MK7 Golf Sound Aktuator retrofit
   #41
quailallstar
Florida & the Nation's Capital
C?ID=53119
Looked up
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,coded
ENG05986-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled
and they were already coded to coded/enabled. I must have checked these off right after I installed the unit and not remembered.
AdpLog.CSV files as promised below. Need me to email them over as well?
A9 Structure-borne Sound Adaptation Map
SW:5G0-907-159   HW:4H0-907-159-A ---  Struct. Borne Sound
Component:SAS-GEN 2     H06 0014	 Coding:
EV_SoundActuaGen2AU64X	3010	EV_SoundActuaGen2AU64X_VW26.rod
Friday	12	May	2017	12:42:42:39394
VCDS Version: Release 17.1.3 (x64)  Data version: 20170320 DS267.7
VCID: 6BDFB9BF821C12192C-803E
IDE04472-Volume of structure-borne noise actuator	100.00%
Elapsed Time: 00:00
19 Can Gateway Adaptation Map
SW:5Q0-907-530-AJ   HW:5Q0-907-530-M ---  CAN Gateway
Component:GW MQB High   212 2246	 Coding:0901000830085900FB00000A1C0F00000001050000000000000000000000
EV_GatewConti	13020	EV_GatewConti_013.rod
Friday	12	May	2017	12:41:43:39394
VCID: 79F393F7F840B089AE-802C
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys	Deactivating
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation	Deactivating
IDE00002-Transport mode	not active
IDE00820-Activating and deactivating all development messages	not active
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation	12.1 V
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering	12.1 V
IDE01211-Static current measuring mode	not activated
IDE01457-Energy management deactivation stage	Mode not active
IDE01459-Energy management heat output control status	Mode not active
IDE01844-Increase idle speed request	Mode not active
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time	--
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation	Mode not active
IDE01860-Generator specified voltage value variable	10.6 V
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1	coded
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module	coded
IDE01996-SFT00003-Installation list: specified installations-Brakes 1	coded
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side	Not coded
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning	coded
IDE01996-SFT00009-Installation list: specified installations-Central Electrics	coded
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater	Not coded
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1	Not coded
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control	Not coded
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics	Not coded
IDE01996-SFT00021-Installation list: specified installations-Airbag	coded
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics	coded
IDE01996-SFT00023-Installation list: specified installations-Dash Board	coded
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater	Not coded
IDE01996-SFT00025-Installation list: specified installations-Gateway	1
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection	Not coded
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance	Not coded
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control	Not coded
IDE01996-SFT00035-Installation list: specified installations-Brake Boost	Not coded
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control	Not coded
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking	coded
IDE01996-SFT00048-Installation list: specified installations-Special Function 2	Not coded
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics	Not coded
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side	Not coded
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant	Not coded
IDE01996-SFT00061-Installation list: specified installations-Special Function	Not coded
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor	Not coded
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side	coded
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance	coded
IDE01996-SFT00071-Installation list: specified installations-Sound System	Not coded
IDE01996-SFT00075-Installation list: specified installations-Multifunction module	Not coded
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module	Not coded
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side	coded
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation	coded
IDE01996-SFT00086-Installation list: specified installations-Radio	Not coded
IDE01996-SFT00087-Installation list: specified installations-TV Tuner	Not coded
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1	coded
IDE01996-SFT00096-Installation list: specified installations-Tachograph	Not coded
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1	Not coded
IDE01996-SFT00105-Installation list: specified installations-Trailer Function	Not coded
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View	Not coded
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit	Not coded
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit	coded
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance	Not coded
IDE01996-SFT00128-Installation list: specified installations-Batterieregelung Zusatzspeicher 1	Not coded
IDE01996-SFT00130-Installation list: specified installations-Head Up Display	Not coded
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module	Not coded
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System	Not coded
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit	Not coded
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound	coded
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface	coded
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side	Not coded
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side	Not coded
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management	Not coded
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left	Not coded
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right	Not coded
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise	Not coded
IDE01996-SFT00197-Installation list: specified installations-Thermal management	Not coded
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module	Not coded
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof	Not coded
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2	Not coded
IDE01996-ENG118226-Installation list: specified installations-Node_0x01	Not coded
IDE01996-ENG118227-Installation list: specified installations-Node_0x02	Not coded
IDE01996-ENG118228-Installation list: specified installations-Node_0x03	Not coded
IDE01996-ENG118229-Installation list: specified installations-Node_0x04	Not coded
IDE01996-ENG118230-Installation list: specified installations-Node_0x05	Not coded
IDE01996-ENG118231-Installation list: specified installations-Node_0x06	Not coded
IDE01996-ENG118232-Installation list: specified installations-Node_0x07	Not coded
IDE01996-ENG118233-Installation list: specified installations-Node_0x08	Not coded
IDE01996-ENG118234-Installation list: specified installations-Node_0x09	Not coded
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D	Not coded
IDE01996-ENG118236-Installation list: specified installations-Node_0x11	Not coded
IDE01996-ENG118237-Installation list: specified installations-Node_0x16	Not coded
IDE01996-ENG118238-Installation list: specified installations-Node_0x17	Not coded
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A	Not coded
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D	Not coded
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F	Not coded
IDE01996-ENG118243-Installation list: specified installations-Node_0x20	Not coded
IDE01996-ENG118244-Installation list: specified installations-Node_0x21	Not coded
IDE01996-ENG118245-Installation list: specified installations-Node_0x22	Not coded
IDE01996-ENG118246-Installation list: specified installations-Node_0x24	Not coded
IDE01996-ENG118247-Installation list: specified installations-Node_0x25	Not coded
IDE01996-ENG118248-Installation list: specified installations-Node_0x26	Not coded
IDE01996-ENG118249-Installation list: specified installations-Node_0x27	Not coded
IDE01996-ENG118250-Installation list: specified installations-Node_0x28	Not coded
IDE01996-ENG118251-Installation list: specified installations-Node_0x29	Not coded
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A	Not coded
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E	Not coded
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F	Not coded
IDE01996-ENG118255-Installation list: specified installations-Node_0x35	Not coded
IDE01996-ENG118256-Installation list: specified installations-Node_0x36	Not coded
IDE01996-ENG118257-Installation list: specified installations-Node_0x37	Not coded
IDE01996-ENG118258-Installation list: specified installations-Node_0x38	Not coded
IDE01996-ENG118259-Installation list: specified installations-Node_0x39	Not coded
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A	Not coded
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C	Not coded
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D	Not coded
IDE01996-ENG118263-Installation list: specified installations-Node_0x40	Not coded
IDE01996-ENG118264-Installation list: specified installations-Node_0x41	Not coded
IDE01996-ENG118265-Installation list: specified installations-Node_0x43	Not coded
IDE01996-ENG118266-Installation list: specified installations-Node_0x45	Not coded
IDE01996-ENG118267-Installation list: specified installations-Node_0x48	Not coded
IDE01996-ENG118268-Installation list: specified installations-Node_0x49	Not coded
IDE01996-ENG118269-Installation list: specified installations-Node_0x51	Not coded
IDE01996-ENG118270-Installation list: specified installations-Node_0x52	Not coded
IDE01996-ENG118271-Installation list: specified installations-Node_0x53	Not coded
IDE01996-ENG118272-Installation list: specified installations-Node_0x55	Not coded
IDE01996-ENG118273-Installation list: specified installations-Node_0x56	Not coded
IDE01996-ENG118274-Installation list: specified installations-Node_0x58	Not coded
IDE01996-ENG118275-Installation list: specified installations-Node_0x59	Not coded
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A	Not coded
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B	Not coded
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C	Not coded
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D	Not coded
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E	Not coded
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F	Not coded
IDE01996-ENG118282-Installation list: specified installations-Node_0x60	Not coded
IDE01996-ENG118283-Installation list: specified installations-Node_0x61	Not coded
IDE01996-ENG118284-Installation list: specified installations-Node_0x62	Not coded
IDE01996-ENG118285-Installation list: specified installations-Node_0x66	Not coded
IDE01996-ENG118286-Installation list: specified installations-Node_0x68	Not coded
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B	Not coded
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C	Not coded
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E	Not coded
IDE01996-ENG118290-Installation list: specified installations-Node_0x74	Not coded
IDE01996-ENG118291-Installation list: specified installations-Node_0x75	Not coded
IDE01996-ENG118292-Installation list: specified installations-Node_0x78	Not coded
IDE01996-ENG118293-Installation list: specified installations-Node_0x79	Not coded
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A	Not coded
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D	Not coded
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E	Not coded
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F	Not coded
IDE01996-ENG118298-Installation list: specified installations-Node_0x80	Not coded
IDE01996-ENG118299-Installation list: specified installations-Node_0x81	Not coded
IDE01996-ENG118300-Installation list: specified installations-Node_0x82	Not coded
IDE01996-ENG118301-Installation list: specified installations-Node_0x83	Not coded
IDE01996-ENG118302-Installation list: specified installations-Node_0x85	Not coded
IDE01996-ENG118303-Installation list: specified installations-Node_0x86	Not coded
IDE01996-ENG118304-Installation list: specified installations-Node_0x87	Not coded
IDE01996-ENG118305-Installation list: specified installations-Node_0x88	Not coded
IDE01996-ENG118306-Installation list: specified installations-Node_0x89	Not coded
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B	Not coded
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C	Not coded
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D	Not coded
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E	Not coded
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F	Not coded
IDE01996-ENG118312-Installation list: specified installations-Node_0x90	Not coded
IDE01996-ENG118313-Installation list: specified installations-Node_0x91	Not coded
IDE01996-ENG118314-Installation list: specified installations-Node_0x92	Not coded
IDE01996-ENG118315-Installation list: specified installations-Node_0x93	Not coded
IDE01996-ENG118316-Installation list: specified installations-Node_0x94	Not coded
IDE01996-ENG118317-Installation list: specified installations-Node_0x95	Not coded
IDE01996-ENG118318-Installation list: specified installations-Node_0x96	Not coded
IDE01996-ENG118319-Installation list: specified installations-Node_0x97	Not coded
IDE01996-ENG118320-Installation list: specified installations-Node_0x98	Not coded
IDE01996-ENG118321-Installation list: specified installations-Node_0x99	Not coded
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A	Not coded
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B	Not coded
IDE01996-ENG118324-Installation list: specified installations-Node_0x9C	Not coded
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D	Not coded
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E	Not coded
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F	Not coded
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0	Not coded
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1	Not coded
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2	Not coded
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3	Not coded
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5	Not coded
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6	Not coded
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7	Not coded
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8	Not coded
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA	Not coded
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB	Not coded
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC	Not coded
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD	Not coded
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF	Not coded
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0	Not coded
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1	Not coded
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2	Not coded
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3	Not coded
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4	Not coded
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5	Not coded
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6	Not coded
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7	Not coded
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8	Not coded
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9	Not coded
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA	Not coded
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB	Not coded
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC	Not coded
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD	Not coded
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE	Not coded
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF	Not coded
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0	Not coded
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1	Not coded
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2	Not coded
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3	Not coded
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4	Not coded
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5	Not coded
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6	Not coded
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7	Not coded
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8	Not coded
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9	Not coded
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA	Not coded
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB	Not coded
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC	Not coded
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD	Not coded
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE	Not coded
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF	Not coded
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0	Not coded
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1	Not coded
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2	Not coded
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3	Not coded
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4	Not coded
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5	Not coded
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6	Not coded
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7	Not coded
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8	Not coded
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9	Not coded
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA	Not coded
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB	Not coded
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC	Not coded
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD	Not coded
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE	Not coded
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF	Not coded
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0	Not coded
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1	Not coded
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2	Not coded
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3	Not coded
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4	Not coded
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5	Not coded
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6	Not coded
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7	Not coded
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8	Not coded
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9	Not coded
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA	Not coded
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB	Not coded
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC	Not coded
IDE01996-ENG118405-Installation list: specified installations-Node_0xED	Not coded
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE	Not coded
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF	Not coded
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0	Not coded
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1	Not coded
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2	Not coded
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3	Not coded
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4	Not coded
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5	Not coded
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6	Not coded
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7	Not coded
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8	Not coded
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9	Not coded
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA	Not coded
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB	Not coded
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC	Not coded
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD	Not coded
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE	Not coded
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF	Not coded
IDE02200-Component protection showroom mode	not active
IDE02332-Deactivate production mode	0
IDE03256-MAS06105-Battery adaptation-Rated battery capacity	60 Ah
IDE03256-MAS06106-Battery adaptation-Battery technology	Wet
IDE03256-MAS06107-Battery adaptation-Battery manufacturer	JCB
IDE03256-MAS06108-Battery adaptation-Battery Serial Number	1111111111
IDE03903-Production process data 1	00 00
IDE04159-Deactivation of start-stop function	Mode not active
IDE04186-Battery terminal recognition	connected
IDE04330-Transfer of release code for a SWaP function	0
IDE04331-Selection of release codes for a SWaP function	FF FF FF FF
IDE06425-MAS06026-Roller test bench mode: functional-Activation stages	not activated
IDE06425-MAS06277-Roller test bench mode: functional-Malfunction states	no error
IDE06530-Distance left for deactivation of static current measuring mode	2
IDE06541-Distance left for deactivation of transport mode	50
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof	activated
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM	activated
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start	activated
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch)	activated
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system	activated
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system	activated
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof	not activated
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D	activated
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill	activated
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button)	activated
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill	activated
IDE06753-MAS06289-Efficiency program display-Comfort use A/C	activated
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater	activated
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater	activated
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater	activated
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation	activated
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater	activated
IDE06753-MAS06295-Efficiency program display-Comfort use fog light	activated
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light	not activated
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission	activated
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater	activated
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater	activated
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater	activated
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater	not activated
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation	activated
IDE07838-Counter for inconsistent states	0
IDE08348-Start/stop start voltage limit	7.6 V
IDE08624-MKE Check box	activated
IDE10735-Number requests autonomous recharging	3
IDE10736-Cyclization limitation request battery service	0
IDE10748-MAS11262-Range gain-Range gain AC system	activated
IDE10748-MAS11263-Range gain-Range gain auxiliary heater	activated
IDE10748-MAS11264-Range gain-Range gain window defogger	activated
IDE10748-MAS11265-Range gain-Range gain seat heater front	activated
IDE10748-MAS11266-Range gain-Range gain front set ventilation	activated
IDE10748-MAS11267-Range gain-Range gain rear heater	activated
IDE10748-MAS11268-Range gain-Range gain fog light	activated
IDE10748-MAS11269-Range gain-Range gain rear fog light	activated
IDE10748-MAS11270-Range gain-Range gain windshield heating	activated
IDE10748-MAS11271-Range gain-Range gain steering wheel heater	activated
IDE10748-MAS11272-Range gain-Range gain mirror heater	activated
IDE10748-MAS11273-Range gain-Range gain rear seat heater	not activated
IDE10748-MAS11274-Range gain-Range gain rear seat heater	activated
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system	not activated
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system	activated
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption	not activated
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain	activated
IDE10748-MAS11279-Range gain-List at engine still stand	activated
IDE10748-MAS12689-Range gain-Catalogue range display	activated
IDE10748-MAS12690-Range gain-Loading condition catalogue range display	activated
IDE10748-MAS13161-Range gain-Listendarstellung Absolutwerte mit Gewichtung	activated
ENG125878-ENG125896-AGW_Calibration-AGW_Brightness_Start_Sequence	100%
ENG125878-ENG126255-AGW_Calibration-AGW_fade_in_deactivation_threshold	100
ENG125878-ENG125890-AGW_Calibration-AGW_Time_Fade_In	0 ms
ENG125878-ENG125892-AGW_Calibration-AGW_Time_Fade_In_Start	0 ms
ENG125878-ENG125891-AGW_Calibration-AGW_Time_Fade_Out	0 ms
ENG125878-ENG125893-AGW_Calibration-AGW_Time_Fade_Out_Start	0 ms
ENG125878-ENG125895-AGW_Calibration-AGW_Time_Start_Delay	0 ms
ENG125878-ENG125894-AGW_Calibration-AGW_Time_Start_Sequence	0 ms
ENG125879-ENG125897-AGW_Function_Releases-AGW_Enabling_Brightness	active
ENG125879-ENG125898-AGW_Function_Releases-AGW_Enabling_Flash_Frequency	active
ENG125879-ENG125899-AGW_Function_Releases-AGW_Enabling_Supression_Symbol	active
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset	active
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation	100
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation	60000 ms
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation	10000 ms
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption	3000 ms
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption	0 ms
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation	180000 ms
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation	1500 ms
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation	800 ms
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption	2500 ms
ENG05988-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen	Mode not active
ENG05988-ENG98711-EM_energy_management_warning_displays-Charge level	Mode not active
ENG05988-ENG113873-EM_energy_management_warning_displays-Generatormeldungen	Mode not active
ENG05988-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen	Mode not active
ENG06003-EM_heating_power_quota_adjustment	1000 W
ENG05989-EM_nominal_voltage_limitation_low_beams	12.1 V
ENG05992-EM_requirement_cyclic_time_voltage_measurement	0 s
ENG05991-EM_requirement_reduction_air_blowers	Mode not active
ENG05990-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature	-50.0 °C
ENG05990-ENG06027-EM_start_stop_requirement_ambient_temperature-Minimum_temperature	-50.0 °C
ENG05986-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1	Enabled
ENG05986-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module	Enabled
ENG05986-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1	not enabled
ENG05986-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side	Enabled
ENG05986-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning	Enabled
ENG05986-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics	Enabled
ENG05986-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1	Enabled
ENG05986-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control	Enabled
ENG05986-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics	Enabled
ENG05986-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag	not enabled
ENG05986-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics	Enabled
ENG05986-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board	Enabled
ENG05986-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater	Enabled
ENG05986-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway	Enabled
ENG05986-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection	Enabled
ENG05986-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance	Enabled
ENG05986-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control	Enabled
ENG05986-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost	Enabled
ENG05986-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control	Enabled
ENG05986-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking	Enabled
ENG05986-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2	Enabled
ENG05986-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics	Enabled
ENG05986-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side	Enabled
ENG05986-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant	Enabled
ENG05986-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function	Enabled
ENG05986-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor	Enabled
ENG05986-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side	Enabled
ENG05986-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance	Enabled
ENG05986-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System	Enabled
ENG05986-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module	Enabled
ENG05986-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side	Enabled
ENG05986-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation	Enabled
ENG05986-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio	Enabled
ENG05986-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner	Enabled
ENG05986-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1	Enabled
ENG05986-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph	Enabled
ENG05986-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1	Enabled
ENG05986-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function	Enabled
ENG05986-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View	Enabled
ENG05986-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit	Enabled
ENG05986-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit	Enabled
ENG05986-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance	Enabled
ENG05986-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module	Enabled
ENG05986-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System	Enabled
ENG05986-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit	Enabled
ENG05986-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound	Enabled
ENG05986-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface	Enabled
ENG05986-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side	Enabled
ENG05986-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side	Enabled
ENG05986-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management	Enabled
ENG05986-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left	Enabled
ENG05986-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right	Enabled
ENG05986-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise	Enabled
ENG05986-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management	Enabled
ENG05986-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module	Enabled
ENG05986-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof	Enabled
ENG05986-SFT09787-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2	Enabled
ENG05986-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00	Enabled
ENG05986-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01	Enabled
ENG05986-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02	Enabled
ENG05986-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03	Enabled
ENG05986-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04	Enabled
ENG05986-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05	Enabled
ENG05986-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06	Enabled
ENG05986-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07	Enabled
ENG05986-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08	Enabled
ENG05986-ENG118474-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x09	Enabled
ENG05986-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D	Enabled
ENG05986-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11	Enabled
ENG05986-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16	Enabled
ENG05986-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17	Enabled
ENG05986-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A	Enabled
ENG05986-ENG118480-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1B	Enabled
ENG05986-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D	Enabled
ENG05986-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F	Enabled
ENG05986-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20	Enabled
ENG05986-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21	Enabled
ENG05986-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22	Enabled
ENG05986-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24	Enabled
ENG05986-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25	Enabled
ENG05986-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26	Enabled
ENG05986-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27	Enabled
ENG05986-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28	Enabled
ENG05986-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29	Enabled
ENG05986-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A	Enabled
ENG05986-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E	Enabled
ENG05986-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F	Enabled
ENG05986-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35	Enabled
ENG05986-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36	Enabled
ENG05986-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37	Enabled
ENG05986-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38	Enabled
ENG05986-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39	Enabled
ENG05986-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A	Enabled
ENG05986-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C	Enabled
ENG05986-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D	Enabled
ENG05986-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40	Enabled
ENG05986-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41	Enabled
ENG05986-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43	Enabled
ENG05986-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45	Enabled
ENG05986-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48	Enabled
ENG05986-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49	Enabled
ENG05986-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51	Enabled
ENG05986-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52	Enabled
ENG05986-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53	Enabled
ENG05986-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55	Enabled
ENG05986-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56	Enabled
ENG05986-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58	Enabled
ENG05986-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59	Enabled
ENG05986-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A	Enabled
ENG05986-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B	Enabled
ENG05986-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C	Enabled
ENG05986-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D	Enabled
ENG05986-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E	Enabled
ENG05986-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F	Enabled
ENG05986-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60	Enabled
ENG05986-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61	Enabled
ENG05986-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62	Enabled
ENG05986-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66	Enabled
ENG05986-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68	Enabled
ENG05986-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B	Enabled
ENG05986-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C	Enabled
ENG05986-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E	Enabled
ENG05986-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74	Enabled
ENG05986-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75	Enabled
ENG05986-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78	Enabled
ENG05986-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79	Enabled
ENG05986-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A	Enabled
ENG05986-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D	Enabled
ENG05986-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E	Enabled
ENG05986-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F	Enabled
ENG05986-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80	Enabled
ENG05986-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81	Enabled
ENG05986-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82	Enabled
ENG05986-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83	Enabled
ENG05986-ENG118542-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x85	Enabled
ENG05986-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86	Enabled
ENG05986-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87	Enabled
ENG05986-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88	Enabled
ENG05986-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89	Enabled
ENG05986-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B	Enabled
ENG05986-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C	Enabled
ENG05986-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D	Enabled
ENG05986-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E	Enabled
ENG05986-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F	Enabled
ENG05986-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90	Enabled
ENG05986-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91	Enabled
ENG05986-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92	Enabled
ENG05986-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93	Enabled
ENG05986-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94	Enabled
ENG05986-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95	Enabled
ENG05986-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96	Enabled
ENG05986-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97	Enabled
ENG05986-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98	Enabled
ENG05986-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99	Enabled
ENG05986-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A	Enabled
ENG05986-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B	Enabled
ENG05986-ENG118564-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9C	Enabled
ENG05986-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D	Enabled
ENG05986-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E	Enabled
ENG05986-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F	Enabled
ENG05986-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0	Enabled
ENG05986-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1	Enabled
ENG05986-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2	Enabled
ENG05986-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3	Enabled
ENG05986-ENG118572-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA4	Enabled
ENG05986-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5	Enabled
ENG05986-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6	Enabled
ENG05986-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7	Enabled
ENG05986-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8	Enabled
ENG05986-ENG118577-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA9	Enabled
ENG05986-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA	Enabled
ENG05986-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB	Enabled
ENG05986-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC	Enabled
ENG05986-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD	Enabled
ENG05986-ENG118582-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAE	Enabled
ENG05986-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF	Enabled
ENG05986-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0	Enabled
ENG05986-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1	Enabled
ENG05986-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2	Enabled
ENG05986-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3	Enabled
ENG05986-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4	Enabled
ENG05986-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5	Enabled
ENG05986-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6	Enabled
ENG05986-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7	Enabled
ENG05986-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8	Enabled
ENG05986-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9	Enabled
ENG05986-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA	Enabled
ENG05986-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB	Enabled
ENG05986-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC	Enabled
ENG05986-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD	Enabled
ENG05986-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE	Enabled
ENG05986-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF	Enabled
ENG05986-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0	Enabled
ENG05986-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1	Enabled
ENG05986-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2	Enabled
ENG05986-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3	Enabled
ENG05986-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4	Enabled
ENG05986-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5	Enabled
ENG05986-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6	Enabled
ENG05986-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7	Enabled
ENG05986-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8	Enabled
ENG05986-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9	Enabled
ENG05986-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA	Enabled
ENG05986-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB	Enabled
ENG05986-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC	Enabled
ENG05986-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD	Enabled
ENG05986-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE	Enabled
ENG05986-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF	Enabled
ENG05986-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0	Enabled
ENG05986-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1	Enabled
ENG05986-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2	Enabled
ENG05986-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3	Enabled
ENG05986-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4	Enabled
ENG05986-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5	Enabled
ENG05986-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6	Enabled
ENG05986-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7	Enabled
ENG05986-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8	Enabled
ENG05986-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9	Enabled
ENG05986-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA	Enabled
ENG05986-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB	Enabled
ENG05986-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC	Enabled
ENG05986-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD	Enabled
ENG05986-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE	Enabled
ENG05986-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF	Enabled
ENG05986-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0	Enabled
ENG05986-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1	Enabled
ENG05986-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2	Enabled
ENG05986-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3	Enabled
ENG05986-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4	Enabled
ENG05986-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5	Enabled
ENG05986-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6	Enabled
ENG05986-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7	Enabled
ENG05986-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8	Enabled
ENG05986-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9	Enabled
ENG05986-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA	Enabled
ENG05986-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB	Enabled
ENG05986-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC	Enabled
ENG05986-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED	Enabled
ENG05986-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE	Enabled
ENG05986-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF	Enabled
ENG05986-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0	Enabled
ENG05986-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1	Enabled
ENG05986-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2	Enabled
ENG05986-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3	Enabled
ENG05986-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4	Enabled
ENG05986-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5	Enabled
ENG05986-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6	Enabled
ENG05986-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7	Enabled
ENG05986-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8	Enabled
ENG05986-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9	Enabled
ENG05986-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA	Enabled
ENG05986-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB	Enabled
ENG05986-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC	Enabled
ENG05986-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD	Enabled
ENG05986-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE	Enabled
ENG05986-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF	Enabled
ENG05987-ENG118464-GW_mirror_mode-mirror_mode_bus	Databus drivetrain
ENG05987-ENG118465-GW_mirror_mode-mirror_mode_typ	not active
ENG05993-GW_routing_0	00 00 00 00 00 00 00 00 00 00 00 00
ENG05994-GW_routing_1	00 00 00 00 00 00 00 00 00 00 00 00
ENG05995-GW_routing_2	00 00 00 00 00 00 00 00 00 00 00 00
ENG05996-GW_routing_3	00 00 00 00 00 00 00 00 00 00 00 00
ENG05997-GW_routing_4	00 00 00 00 00 00 00 00 00 00 00 00
ENG05998-GW_routing_5	00 00 00 00 00 00 00 00 00 00 00 00
ENG05999-GW_routing_6	00 00 00 00 00 00 00 00 00 00 00 00
ENG06000-GW_routing_7	00 00 00 00 00 00 00 00 00 00 00 00
ENG06001-GW_routing_8	00 00 00 00 00 00 00 00 00 00 00 00
ENG06002-GW_routing_9	00 00 00 00 00 00 00 00 00 00 00 00
ENG118779-ENG118724-Multi_function_steering_wheel_control_module Coding Value-development_1	active
ENG118779-ENG118725-Multi_function_steering_wheel_control_module Coding Value-development_2	not active
ENG118779-ENG118722-Multi_function_steering_wheel_control_module Coding Value-Temp Sensor	not installed
ENG118779-ENG109457-Multi_function_steering_wheel_control_module Coding Value-Tiptronic	installed
ENG118774-WakeUpMonitor_Activation	activated
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events	100
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events	12 s
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay	0 s
Elapsed Time: 00:27
Same A9 fault continues to come up
   Serial number: 150929202770
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
0005 - Incorrect Vehicle Type
          U10D9 00 [009] - -
Dana
Western PA, USA
No it didn't :( .. but "Incorrect Vehicle Type" might be a software issue, meaning that A9 just isn't going to work with this 1.8T.
"IDE01996-SFT00071-Installation list: specified installations-Sound System Not coded " so I don't have an explanation for the new sound system DTC that appeared in #19 (U106A/131695 - Digital sound System control module - No Communication per this scan). I could try turning that (IDE01996-SFT00071) off in my car with factory amp to see if I get an incorrectly coded DTC just to rule out a bug in VCDS data.
quailallstar
C?ID=53119
You might be correct about it just not working for this 1.8T. Total bummer... In post #22 @NEtech mentioned someting about sourcing a Sound Aktuator off SEAT which is used in the 1.8T - which model is anyones guess???
[/URL]
Or maybe you should have tried from Seat:
Part No SW: 5F0 907 159 A HW: 4H0 907 159 A (used for 1.8l R4 TFSI)
Part No SW: 5F0 907 159 HW: 4H0 907 159 A (used for R4 2.0l EDC)
Part No SW: 5F0 907 159 B HW: 4H0 907 159 A (used for 2.0l R4 TFSI)
Part No SW: 5F0 907 159 C HW: 4H0 907 159 A (used for 2.0l R4 TFSI)
About the sound system error I too have no idea why that showed up. I removed the instilation list item off and the DTC went away. My amp and sound system are working fine.
Although not a TSI - this SEAT owner installed on into his TDI without issues.
http://www.clubseatleon.net/viewtopic.php?f=40&t=117000
BRICO - sound installation actuator motor
Noteby red 18 Apr 2016, 15:01
Hey guys, I leave a new brico to encourage anyone who wants to ride the sound aktuador the Cupra and some other engine variant.
for this we need:
PBX: 5F0907159 B
loudspeaker 's : D 4H0907601
support unit: 5F0907591
speaker stand: 5F0906559 B
unit connector: 4F0973706
speaker connector:
4 nuts m6
two screws m6 about 2.5cm
wiring (all of 0.35mm ), consists of:
two twisted wires to line connected to the line can can motor (orange - black / orange - brown)
2 speaker cables
2 wire feed (positive and negative)
location: holder unit: the control unit (hard on one side and enters pressing on the other easily): Speaker solid support: speaker solid: 1st step will place the stand unit, for this we will lift the poliespam of the side, rubber and staples to get inside the hollow (left) now let's move the power cables and the can line the inside top of the battery have access out there, for it we removed the cover grommet once we lines placed into the hole connectors and connect the ECUs speaker
speaker connection and unit:
pin 1 speaker to pin 1 of the control
pin 2 speaker to pin 2 of the control
positive to pin 3 of the control
negative pin 4 the unit
can H to pin 6 of the control unit
can L to pin 5 of the switchboard
I used tape to make it more OEM :and:
once connected all the vag com we can only discharge the switchboard A9:
stg19 gateway> list of facilities> we enable A9 - struct borne sound
delete 1 Fault in module 19 and 2 on the A9 .... and voila! ... if all is well again not to bug
Andy
Sector 7G
HC424490
Have you tried opening up the soundaktor box to see what's inside? I wonder if there are jumpers or other clues.
   #46
quailallstar
Florida & the Nation's Capital
C?ID=53119
The actual noise maker looks like this inside
attachment.php
The control module I can't find a picture of one taken apart
   #47
Andy
Sector 7G
HC424490
If it were me, I'd pop open this part to see what the guts look like:
   #48
iichel
Netherlands, eastern part
C?ID=284912
CAN chip, DAC driver / amplifier for the 'speaker'
   #49
quailallstar
C?ID=53119
I've been thinking about this. Hear me out... What if this isn't working because my vehicle by default is not programmed to have Driver Profile Selection from the factory? Wonder if this being enabled (switch or no switch) would allow the unit to function?
   #50
Dana
Western PA, USA
I have not messed with my CAN GW (try to do that tonight) but I located 3 Seat scans with "5F0 907 159 A" SW #s in our emails. I can't share the complete scans but:
  1. Code:
    Model	leon fr
    LE
    Date of production	11.04.2013
    Year	2013
    Sales type	5F15D5
    Engine Code	CJSA
    Transmission Code	PNC
    > Address 01: Engine (J623-CJSA)       Labels: None
    >     Part No SW: 8V0 906 264 B    HW: 06K 907 425 A
    >     Component: 1.8l R4 TFSI  H07 0001
    >     Revision: --H07---
    >     Coding: 0B2500322424010B0000
    >     Shop #: WSC 00049 770 00127
    >     ASAM Dataset: EV_ECM18TFS0218V0906264B 001001
    > Address 19: CAN Gateway (J533)       Labels: None
    >     Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
    >     Component: GW MQB High   125 1109
    >     Coding: 030100F42B085800EF0006E81C0F00010001000000000000000000000000
    >     Shop #: WSC 00049 770 00101
    >     ASAM Dataset: EV_GatewLear 006010
    >     ROD: EV_GatewLear_AU37.rod
    > Address A9: Struct. Borne Sound (J869)       Labels: None
    >     Component: SAS-GEN 2     H06 0001
    >     ROD: EV_SoundActuaGen2AU64X.rod
  2. Code:
    Model	leon fr
    LE
    Date of production	17.04.2013
    Year	2013
    Sales type	5F15D5
    Engine Code	CJSA
    >     Revision: --H07---
    >     Shop #: WSC 00049 770 00129
    >     Shop #: WSC 00049 770 00105
    >     ROD: EV_GatewConti_VW37.rod
    > Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
    >     Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
    >     Component: MQB_MFK       H05 0050
    >     Coding: 0100010001000004000500000000000100
    >     ASAM Dataset: EV_MFKBoschAU370 001001
  3. Code:
    Model	leon st x-perience
    LE
    Date of production	31.07.2014
    Year	2015
    Sales type	5F88DT
    Engine Code	CJSB
    Transmission Code	QSM
    > Address 01: Engine (J623-CJSB)       Labels: None
    >     Part No SW: 8V0 906 264 E    HW: 06K 907 425 A
    >     Component: 1.8l R4 TFSI  H09 0002
    >     Revision: --H09---
    >     Coding: 339D00322426010B0000
    >     ASAM Dataset: EV_ECM18TFS0218V0906264E 001003
    >     Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 E
    >     Component: GW MQB Mid    127 1204
    >     Coding: 030100F42F085900EF0002681C0F00010001050000000000000000000000
    >     Shop #: WSC 00049 770 00102
    >     ASAM Dataset: EV_GatewLear 011020
    >     ROD: EV_GatewLear_SE37.rod
    >     Component: SAS-GEN 2     H06 0002
The complete chassis codes, production dates and modules may help if you shoot for another module.
cbx750p
Singapore
C?ID=101445
I hear you ! I may be able to answer your thoughts soon hopefully, as I follow your path down this probable bummer undertaking with my Golf 1.4 TSi. as well :confused:
   #53
cbx750p
Singapore
C?ID=101445
Sounds good! Have all the parts required to install?
I have fitted the system using the latest parts from VW brand new....but ended up with the same error as you have...."Wrong Engine Type" :banghead::banghead:
I have the original Driver Profile from a 2017 Golf R loaded onto the Gateway. I believe the problem is with the engine coding.
   #54
quailallstar
C?ID=53119
Well that just sucks. Is there anyway to reprogram our vehicles to have driver profile selection without making a trip to the dealer? Overseas VW sells a kit which includes the lower console buttons and instructions for reprogramming the vehicle. Hmmmmm.
Edit: This is the kit I believe.
Use Google translate as it's a Russian car forum - > https://www.drive2.com/l/6261375/
Italian tuner shop - > https://www.facebook.com/carfixretrofit/photos/pcb.484097088381167/484097035047839/?type=3
cbx750p
Singapore
C?ID=101445
I am afraid that the road ends here but I can't see any light. 😣
   #57
quailallstar
C?ID=53119
I am afraid that the road ends here but I can't see any light. ��
That is a shame...
I'm still thinking driver profile selection may help the situation by telling the car what mode you want. Thinking of doing this mod below in hopes of it all tieing in together. Looks like ODIS access is needed in addition to VCDS for proper coding.
http://www.golfmk7.com/forums/showpost.php?p=388127&postcount=15
XaGiCo has a guide written in Spanish:
https://drive.google.com/file/d/0B6p...?usp=drive_web
I've seen kits on aliexpress that include the 3 buttons and wiring harness.
VW has an official kit. Part number: 5G0 054 809. The instructions are here
It's not entirely clear, but it seems that you might need ODIS to activate the driver profile select. I believe that Golfdave already had driver profile enabled and was only adding an ESC On/Off button. So you might need to have a dealer activate it after the switch is installed.
   #58
cbx750p
Singapore
C?ID=101445
I believe the problem is in the A9 Soundator error. Because of the error message "wrong engine type", the system cannot activate itself.
My Golf 1.4TSi already have the Golf R driver profile but cannot recognise the A9 Soundator presence because of this error.
My retrofitted was recognised by the system but lacked the control until I did the ODIS online SWAP.
   #59
quailallstar
C?ID=53119
What did you retrofit that required the online ODIS SWAP? I've never used ODIS - how could I obtain the software, etc?
   #60
XaGiCo
Ponferrada of Spain
C?ID=243154
Hi
Yes
You need ODIS Online.
The 3 codes are only used once.
Regards
