPHBO18VW3260000_007_VW37.rod
       VCID: 76CD3D4EC9E2FEF726-8022
    Address 13: Auto Dist. Reg (J428)       Labels: 2Q0-907-572.clb
       Part No SW: 2Q0 907 572 H    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H01 0155
       Coding: 2A00404150FF8728749C806D004087
       ASAM Dataset: EV_ACCMRRCONTIVW376 001010
       ROD: EV_ACCMRRCONTIVW376_001_VW37.rod
       VCID: 3957F672B87C518F0B-806C
    196741 - Sensor for Automatic Distance Control
                        Reset counter: 28
                        Mileage: 12650 km
                        Date: 2017.05.15
                        Time: 19:30:45
                        Voltage terminal 15: 13.2 V
                        Control Module temperature: 32 C
                        Velocity_vehicle_reference: 8.03 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.69 m/s
       Part No SW: 5Q0 959 655 AD    HW: 5Q0 959 655 AD
       Component: AirbagVW21    005 0130
       Serial number: 003NMR1NW0AC
       Coding: 98CCC0C00C0000005C5400CF00C800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
       VCID: 0225519E952AD2571A-8056
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 5NC857705C0111Q00025
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 5NC857706C0111Q00245
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 001 504 16
       Serial number: 3570000000095420E91G
       Subsystem 4 - Part No SW: -----------    HW: 480 002 004 16
       Serial number: 35800000000A329CBA1V
       Subsystem 5 - Part No SW: -----------    HW: 480 401 904 16
       Serial number: 3510001992080C22264N
       Subsystem 6 - Part No SW: -----------    HW: 480 401 904 16
       Serial number: 3520001992080C24E72.
       Subsystem 7 - Part No SW: -----------    HW: 480 401 304 16
       Serial number: 3550001C52080C26B42Z
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 480 401 904 16
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001B52080C26054P
       Subsystem 9 - Part No SW: -----------    HW: 480 401 904 16
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001B92080C2326E/
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 480 401 904 16
       Component: PedP_Sensor_C  000 6149
       Serial number: 2300001B7209F106D49/
       Subsystem 11 - Part No SW: -----------    HW: 480 001 104 16
       Serial number: I0M0000000016638B91%
       Subsystem 12 - Part No SW: -----------    HW: 480 001 104 16
       Serial number: I0N0000000077638B917
       Part No SW: 5Q0 953 521 FC    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0205
       Revision: FF034034    Serial number: 20160303500912
       Coding: 0C00
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
       ROD: EV_SMLSVALEOMQBLRH_VW37.rod
       VCID: 78D13376C3F6888734-802C
       Part No SW: 5NA 920 951     HW: 5NA 920 951
       Component: KOMBI         308 6430
       Coding: 27A501006384260001886A031401000000000000
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1244
       Revision: --------    Serial number: 0004714076
       Coding: 030100041F087300FB00024C080F00010001050000000000000000000000
       VCID: 79D73672F8FC918F4B-802C
       Subsystem 2 - Part No SW: 5TA 959 442 A    HW: 5TA 959 442 A  Labels: 3C8-959-537.CLB
       Serial number: 0831600260400045AM2B
       Coding: 2A0000
       Subsystem 3 - Part No SW: 5QA 915 181 B    HW: 5QA 915 181 B
       Component: J367-BDMHella  H10 9052
       Serial number: 8614749903
       Serial number: 220316ECG11866
       Coding: 00310220D001048000001000
       VCID: 43AB949ACAB01B5F51-8016
       Serial number: 00000000000009624994
       Coding: 0D0000
       Component: EPS_MQB_ZFLS  128 1072
       Coding: 1107
       ROD: EV_SteerAssisMQB_013_VW37.rod
       VCID: 45AF8A82C484256F7F-8010
       Serial number: 020416ED127785
       Coding: 00310020DE01048000001000
       VCID: 42A5919ED5AA12575A-8016
       Serial number: 00000000000009663057
       Coding: 050000
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
       Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
       Component: MU-S-ND-ER    820 0624
       Coding: 02730601FF00000051111101008808001F0100C6012001008F
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 3041CB566B0690C7BC-8064
       Component: ABT_High  H63 0032
       Serial number: VWZ8Z9SKL00RE3
       Subsystem 2 - Part No SW: 3G0 919 866 AQ    HW: -----------
       Component: ECE1 2017  --- 0730
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
       Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0220
       Serial number: 15041611P20577
       Coding: 0003070600000401000213448040A10094000E000020
       ROD: EV_MFKBoschMQBB_VW36.rod
       VCID: 3A55E97EBD7A5A9702-806E
    1275 - Camera Interference
              C1104 00 [024] -  -
              Intermittent - Confirmed - Not Tested Since Memory Clear
                        Reset counter: 170
                        Mileage: 10773 km
                        Date: 2017.04.07
                        Time: 17:31:53
                        Control Module temperature: 45 C
                        Outside air temperature: 18.5 C
                        Vehicle speed: 31.24 km/h
                        System run time: 2123.6 s (second)
                        Voltage terminal 15: 13.0 V
                        mid: 01 62
                        Camera_state: operational
                        Engine_Running_Info: 1
                        Software_Info_4: 0
                        Software_Info_3: 2
                        Software_Info_2: 2
                        Software_Info_1: 0
    End-------------------------(Elapsed Time: 03:37)--------------------------
  11. Likes Uwe liked this post
