C7 Audi A6 Vagcom Tweaks
Devilz
Birmingham, England
C?ID=253973
Feed with some idea's what can be done to it through VCDS
I have done first scan and saved it for future reference. So far I have activated secret menu, battery info and lap timer but when I go to vehicle DIS I don't see battery info nor lap timer option. Can anyone help. Also I can change the splash screen through secret menu but there is no option to apply it. Does it mean I can't change MMI screen when it loads up
Here is the scan:
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 42 44 46 52 53 55 56
          5F 62 6C 72
VIN: --------------------   Mileage: 82679km-51374miles
Address 01: Engine (J623-CDUC)       Labels: 059-907-401-V2.clb
   Part No SW: 4G0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  X37 0004
   Revision: 53X37---
   Coding: 0A254012052601020000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
   ROD: EV_ECM30TDI0114G0907401F.rod
   VCID: 2643A6A259844272EE-8072
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 4G1 927 156 B    HW: 0B5 927 156 F
   Component: 0B5 30 TDIRdW H10 0001
   Revision: --H10---    Serial number: 0000001340
   Coding: 000001
   Shop #: WSC 02311 785 00200
   ROD: EV_TCMDL501.rod
   VCID: 2C57548A4768782238-8078
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379-V1.clb
   Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
   Component: ESP PREMIUM   H09 0250
   Coding: 27A68701E465E180DB00
   ASAM Dataset: EV_ESPPremiAU57X 004017
   VCID: 34674CEA9F5820E260-8060
   Part No SW: 4H0 907 064 BP    HW: 4H0 907 064 BP
   Coding: 05B82F06000000000000
   VCID: 78FFB8DACBB004828C-802C
   Component: J764 ELV MLB  H39 0046
   Serial number: 2311000236227013
Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
   Component: KLIMA 2 ZONEN H10 0062
   Serial number: 24101100040370
   Coding: 3621000820
   ASAM Dataset: EV_AirCondiBasisUDS 002037
   VCID: 2447BCAA2FB8B062F0-8070
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 BF    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0100
   Revision: 20012002    Serial number: 00000001095564
   Coding: 2600201040349FE00181008380001D0C0F9DC30827090101000004602100
   VCID: 6DD1998EB4F2B12A6F-8038
   Component: WWS57X 110909  H35 0051
   Serial number:         110922020435
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11726788
   Coding: 02512B
   Component: E1 - LDS  H07 0044
   Serial number: 05 08 2015  00000345
   Component: Humidity_Sens  H02 0002
   Serial number: 252843D5000000000001
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0050
   Revision: 11001001    Serial number: 55901127401046
   Coding: 280106
   ROD: EV_EPHVA18AU57X0000.rod
   VCID: 3D7169CEAC12E1AA9F-8068
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG004YW4Q
   Coding: 30323436313330303537554A305234473053
   VCID: 366376E2892432F25E-8062
   Serial number: 3575HRB405J0SM2ME18S
   Serial number: 3585HRB40590SM2O5PE%
   Serial number: 3515JRB40510Q8K4A16R
   Serial number: 3525JRB405R0Q8K47OVD
   Serial number: 3554VRB40510ODIIAPLA
   Serial number: 3564VRB40510ODII719F
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Revision: 00000000    Serial number: 20111022000145
   Coding: 000034
   VCID: 306F40FA63401CC204-8064
   Component: E221 - MFL  H08 0009
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 981 S    HW: 4G8 920 981 S
   Component: TDieGb        H79 0375
   Revision: 26181120    Serial number: 658191011591003
   Coding: 33A708000B010600010000
   ASAM Dataset: EV_RBD4K 004040
   ROD: EV_RBD4K.rod
   VCID: 43851F36CAF6975AE9-8016
   Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000280459
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 326B4AF2654C2ED272-8066
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790807577
   Voltage stabilizer:
0267 - Optical data bus
          U1049 00 [008] - Open circuit
                    Reset counter: 88
                    Mileage: 82421 km
                    Date: 2016.12.02
                    Time: 09:42:03
                    Voltage terminal 30: 12.0 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 16 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
                    Reset counter: 88
                    Mileage: 82421 km
                    Date: 2016.11.29
                    Time: 02:58:59
                    Voltage terminal 30: 12.3 V
                    Control Module temperature: -2 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
   Revision: AA000000    Serial number: 00000015433347
   Coding: 00781B0000006001000001010101102030303232203232
   VCID: 77FDBBE6C6AE0BFA85-8022
   Part No SW: 4G0 907 637     HW: 4G0 907 637
   Component: SARA 3D       H02 0004
   Revision: --------    Serial number: EJ1BPA3200NYZ50
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 6BD5979682E6BF1A71-803E
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   Coding: 011C16205E01620002080002
   Shop #: WSC 02312 785 00200
   VCID: 428B1A32DDEC9E52E2-8016
Address 44: Steering Assist (J500)       Labels: None
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0006189314
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009_AU57.rod
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0160786197
   Coding: 011B0E2200B9048183200800000100000000000000000000000000000000
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   VCID: 4189153ED8EA854AFB-8014
   Revision: --------    Serial number: 00000000163118
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 2A5B52924D9C6612CA-807E
Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
   Serial number: 111020-0004-085
   Coding: 1121A6101000A300
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 4G0 035 056 C    HW: 4G0 035 056
   Component: Radio U STD   H52 0079
   Revision: AB001007    Serial number: 051JY0B7544128
   Coding: 010003020100000001
   VCID: 2149B5BE38AAA54A9B-8074
   Part No SW: 4G0 035 670 E    HW: 4G0 035 670
   Component: H-BNT-EU      H47 0410
   Revision: --------    Serial number: 428J50B7524929
   Coding: 050101000003A1EF45008B3E00000003000001000000000000
   VCID: 2541A1AE2C82496AE7-8070
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Serial number: AUZ8ZDB1301U7V0
   Subsystem 3 - Part No SW: 4G2 919 610 A    HW: 4G2 919 610 A
   Component: E380 BDT C7  H08 0203
   Serial number: 90349KJK00025
   Component: CD-Database  3371
02067 - Optical Databus; Unpermitted Wake-Up Request
            000 -  -  - Intermittent
                    Reset counter: 88
                    Mileage: 82421 km
                    Date: 2016.12.02
                    Time: 09:39:20
                    Voltage: 12.00 V
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010814204001620002080002
   VCID: 44871C2AC7F89062D0-8010
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 4H0 907 428     HW: 7P6 907 441 D
   Component: TopView       H05 0090
   Revision: 11001001    Serial number: 82330JF0013479
   Coding: 0200000001000100000102000000
   Shop #: WSC 02314 785 00200
   ASAM Dataset: EV_CamerSysteTopViewAUDI 003019
   ROD: EV_CamerSysteTopViewAUDI_003.rod
   VCID: 6ADB92928D1CA6120A-803E
   Component: TSG HR        H04 0212
End-------------------------(Elapsed Time: 04:38)--------------------------
Devilz
Birmingham, England
C?ID=253973
Try at own risk, I won't be responsible if you make mistake
Here's my complete list
1. Enabling Gauge Test/Needle Sweep (already activated)
This will sweep the needles of the speedo and rev counter through their full range automatically when you start the engine.
[Select]
[17 - Instruments]
[Coding - 07]
[Long Coding Helper]
Click on byte 1 and you'll see the selectable option: "Gauge Test/Needle Sweep active"
Check this option
[Do It!]
This produced expected results
2. Enabling Lap Timer (Did nothing on my car - I have been told I need to get instruments firmware updated by Audi)
[Select]
[17 - Instruments]
[Coding - 07]
Click on byte 1 and you'll see the selectable option: "Lap Timer active"
Check this option
[Do It!]
3. Kerb lighting (Activated)
Illuminating the kerb when turning hard left or right at low speeds with dipped beam on, by turning on the all-weather light on the relevant side of the car.
[Select]
[09-Cent. Elect.]
[Coding - 07]
Click on byte 4 and enable bit 0
[Do It!]
4. Beep on lock (Activated)
Chirp the alarm siren briefly when the alarm activates (ie all doors are closed and the car is locked)
[Select]
[46-Central Conv.]
[Coding - 07]
Click on byte 1 and in bit 2 you'll see the selectable option: "Anti-Theft-System: Horn Confirmation active"
Check this option
[Do It!]
5. Hidden menu (Activated)
Enable access to the green engineering menu in the MMI
[Select]
[5F - Information Electr.]
[Adaptation - 10]
Select Channel 6 and Read
change the value from 0 to 1 then Test then Save
Reboot the MMI (Press MENU, central MMI knob and top right softkey)
To get to the Hidden Menu, press and hold the CAR and MENU buttons for a few seconds. You may have to have a few attempts - if you don't press them at the exact same moment either CAR or MENU activates. You know if you have done it right because the red LEDs in the buttons do not illuminate.
WARNING!!!! BE CAREFUL!!! Do not mess with settings in the Hidden Menu unless you know what you are doing. On earlier MMI versions, people managed to activate the bootloader menu and fried their MMI. Use at your own risk. If in doubt, leave well alone!
6. Battery Meter. (Did this but no information in MMI)
Enter the Hidden Menu as in step 5 above.
Select Car
Select Carextdevicelist
Check "Battery"
Return
Select Carmenuoperation
Set "Battery" from 0 to 5
Return
Press CAR to exit the hidden menu
Reboot the MMI
7. VIM (Retrived code - will try tomorrow)
Video In Motion - prevent the car from suppressing DVD playback once the speed of the car rises above 5mph
I used the same technique as in my C6 with MMI 3G. These are the steps I followed:
[Select]
[5F-Information Electr.]
[Advanced ID - 1A]
Make a note of the Serial Number
Go to Enable VIM TV-playback using VCDS/VAG-COM in your Audi MMI | trick77.com
Follow the link for MMI 3G
Enter your serial number into the input field
Make a note of the personal login code and the alternative login code it returns
[Security Access - 16]
Enter your personal login code.
[Do it!]
If you receive a "code not valid" message try the alternative code. If neither code works it's likely that your control module doesn't support VIM adaptation.
[Adaptation - 10]
Select channel 48
Press read
Set the value from 0 to 255
Press test
Press save
Press "Done, Go Back"
Close VCDS and reboot your MMI as detailed in step 5 above
8. Passenger door mirror dip on selecting reverse.
(Already activated)
When reverse gear is selected, the passenger door mirror dips to show the kerb if the mirror control knob is set to the passenger door mirror position. When driving forwards and exceeding 5mph or when switching off the car, the passenger mirror returns to its original position. If the position of the mirror is changed when dipped, this change is remembered the next time the mirror dips.
[Select]
[52 - Door Elect, Pass]
[Coding - 07]
Click on Byte 4 (5th one along from the left)
Set Bit 2 to "on"
[Do It!]
9. Disabling seatbelt reminder chimes.
Turn off the annoying "Bing bong" when you move the car on the driveway without your seatbelt fastened.
[Select]
[17 - Instruments]
[Coding - 07]
Click on byte 0 and in bit 4 you'll see the selectable option: "Seat Belt Warning inactive"
Check this option
[Do It!]
10. Disabling engine stop when opening driver's door.
Recode the Central Convenience module to STOP the engine from turning off when you get out, having moved the car.
[Select]
[46 - Central Conv.]
[Coding - 07]
Click on the red byte (below) and in the binary code you will see: 00000111
Change it to: 00001111
ie. with 1111 at the end not 111
Tab into the next bit box and you will see the code change to 0F (013F062220B9000083200904200104070000000000000000000000000000 to 013B062220B90000832009042001040F0000000000000000000000000000)
[close the long code helper]
[Do It!]
11. Enabling the default distance setting in the MMI for Adaptive Cruise Control
Adding the option to modify the default distance for ACC (values 1 to 4) via the MMI
[Select]
[13 - Auto Distance Regulation]
[Adaptation - 10]
Select channel 07
Press read
Set the value from 0 to 1
Press test
Press save
In the MMI you should now be able to go to Car > Driver Assistance > Adaptive Cruise and see a new option there to set the adaptive cruise distance.
12. Modifying the High Beam Assist speed threshold
Changing the threshold speed at which High Beam Assist activates
[Select]
[20 - High Beam Assist]
[Adaptation - 10]
From the drop-down menu, select "High Beam Speed Threshold"
In the third entry box down on the left, enter the speed to set the threshold to in KM/h (eg 40)
Press save
13. Enabling the Daytime Running Lights on/off setting in the MMI
(Done but can't find it in MMI)
Adding the option to turn off / turn on the DRLs via the MMI
[Select]
[09-Cent. Elect.]
[Coding - 07]
Click on byte 3 and enable bit 0 (Daytime running lights adjustable via MMI)
[Do It!]
14. Enabling tourist mode setting for headlights in the MMI
[Select]
[09-Cent. Elect.]
[Coding - 07]
Click on byte 4 and enable bit 6
[Do It!]
15. Enable auto handbrake when shift into P (tried this but it gave error)
[Select]
[53 - Parking Brake]
Code displayed to me was - 78713
[Adaption - 10]
[Select]
"Shift P to EPB"
Set to Activated
[Do It!]
16. Close electric boot lid from key
[Select]
[46 - Cent Conv]
[Coding - 07]
Click on byte 2, bit 2
Tick Comfort operation: Remote control active
[Do It!]
[Select]
[4D - Trunk Elec]
Input 12345
[Adaption - 10]
Activation using rear lid opening button in remote key - Touch function for closing
Change to ACTIVE
[Do It!]
17. Enable double disarm chirp
[Select]
[Adaption - 10]
Channel 63
Add 4
[Do It!]
(Prompt shows options for other settings)
18. Disable DRL dim on turn signal (Activated)
[Select]
[09 - Central Elec.]
Code: 20113
[Adaption - 10]
Channel 3
Set between 5 and 100
[Do It!]
(I found 50 to be a good setting)
19. Parking brake release without seat belt on
[Select]
Code presented by program
[Adaption - 10]
Select from drop down menu
Change parameter
[Do It!]
20. Tail lights on with front DRLs (Activated - looks awesome)
[Select]
[09-Cent. Elect.]
[Coding - 07]
Click on byte 2 and enable bit 7
[Do It!]
21. Enable ripping from CD to MMI HDD
Select Main
Select Diagnose
Select Settings
Select Import_Multimedia
Check "Ripping"
Return
Reboot the MMI
22. Disable NAV & Phone warning messages while entering data at speed
[5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
23. Enable Adaptive brake lights
[46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
24. Enable Independent Fogs control with high beams
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0
25. Enable TPMS
* You need the 1AT ABS unit – check your stickers (1AS does not work)
[Hidden menu] [car] [cardevicelist] [RDK] Enable
[Hidden menu] [car] [carmenuoperation] [Tires Air Pressure Control] Set to 5
[03 - ABS Brakes]
[Security Access - 16] (probably with login code: 61378)
[Coding - 07] -> Long Coding Helper -> Byte 1
Bit 3 - Tire Pressure Monitoring (PR-7K6) active (1 = active)
The TPMS need to be enabled in the Instrument Cluster:
[17 - Instruments]
Bit 0 - Tire Pressure Monitoring (TPMS) installed (1 = active)
Reset MMI
26. Set Audi parking system - Switch OFF Speed
[10 - Park/Steer Assist] [Adaptation - 10] -> Channel 23
Set to 20 (max value in km/h)
27. Adjust LED brightness
[09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
[Adaptation - 10] -> Channel 3
28. Adjust bluetooth microphone sensitivity
Hidden menu
Diagnose
Settings
Mic sensiblity - choose -6db/0db/+6db
29. Enable Drivers Memory Seat
36: Seat Mem - 07 Coding - Long Coding Helper - change Byte 2, bit 0, to 1
Seat memory will be there however greyed out in MMI
Press and hold down unlock button on key fob for 5 seconds for the windows to come down
Press and hold down lock button on key fob for 5 seconds for the windows to go back up
In MMI, Seat Adjustment you are now able to find Driver's seat, you can set Key memory on/off. Set it "on" for both keys separately.
30. Disable/memorize/invert Start & Stop:
- module 09-Cent. Elec.
- enter Security Code (20113)
- Adaptation on Channel 34:
subtract 4 to the value --> Start&Stop always disabled
add 32 to the value --> memorize last status (the Start & Stop status at engine startup will be the one at last engine shutdown)
- test & save
In addition of these values, if you add 64 to the value, the Start & Stop button light will be reversed: off if Start & Stop is disabled, and on if Start & Stop is enabled
31. Activation of footwell lighting for vehicles without Lighting Pack / Ambient Lighting
This allows you to use the MMI to set the footwell lighting level while driving. Tested on cars with MMI 3G+ (Tech pack).
[Select]
[09-Cent. Elect]
[Coding - 07]
Click on byte 16 and enable bit 6
[Do It!]
Select Car
Select Cardevicelist
Check "Interior Light"
Return
Set "Interior Light" from 0 to 5
Return
Reboot the MMI
And a little bonus :
Lowering AAS with VCDS
0) Set your car to "Auto" mode (not dynamic, comfort, etc.). Make sure car is on level ground. Close doors. If any doors are opened during the procedure, it will be interrupted. Make sure your car is NOT in a towing or tire changing mode.
1) Load up VCDS, go to Module 34 - Level Control
2) Go to "10 - Adaptation", take note of 4 values titled as "Body height front left wheel house edge" - mine were set to around 384 from factory.
3) Take the values you noted above, and ADD your desired drop in millimeters (mm) to each value, write it down... So if your left front wheel was 384.5, your new value will be 401.5. Repeat for the other wheels. It is not critical to be 100% precise here, rounding the values is fine. Note that maximum Audi-approved drop is 17mm from what I've gathered. You can go lower, but if you go lower, you're also affecting other systems, such as cameras, adaptive cruise, etc., so be careful.
Technically, if you want this procedure to be done properly, instead of taking existing values, you will measure all 4 wheels after completion of the step 7, and then add your drop value if desired. Suspension height values are measured from the center of the wheel to the edge of the fender.
4) Go to Security Access, enter code provided on the following website, under VCDS section, item #3 (I'm not posting this directly to avoid spreading sensitive data, although it's been posted on other forums in past) http://www.stemei.de/pages/coding/au...ng-des-aas.php
5) You should get a message stating that security code has been accepted - if you don't, something failed, stop doing what you're doing
6) Go to 04 - Basic Settings
*** IMPORTANT: Whatever you do, DO NOT select "Reset All Adaptations" - this is not undoable, and will require a visit to the dealer. ***
7) Select "Activate Level Control", hit "Go", wait for it to complete (should only take a second, until it says "not running").
8) Select "Delete Calibration For Level Control", hit "Go", wait for it to complete, your car will throw a fault code and you will see an error message stating Air Suspension Malfunction - this is normal.
7) Select "Start Up to Reference Level", hit "Go". This step will take about a minute, and your car will go up/down during the process (you'll hear hissing noises). Wait for it to complete, until it says "not running". DO NOT use the "start up to reference level production" option.
9) Select "Go Back", go to "10 - Adaptation" on the previous screen.
10) Next you will need to enter new adaptation values for all 4 wheels. Select "Body height front left wheel house edge", then enter new adaptation value, and hit "Do it", then repeat for the other 3 wheels. I did it in the order the menu was arranged (FL, RL, FR, RR) - not sure if the order matters, but just in case. Each time you enter a value, you should get a message stating that it has been accepted.
11) After you're done entering adaptation for all 4 wheels, select "Go Back", and return to "04 - Basic Settings" again.
12) In basic settings, select "Calibrate Level Control" and hit go, it will take a few seconds. Wait for it to say "not running". If you get an error during this step, you either missed a step, or something went horribly wrong.
13) Select "Activate Level Control", hit "Go"
14) You're done, now go to "02 - Fault Codes" and Reset codes.
If this did or didn't work - please share your experience with the rest of us here.
UPDATE:
There is an additional setting that will prevent your car from auto-lowering at ~30 mph, as well as allow you to raise the suspension while driving at any speed. Standard settings gray out the "raise" button over a certain speed, and are particularly annoying if your car is lowered via the steps above and you would like to keep it raised for an extended period of time (such as city driving with a lot of dips, bumps, ramps, sloped driveways, etc.)
1) Launch the green menu by holding Car + Menu buttons. (If you don't know how to enable or use the green menu, see the main VCDS thread)
2) Go to "car" then "carmenuoperation" menu
3) Scroll down to "suspension"
4) Change the value to "5"
5) Press the center menu knob to save
6) Reboot the MMI (Menu button +Center knob+Top Right soft button)
7) Turn the ignition on/off
sportmotor
Czech Republic
C?ID=14747
Not bad, but VIM doesn't work for facelift C7 (C7.5). Does anybody know how to enable VIM on these C7.5 cars with VCDS?
DJAlix
London, United Kingdom
C?ID=238277
Cannot be done via VCDS unfortunately as the MMI used changes from MMI3Gx to MIB (MMI4Gx).
Hakkapeliitta
C?ID=315485
Hi ya'll!
I tried a trick which apparently worked on a 2016 VW Golf R but doesn't work on my 2014 A6 C7. The video showed it done in 017 - instruments - adaptations - ignition active message, actuator. In my adaptations drop down menu there isn't an option like that.
Is there a way to disable the alarm chime opening the driver door with ignition on? It's quite annoying... I know i can mute it by pressing 'OK' on steering wheel but I would prefer to disable the whole chime.
Geoffarnold1
C?ID=328052
The lowering method worked great for me on my 2013 D4. I followed the instruction to reset and when it came to entering the values for each wheel, I added 10mm to each whereby giving me a much better ride height that still allows me to raise when needed. I didn't have to mess with the hidden green screen (I don't think it was done prior to my owning the car) Instructions very much appreciated. Thanks!
langyyyy
Slovakia
C?ID=44692
Is possible to make US lighting via turn signal?
Rizzio
Trondheim, Norway
C?ID=369124
Deactivation of instrument sound when opening driver door while engine running.
ecu 46
Coding 07: byte 15 bit 3 set to 1 (01001111)
Adaptation: channel 98 change from 1 to 0
mreuss222
C?ID=277851
2016 audi a6 tdi
I'm.Trying to enable the green screen my vcds screen does not look like others I see in.the videos.
I can't pick a channel
It says channel I click it and is a huge drop down menu..
I am using vcds 22.9.0
Can someone help
Sounds like your infotainment module uses the newer UDS protocol.
Please post an Auto-Scan for context so people can see exactly what it's made of.
