Results 1 to 9 of 9
Thread: DSG question
    Sep 2016
    DSG question
    I was driving my 2014 2.0 tdi passat estate yesterday in a car park so I was on and off the accelerator frequently I could hear a very slight tap every time I pressed the accelerator, I assume it's normal and I have only just noticed it as the car was silent (no radio) otherwise the car drives perfect having only covered 14000 miles
    I just wanted to check this with other dsg owners
    Cheers
    Moved to General VW/Audi Repair.
    Do you have any idea where this sound was coming from? The pedal itself? Under the hood ("bonnet")? Somewhere else?
    Sep 2016
    I would say under the hood/bonnet as I press the accelerator/gas it's almost like when you release a clutch on a manual quickly it doesn't sound rough it's just noticeable
    Cheers
    Sep 2016
    I am trying to pin point this it actually makes the light thud in P,N and drive when the Gas/Accelerator is pushed any ideas appreciated ?
    I could just be paranoid
    Dec 2015
    India
    Although the low mileage makes it not so likely, maybe you should check the mountings.
    Sep 2016
    Quote Originally Posted by vu2gte View Post
    The odd thing is if I put my foot on the brake in neutral it doesn't do it I wondered if it could be the auto hold
  7. #7
    Sep 2016
    Had the DMF changed however when I went to collect they car it was the same as before so I left it overnight with them ,today they left a message to say they had secured some components that were loose after reassembly odd since the car was apparently fixed .
    Cold start tomorrow to see
  8. #8
    Verified VCDS User Ashraf6119's Avatar
    Dec 2015
    Only at 14000 miles DMF changed.......... was it changed at the dealers...?
  9. #9
    Sep 2016
    Quote Originally Posted by Ashraf6119 View Post
    Yup flywheel changed under warranty however after they called today to say it was ready and gave a bs story I went to see it and it was still the same and surprisingly it's the n75 boost solenoid making the thud
  10. Likes Ashraf6119, Uwe liked this post
