Results 1 to 7 of 7
Thread: 2.0 TDI will not rev above 2K
    Jun 2014
    Went to help a veteran today.
    Here is a scan and a brief log.
    Is the egr not being ready responsible for the limiting of revs? Is there a readiness script here? We were able to set the steering sensor.
    11	November	11:48:58:34689-VCID:78F47EFB0B54CA8284-802C	Data version: 20161010 DS267.0
    ADVMB	R4 2.0L EDC G000AG  2260
    	G003	G003	G003	F3	G011	G011
    TIME	Group 3 - Field 1	Group 3 - Field 2	Group 3 - Field 3	TIME	Group 11 - Field 1	Group 11 - Field 2
    STAMP	Exhaust Gas - Recirculat. (spec.)	Exhaust Gas - Recirculat. (actual)	Exhaust Gas - Recirc. Duty Cycle	STAMP	Boost Pressure - (specified)	Boost Pressure - (actual)
    	 mg/str	 mg/str	 %		 mbar	 mbar
    0.12	505	270	100	0.01	1004.3	859.1
    0.37	440	255	100	0.25	1004.3	859.1
    0.64	470	285	100	0.51	1004.3	859.1
    0.89	460	290	100	0.76	1004.3	859.1
    1.15	415	255	100	1.03	1004.3	859.1
    1.4	345	265	87.8	1.28	1016.4	859.1
    1.67	345	275	90.2	1.54	1016.4	859.1
    1.92	335	275	89.8	1.79	1016.4	859.1
    2.18	315	265	88.6	2.06	1016.4	859.1
    Friday,11,November,2016,11:22:32:34689
    VCDS Version: 16.8.3.1
    VIN: 3VWLL7AJ2CM361667   License Plate:
    Readiness Status: 00000000 00001111 11101011 11101011
    MIL Status: MIL OFF
    Comprehensive Components: Passed
    Fuel System: Passed
    Exhaust Gas Recirculation: Failed or Incomplete
    Number of EOBD-related DTC(s): 0
                    Address 01: Engine  (03L 906 019 HH)
    11:24:37
      828 /min   Engine Speed (G28)
      290.0 mg/str   Exhaust Gas Recirculat. (spec.)
      300.0 mg/str   Exhaust Gas Recirculat. (actual)
      78.0 %   Exhaust Gas Recirc. Duty Cycle
    Chassis Type: AJ (6N0)
    Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 44 47 56
    VIN: 3VWLL7AJ2CM361667   Mileage: 120320km-74763miles
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 906 019 HH    HW: 03L 907 309 AA
       Component: R4 2,0L EDC G000AG  2260
       Revision: 12H14---    Serial number:
       Coding: 0050078
       VCID: 78F47EFB0B54CA8284-802C
       Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 3102
       Revision: 05351113    Serial number: 00001111070521
       VCID: 2648608391608C72E6-8072
       Revision: 00H31001
       Coding: B14B400C492800FB8D1102EA92200042A71000
       VCID: 7DFA6FEFE476EFAAD7-8028
                        Reset counter: 58
                        Mileage: 120321 km
                        Date: 2016.11.06
                        Time: 00:01:16
                        Count: 2
                        Count: 14
                        Count: 29184
                        Count: 16390
                        Count: 50688
                        Count: 65532
    Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
       Part No SW: 5K0 959 434 B    HW: 5K0 959 434 B
       Revision: 00085000    Serial number: 0156976223
       Coding: 030C0C
       ROD: EV_KESSYPQ35G_VW01.rod
       VCID: 346C8ACB9FBCEEE268-8060
       Part No SW: 5C0 820 047 AQ    HW: 5C0 820 047 AQ
       Component: J301  Klimaanlage   0203
       Revision: 2001010S    Serial number: 00000000739057
       VCID: 6FE645A77E1A8D3A55-803A
    Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
       Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
       Component: BCM25 JLB H3  H66 0251
       Revision: B2066001    Serial number: 04371343110238
       Coding: 7B994B9A08AB0B0008382000240884C50082502E6000000030A000000000
       VCID: 2F6685A77E9ACD3A15-807A
       Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  002 3464
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  002 3464
       Coding: 820000
       Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
       Component: J245 PS41.022  H09 0007
       Serial number:     WRH0003L2C8
       Coding: 180000
       Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
       Serial number: 0785742
       Coding: 020000
       Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
       Component: J388__TSG_HL  002 3464
       Coding: 800000
       Subsystem 6 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
       Component: J389__TSG_HR  002 3464
       Coding: 800000
       Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
       Component: AirbagVW10G   014 0808
       Serial number: 003GTM03BVSE
       Coding: 00003936
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
       ROD: EV_AirbaVW10SMEVW360.rod
       Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
       Component: BF-Gewichtss.  H10 0045
       Serial number: 6940000Y1100009P2P0U
       Coding: 303036
       Serial number: 3572MSME17584165ZZZU
       Serial number: 3582MSME212B0065ZZZL
       Serial number: 3516KSME230B2415ZZZH
       Serial number: 3526KSME5B143615ZZZQ
       Serial number: 3556LSME1A0D5411ZZZT
       Serial number: 3566LSME10095411ZZZG
       Part No SW: 5C6 920 951 A    HW: 5C6 920 951 A
       Component: KOMBI         H04 0604
       Coding: 270A01
       Shop #: WSC 00066 000 00123
       VCID: 29526BBF487EA30ACB-807C
    Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
       Part No SW: 6N0 909 901     HW: 5C0 937 087 A
       Component: GW-K-CAN TP20 H66 0251
       Revision: B2066001
       Coding: 102200
       VCID: 70E446DBA32492C24C-8024
       Component: IMMO          H04 0604
       Coding: 000007
       VCID: 6AD054B38DF8681202-803E
    Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
       Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
       Component: ELV-PQ35      H20 0230
       Revision: 00000000    Serial number: 11000237186001
       Coding: 4900000000000000
       Shop #: WSC 00066 790 50316
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2E5898A37190C4321E-807A
       Revision: A1001003    Serial number: 7660909429
       Coding: 020000
       VCID: 29526BBF407EA30ACB-807C
       Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
       Component: RNS315-NAR    H33 0265
       Serial number: VWZAZ2L8482754
       Coding: 04090001010006000000100A
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_RNS315NARV2UDS A01004
       ROD: EV_RNS315NARV2UDS.rod
       VCID: 234E79972A52795A81-8076
       Component: NAR_V7N  0060
              B11CF 53 [009] - Deactivated
                        Reset counter: 23
                        Mileage: 119004 km
                        Date: 2016.10.21
                        Time: 19:56:59
       Part No: 1K0 909 144 N
       Component: EPS_ZFLS Kl. 70     3301
       Revision: 00H22000
       VCID: 356AB7CF5CC6F7EA5F-8060
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 12.1 V
                            PD
                        Temperature: 19.0C
                        Count: 2
                        Steering Angle: 0.00
                            SteerAng n.Init
       Part No SW: 3T0 035 456 B    HW: 3T0 035 456 B
       Component: KonzernAmp10K H06 0362
       Revision: --------    Serial number: BP225311000754
       VCID: 306486DB6BA4D2C20C-8064
    End-------------------------(Elapsed Time: 03:12)--------------------------
  2. Likes Boki Ar liked this post
  3. #2
    Jul 2014
    Poland
    Rev limit at 2-2.5k RPM when stand still is normal behaviour of the CR TDI engines.
  4. Likes Jetta ,97 liked this post
  5. #3
    Stoke on Trent, England
    Quote Originally Posted by automech View Post
    Correct, which I find is totally ridiculous when testing anything.
    New User Keith
  6. #4
    Jun 2014
    Problem is, the vehicle will not go more than about 15 mph. IIRC the DSG did go into 2nd while testing.
    Jul 2014
    Poland
    Sounds like Transport mode. Worth to try turning it OFF again.
    Jun 2014
    Any idea how it would get into Transport Mode?
    Jun 2014
    Newcastle, England
    From the main screen of VCDS, click the [Applications] button.
  10. Likes Jetta ,97, Uwe liked this post
