Results 1 to 6 of 6
Thread: C7 Audi A6 Vagcom Tweaks
    Verified VCDS User Devilz's Avatar
    Aug 2015
    Feed with some idea's what can be done to it through VCDS
    I have done first scan and saved it for future reference. So far I have activated secret menu, battery info and lap timer but when I go to vehicle DIS I don't see battery info nor lap timer option. Can anyone help. Also I can change the splash screen through secret menu but there is no option to apply it. Does it mean I can't change MMI screen when it loads up
    Here is the scan:
    Chassis Type: 4G (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 42 44 46 52 53 55 56
              5F 62 6C 72
    VIN: --------------------   Mileage: 82679km-51374miles
    Address 01: Engine (J623-CDUC)       Labels: 059-907-401-V2.clb
       Part No SW: 4G0 907 401 F    HW: 4G0 907 401
       Component: 3.0TDI EDC17  X37 0004
       Revision: 53X37---
       Coding: 0A254012052601020000
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
       ROD: EV_ECM30TDI0114G0907401F.rod
       VCID: 2643A6A259844272EE-8072
    Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
       Part No SW: 4G1 927 156 B    HW: 0B5 927 156 F
       Component: 0B5 30 TDIRdW H10 0001
       Revision: --H10---    Serial number: 0000001340
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_TCMDL501 A02087
       ROD: EV_TCMDL501.rod
       VCID: 2C57548A4768782238-8078
    Address 03: ABS Brakes (J104)       Labels: 4G0-907-379-V1.clb
       Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
       Component: ESP PREMIUM   H09 0250
       Coding: 27A68701E465E180DB00
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ESPPremiAU57X 004017
       VCID: 34674CEA9F5820E260-8060
       Part No SW: 4H0 907 064 BP    HW: 4H0 907 064 BP
       Component: BCM2 2.0      H31 0333
       Coding: 05B82F06000000000000
       VCID: 78FFB8DACBB004828C-802C
       Component: J764 ELV MLB  H39 0046
       Serial number: 2311000236227013
    Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-2Z.clb
       Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
       Component: KLIMA 2 ZONEN H10 0062
       Serial number: 24101100040370
       Coding: 3621000820
       ASAM Dataset: EV_AirCondiBasisUDS 002037
       VCID: 2447BCAA2FB8B062F0-8070
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
       Part No SW: 4H0 907 063 BF    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0100
       Revision: 20012002    Serial number: 00000001095564
       Coding: 2600201040349FE00181008380001D0C0F9DC30827090101000004602100
       VCID: 6DD1998EB4F2B12A6F-8038
       Component: WWS57X 110909  H35 0051
       Serial number:         110922020435
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11726788
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
       Component: E1 - LDS  H07 0044
       Serial number: 05 08 2015  00000345
       Component: Humidity_Sens  H02 0002
       Serial number: 252843D5000000000001
    Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
       Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0050
       Revision: 11001001    Serial number: 55901127401046
       Coding: 280106
       ROD: EV_EPHVA18AU57X0000.rod
       VCID: 3D7169CEAC12E1AA9F-8068
    Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG004YW4Q
       Coding: 30323436313330303537554A305234473053
       VCID: 366376E2892432F25E-8062
       Serial number: 3575HRB405J0SM2ME18S
       Serial number: 3585HRB40590SM2O5PE%
       Serial number: 3515JRB40510Q8K4A16R
       Serial number: 3525JRB405R0Q8K47OVD
       Serial number: 3554VRB40510ODIIAPLA
       Serial number: 3564VRB40510ODII719F
    Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
       Revision: 00000000    Serial number: 20111022000145
       Coding: 000034
       VCID: 306F40FA63401CC204-8064
       Component: E221 - MFL  H08 0009
    Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
       Part No SW: 4G8 920 981 S    HW: 4G8 920 981 S
       Component: TDieGb        H79 0375
       Revision: 26181120    Serial number: 658191011591003
       Coding: 33A708000B010600010000
       ASAM Dataset: EV_RBD4K 004040
       ROD: EV_RBD4K.rod
       VCID: 43851F36CAF6975AE9-8016
       Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0213
       Revision: --------    Serial number: 00000000280459
       Coding: 00CD077D00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 326B4AF2654C2ED272-8066
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790807577
       Voltage stabilizer:
    0267 - Optical data bus
              U1049 00 [008] - Open circuit
                        Reset counter: 88
                        Mileage: 82421 km
                        Date: 2016.12.02
                        Time: 09:42:03
                        Voltage terminal 30: 12.0 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 16 C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 0
              U140B 00 [008] - -
                        Reset counter: 88
                        Mileage: 82421 km
                        Date: 2016.11.29
                        Time: 02:58:59
                        Voltage terminal 30: 12.3 V
                        Control Module temperature: -2 C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 1
       Component: MEM-FS        H03 0154
       Revision: AA000000    Serial number: 00000015433347
       Coding: 00781B0000006001000001010101102030303232203232
       VCID: 77FDBBE6C6AE0BFA85-8022
       Part No SW: 4G0 907 637     HW: 4G0 907 637
       Component: SARA 3D       H02 0004
       Revision: --------    Serial number: EJ1BPA3200NYZ50
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 6BD5979682E6BF1A71-803E
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011C16205E01620002080002
       Shop #: WSC 02312 785 00200
       VCID: 428B1A32DDEC9E52E2-8016
    Address 44: Steering Assist (J500)       Labels: None
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0006189314
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009_AU57.rod
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0160786197
       Coding: 011B0E2200B9048183200800000100000000000000000000000000000000
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       VCID: 4189153ED8EA854AFB-8014
       Revision: --------    Serial number: 00000000163118
       ROD: EV_ParkiBrake_AU57.rod
       VCID: 2A5B52924D9C6612CA-807E
    Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
       Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
       Serial number: 111020-0004-085
       Coding: 1121A6101000A300
       ROD: EV_HeadlRegulBasic.rod
       Part No SW: 4G0 035 056 C    HW: 4G0 035 056
       Component: Radio U STD   H52 0079
       Revision: AB001007    Serial number: 051JY0B7544128
       Coding: 010003020100000001
       VCID: 2149B5BE38AAA54A9B-8074
    Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
       Part No SW: 4G0 035 670 E    HW: 4G0 035 670
       Component: H-BNT-EU      H47 0410
       Revision: --------    Serial number: 428J50B7524929
       Coding: 050101000003A1EF45008B3E00000003000001000000000000
       VCID: 2541A1AE2C82496AE7-8070
       Subsystem 1 - Part No: 8R0 060 884 N
       Component: EUR 2011  1205
       Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
       Component: DU8 C7 SV  H42 0021
       Serial number: AUZ8ZDB1301U7V0
       Subsystem 3 - Part No SW: 4G2 919 610 A    HW: 4G2 919 610 A
       Component: E380 BDT C7  H08 0203
       Serial number: 90349KJK00025
       Subsystem 4 - Part No: 8R0 060 961 B
       Component: CD-Database  3371
    02067 - Optical Databus; Unpermitted Wake-Up Request
                000 -  -  - Intermittent
                        Reset counter: 88
                        Mileage: 82421 km
                        Date: 2016.12.02
                        Time: 09:39:20
                        Voltage: 12.00 V
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010814204001620002080002
       VCID: 44871C2AC7F89062D0-8010
    Address 6C: Back-up Cam. (J928)       Labels: None
       Part No SW: 4H0 907 428     HW: 7P6 907 441 D
       Component: TopView       H05 0090
       Revision: 11001001    Serial number: 82330JF0013479
       Coding: 0200000001000100000102000000
       Shop #: WSC 02314 785 00200
       ASAM Dataset: EV_CamerSysteTopViewAUDI 003019
       ROD: EV_CamerSysteTopViewAUDI_003.rod
       VCID: 6ADB92928D1CA6120A-803E
       Component: TSG HR        H04 0212
    End-------------------------(Elapsed Time: 04:38)--------------------------
    A6 3.0 Quattro - 333hp 780nm
  2. Likes Boki Ar liked this post
  3. #2
    Aug 2015
    Try at own risk, I won't be responsible if you make mistake
    Here's my complete list
    1. Enabling Gauge Test/Needle Sweep (already activated)
    This will sweep the needles of the speedo and rev counter through their full range automatically when you start the engine.
    [Select]
    [17 - Instruments]
    [Coding - 07]
    [Long Coding Helper]
    Click on byte 1 and you'll see the selectable option: "Gauge Test/Needle Sweep active"
    Check this option
    [Do It!]
    This produced expected results
    2. Enabling Lap Timer (Did nothing on my car - I have been told I need to get instruments firmware updated by Audi)
    [Select]
    [17 - Instruments]
    [Coding - 07]
    Click on byte 1 and you'll see the selectable option: "Lap Timer active"
    Check this option
    [Do It!]
    3. Kerb lighting (Activated)
    Illuminating the kerb when turning hard left or right at low speeds with dipped beam on, by turning on the all-weather light on the relevant side of the car.
    [Select]
    [09-Cent. Elect.]
    [Coding - 07]
    Click on byte 4 and enable bit 0
    [Do It!]
    4. Beep on lock (Activated)
    Chirp the alarm siren briefly when the alarm activates (ie all doors are closed and the car is locked)
    [Select]
    [46-Central Conv.]
    [Coding - 07]
    Click on byte 1 and in bit 2 you'll see the selectable option: "Anti-Theft-System: Horn Confirmation active"
    Check this option
    [Do It!]
    5. Hidden menu (Activated)
    Enable access to the green engineering menu in the MMI
    [Select]
    [5F - Information Electr.]
    [Adaptation - 10]
    Select Channel 6 and Read
    change the value from 0 to 1 then Test then Save
    Reboot the MMI (Press MENU, central MMI knob and top right softkey)
    To get to the Hidden Menu, press and hold the CAR and MENU buttons for a few seconds. You may have to have a few attempts - if you don't press them at the exact same moment either CAR or MENU activates. You know if you have done it right because the red LEDs in the buttons do not illuminate.
    WARNING!!!! BE CAREFUL!!! Do not mess with settings in the Hidden Menu unless you know what you are doing. On earlier MMI versions, people managed to activate the bootloader menu and fried their MMI. Use at your own risk. If in doubt, leave well alone!
    6. Battery Meter. (Did this but no information in MMI)
    Enter the Hidden Menu as in step 5 above.
    Select Car
    Select Carextdevicelist
    Check "Battery"
    Return
    Select Carmenuoperation
    Set "Battery" from 0 to 5
    Return
    Press CAR to exit the hidden menu
    Reboot the MMI
    7. VIM (Retrived code - will try tomorrow)
    Video In Motion - prevent the car from suppressing DVD playback once the speed of the car rises above 5mph
    I used the same technique as in my C6 with MMI 3G. These are the steps I followed:
    [Select]
    [5F-Information Electr.]
    [Advanced ID - 1A]
    Make a note of the Serial Number
    Go to Enable VIM TV-playback using VCDS/VAG-COM in your Audi MMI | trick77.com
    Follow the link for MMI 3G
    Enter your serial number into the input field
    Make a note of the personal login code and the alternative login code it returns
    [Security Access - 16]
    Enter your personal login code.
    [Do it!]
    If you receive a "code not valid" message try the alternative code. If neither code works it's likely that your control module doesn't support VIM adaptation.
    [Adaptation - 10]
    Select channel 48
    Press read
    Set the value from 0 to 255
    Press test
    Press save
    Press "Done, Go Back"
    Close VCDS and reboot your MMI as detailed in step 5 above
    8. Passenger door mirror dip on selecting reverse.
    (Already activated)
    When reverse gear is selected, the passenger door mirror dips to show the kerb if the mirror control knob is set to the passenger door mirror position. When driving forwards and exceeding 5mph or when switching off the car, the passenger mirror returns to its original position. If the position of the mirror is changed when dipped, this change is remembered the next time the mirror dips.
    [Select]
    [52 - Door Elect, Pass]
    [Coding - 07]
    Click on Byte 4 (5th one along from the left)
    Set Bit 2 to "on"
    [Do It!]
    9. Disabling seatbelt reminder chimes.
    Turn off the annoying "Bing bong" when you move the car on the driveway without your seatbelt fastened.
    [Select]
    [17 - Instruments]
    [Coding - 07]
    Click on byte 0 and in bit 4 you'll see the selectable option: "Seat Belt Warning inactive"
    Check this option
    [Do It!]
    10. Disabling engine stop when opening driver's door.
    Recode the Central Convenience module to STOP the engine from turning off when you get out, having moved the car.
    [Select]
    [46 - Central Conv.]
    [Coding - 07]
    Click on the red byte (below) and in the binary code you will see: 00000111
    Change it to: 00001111
    ie. with 1111 at the end not 111
    Tab into the next bit box and you will see the code change to 0F (013F062220B90000832009042001040700000000000000000 00000000000 to 013B062220B90000832009042001040F000000000000000000 0000000000)
    [close the long code helper]
    [Do It!]
    11. Enabling the default distance setting in the MMI for Adaptive Cruise Control
    Adding the option to modify the default distance for ACC (values 1 to 4) via the MMI
    [Select]
    [13 - Auto Distance Regulation]
    [Adaptation - 10]
    Select channel 07
    Press read
    Set the value from 0 to 1
    Press test
    Press save
    In the MMI you should now be able to go to Car > Driver Assistance > Adaptive Cruise and see a new option there to set the adaptive cruise distance.
    12. Modifying the High Beam Assist speed threshold
    Changing the threshold speed at which High Beam Assist activates
    [Select]
    [20 - High Beam Assist]
    [Adaptation - 10]
    From the drop-down menu, select "High Beam Speed Threshold"
    In the third entry box down on the left, enter the speed to set the threshold to in KM/h (eg 40)
    Press save
    13. Enabling the Daytime Running Lights on/off setting in the MMI
    (Done but can't find it in MMI)
    Adding the option to turn off / turn on the DRLs via the MMI
    [Select]
    [09-Cent. Elect.]
    [Coding - 07]
    Click on byte 3 and enable bit 0 (Daytime running lights adjustable via MMI)
    [Do It!]
    14. Enabling tourist mode setting for headlights in the MMI
    [Select]
    [09-Cent. Elect.]
    [Coding - 07]
    Click on byte 4 and enable bit 6
    [Do It!]
    15. Enable auto handbrake when shift into P (tried this but it gave error)
    [Select]
    [53 - Parking Brake]
    Code displayed to me was - 78713
    [Adaption - 10]
    [Select]
    "Shift P to EPB"
    Set to Activated
    [Do It!]
    16. Close electric boot lid from key
    [Select]
    [46 - Cent Conv]
    [Coding - 07]
    Click on byte 2, bit 2
    Tick Comfort operation: Remote control active
    [Do It!]
    [Select]
    [4D - Trunk Elec]
    Input 12345
    [Adaption - 10]
    Activation using rear lid opening button in remote key - Touch function for closing
    Change to ACTIVE
    [Do It!]
    17. Enable double disarm chirp
    [Select]
    [Adaption - 10]
    Channel 63
    Add 4
    [Do It!]
    (Prompt shows options for other settings)
    18. Disable DRL dim on turn signal (Activated)
    [Select]
    [09 - Central Elec.]
    Code: 20113
    [Adaption - 10]
    Channel 3
    Set between 5 and 100
    [Do It!]
    (I found 50 to be a good setting)
    19. Parking brake release without seat belt on
    [Select]
    Code presented by program
    [Adaption - 10]
    Select from drop down menu
    Change parameter
    [Do It!]
    20. Tail lights on with front DRLs (Activated - looks awesome)
    [Select]
    [09-Cent. Elect.]
    [Coding - 07]
    Click on byte 2 and enable bit 7
    [Do It!]
    21. Enable ripping from CD to MMI HDD
    Select Main
    Select Diagnose
    Select Settings
    Select Import_Multimedia
    Check "Ripping"
    Return
    Reboot the MMI
    22. Disable NAV & Phone warning messages while entering data at speed
    [5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
    23. Enable Adaptive brake lights
    [46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
    Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
    Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
    24. Enable Independent Fogs control with high beams
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
    Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
    Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0
    25. Enable TPMS
    * You need the 1AT ABS unit – check your stickers (1AS does not work)
    [Hidden menu] [car] [cardevicelist] [RDK] Enable
    [Hidden menu] [car] [carmenuoperation] [Tires Air Pressure Control] Set to 5
    [03 - ABS Brakes]
    [Security Access - 16] (probably with login code: 61378)
    [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 3 - Tire Pressure Monitoring (PR-7K6) active (1 = active)
    The TPMS need to be enabled in the Instrument Cluster:
    [17 - Instruments]
    Bit 0 - Tire Pressure Monitoring (TPMS) installed (1 = active)
    Reset MMI
    26. Set Audi parking system - Switch OFF Speed
    [10 - Park/Steer Assist] [Adaptation - 10] -> Channel 23
    Set to 20 (max value in km/h)
    27. Adjust LED brightness
    [09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
    [Adaptation - 10] -> Channel 3
    28. Adjust bluetooth microphone sensitivity
    Hidden menu
    Diagnose
    Settings
    Mic sensiblity - choose -6db/0db/+6db
    29. Enable Drivers Memory Seat
    36: Seat Mem - 07 Coding - Long Coding Helper - change Byte 2, bit 0, to 1
    Seat memory will be there however greyed out in MMI
    Press and hold down unlock button on key fob for 5 seconds for the windows to come down
    Press and hold down lock button on key fob for 5 seconds for the windows to go back up
    In MMI, Seat Adjustment you are now able to find Driver's seat, you can set Key memory on/off. Set it "on" for both keys separately.
    30. Disable/memorize/invert Start & Stop:
    - module 09-Cent. Elec.
    - enter Security Code (20113)
    - Adaptation on Channel 34:
    subtract 4 to the value --> Start&Stop always disabled
    add 32 to the value --> memorize last status (the Start & Stop status at engine startup will be the one at last engine shutdown)
    - test & save
    In addition of these values, if you add 64 to the value, the Start & Stop button light will be reversed: off if Start & Stop is disabled, and on if Start & Stop is enabled
    31. Activation of footwell lighting for vehicles without Lighting Pack / Ambient Lighting
    This allows you to use the MMI to set the footwell lighting level while driving. Tested on cars with MMI 3G+ (Tech pack).
    [Select]
    [09-Cent. Elect]
    [Coding - 07]
    Click on byte 16 and enable bit 6
    [Do It!]
    Select Car
    Select Cardevicelist
    Check "Interior Light"
    Return
    Set "Interior Light" from 0 to 5
    Return
    Reboot the MMI
    And a little bonus :
    Lowering AAS with VCDS
    0) Set your car to "Auto" mode (not dynamic, comfort, etc.). Make sure car is on level ground. Close doors. If any doors are opened during the procedure, it will be interrupted. Make sure your car is NOT in a towing or tire changing mode.
    1) Load up VCDS, go to Module 34 - Level Control
    2) Go to "10 - Adaptation", take note of 4 values titled as "Body height front left wheel house edge" - mine were set to around 384 from factory.
    3) Take the values you noted above, and ADD your desired drop in millimeters (mm) to each value, write it down... So if your left front wheel was 384.5, your new value will be 401.5. Repeat for the other wheels. It is not critical to be 100% precise here, rounding the values is fine. Note that maximum Audi-approved drop is 17mm from what I've gathered. You can go lower, but if you go lower, you're also affecting other systems, such as cameras, adaptive cruise, etc., so be careful.
    Technically, if you want this procedure to be done properly, instead of taking existing values, you will measure all 4 wheels after completion of the step 7, and then add your drop value if desired. Suspension height values are measured from the center of the wheel to the edge of the fender.
    4) Go to Security Access, enter code provided on the following website, under VCDS section, item #3 (I'm not posting this directly to avoid spreading sensitive data, although it's been posted on other forums in past) http://www.stemei.de/pages/coding/au...ng-des-aas.php
    5) You should get a message stating that security code has been accepted - if you don't, something failed, stop doing what you're doing
    6) Go to 04 - Basic Settings
    *** IMPORTANT: Whatever you do, DO NOT select "Reset All Adaptations" - this is not undoable, and will require a visit to the dealer. ***
    7) Select "Activate Level Control", hit "Go", wait for it to complete (should only take a second, until it says "not running").
    8) Select "Delete Calibration For Level Control", hit "Go", wait for it to complete, your car will throw a fault code and you will see an error message stating Air Suspension Malfunction - this is normal.
    7) Select "Start Up to Reference Level", hit "Go". This step will take about a minute, and your car will go up/down during the process (you'll hear hissing noises). Wait for it to complete, until it says "not running". DO NOT use the "start up to reference level production" option.
    9) Select "Go Back", go to "10 - Adaptation" on the previous screen.
    10) Next you will need to enter new adaptation values for all 4 wheels. Select "Body height front left wheel house edge", then enter new adaptation value, and hit "Do it", then repeat for the other 3 wheels. I did it in the order the menu was arranged (FL, RL, FR, RR) - not sure if the order matters, but just in case. Each time you enter a value, you should get a message stating that it has been accepted.
    11) After you're done entering adaptation for all 4 wheels, select "Go Back", and return to "04 - Basic Settings" again.
    12) In basic settings, select "Calibrate Level Control" and hit go, it will take a few seconds. Wait for it to say "not running". If you get an error during this step, you either missed a step, or something went horribly wrong.
    13) Select "Activate Level Control", hit "Go"
    14) You're done, now go to "02 - Fault Codes" and Reset codes.
    If this did or didn't work - please share your experience with the rest of us here.
    UPDATE:
    There is an additional setting that will prevent your car from auto-lowering at ~30 mph, as well as allow you to raise the suspension while driving at any speed. Standard settings gray out the "raise" button over a certain speed, and are particularly annoying if your car is lowered via the steps above and you would like to keep it raised for an extended period of time (such as city driving with a lot of dips, bumps, ramps, sloped driveways, etc.)
    1) Launch the green menu by holding Car + Menu buttons. (If you don't know how to enable or use the green menu, see the main VCDS thread)
    2) Go to "car" then "carmenuoperation" menu
    3) Scroll down to "suspension"
    4) Change the value to "5"
    5) Press the center menu knob to save
    6) Reboot the MMI (Menu button +Center knob+Top Right soft button)
    7) Turn the ignition on/off
  4. Likes Uwe, acarlborg, FrA1l3, blue moon liked this post
  5. #3
    Jul 2014
    Czech Republic
    Not bad, but VIM doesn't work for facelift C7 (C7.5). Does anybody know how to enable VIM on these C7.5 cars with VCDS?
    Verified VCDS User DJAlix's Avatar
    Apr 2015
    London, United Kingdom
    Cannot be done via VCDS unfortunately as the MMI used changes from MMI3Gx to MIB (MMI4Gx).
    VAG Car Coding
    Adaptation | Coding | Diagnostic | Retrofit - London, United Kingdom
    Authorised VW Group Services Provider and Independent Repairer
    @vagcarcoding
    Oct 2017
    Hi ya'll!
    I tried a trick which apparently worked on a 2016 VW Golf R but doesn't work on my 2014 A6 C7. The video showed it done in 017 - instruments - adaptations - ignition active message, actuator. In my adaptations drop down menu there isn't an option like that.
    Is there a way to disable the alarm chime opening the driver door with ignition on? It's quite annoying... I know i can mute it by pressing 'OK' on steering wheel but I would prefer to disable the whole chime.
    Feb 2018
    The lowering method worked great for me on my 2013 D4. I followed the instruction to reset and when it came to entering the values for each wheel, I added 10mm to each whereby giving me a much better ride height that still allows me to raise when needed. I didn't have to mess with the hidden green screen (I don't think it was done prior to my owning the car) Instructions very much appreciated. Thanks!
