Steering issue on MkVII GTI
ReflexSilverMkVII
C?ID=256588
My 2016 GTI has some weird steering issues going on when the engine revs reach a certain point or when accelerating. To be more specific, I can rev the engine while going down the road in neutral and the wheel will slightly go right. I have also noticed that when in stop and go traffic around 1600-2000 rpm in gear the steering almost feels as if there is something that makes the wheel temporarily hard to keep straight. I've had the car aligned and inspected and the dealership found no suspension or tie rod issues. They thought it was the alignment but I am still experiencing the same issue. I've scanned my car and have no faults. My car was seriously out of alignment. I've seen on other forums where people said their car had yaw sensors that were out of calibration and when the dealer reset them this fixed their steering issues. If possible I would prefer being able to do this myself with my HexNet. I've also noticed the steering doesn't return to center and seems to be slightly off center going down the highway. What steering settings can I reset or recalibrate with VCDS?
Is there a recalibration or relearning of the yaw sensors that can be done through VCDS? How do I "recenter" my steering wheel with VCDS? I only saw one post about recentering the wheel and someone said it worked but then updated their post and said the steps didn't work. Thanks for your help.
ReflexSilverMkVII
C?ID=256588
Here's my auto scan. I'm not sure how to describe this issue I'm experiencing other than saying the steering wheel randomly and suddenly moves to the right about 5 degrees and its almost as if something locks the steering in that position for a brief second making it hard to turn back to the left to straighten the car out. The car pulls to the right. If its not something computer related with steering control, I'm not sure what else it could be. There are no strange noises when this occurs, just the pulling and dealership swears up and down their inspection of the suspension/steering components did not shed light on loose bolts or a bent axle or anything. I have personally inspected the tie rods, sway bar links and nothing seems to be loose or worn at least not that I can see or feel. It only happens at low speeds, between 1500-2000 RPM. It seems to be the worst when just lightly applying throttle so its not torque steer. My car is equipped with the VAQ differential.
VCDS Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: Release 16.8.3(x64) Data version: 20161010 DS267.0 www.Ross-Tech.com
Dealer/Shop Name: Workshop Code: 000 00000 000000
Self-Diagnosis Log Tuesday,01,November,2016,20:27:15:27792
VIN: 3VW547AU7GM063637   License Plate: FLASH Mileage: 19991km-12421mi   Repair Order:
Chassis Type: AU (5Q0) Scan: 01 03 05 08 09 14 15 16 17 19 2B 32 42 44 47 52 55 5F 75 A9
VIN: 3VW547AU7GM063637   Mileage: 19991km-12421miles
01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 14-Susp. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 2B-Steer. Col. Lock -- Status: OK 0000 32-Differential Locks -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 75-Telematics -- Status: OK 0000 A9-Struct. Borne Sound -- Status: OK 0000 ------------------------------------------------------------------------------Address 01: Engine (J623-CXCB)       Labels: 06K-907-425-V1.clb   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B   Component: 2.0l R4 TFSI  H13 0002     Revision: --H13---       Coding: 091900122424002F1000   Shop #: WSC 00066 790 00202   ASAM Dataset: EV_ECM20TFS0205G0906259D 001003   ROD: EV_ECM20TFS0205G0906259D.rod   VCID: 2F2EC4567671DC3A15-807A
No fault code found. Readiness: 1110 1101
VCDS Self-Diagnosis Log Tuesday,01,November,2016,20:27:15:27792 Page 2
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-ESP-V1.clb   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C   Component: ESC           H32 0393     Revision: 00000000    Serial number: 50986000001546   Coding: 01FA6BA15426096F007D020341CA6880D62A9000408216B6004300D1C009   Shop #: WSC 01383 790 50316   ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033   ROD: EV_Brake1UDSContiMK100ESP_034_VW37.rod   VCID: 4BD6B0C6E2A9801A19-801E
------------------------------------------------------------------------------Address 05: Acc/Start Auth. (J518)       Labels: 5Q0-959-435.clb   Part No SW: 5Q0 959 435 A    HW: 5Q0 959 435    Component: VWKESSYMQB    021 0604     Revision: 00021000    Serial number: 0397278433   Coding: 030C0C   Shop #: WSC 01383 790 50316   ASAM Dataset: EV_KessyHellaMQBAB 002011   ROD: EV_KessyHellaMQBAB_002.rod   VCID: 3A38E502BD330992B2-806E
------------------------------------------------------------------------------Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A   Component: Climatronic   H03 1001     Revision: 00001K01       Coding: 00020014200100000005000012111402   Shop #: WSC 01383 790 50316   ASAM Dataset: EV_ACClimaBHBVW37X 003018   ROD: EV_ACClimaBHBVW37X_003_VW37.rod   VCID: 42C89DE2D5E34152EA-8016
VCDS Self-Diagnosis Log Tuesday,01,November,2016,20:27:15:27792 Page 3
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA   Component: BCM PQ37BOSCH 028 0162     Revision: --------    Serial number: 865817031601W7   Coding: 00110A464041A2E969E44000001407201800000000000000000000000000   Shop #: WSC 00066 790 00200   ASAM Dataset: EV_BodyContrModul1UDSBosc 015002   ROD: EV_BCMBOSCH_016_AU37.rod   VCID: 7AB82502FDB3C992F2-802E
   Control Unit For Wiper Motor:    Subsystem 1 - Part No SW: 5GM 955 119     HW: 5GM 955 119   Labels: 5QX-955-119-V1.CLB   Component: WWS    150906  043 0581    Serial number:         160404113719   Coding: 0E4DDD
   Rain Light Recognition Sensor:    Subsystem 2 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB   Component: RLHS  037 0059    Serial number: S4Y16M02D17H10M51S33   Coding: 90A8DD
   Sun Roof:    Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591    Component: J245 PS60.036  H06 0150    Serial number: 03691600812401160015   Coding: 181803
------------------------------------------------------------------------------Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A   Component: DAEMPFUNGS-SG H17 0120     Serial number: 06031641350156   ASAM Dataset: EV_DRCONTITEMIC 001019   ROD: EV_DRCONTITEMIC.rod   VCID: 373EFC368E2114FA4D-8062
VCDS Self-Diagnosis Log Tuesday,01,November,2016,20:27:15:27792 Page 4
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb   Part No SW: 5Q0 959 655 J    HW: 5Q0 959 655 J   Component: AirbagVW20    010 0830     Serial number: 003GCR04JUXF   Coding: 8CCCFC00000000005000001AC24800000065   Shop #: WSC 01383 790 50316   ASAM Dataset: EV_AirbaVW20SMEVW37X 002144   ROD: EV_AirbaVW20SMEVW37X_VW37.rod   VCID: 47DE8CF6FEC1647A3D-8012
   Occupant Detection:    Subsystem 1 - Part No SW: 4M0 959 339 B    HW: 4M0 959 339 B   Component: BF-Gewichtss.  H12 0021    Serial number: IBH000000000004XC7P+   Coding: 303131
   Side Sensor Driver Front:    Subsystem 2 - Part No SW: -----------    HW: 480 000 803 16   Component: SideSensor_Df  001 0887    Serial number: 3570000000087B85591Q   Coding: 2D2D2D
   Side Sensor Passenger Front:    Subsystem 3 - Part No SW: -----------    HW: 480 000 803 16   Component: SideSensor_Pf  001 0887    Serial number: 35800000000A3945791L   Coding: 2D2D2D
   Side Sensor Driver Rear:    Subsystem 4 - Part No SW: -----------    HW: 480 400 603 16   Component: SideSensor_Dr  001 6149    Serial number: 3510002AB1F35391E344   Coding: 2D2D2D
   Side Sensor Passenger Rear:    Subsystem 5 - Part No SW: -----------    HW: 480 400 603 16   Component: SideSensor_Pr  001 6149    Serial number: 3520002C91F3545142C%   Coding: 2D2D2D
   Front Sensor Driver:    Subsystem 6 - Part No SW: -----------    HW: 480 400 203 16   Component: FrontSensor_D  001 6149    Serial number: 3550002A11F93A0271C0   Coding: 2D2D2D
   Front Sensor Passenger:    Subsystem 7 - Part No SW: -----------    HW: 480 400 203 16   Component: FrontSensor_P  001 6149    Serial number: 3560002A31F93A04734%   Coding: 2D2D2D
VCDS Self-Diagnosis Log Tuesday,01,November,2016,20:27:15:27792 Page 5
------------------------------------------------------------------------------Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A   Component: Lenks.Modul   075 0195     Revision: FF033033    Serial number: 20160311400779   Coding: 0400   Shop #: WSC 66564 385 16448   ASAM Dataset: EV_SMLSVALEOMQB 001015   ROD: EV_SMLSVALEOMQB.rod   VCID: 04445BFA8F778F6298-8050
------------------------------------------------------------------------------Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb   Part No SW: 5G1 920 856 A    HW: 5G1 920 856 A   Component: KOMBI         342 6420     Coding: 0BAD0912B980CF0502086A001000000000000000   Shop #: WSC 00066 790 00200   ASAM Dataset: EV_DashBoardVDDMQBAB 009046   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod   VCID: 2C14D35A4767A72230-8078
------------------------------------------------------------------------------Address 19: CAN Gateway (J533)       Labels: 5Q0-907-530-V1.clb   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M   Component: GW MQB High   212 2246     Revision: --------    Serial number: 23021610802078   Coding: 0101000830085900FB00022B880F00000001050000000000000000000000   Shop #: WSC 00066 790 00199   ASAM Dataset: EV_GatewConti 013020   ROD: EV_GatewConti_013.rod   VCID: 79BA3A0EF8B5C28AFB-802C
   Multi Function Steering Wheel Control Module:    Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q   Component: E221__MFL-DC1  H11 0103    Serial number: 29150002567840105522   Coding: 30FFFF
VCDS Self-Diagnosis Log Tuesday,01,November,2016,20:27:15:27792 Page 6
Address 2B: Steer. Col. Lock (J764)       Labels: 5Q0-905-861.clb   Part No SW: 5Q0 905 861 A    HW: 5Q0 905 861 A   Component: ELV-MQBA      H01 0120     Revision: 00000000    Serial number: 16000046463002   Coding: 5500000000000000   Shop #: WSC 00066 790 00199   ASAM Dataset: EV_ELVMarquMQB 004111   ROD: EV_ELVMarquMQB_SK25.rod   VCID: 3424CB3A9F57FFE268-8060
------------------------------------------------------------------------------Address 32: Differential Locks (J492)       Labels: 0CQ-907-554.clb   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E   Component: Quersperre    H52 8042     Serial number: HA1-00013.01.16   Coding: 0001   Shop #: WSC 00000 000 00000   ASAM Dataset: EV_LockElectHA1VW37X 001007   ROD: EV_LockElectHA1VW37X.rod   VCID: 47DE8CF6FEC1647A3D-8012
------------------------------------------------------------------------------Address 42: Door Elect, Driver (J386)       Labels: 5QX-959-X93-42.clb   Part No SW: 5Q0 959 593 E    HW: 5Q0 959 593 B   Component: TSG FS        020 0041     Serial number: 2204160605020C   Coding: 003E13200000020000000000   Shop #: WSC 01383 790 50316   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003   ROD: EV_DCUDriveSideEWMAXCONT.rod   VCID: 43C698E6CAF9485AE1-8016
   Drivers Door Rear Control Module:    Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D   Component: Fond FHSG DRV  007 0002    Serial number: 00000000000012065310   Coding: 011000
VCDS Self-Diagnosis Log Tuesday,01,November,2016,20:27:15:27792 Page 7
Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H   Component: EPS_MQB_ZFLS  505 5063     Coding: 8102   Shop #: WSC 00066 790 00202   ASAM Dataset: EV_SteerAssisMQB 012140   ROD: EV_SteerAssisMQB_VW31.rod   VCID: 393AFA0EB835028ABB-806C
------------------------------------------------------------------------------Address 47: Sound System (J525)       Labels: None   Part No SW: 5Q0 035 456     HW: 5Q0 035 456    Component: MIB2_lite_amp H20 0150     Revision: 00000001    Serial number: VWZ8Z1FBA01MTET   Coding: 2200000000AAAAAA000000000000   Shop #: WSC 01383 790 50316   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003   ROD: EV_AMPMst12C1Gen2ALPI.rod   VCID: 6D921E5EBCFD6E2A67-8038
------------------------------------------------------------------------------Address 52: Door Elect, Pass. (J387)       Labels: 5QX-959-X92-52.clb   Part No SW: 5Q0 959 592 E    HW: 5Q0 959 592 B   Component: TSG BFS       020 0041     Serial number: 220416060505EK   Coding: 003E13200000020000000000   Shop #: WSC 01383 790 50316   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003   ROD: EV_DCUPasseSideEWMAXCONT.rod   VCID: 42C89DE2D5E34152EA-8016
   Passengers Rear Door Control Module:    Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D   Component: Fond FHSG PSG  007 0002    Serial number: 00000000000012331318   Coding: 091000
VCDS Self-Diagnosis Log Tuesday,01,November,2016,20:27:15:27792 Page 8
Address 55: Headlight Range (J745)       Labels: 7P6-907-357.clb   Part No SW: 7P6 907 357 D    HW: 7P6 907 357 A   Component: AFS-ECU       H07 0090     Revision: --------    Serial number: -------------   Coding: 021203010B000400   Shop #: WSC 01383 790 50316   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120   ROD: EV_HeadlRegulVWAFSMQB.rod   VCID: 40CC97EADBEF5342FC-8014
   Left Headlamp Power Output Stage:    Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB   Component: LeiMo links  H01 0004    Coding: 2E0000
   Right Headlamp Power Output Stage:    Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB   Component: LeiMo rechts  H01 0004    Coding: 2E0000
------------------------------------------------------------------------------Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb   Part No SW: 3Q0 035 876     HW: 3Q0 035 876    Component: MU-S-NS-US    820 0613     Serial number:                  Coding: 027300020000000051220002001808001F0203F401200105C6   Shop #: WSC 00066 790 00199   ASAM Dataset: EV_MUStd4CDELP 001001   ROD: EV_MUStd4CDELP_VW26.rod   VCID: 71AA022EA0C58ACA43-8024
   Operating And Display Unit 1:    Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605    Component: ABT_Std-2_Nav  H53 1031    Serial number: VWZ8Z9SJX00524
   Data medium:    Subsystem 2 - Part No SW: 3G0 919 866 R    HW: ----------   Component: NAR 2016  --- 0321    Serial number: -------------------
VCDS Self-Diagnosis Log Tuesday,01,November,2016,20:27:15:27792 Page 9
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb   Part No SW: 5QE 035 285 A    HW: 5QE 035 285 A   Component: OCULowMQBUS   007 0568     Coding: 02730002C2823A017F1E06000000   Shop #: WSC 00066 790 00199   ASAM Dataset: EV_OCULowMQB 001006   ROD: EV_OCULowMQB.rod   VCID: 43C698E6CAF9485AE1-8016
------------------------------------------------------------------------------Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb   Part No SW: 5G0 907 159     HW: 4H0 907 159 A   Component: SAS-GEN 2     H06 0014     Serial number: 160131202169   ASAM Dataset: EV_SoundActuaGen2AU64X 003010   ROD: EV_SoundActuaGen2AU64X_VW26.rod   VCID: 6B96104682E9601A79-803E
End----------(Elapsed Time: 01:38, VBatt start/end: 12.4V/12.3V)----------
MartinsX
Riga, Latvia
C?ID=268515
Could be easier to read if You use Notepad, not Word.
Boki Ar
Arandjelovac, Serbia
C?ID=57300
I agree. ReflexSilverMkVII please save txt. file using Notepad, please. :thumbs:
PetrolDave
Westbury, UK
C?ID=1423
Might be worth checking the Torque Steer Compensation value in Controller 44, Byte 0, Bits 2&3
00 = TSC inactive
04 = TSC with Learned Value active
08 = TSC without Learned Value active
To change these bits you would need to use the Security Access code of 19249.
ReflexSilverMkVII
C?ID=256588
On my computer when I saved the file, it created it as an ePDF, which opens in Microsoft Edge. I copied the information from that PDF and used "
] " when pasting into my reply. Do you just want me to copy and paste the information from the PDF into a notepad file and save as .txt? I'm sorry I have not had to post many times before and if I had remembered to click "Copy" instead of Save, I would have done that. IS there any way to get the formatting correct without doing another autoscan? I don't have my tool with me. The PDF's formatting looks perfect, its just when I copied and pasted text from the PDF that the formatting got awry. I can post a URL to view the autoscan PDF online as I can't figure out a way to convert the PDF to .txt.
UPDATE: Please let me know if this is better. I figured out a convoluted way to get it as close as I could to the PDF formatting. Hope this is better.
Dealer/Shop Name:
Self-Diagnosis Log
Revision: --H13---
   Coding: 030C0C
   Revision: 00001K01
Coding: 90A8DD
   Sun Roof:
Coding: 181803
   Occupant Detection:
Coding: 303131
   Coding: 0400
Coding: 30FFFF
   Coding: 0001
Coding: 011000
   Coding: 8102
Coding: 091000
Coding: 2E0000
Coding: 2E0000
   Subsystem 2 - Part No SW: 3G0 919 866 R    HW: ----------   Component: NAR 2016  --- 0321    Serial number: --------------------
End----------(Elapsed Time: 01:38, VBatt start/end: 12.4V/12.3V)-----------
Self-Diagnosis Log
Page 2
Self-Diagnosis Log
When you click [Save] in VCDS, it creates a plain text file. VCDS has no capability to create PDFs.
ReflexSilverMkVII
C?ID=256588
I'm not sure what happened. The file my computer generated is an "ePDF" and it opens in Microsoft Edge or Adobe as a PDF.
Try opening it using Notepad please.
ReflexSilverMkVII
C?ID=256588
It will open the file, but it turns into Japanese characters. I copied and pasted the below in a post a couple up. I figured out a way to convert the PDF to a Word document and keep the formatting, then save Word doc as .txt and it appears to be properly formatted. Will this be okay?
Dealer/Shop Name:
Self-Diagnosis Log
Revision: --H13---
   Coding: 030C0C
   Revision: 00001K01
Coding: 90A8DD
   Sun Roof:
Coding: 181803
   Occupant Detection:
Coding: 303131
   Coding: 0400
Coding: 30FFFF
   Coding: 0001
Coding: 011000
   Coding: 8102
Coding: 091000
Coding: 2E0000
Coding: 2E0000
Self-Diagnosis Log
Page 2
Self-Diagnosis Log
^^^^ Not quite optimal, but far more legible than it was. :thumbs: ^^^^
DV52
C?ID=194404
^^^^^^^^^^^^^ reflexsilverMkVII: Yep -some weird formatting issues with your auto-scan report! Anyhow, back to your original problem (equally weird), has it been resolved? If so - what was the fix? If not, have you done a steering angle sensor (G85) calibration? on the module @ address hex44? If you aren't sure how to do this, Andy (from RT) wrote-up the process HERE in response to another question. It's an easy try - so might be worth doing to "neutralize" the bias in your steering (notwithstanding that the module reports no DTCs in your auto-scan)
PS: Andy - can this calibration procedures be added to the Golf AU wiki page?
ReflexSilverMkVII
C?ID=256588
I tried the G85 reset steps and my car never flashed TPMS, steering light or any warnings at all. The controller just kept saying running as he mentioned in the post. I took the car out for a ride after and nothing really seemed any different. I also took off both front rims and played around to see if I could find any slack by shaking the hub/drop links and nothing budged, not even a mm. Do you know what someone may have referred to as a yaw sensor is exactly, and how I can recalibrate? They mentioned the dealer recalibrated in a matter of minutes and it fixed their issue with car not tracking straight, floaty steering, etc. This seemed to start after I had my car aligned and I'm not sure if they should have reset something or if there truly is a hardware issue that I can't find or the dealer. Thanks again for your help!
Here is a new autoscan. Hopefully I did right this time!
Wednesday,02,November,2016,19:56:36:27792
VCDS Version: 16.8.3.1 (x64)  HEX-NET CB: 0.4323.4
VIN: 3VW547AU7GM063637   Mileage: 20114km-12498miles
   Revision: --H13---
Readiness: 0010 0001
   Coding: 030C0C
   Revision: 00001K01
   Coding: 90A8DD
   Sun Roof:
   Coding: 181803
   Occupant Detection:
   Coding: 303131
   Coding: 0400
   Coding: 30FFFF
   Coding: 0001
   Coding: 011000
   Coding: 8102
   Coding: 091000
   Coding: 2E0000
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3G0 919 866 R    HW: -----------
End----------(Elapsed Time: 01:47, VBatt start/end: 14.1V/14.1V)-----------
DV52
C?ID=194404
ReflexSilverMkVII: OK, that's a little different than I had understood! If the steering wheel (itself) is centred, and the car has a systemic bias to one side, then it doesn't sound like a G85 problem. Is the car "crabbing" - perhaps a thrust axis problem with the wheel alignment (just guessing)?
ReflexSilverMkVII
C?ID=256588
The alignment specs look good, and it doesn't feel like its crabbing. The steering wheel literally feels like the assistance stops and the wheel tugs to the right a few degrees and becomes increasingly hard to steer back to the left to keep the car on the straight ahead. As I mentioned, this only seems to be an issue at lower speeds as I've not noticed it doing this over 40 mph. Someone mentioned the torque steer assist, but I'm not sure what exactly that does and what I'm supposed to do to alter it or check. I'm very new at using VCDS so it is all very complex to me and I don't quite know the lingo as well as most on here do, even though I'm trying to learn as quickly as possible. One final note to add, I noticed the steering wheel returns to center much faster and fully when steering to the left and letting the wheel go back to the right, when turning right and the wheel returning to center, it doesn't seem to be as fast or to return to center as quickly. With my car having been out of alignment, are there possibly some sensors that were used to the off specs and simply need to be reset? My car's been to VW twice and they didn't find anything wrong mechanically, but I never can trust the dealership fully to actually look at the car thoroughly and I simply don't have the time to go over there and sit all day to watch them do the work. Plus its pricey.
Oh, I also wanted to mention that this doesn't occur when I floor the car, it is literally a low speed, light throttle issue especially on crowned roads.
ReflexSilverMkVII
C?ID=256588
So, I'm wondering if there are any additional settings/steps needed to reset the steering angle sensor. The one thread I found on here about a Mk7 Golf did not induce any lights on my car as it said it would. I let it run for 1 minute and it just said "running". I have narrowed this issue down to a software/sensor problem. There are no loose nuts or bolts, no worn bushings, no torn CV boots, etc. I seriously think the problem is with this steering angle sensor, but it appears that following that one procedure doesn't do anything on this car. I took the car back to the dealership a third or fourth time and they said straight up "we won't do any software diagnosis without a fault code". Well that's great, they're no help as usual. This issue is extremely annoying in day to day driving. It makes the car feel like it darts all over the place without any steering inputs. Also, is there a procedure on MK7 cars to recalibrate steering end stop limit? I followed procedure I saw on older generations and it didn't seem to do anything either. Thanks for any help!
Tuesday,29,November,2016,16:14:43:27792
VCDS Version: 16.8.4.2 (x64) HEX-NET CB: 0.4323.4
Data version: 20161129 DS267.0
Mileage: 21887km-13599mi Repair Order:
Address 44: Steering Assist Labels: 5Q0-909-144.clb
Control Module Part Number: 3Q0 909 144 J HW: 3Q0 909 144 H
Component and/or Version: EPS_MQB_ZFLS 505 5063
Software Coding: 8102
Work Shop Code: WSC 00066 790 00202
ASAM Dataset: EV_SteerAssisMQB 012140 (VW37)
VCID: 393AFA0EB835028ACE-806C
16385 - Steering End Stops Not Learned
C10AC F0 [009] - Unknown Error Elaboration
Reset counter: 157
Mileage: 21887 km
Date: 2016.11.29
Time: 16:04:39
Motor status: 01
System status: Driving mode
Supply voltage: 14.00 V
Temperature: 36.0 °C
KFC: 40
KFA: 00 01
Environmental conditions: 5F
Rotorlagesensorspannung AMR Sinus: 0.857 V
Rotorlagesensorspannung AMR Kosinus: 8.813 V
Rotorlagesensorspannung AMR Sinus 2: 0.837 V
Rotorlagesensorspannung AMR Cosinus 2: 3.916 V
Rotorlagesensorspannung Hall 1: 0.0 V
Rotorlagesensorspannung Hall 2: 0.0 V
Aktueller Sinus-Offset für ASIC: -0.0 mV
Aktueller Cosinus-Offset für ASIC: -0.1 mV
aktuelle Sinusverstärkung für ASIC: 0.169
ReflexSilverMkVII
C?ID=256588
Uwe,
I now have this fault code and was wondering if you had any ideas on what to do in my MKVII GTI...
Thank you!
                    Reset counter: 157
                    Mileage: 21887 km
                    Date: 2016.11.29
                    Time: 16:04:39
                    Motor status: 01
                    KFC: 40
                    KFA: 00 01
