Thursday,22,September,2016,17:19:59:56745
VCDS Version: 16.8.1.1 (x64)
Data version: 20160902 DS256
VIN: WA1BY74L27D052323 License Plate:
Mileage: 119520km-74266mi Repair Order: 2016.09.22@1719
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 28 37 42 46 47 4F 52 55
56 61 62 65 6F 72
VIN: WA1BY74L27D052323 Mileage: 119520km-74266miles
0E-Media Player 1 -- Status: Malfunction 0010
37-Navigation -- Status: Not registered 0011
Address 01: Engine Labels: 03H-907-309-V1.clb
Part No SW: 03H 906 032 L HW: 03H 906 032 G
Component: Q7 3.6-FSI-LEV2 G00 9547
Revision: 5CH03--- Serial number:
Coding: 0001175
Shop #: WSC 31414 790 00001
VCID: 2B5505CD8AD8991A2D-807E
009529 - Low Pressure Fuel Sensor (G410)
P2539 - 001 - Open Circuit - MIL ON
Fault Status: 11100001
Mileage: 119516 km
Date: 2007.05.27
Time: 07:20:40
Temperature: 38.0°C
Temperature: 36.0°C
Absolute Pres.: 950.0 mbar
Voltage: 12.319 V
005161 - Circuit for Brake Vacuum Pump
P1429 - 004 - Open Circuit
Mileage: 119516 km
Date: 2007.05.29
Time: 12:33:14
RPM: 823 /min
Load: 72.5 %
Temperature: 38.0°C
Temperature: 36.0°C
Voltage: 11.811 V
001393 - Brake Switch (F)
P0571 - 008 - Implausible Signal
Mileage: 119516 km
Date: 2007.05.29
Time: 16:36:42
RPM: 2539 /min
Load: 69.0 %
Speed: 65.0 km/h
Temperature: 88.0°C
Temperature: 33.0°C
Voltage: 13.716 V
Readiness: 0010 0101
Part No SW: 4L0 910 156 A HW: 0AT 927 156
Component: AG6 0AT 3,6 FSI USA 0040
Revision: --H01--- Serial number: 4007027
VCID: 275DF9FD9630BD7AC9-8072
P0571 - 000 - Implausible Signal - Intermittent
Mileage: 119518 km
Date: 2007.06.02
Time: 04:51:15
RPM: 896 /min
RPM: 352 /min
RPM: 64 /min
(no units): 1.0
(no units): 42.0
Temperature: 42.0°C
T.B. Angle: 27.4°
Address 03: ABS Brakes Labels: 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H21001
Coding: 0017425
VCID: 285FFAC19B2EB202C0-807C
Reset counter: 145
Mileage: 119518 km
Date: 2007.06.02
Time: 15:43:02
Count: 14337
Count: 128
Count: 31488
Reset counter: 145
Mileage: 119518 km
Count: 192
Count: 15105
Count: 297
Count: 32256
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100556624
Coding: 0000131
VCID: 63C5ADEDA288115AD5-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0040
00230 - Transmission Park Selector Switch (F305)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 105
Mileage: 119518 km
Date: 2007.06.02
Time: 15:37:56
00532 - Supply Voltage B+
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 15:44:07
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 15:43:05
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 729 Q HW: 4E0 035 729
Component: Interfacebox H43 2740
Revision: 00000000 Serial number: 308I.067507839
Coding: 0002003
VCID: 3D713B9564AC07AA83-8068
Component: E0380 BedienteilH01 0060
Subsystem 2 - Serial number: 00000001231804
Subsystem 3 - Serial number: 0121.11.080000000100010301ÿ
Subsystem 4 - Serial number: 010301ÿ
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 15:43:18
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Revision: 00---010 Serial number: 00000030004999
Coding: 0786470
VCID: 61C9A7E5B894034AC7-8034
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 15:42:41
Bin. Bits: 01111
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 15:43:18
Voltage: 9.00 V
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Coding: 0014123
VCID: 316917A5A8F4F3CA17-8064
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Reset counter: 144
Mileage: 119516 km
Date: 2007.06.02
Time: 16:02:00
Reset counter: 144
Mileage: 119516 km
Date: 2007.06.02
Time: 16:02:00
Part No SW: 4L0 910 111 A HW: 4L0 035 111
Component: CD-Changer H41 0100
Revision: 00000000 Serial number: AUZ5ZBF3044471
VCID: 1E33DC19C96A7CB2BA-804A
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 16:09:59
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 15:44:22
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH39 0210
Revision: 03H39000 Serial number: 0038QD039SKO
Coding: 0014131
Subsystem 1 - Part No: 4L0 910 339
Component: BF-Gewichtsens. H02 0020
Subsystem 2 - Serial number: 6332QSME14170C73A
Subsystem 3 - Serial number: 6342QSME105251774
Subsystem 4 - Serial number: 6352QSME134441352
Subsystem 5 - Serial number: 6362QSME14194815B
Subsystem 6 - Serial number: 63734SME15323A49
Subsystem 7 - Serial number: 63834SME15247745.
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Revision: 00H08000 Serial number: 90026062640544
Coding: 0002022
VCID: 66C3B4F951BA647232-8032
Component: Lenkradmodul H07 0090
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 15:43:28
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 15:44:23
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 900 C HW: 4L0 920 950 B
Component: KOMBIINSTR. M73 H11 0240
Revision: 00400000 Serial number: 4ZS75Z2A6
Coding: 0531263
Shop #: WSC 06158 444 67030
VCID: 204FE2E1F31E4A4288-8074
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 15:43:03
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B069198017
Coding: E5779E77300202
Shop #: WSC 06158 444 54724
VCID: 6CD7C6D14F565E2264-8038
Reset counter: 106
Mileage: 119526 km
Date: 2007.05.20
Time: 08:47:40
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 D
Revision: 00---009 Serial number: 00000030118185
Coding: 0000006
VCID: 68DFBAC15BAE720200-803C
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 15:43:15
Voltage: 9.10 V
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 104
Mileage: 119517 km
Date: 2007.05.16
Time: 12:02:30
Part No SW: 4E0 910 888 M HW: 4E0 919 887 D
Component: MNS US H48 1100
Revision: 00000000 Serial number: 381J 067506749
VCID: 387F2A814B8E228250-806C
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 15:43:06
Hex Value: 0x4661
Hex Value: 0x9584
Hex Value: 0x0054
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00000000 Serial number: Fr
Coding: 0035403
VCID: 2F6D11DDBEC0E53A01-807A
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 15:44:20
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01020822680000
Coding: 4487197
02957 - Lamp in Trunk/Hatch Lid; Right
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 106
Mileage: 83901 km
Date: 2012.10.03
Time: 06:35:53
Bin. Bits: 000 010
02956 - Lamp in Trunk/Hatch Lid; Left
Reset counter: 106
Mileage: 85361 km
Date: 2012.11.06
Time: 07:02:16
Bin. Bits: 000 001
01503 - Bulb for 3rd Brake Light (M25)
Fault Frequency: 7
Reset counter: 106
Mileage: 119518 km
Date: 2007.06.02
Time: 15:46:39
01403 - Glass-Break Sensors; Rear
Reset counter: 106
Mileage: 119513 km
Date: 2007.05.16
Time: 12:00:00
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 D HW: 4L0 035 223 A
Component: DSP-High AU716 H02 0110
Revision: PROD_01 Serial number: 00000000018269
Coding: 0000016
VCID: 2541F3F5EC3CAF6AFB-8070
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 16:04:46
Voltage: 8.40 V
Fault Frequency: 7
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 15:43:13
Voltage: 6.90 V
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000042711
Coding: 0012001
VCID: 5EB39C1989EA3CB2FA-800A
Fault Status: 00110010
Reset counter: 144
Mileage: 119516 km
Date: 2007.06.02
Time: 15:44:00
Voltage: 6.800 V
Temperature: 38.0°C
Reset counter: 144
Mileage: 119516 km
Date: 2007.06.02
Time: 15:43:00
Voltage: 7.700 V
Temperature: 38.0°C
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00000000 Serial number: "#
Coding: 0035403
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 15:44:20
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Coding: 0000007
Fault Frequency: 0
Reset counter: 144
Mileage: 119512 km
Date: 2000.01.01
Time: 12:00:00
Part No SW: 4E0 910 541 M HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial number: 388I+067556732
VCID: 2A5B00C985228012D6-807E
Reset counter: 145
Mileage: 119518 km
Date: 2007.06.02
Time: 16:02:43
Fault Frequency: 251
Reset counter: 145
00856 - Radio Antenna
Reset counter: 104
Mileage: 119513 km
Date: 2007.05.16
Time: 12:04:30
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000048984
Shop #: WSC 06133 444 52622
VCID: 64C7AEF1A78616622C-8030
Component: von TU3 0538800465
Coding: 344630393135313035442054553330353338383030343635
Reset counter: 144
Mileage: 119516 km
Date: 2007.05.26
Time: 10:12:04
Fault Frequency: 37
Mileage: 119516 km
Date: 2007.05.26
Time: 15:38:08
02256 - Quiescent Current
Fault Status: 00100001
Fault Frequency: 7
Reset counter: 145
Mileage: 119516 km
Date: 2007.05.26
Time: 23:05:41
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0035338
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 16:10:01
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900031970
Coding: 0062424
VCID: 224BE8E9FD1258529E-8076
02214 - Tire Pressure Warning
Fault Frequency: 40
Reset counter: 0
Mileage: 119518 km
Date: 2007.06.02
Time: 15:39:19
(no units): 0.0
Temperature: 37.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002010187-----
Coding: 0003595
VCID: 2643F4F9913AA472F2-8072
Component: J_245_EE15_SKB09H10 0180
Component: J_394_EE15_SKB09H10 0180
Component: J_392_EE15_SKB09H10 0180
02914 - Sensor 1 for Trunk/Hatch Closed (G525)
Fault Status: 00101010
Reset counter: 143
Mileage: 119516 km
Date: 2007.05.26
Time: 11:21:36
02915 - Sensor 2 for Trunk/Hatch Closed (G526)
Reset counter: 143
Mileage: 119516 km
Date: 2007.05.26
Time: 11:21:36
Fault Frequency: 7
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 15:44:07
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0035338
Reset counter: 144
Mileage: 119518 km
Date: 2007.06.02
Time: 15:44:20
End-------------------------(Elapsed Time: 02:45)--------------------------
