ABS CODING HELP!
NNVirginia
C?ID=287168
Hello! so my name is Donald, I am driving a 2009 VW Rabbit/golf, 2.5cyl, Gas, hatch.
my ABS control module failed recently((1K0907379AD), so I replaced it with the revised version (1K0907379AN). I really need a code for this thing..
I was unable to pull my old code because the way the module failed, though I have heard that the old code would not work for My car this particular instance.
does anyone have any suggestions?
I have tried using a code from a similar rabbit, with the same module/pump that I had/have , with no luck. was told when he tried it, it never said "code accepted" , so when he tried to do the calibration tests directly after, they would not stick? though he never drove it anywhere either. I have his code number and will probably try it again myself tomorrow. So this is my daily driver, not to mention I really enjoyed driving this car before these lights came on, i just want it to go back to normal haha.. Does anyone have any ideas? can help? Greatly appreciated.
happy to be a new part of the rosstech family , Donald L:banghead:
Monday,26,September,2016,19:18:31:59596
VCDS Version: 16.8.1.3 (x64)
Data version: 20160902 DS256
VIN: WVWAB71K19W026463   License Plate:
Chassis Type: 1K (1K0)
VIN: WVWAB71K19W026463   Mileage: 207780km-129108miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 N    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   0114
   Revision: G6H01---    Serial number: VWX7Z0H53NA8HD
   Coding: 0000071
   Shop #: WSC 06530 444 13785
   VCID: 3978AB3A70B15E8AA9-806C
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
               P0106 - 000 - Implausible Signal - Intermittent
                    Mileage: 207745 km
                    Time: 16:39:52
                    RPM: 1650 /min
                    Load: 13.3 %
                    Speed: 38.0 km/h
                    Temperature: 77.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.097 V
Readiness: 0000 1100
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Revision: 00H45001
   VCID: 7EF27826E91FB9B2DC-802A
                    Reset counter: 0
                    Mileage: 207723 km
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 195
                    Count: 35840
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   Component: Climatic PQ35   142 1111
   Revision: 00142031    Serial number: 00000000000000
   VCID: 7CF6722E3F03ABA2F2-8028
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Revision: 00H54000    Serial number: 00000008507058
   Coding: 008D8F21400415004714003C001400000008730B5C000100000000000000
   Shop #: WSC 00000 785 00200
   VCID: 326A9C16ADC7ADD268-8066
   Component: Wischer 300508 021  0501
   Coding: 00038805
                    Reset counter: 81
                    Voltage: 12.60 V
   Component: 6K AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0BBU65
   Coding: 0013899
   VCID: 6CD6426E4F633B2262-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME2C3207063
   Subsystem 3 - Serial number: 6342MSME392104450
   Subsystem 4 - Serial number: 6352QSME6A625611E
   Subsystem 5 - Serial number: 6362QSME6A730F53R
   Subsystem 6 - Serial number: 63727SME16711121N
   Subsystem 7 - Serial number: 63827SME16710610Q
   Part No SW: 1K0 953 549 BN    HW: 1K0 953 549 BN
   Coding: 0000022
   Shop #: WSC 01279 785 00200
   VCID: 7F0C85222E15B0BAD7-802A
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT VDD 1222
   Revision: V0003000    Serial number: VWX7Z0H53NA8HD
   Coding: 0005103
   Shop #: WSC 01814 444 53366
   VCID: 3C76B22E7F836BA2B2-8068
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 290508F2002580
   Coding: E9801F060002020000
   VCID: 3560A70A5CA9BAEA4D-8060
                    Fault Frequency: 15
                    Reset counter: 81
                    Mileage: 207723 km
                    Time: 17:34:36
   Component: IMMO            VDD 1222
   Component: Tuer-SG         006 1207
   Coding: 0001077
   VCID: 387EAE3E4BBB478256-806C
00105 - Signal Central Locking SAVE/LOCK Drivers Side
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   Shop #: WSC 00000 028 00001
02546 - Steering Limit Stop
                    Mileage: 207710 km
                    Temperature: 46.0°C
                    Voltage: 13.80 V
                    Voltage: 13.60 V
   Coding: 1B9006885103483F0904058530080A0488BC80
   Shop #: WSC 12345 785 00200
   VCID: 04060ACE47F3D3628A-8050
   Coding: 0001072
Address 56: Radio
End-------------------------(Elapsed Time: 01:25)--------------------------
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
If you ever did Auto Scan on car before ABS module want bad, and you have save it, you can use that coding.
WVWAB71K19W026463
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN ( Legacy AD )
Revision: 00H45001
Please JPPSG and clear those faults in 0x16 or fix ignition switch..........!
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
What size brakes front and rear?
Booster part #
PR-Tag picture...........?
Scans of the net.........
Coding: 114B400C49250002880C02EB921E00413400 Auto and 2010 Jetta
Coding: 114B400C492800FA881302EC921C00413000 00 AS string additional byte
Coding: 114B400C49230000880F02E792200041B700 00 BJ "
Coding: 113B400D49250001880C02EA922000413000 "
Coding: 113B400D49220003880C02EA921E00413000 Stick Match.......for config
114B000C09240000880F00EA901C00000000 00 Striped attributes based on VIN
114B400C09240000880F02EA901C00413000 LHD
114B400D09240000880F02EA901C00413000
113B400D09240000880F02EA901C00413000
113B400C09240000880F02EA901C00413000
113B400D49240000880F02EA901C00413000
113B400C49240000880F02EA901C00413000
Try these in red and report back
Dana
Western PA, USA
Quick update here. Donald was able to plug in the old controller and retrieve the original coding of:
113B400D49240000880F02EA921C00413000
Internal ref to TSD?ID=91240
Thank you Dana
901C00413000 <<<<<<<<<<< 13TH byte 90
113B400D49240000880F02EA921C00413000 <<<<<<<<<<< 13TH byte 92
