MK7 Golf Sound Aktuator retrofit
quailallstar
Florida & the Nation's Capital
C?ID=53119
For some time now I've thought of picking up a used sound aktuator and harness for retrofit into my NAR Golf Wagon MY16. Does anyone have a wire diagram of the harness and where it terminates into the BCM???? If anything I can fabricate a harness and play around with coding in hopes of it working on the 1.8t FSI. :D Willing to be the guinea pig on this one.
NitrousOxide
Jamaica
C?ID=269481
If additional engine noise is what you want, it would be better to buy an aftermarket intake or downpipe to get some REAL engine roar and power to go with it.
Folks are taking out the Soundaktor and noise pipes from their cars, while you are looking to put one in. The soundaktor is more hassle than it is worth, and it provides no gains like an intake or downpipe upgrade.
quailallstar
C?ID=53119
Is anyone here with access to an ETKA or shop manual able to provide me a wiring diagram for 4H0907601D (borne sound actuator). I am interested in learning where this plugs into (what pins) + the type of harness so that I can fabricate one and attempt a retrofit.
Dana
Western PA, USA
Hi Michael,
Haven't talked to you for a while. I'm picking up my 2017 Alltrack tomorrow :)
I couldn't locate a scan (for the VIN/application) with that 4H0 # in it but Andy's 2015 GTI has 5G0 907 159 and Uwe's R shows a slightly newer flavor: 5G0 907 159 D. I can take a look at the 2.0T flavor diagrams to see if they're the same and report back.
NitrousOxide
Jamaica
C?ID=269481
Hi Michael,
Dana, I suspect you are dropping hints at us that our cars are too old. :D
Dana
Western PA, USA
I didn't check Uwe's car but ... I suspect they'll be the same based on the direct CAN connections. I did Andy's 2015 GTI with Engine Code: CNTA
Structure borne sound control module -J869-
6-pin connector T6cu
1 = Signal (+), actuator
2 = Signal (-), actuator
3 = Power (15) (from fuse SC34)
4 = Ground (31)
5 = CAN-L
6 = CAN-H
The CAN connections are direct to B384 - Powertrain CAN bus high connection 2 and B391 - Powertrain CAN bus low connection 2 in the diagrams.
The "Structure-borne sound actuator , CHHB,CNTA,CXCA,CXDA from January 2014" diagram # 34 shows some sorta TIUL - Coupling point in interior, bottom left station so I'd splice into that for CAN high/low if your car has it. They hit the CAN GW (J553) at terminals T20/16 and T20/6 if you make an adapter at the module. (I never splice CAN wires where they could corrode under the hood)
The R214 - Structure-borne sound actuator speaker is a direct shot from J869 T6cu/1 to T2gb/1 -and- T6cu/2 to T2gb/2.
If that isn't enough you may want to invest in a $35 pass for a 1 day erWin subscription. http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
Dana
Western PA, USA
Shit, I finally sold my 2002 GTI! That thing had metal parts on the engine! Valve cover, intake, etc :)
We kept the 2012 Tiggy because I don't need a newer/larger model. I am pretty excited about the new Golf Alltrack but - too bad they aren't bringing the SEL in a MT. I went for it and that DSG may be of some use to RT (for procedures, etc).
quailallstar
C?ID=53119
Hi Michael,
Hey Dana!
Yeah it's been some time since we've spoken. Hope all has been well with you. My MK6 TDI was just bought back last night and missing it already :( Congrats on the new car by the way!
Yes, please take a look at the diagrams and see if they are the same part by chance. FYI I found a SEAT forum post from Spain were someone retrofitted it into their 1.6 TDI (hardware and VCDS re-coding).
Thank you for the help in advance :thumbs:
DV52
C?ID=194404
4 = Ground (31)
5 = CAN-L
6 = CAN-H
Dana: I hope that I haven't stolen your thunder, but I had to translate your connection list into a picture (just one of my many peculiarities!!)
But the real reason why I have responded is to say how thrilled I am at your choice of new vehicle - I always suspected that you were a discerning person when it came to choosing a car and your decision on a Golf proves my suspicion!! Pretty-soon the entire RT parking lot will be filled with Golfs of every variety!!
Congratulations
quailallstar
C?ID=53119
4 = Ground (31)
5 = CAN-L
6 = CAN-H
Congratulations
Thank you both for the information! The visual helps a lot! So I'll not only need to get a borne sound actuator but also the J869 (black control box) to make this work. I suspect this retrofit would work on my vehicle :)
attachment.php
Now on to ebay to find used parts for sale & ordereing wires/connectors to make a harness.
quailallstar
C?ID=53119
andyhud
C?ID=32695
I'm doing the same for my Q7 4M
I've got the control module and actuator and got the connectors from my local Audi dealer. I'll make up the wiring looms myself to plug into power + Extended Can
I believe coding in Module 09 is needed but not sure exact coding yet.. .working on that from an SQ7 which has this natively installed from factory
Cheers
Andy
quailallstar
C?ID=53119
Cheers
Andy
Would you mind sharing how you are putting this harness together? What @Dana provided via her written instructions and wire schematic by @DV52 helps me some, but creating a bypass or in-between modified hardness taping into the CAN would make me feel better about this mod.
I picked up a slightly used control module and actuator off a 2016 Golf 7 GTI that includes both cut harnesses going into the control module and actuator - albeit cut off rather short.
quailallstar
C?ID=53119
April 20th update:
Successfully installed the soundaktor and control module. A9 - Borne Sound module came right up on VCDS as A9 - Borne Sound.
Although recognized by the vehicle when scanning, there is a fault code which I was expecting. The soundaktor won't run when attempting to test for functionality. I checked and the unit is turned up to 100% sound level.
Below is a fresh full autoscan. Genius gurus please help me get this working :)
Thursday,20,April,2017,07:09:03:39394
VCDS Version: 17.1.3.0 (x64)
Gateway Installation List:  5Q0 907 530 AJ
A9-Struct. Borne Sound -- Status: Malfunction 0010
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 75 A9
VIN: 3VWC17AU2GM517860   Mileage: 19930km-12383miles
Address 01: Engine (J623-CXBB)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091A00122424002F1000
   Shop #: WSC 00066 790 00060
   ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
   ROD: EV_ECM18TFS0208V0906264F.rod
   VCID: 3F873DEFA6E45EB9D0-806A
Readiness: 1110 1101
   Part No SW: 09G 927 749 AP    HW: 09G 927 749 AP
   Component: AISIN AG6 G3  129 2943
   ROD: EV_TCMAQ250031_VW31.rod
   VCID: 0717E50FBEB4D679A8-8052
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 53345000000435
   Coding: 04FA6AA124210973007F020681C3292056249000408194B400400050C009
   Shop #: WSC 12345 123 61029
   VCID: 4B9F193FE25CF2194C-801E
   Revision: 00021000    Serial number: 0381142691
   Coding: 030C1C
   Shop #: WSC 01383 790 50316
   VCID: 3A714CFBBDC67B91E7-806E
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Revision: 00001K01
   Coding: 02020004100100000000000010000002
   ROD: EV_ACManueBHBVW37X_SK48.rod
   VCID: 4689280BF93E0F7193-8012
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86580111150438
   Coding: 00511A464041A2796DE44000111407001800000000000000000000000000
   ROD: EV_BCMBOSCH_016_AU37.rod
   VCID: 7AF18CFBFD46BB91A7-802E
   Component: WWS    150812  043 0581
   Serial number:         160113075324
   Coding: 1E4DFF
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y15M11D26H23M31S18
   Coding: 84A8DD
   Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000055391009
   Sun Roof:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST000FDNT800000
   Coding: 191800
   Roof Blind:
   Subsystem 5 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST000FDMS600000
   Coding: 191800
   Serial number: 003GCR03MZUJ
   VCID: 4797250FFE34167968-8012
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH00000000000439RNQ
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 002 110 15
   Serial number: 35700000000814CCA61Q
   Subsystem 3 - Part No SW: -----------    HW: 480 002 110 15
   Serial number: 35800000000D1DCC371Z
   Subsystem 4 - Part No SW: -----------    HW: 480 402 310 15
   Serial number: 3510002AB1D3F97290EJ
   Subsystem 5 - Part No SW: -----------    HW: 480 402 310 15
   Serial number: 3520002B71CF1D22013.
   Subsystem 6 - Part No SW: -----------    HW: 480 401 010 15
   Serial number: 3550002A51CCEA02F0EO
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 010 15
   Serial number: 3560002A51CCEA02F06H
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20151021501479
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 040DF2038F82FD61CD-8050
   Part No SW: 5G1 920 840 A    HW: 5G1 920 840 A
   Component: KOMBI         242 6420
   Coding: 03A5111AA980CF050108FE001000000000000000
   VCID: 254B8F872478E469BA-8070
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 25111510803678
   Coding: 0901000830085900FB00000A1C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00199
   ROD: EV_GatewConti_013.rod
   VCID: 79F393F7F840B089AE-802C
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29150001545520065326
   Coding: 31FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0111854
   Revision: 00000000    Serial number: 15000220563001
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 346D62C39FA28DE13D-8060
   Serial number: 02121506050ANJ
   Coding: 003F13205C00020000000000
   VCID: 438F311FCA0C3A59B4-8016
   Serial number: 00000000000002425948
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 8102
   ROD: EV_SteerAssisMQB_VW31.rod
   VCID: 448D3203CF023D618D-8010
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H20 0130
   Revision: 00000001    Serial number: VWZ8Z1FBA014RA5
   VCID: 6DDBB7A7BC081C2932-8038
   Serial number: 20111506050CZO
   Coding: 003F13205E00020000000000
   VCID: 4281341BD5163351BF-8016
   Serial number: 00000000000002251843
   Coding: 091000
   Coding: 061A00000B000400
   VCID: 40853E13DB1A2141A9-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Coding: 02730200FF00000051220002001808001F0106F40120010003
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 6CDDBAA38712152125-8038
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H52 1028
   Serial number: VWZ8Z9RES01133
          B11CF 53 [009] - Deactivated
                    Reset counter: 211
                    Mileage: 19930 km
                    Date: 2017.04.20
                    Time: 07:09:05
                    Voltage terminal 30: 12.2 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Channel selection for satellite radio: 0
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 129 mA
                    SDARS_tuner_status_2-Reception quality: good_signal
                    SDARS_tuner_status_2-Tuner für Satellitenradio: Status der Voraktivierung: 05
                    SDARS_tuner_status_2-Tuner für Satellitenradio: Wert der Voraktivierung: 05
7219 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 211
                    Mileage: 19930 km
                    Date: 2017.04.20
                    Time: 07:08:41
                    BAP-BAP_Function_ID: 02
7223 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 211
                    Mileage: 19930 km
                    Date: 2017.04.20
                    Time: 07:08:41
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0568
   Coding: 02730002C2823A01000000000000
   ROD: EV_OCULowMQB.rod
   Part No SW: 5G0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0014
   Serial number: 150929202770
   VCID: 6BDFB9BF821C12192C-803E
0005 - Incorrect Vehicle Type
          U10D9 00 [009] - -
                    Reset counter: 211
                    Mileage: 19930 km
                    Date: 2017.04.20
                    Time: 07:08:36
End-------------------------(Elapsed Time: 04:23)--------------------------
Andy
Sector 7G
HC424490
Wow, I wonder if it sees the 1.8T ECU or other config and says "nope". I searched our records and found some scans from similar cars but no 1.8T with A9, only 2.0T.
quailallstar
C?ID=53119
From what I've found there are no VW models with a 1.8t and a soundaktor. However, Seat does 😁 There is hope.
Andy
Sector 7G
HC424490
AFAIK, there's only one Adaptation channel in soundaktor, for volume level.
