16.8.2 - Speed & Crashing Problems
   #21
PetrolDave
Westbury, UK
C?ID=1423
Did some more tests using 16.8.2 on my Acer Aspire One yesterday trying to connect to 09, 17 and 5F controllers on my MQB Octavia III.
- VCDS read 19 (CAN Gateway) and showed correct controller installation list.
- 09 (BCM) hung 3 times and had to Alt-Ctrl-Del VCDS and restart it each time. So then to see if VCDS was somehow corrupted I tried ...
- 17 (Instruments) connected OK, and was able to change coding I wanted.
- 5F (Infotainment) connected OK, and was able to change adaptations I wanted.
- 09 (BCM) now connected OK, and was able to change adaptations I wanted.
- Full Auto-Scan OK.
- Downloaded adaptation maps from all controllers in car except 15 (Airbags).
So it seems as though the very large adaptation channel count of 09 (over 2200 channels) is a factor, but having successfully opened other controllers it's OK opening 09.
Gizmo
S.E.Kent UK
C?ID=49193
Here is my results from a two week old UK spec MY17 Škoda Superb L&K (220 petrol) using16.8.2,
although 09 opened without issue, it took quite a while to open and the search facility under adaptations did not work (it worked on all other controllers I opened) however the long code is all zero’s, I was therefore not brave (stupid?) enough to do any coding on 09 at this time.
Sunday,09,October,2016,10:07:47:36443
VCDS Version: 16.8.2.3  HEX-NET CB: 0.4321.4
Data version: 20160926 DS261.0
VIN: TMBKD7NP6H7017657   License Plate: **66 **
Mileage: 424km-263mi   Repair Order: 1
Chassis Type: NP (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 47 52
          55 5F 6D A5 BB BC CA
VIN: TMBKD7NP6H7017657   Mileage: 424km-263miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CHHB)       Labels: 06K-907-425-V1.clb
   Part No SW: 3G0 906 259     HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 0C1D00322464010B3000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM20TFS0203G0906259 001007
   ROD: EV_ECM20TFS0203G0906259.rod
   VCID: 699A78F888F7B90A03-803C
   Part No SW: 0D9 300 042 H    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H54 4901
   Revision: 06354004    Serial number: TFK01606100283
   ROD: EV_TCMDQ250021.rod
   VCID: 1E701B2401398EB2A6-804A
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 61736000000666
   Coding: 1E07929C34211373477D060541CA4978492CC8E2608292753841F0F8C2A902
   ROD: EV_Brake1UDSContiMK100IPB_035_SK37.rod
   VCID: 7BB632B0F26B3B9AE1-802E
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0408513457
   Coding: 032C0C0F03
   VCID: 3C34F1ACB7E5FCA2A8-8068
   Subsystem 1 - Part No SW: 3AA 962 243 G    HW: 3AA 962 243 G
   Component: GEB.F.Heckoef  H16 0903
   Serial number: 84395804
Address 08: Auto HVAC (E87)       Labels: 3V0-907-044.clb
   Part No SW: 3V0 907 044 BE    HW: 3V0 907 044 BE
   Component: AC Automat    H34 4003
   Revision: 20K06000    Serial number: 00000B00149463
   Coding: 1211000400041001100510010010110A
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ACClimaPrehVW37X 002014
   ROD: EV_ACClimaPrehVW37X_SK48.rod
   VCID: 78BC2DBCC35D10828C-802C
   Subsystem 1 - Part No SW: 3V0 907 049 C    HW: 3V0 907 049 C
   Component: E265KlimaHeck  H02 0101
   Serial number: 00000000000000000000
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001617501235
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F4EC6A0E67327BACD-802A
   Subsystem 1 - Part No SW: 3V2 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x RL 160608  032 0121
   Serial number: 00000001606070300846
   Coding: 165DDD
   Component: RLHS  042 0105
   Serial number: S7Y16M06D25H07M47S49
   Coding: 0088DF
   Subsystem 3 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY1613806EM
   Serial number: 00000000000066333149
133387 - Voltage Supply; Terminal 30 for Central Locking
          B140F 13 [008] - Open Circuit
                    Reset counter: 67
                    Mileage: 1048574 km
                    Time: 00:00:00
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183616164
   Coding: 0371067851
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000_009_SK48.rod
   VCID: 0D526C68DCDF052ACF-8058
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Component: ACC BOSCH MQB H04 0194
   Coding: 320067C355FFC428949C8045
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3424D98C9FB534E260-8060
   Serial number: 10061641350569
   ROD: EV_DRCONTITEMIC.rod
   VCID: 383CEDBC83DDD0824C-806C
   Part No SW: 5Q0 959 655 AK    HW: 5Q0 959 655 AK
   Component: AirbagVW21    005 0130
   Serial number: 003Q5R1W1H7X
   Coding: 98CCC0C0000000005C5400CF00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   ROD: EV_AirbaVW20SMEVW37X_SK48.rod
   VCID: 095A5878A8B7190AE3-805C
   Subsystem 1 - Part No SW: -----------    HW: 480 001 706 16
   Serial number: 35700000000BF46DFB15
   Subsystem 2 - Part No SW: -----------    HW: 480 001 706 16
   Serial number: 358000000009CB553C1V
   Subsystem 3 - Part No SW: -----------    HW: 480 401 806 16
   Serial number: 3510002AD20EDB60F1DN
   Subsystem 4 - Part No SW: -----------    HW: 480 401 806 16
   Serial number: 3520002AB20EDB650356
   Subsystem 5 - Part No SW: -----------    HW: 480 401 706 16
   Serial number: 3550002C721160C3B2B/
   Part No SW: 3Q0 953 521 EF    HW: 5Q0 953 569 A
   Revision: FF035035    Serial number: 20160617501290
   Coding: 6410
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 3V0 920 910 A    HW: 3V0 920 910 A
   Component: KOMBI         304 8311
   Coding: 27A5091A7F80A600018B6B0B5001000000000000
   Shop #: WSC 73430 031 00063
   ROD: EV_DashBoardVDDMQBAB_SK25.rod
   VCID: 2F2ED6E07693173A1D-807A
   Revision: --------    Serial number: 13081610802153
   Coding: 030100047F085900EB00025A9C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CB431ACF7653CA2E8-8028
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000A2328070616
   Serial number: 4911320304
   Serial number: 16000129026001
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71AA1098A02741CA4B-8024
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Component: Sitzmemory    H08 0020
   Serial number: Y0006PFR10152
   Coding: 0014000000000500018280808080000000008181000000D400
   ROD: EV_SeatMemorDriveSide_VW37.rod
Address 3C: Lane Change (J1086)       Labels: None
   Component: HRE_Master    H12 0071
   Serial number: 0407491910
   Coding: 02011203
   ROD: EV_HREntryHella.rod
   Lane Change Assistant 2:
   Serial number: 0000206041672
   Coding: 001D0820DE01040000001100
   VCID: 47DE9E40FE23AF7A35-8012
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45C29448C42FBD6AC7-8010
   Part No SW: 3Q0 035 466 A    HW: 3Q0 035 466 A
   Component: MIB2_amp_P_SK H02 0250
   Revision: 00000001    Serial number: SKZ8Z1GAS01V98F
   Coding: 0384020000AA002FAA0000000000
   ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
   ROD: EV_AMPMst16C5Gen2ALPI.rod
   VCID: 2D12CCE87C9F652A2F-8078
   Serial number: 0000205958236
   Coding: 001D0220DE01040000001100
   VCID: 46C09344F929B672CE-8012
   Coding: 06D602007F010000
   VCID: 40CC855CDB0D9842F4-8014
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0013
   Coding: B30000
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0013
   Coding: B30000
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 020 C    HW: 3V0 035 020
   Component: MU-H-ND-EU    H50 0702
   Serial number: A676E0G7507292
   Coding: 038402010000000051111202008808002F0103E601200100DE
   Shop #: WSC 33361 790 00145
   VCID: 260033C459695672EE-8072
   Subsystem 1 - Part No SW: 3V0 919 606     HW: 3V0 919 606
   Component: ABT_High-2  H47 1031
   Serial number: SKZ8Z9SLU003AC
   Subsystem 2 - Part No SW: V03 959 801 JL    HW: -----------
   Component: ECE 2016/2017  --- 0153
   Component: Gracenote2---  --- 1013
Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30785212700000
   Coding: 0D08
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   VCID: 3FCE86A0A6F3E7BA8D-806A
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0220
   Serial number: 01061611P20912
   Coding: 020408020000040100062354C050A10088000E100040
   ROD: EV_MFKBoschMQBB.rod
   VCID: 3A38F7B4BDD1C292BA-806E
Address BB: Door Rear Drv (J388)       Labels: None
   Part No SW: 5Q4 959 395 E    HW: 5Q4 959 395 B
   Component: TSG HFS       011 0031
   Serial number: 0000205098652
   Coding: 001C00208001040000001100
   ASAM Dataset: EV_DCURearDriveMAXCONT 006001
Address BC: Door Rear Pass (J389)       Labels: None
   Component: TSG HBFS      011 0031
   Serial number: 0000205098739
   ASAM Dataset: EV_DCURearPasseMAXCONT 006001
Address CA: Sunroof (J245)       Labels: None
   Part No SW: 4M0 907 594 D    HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Coding: 108040648202
   ASAM Dataset: EV_SunRoofCONTIAU736 004008
   ROD: EV_SunRoofCONTIAU736_004_VW48.rod
   VCID: 373EEE808EC3DFFA45-8062
End----------(Elapsed Time: 02:15, VBatt start/end: 12.2V/12.2V)-----------
   #23
Eric
HC800000
I've been doing some benchmarking with a deplorable netbook here (an Atom N570 with 1GB RAM on which Santos installed Windows 10 x64 :confused: ), and hopefully this will give you an overview of the issues and fixes. Those are the times for an autoscan of Andy's Mk7 GTI using the 32bit version, which is traditionally slower:
VERSION-CPU		MQB HEX-NET	MQB HUC
16.8.1 Atom		1:41		5:03
16.8.2 Atom		2:16		5:26
16.8.3 Atom		1:16		4:37
16.8.2 6700K		1:10		4:00
16.8.3 6700K		1:08		3:58
The upcoming 16.8.3 makes use of a new optimized UDS dataset as well as optimized search algorithms; we've managed to make it faster than 16.8.1 which had a dataset with considerably less information. But there are different columns and CPUs in my benchmarks for a reason:
*If you insist on using an Atom on a UDS car, you'd better be using a HEX-NET that considerably relieves the CPU while it's doing the parsing of the UDS data.
*If you insist on using a HUC on a UDS car, you'd better get a faster CPU than an atom. See the difference going from Atom to 6700K does with the HUC: 5:26 to 4:00 with 16.8.2 that's purely CPU time, not car communication time.
*If you insist on keeping that Atom with a HUC, well, the amount of UDS data VCDS has to handle isn't going to get smaller anytime soon, and you'd better take on some other activity like meditation while VCDS loads that data. Clicking everywhere because you're getting impatient that the CPU and OS are overwhelmed does not make things better, and I suspect this is what some people call "crashing" (and recovering from it :D)
   #24
PetrolDave
Westbury, UK
C?ID=1423
Are those HEX-NET timings using a USB cable or WiFi? And does it make much difference?
I normally use my HEX-NET connected via USB to my netbook.
   #25
Eric
HC800000
USB. WiFi with a good signal can get pretty close, but there's always some level of variability. Lots of interference in my office for instance, with all the power supplies/HEX-NETs/computers/control modules that are plugged in :)
   #26
OK, you folks who had speed and "crashing" problems with 16.8.2 should try 16.8.3 please, which is now available on our download page.
Feedback appreciated.
PetrolDave
Westbury, UK
C?ID=1423
16.8.3 is MUCH faster and no crashing.
Auto-Scan times on my MQB platform Octavia III:
16.8.0: 1:41
16.8.1: 1:44
16.8.2: 2:48 (but only after connecting to "simple" modules first as per earlier post in this thread)
16.8.3: 1:28
Good job guys!!!
