Results 1 to 10 of 10
Thread: Towbar coding problem - ACC Module 13 Auto Dist Reg (Audi A4 Avant B8 8K5 2013 )
    Jul 2014
    Oulu, Finland
    I had Westfalia detachable aftermarket towbar installed in a garage (not official Audi), but they failed to code all the modules in my car.
    All other modules seem to be fine except the "13 - Auto Dist. Reg (J428)" module for which there are no label files in VCDS, thus it was not modified. The garage also uses VCDS.
    My car is Audi A4 Avant 2.0 TDI Multitronic 2013 (built 05/2012). The car has start/stop, front/rear parking aid (no cam), lane maintenance, auto trans, front wheel drive, adaptive cruise control.
    The module (8K0 907 561 B) is now reporting fault (Control Module Incorrectly Coded) and adaptive cruise control (ACC) and lane maintenance functions do not work at all.
    I saw a recent thread on the same issue in this forum but it was for the older control module of Audi B8 2009 (Byte1: set bits 0 and 3, clear bit 4).
    I have a newer "B" version of the module so setting these bits 0 & 3 do not work for me (value out of range error). Bit 4 already cleared by default in my module.
    Any information would be appreciated to help determining the correct coding for the adaptive cruise control module, before giving up and taking the car to Audi service (which has long waiting queue at the moment)
    The following coding has already been done:
    01 Engine
    03 ABS Brakes
    09 Cent. Elect.
    13 Auto Dist. Reg - *** INFO MISSING FOR CODING *** (SOLVED)
    19 CAN Gateway  - added module 69 Trailer
    46 Central Conv.  - I found a trailer setting here also and set it although not sure if needed, Byte12: bit5
    5C Lane Maintenance - *** INFO MISSING FOR CODING *** (SOLVED)
    69 Trailer
    VCDS Scan:
    Tuesday,08,July,2014,20:17:39:24988
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN: WAUZZZ8K9DA064011   License Plate:
    Mileage: 14850km-9227mi   Repair Order:
    Chassis Type: 8K (8R0)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 20 42 44 46 47 52 53 56 5C
              5F 62 69 72
    VIN: WAUZZZ8K9DA064011  Mileage: 14850km/9227miles
    5C-Lane Maintain. -- Status: OK 0000
    Address 01: Engine (J623-CGLC)       Labels: 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 JJ    HW: 03L 906 018 JL
       Component: R4 2,0L EDC   H24 3108
       Revision: 45H24---
       Coding: 12034012235401080000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM20TDI01103L906018JJ 003006
       ROD: EV_ECM20TDI01103L906018JJ.rod
       VCID: 7BF5F98EF284FCC6CE5-802E
    4330 - Function Restriction due to Faults in Other Modules
              U1113 00 [047] - -
                        Mileage: 14837 km
                        Date: 2014.07.08
                        Time: 13:13:38
    Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
       Part No SW: 8K2 927 155 L    HW: 0AW 927 156 K
       Component: 0AW 20TDI RdW H04 0003
       Revision: --H04---    Serial number: 0000001274
       Coding: 000002
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMVL381 A02431
       ROD: EV_TCMVL381.rod
       VCID: 3E73309AA11629EEA9B-806B
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
       Part No SW: 8K0 907 379 CH    HW: 8K0 907 379 CH
       Component: ESP8 front    H09 0100
       Coding: 179D4C
       Shop #: WSC 06324 000 00000
       VCID: 81090B6618681616149-80D4
       Part No SW: 8K0 907 064 FD    HW: 8K0 907 064 FD
       Component: BCM2 2.0      H10 0602
       Coding: 01A20000000000000000
       VCID: 77FDE5BEC6ACD8A6AAD-8022
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: FBSAUDIB8 IDG  H60 0072
       Part No SW: 8K1 820 043 AD    HW: 8K1 820 043 AD
       Component: KLIMA 3 ZONEN H04 0036
       Revision: C1000000    Serial number: 01260420122306
       Coding: 342002E080
       VCID: 6ADBCCCA851E754E253-803F
       Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 AH
       Component: BCM1 1.0      H14 0103
       Revision: 08014001    Serial number: 00000029580402
       Coding: 260000108074AFE20181408300001D0D0F9CE70826090201000008000401020100000024000000
       Shop #: WSC 21721 136 86748
       VCID: 78FFE682CBB2D7DEA37-802D
       Component: WWS 030512  H07 70
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
       Coding: 02005D
       Component: E1 - LDS  H03 0031
    Address 13: Auto Dist. Reg (J428)       Labels: None
       Part No SW: 8K0 907 561 B    HW: 8K0 907 561 B
       Component: ACC3          H09 0100
       Coding: 00F6C0
       VCID: 31691BA66848C696249-8064
                        Reset counter: 241
                        Mileage: 14837 km
                        Date: 2014.07.08
                        Time: 13:28:51
                        Temperature: 35.0C
                        Voltage: 12.29 V
                        Hex Value: 0x005D
                        Lateral Accel.: 0.00 m/s^2
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Serial number: 003KFD92S0GK
       Coding: 30514235363030303030554A304C384B3053
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 489F5642F3D2675E137-801D
       Serial number: 6334MSME6E236A72N
       Serial number: 6344MSME6D413A18K
       Serial number: 6352QSME36134648C
       Serial number: 6362QSME7A14075CO
       Serial number: 63732SME36111152J
       Crash sensor for front airbag; passenger side:
       Serial number: 63832SME39115054S
       Component: Lenks.Modul   H03 0004
       Revision: --------    Serial number: 90372LDJ000D8
       Coding: 0000FF
       VCID: 44874272C7FA433EFFF-8011
       Component: E221 - MFL  H03 0003
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 931 F    HW: 8K0 920 931 F
       Component: KOMBIINSTR.   H35 0540
       Revision: 00000000    Serial number: NTL319U4D
       Coding: 1366100047010008000000
       Part No SW: 8R0 907 468 D    HW: 8R0 907 468 D
       Component: GW-BEM 5CAN-M H10 0025
       Revision: 1Z070014    Serial number: 1441Z12425014D
       Coding: 00CF07FF00
       VCID: 408F4E62D3E25F1EDB7-8015
    Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
       Revision: AA001002
       Coding: 02019164747464545425363E00
       VCID: 7CF7FA92FF8AFBFEC7F-8029
       Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
       Component: TSG FA        H02 0506
       Revision:             Serial number: 0000028985298
       Coding: 011C02205000410001
       VCID: 4D91675614B08276201-8018
    Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
       Component: RCEPS         H36 0507
       Revision: 00001000    Serial number: 0003488626
       Coding: 100001010001
       ROD: EV_RCEPSAU48X.rod
       VCID: 346712B29F5AF3BE4FF-8061
       Revision: 00002001    Serial number: 0176009410
       Coding: 0100062020B900808120023680000000
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
       Component: DSP Prem      H04 0030
       Revision: 00004001    Serial number: 94814002992401
       VCID: 2D5107D67470A276001-8078
       Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
       Component: TSG BF        H02 0506
       Revision:             Serial number: 0000029095654
       VCID: 4C976A52EFAA8B7E37F-8019
       Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
       Component: EPB-4         H01 0001
       Revision: --------    Serial number: 00000000055606
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 366328BA8926E1AE71B-8063
       Part No SW: 4G1 035 053 E    HW: 4G1 035 053
       Component: Radio U Basic H41 0093
       Revision: AB001007    Serial number: 227D 0C7574183
       Coding: 010003010000000001
       VCID: 2149EBE638A87616B49-8074
    Address 5C: Lane Maintain.        Labels: None
       Part No SW: 8T0 907 217     HW: 4E0 907 217 C
       Component: J759 HC             0020
       Revision: 00H08003    Serial number: 30021242600070
       Coding: 0022001
       VCID: F6E368BA81A621AE31B-80A3
       Part No SW: 8R1 035 670 C    HW: 8R1 035 670 C
       Component: H-BNT-EU      H44 0524
       Revision: --------    Serial number: 207DO0C7500821
       Coding: 0F0100010006A9ED2D80CB5E00000403040000000000000000
       VCID: 336511AE9254F486565-8066
       Subsystem 1 - Part No: 8R0 060 884 AH
       Component: EUR 2012  1308
       Component: DU7 High  H41 0104
       Subsystem 3 - Part No SW: 8T0 919 611 B    HW: 8T0 919 611 B
       Component: E0380 Bedient  H02 0020
       Component: CD-Database  3638
       Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
       Revision:             Serial number: 0000029444896
       Coding: 010C02204000210001
       VCID: 4385416EC2F44406C65-8016
    Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
       Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Revision: 1A001001    Serial number: 00008200356497
       Coding: 0100000000000000
       VCID: 366328BA8126E1AE71B-8063
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
       Revision:             Serial number: 0000029445418
    Last edited by spheikki; 07-16-2014 at 11:55 AM. Reason: 5C dist reg module coding marked as solved
    Jun 2014
    Newcastle, England
    It was my thread you were referring to.
    I see you have ACC3 and mine looks to be ACC2. I tried Westfalia tech support (to no avail) and a local trailer centre tried his guy at Westfalia and couldn't help either. However, they both kept on saying set Byte 0, Bit 0. You've seen from mine that it wasn't as simple as that, however, you may as well try it.
    As we say here in Newcastle - you've got nowt to lose!
    *edit* I see you have automatic transmission. Please check in there whether you need to code that module too.
    Jul 2014
    Oulu, Finland
    Yes it was your thread. Thanks for opening the topic
    Unfortunately setting Byte0 Bit0 does not work either. I get the same "Error 31: request out of range" message, the same as for Byte2 bits 0 & 3 earlier.
    I guess this error means only that the coding value is not valid, not like I would need to do some secure log in etc first.
    About the "02 Auto Trans": VCDS does not show any explanations for the bits, so I do not have any clue if anything would need to be changed here. I have not seen any trans. coding in other threads related to tow bar installation though.
    The same goes for "5C Lane Maintain." module.
    Quote Originally Posted by Zenerdiode View Post
    Jun 2014
    Newcastle, England
    I didn't require a Login or Security Access code to enable re-coding; yes, Error 31 is simply that the code you have offered is rejected by the controller. I had numerous Error 31s until I was provided with the correct one.
    Give it a week or so, NETech may be able to help you too.
    Jul 2014
    Oulu, Finland
    Thanks. I have no other choice than wait at the moment
    Have you changed the Coding in 13 Auto Dist. Reg, compared original ?
    It looks a little special, could you please send VIN.
  7. #7
    Jul 2014
    Oulu, Finland
    I edited the first original post and made complete VIN visible in the scan result. Please take a look.
    13 Auto Dist Req coding has not been changed. Luckily I had a scan done (for some modules only) before the tow bar installation, so I could verify that this module was not re-coded.
    The car was originally registered and taken into use in Germany (just imported to Finland).
  8. #8
    You know the car is not prepared for Trailer (engine cooling/ your/owner responsibility) !!
    I would use 00F6B9 for [13]
    There is also 0122001 for [5C]
    Remember to change non-zero values in wsc, importer, device no., like explained here before accept coding.
  9. Likes Uwe, spheikki liked this post
  10. #9
    Jul 2014
    Oulu, Finland
    Yes, I am aware of that the car has no preparation for trailer. I don't think this is a problem for me, but good to know.
    The new code for 13 Auto Dist Reg WORKS! Adaptive cruise control is now back and alive. Big thanks. I wish you had the label file with bit explanations available for this in VCDS
    The new code for 15 Lane Maintenance WORKS! Lane maintenance functions is back and alive. I must confess now that the lane assist was turned off by the garage using the button in the turn signal lever, and I have missed there even exist such button (new car). So the coding was never a problem for lane assist not to work. I feel ashamed now .
    It works also without the new coding provided, but I will use the one as also based on my own investigation the provided code is correct when trailer is installed. Just wanted to add this info here if someone else ever faces the same
    I come bakc later and summarize all the codings done for my car for tow hitch installation. Might be useful others.
    BIG THANKS FOR THE SUPPORT!
    Last edited by spheikki; 07-16-2014 at 12:05 PM. Reason: Updated response as lane assist (maint) works ok also.
  11. #10
    Feb 2018
    Australia
    Wow - cannot thank you enough for this coding above. I too had no active cruise control on my B8.5 A4 following on from my Westfalia towbar home install and this sorted out the last piece of the puzzle! I found the threads on other Audi forums showing me where to do all the long coding changes for the towbar but those steps are missing this piece. Everything now works perfectly and I am super pleased! Thanks a million! Charles
  12. Likes Uwe liked this post
