I am using a Micro-CAN with VCDS 16.8.3.
VCDS is able to scan and clear basic codes but offers no extended access to adaptation, etc.
Looks as if VCDS needs to be updated for the new modules.
Car Info, Build and Error are above.
Autoscan pulled the following:
Friday,04,November,2016,18:18:59:18648
VCDS Version: 16.8.3.1
VIN: WVWVF7AU4HW07xxxx License Plate:
Mileage: 414km-257mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
55 5F 75 A5 A9
VIN: WVWVF7AU4HW07xxxx Mileage: 414km-257miles
Address 01: Engine (J623-CYFB) Labels: None
Part No SW: 8V0 906 259 K HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 091D00122466000E3004
ASAM Dataset: EV_ECM20TFS0208V0906259K 001003
ROD: N/A
VCID: 48B1B1EEF3FB230234-801C
No ASAM data for: "EV_ECM20TFS0208V0906259K" (VW37)
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H54 4937
Revision: 06354004 Serial number: TFK01607080421
ROD: EV_TCMDQ250021.rod
VCID: 538B96823ABD90DA51-8006
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 62216000000213
Coding: 01FA6BA1542709734579030541C56980D62A90A2C0829637184050D8C2A803
VCID: 7BDB1E22F2ADB89AE9-802E
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0415694328
Coding: 032C0C
VCID: 3B5BDE22B22D789AA9-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 BL HW: 5G0 907 044 BL
Component: Climatronic H04 1601
Revision: 00001K08
Coding: 00020004200100000105000012111402
ROD: EV_ACClimaBHBVW37X_005_VW37.rod
VCID: 72C53306A5E7F9D2BA-8026
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 085 BL HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number: 01061623000116
Coding: 00011B46C041A2E169E44000091C07201800000000000000000000000000
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: 042965DE8F53C76298-8050
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160813 043 0551
Serial number: 160820061829
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S6Y16M09D05H10M53S35
Coding: 00A8DD
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331624602444
Coding: 0071155011
VCID: 43ABA6C2CADD005AE1-8016
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Coding: 350000C151FFC428949C8045000016
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: N/A
No ASAM data for: "EV_ACCBOSCHVW416" (VW37)
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 11081641350344
ROD: EV_DRCONTITEMIC.rod
VCID: 3851C12E831B538244-806C
Component: AirbagVW20 010 0830
Serial number: 003GCR05LJU4
VCID: 47B3B2D2FEE52C7A3D-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000005MSLB4
Coding: 30324E
Subsystem 2 - Part No SW: ----------- HW: 480 003 108 16
Serial number: 357000000003A21D0D1F
Subsystem 3 - Part No SW: ----------- HW: 480 002 608 16
Serial number: 3580000000028C8C0E1U
Subsystem 4 - Part No SW: ----------- HW: 480 402 008 16
Serial number: 35100029F215E1E2301Z
Subsystem 5 - Part No SW: ----------- HW: 480 400 606 16
Serial number: 3520002B92076365F2F7
Subsystem 6 - Part No SW: ----------- HW: 480 400 808 16
Serial number: 3550002B521FBE83D3DS
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 708 16
Serial number: 35600029D2095062039V
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Revision: -------- Serial number: 13081604220541
Coding: 0C10
ROD: EV_SMLSKLOMQB_SK48.rod
VCID: 093774EAA8719A0AEB-805C
Part No SW: 5G1 920 858 B HW: 5G1 920 858 B
Component: KOMBI 304 8311
Coding: 0BAD081A7F88CF0502886B0B5400000000000000
VCID: 2F43FA727655943A15-807A
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
Component: GW MQB High 128 1265
Revision: -------- Serial number: 0005263671
Coding: 0101000838085900FB00023A9C0F00000001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 7CD91D3EF7A3BFA2E0-8028
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S
Component: E221__MFL-DC1 H11 0040
Serial number: 29160001259320106263
Coding: 35FFFF
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00018.07.16
Coding: 0001
VCID: 4AB58BE6EDF7D11222-801E
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000131082008
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_SK25.rod
VCID: 3449F51E9F73B7E268-8060
Address 3C: Lane Change (J1086) Labels: None
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0414177386
Coding: 02011103
ROD: EV_HREntryHella.rod
VCID: 3C59DD3EB7237FA2A0-8068
Lane Change Assistant 2:
Component: TSG FS 020 0041
Serial number: 010616EF106162
Coding: 003E13208000040000000000
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000011414783
Coding: 111000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 9102
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A55DB26BD174192B2-806E
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H30 0150
Revision: 00000001 Serial number: VWZ8Z1GBA0274L+
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 6DFF207ABCD9262A67-8038
Component: TSG BFS 020 0041
Serial number: 290516EES08005
Coding: 003E13208000040000800000
VCID: 42A5A3C6D5C70952EA-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000011155584
Coding: 091000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 022202010B000400
VCID: 40A1A9CEDBCB1B42FC-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 876 A HW: 3Q0 035 876 A
Component: MU-S-NS-US 840 0751
Coding: 027300020000000051220002001808009F0207F401200105C6
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 3245F3066567B9D27A-8066
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H53 1031
Serial number: VWZ8Z9SJX00840
Subsystem 2 - Part No SW: 3G0 919 866 AC HW: -----------
Component: NAR 2016/17 --- 0445
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02730002C2821A017F1E06020000
ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 19081611P22253
Coding: 0003070000000201002213548040490084000E100020
ROD: EV_MFKBoschMQBB.rod
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 160622202345
ROD: EV_SoundActuaGen2AU64X_VW26.rod
End-------------------------(Elapsed Time: 05:18)--------------------------
