2007 3.6L-VR6 Brake Vacuum Pump Recode
natedog01nse
C?ID=204427
I have an early 2007 Q7 that had a 3.6L-VR6 with an electric brake vacuum pump. I had to replace the motor and ended up doing so with a later version of the 2007 3.6L-VR6...that came with a mechanical brake vacuum pump. Now I am left with an open circuit code P1429. Is there a way for me to long-code it so that I stop getting this code?
It would probably be useful if you would post an Auto-Scan so people could see exactly what ECU your car has and how it's coded.
natedog01nse
C?ID=204427
Here is the full-length Auto Scan.
Thursday,22,September,2016,17:19:59:56745
VCDS Version: 16.8.1.1 (x64)
Data version: 20160902 DS256
VIN: WA1BY74L27D052323   License Plate:
Mileage: 119520km-74266mi   Repair Order: 2016.09.22@1719
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 28 37 42 46 47 4F 52 55
          56 61 62 65 6F 72
VIN: WA1BY74L27D052323   Mileage: 119520km-74266miles
0E-Media Player 1 -- Status: Malfunction 0010
37-Navigation -- Status: Not registered 0011
Address 01: Engine        Labels: 03H-907-309-V1.clb
   Part No SW: 03H 906 032 L    HW: 03H 906 032 G
   Component: Q7 3.6-FSI-LEV2 G00 9547
   Revision: 5CH03---    Serial number:
   Coding: 0001175
   Shop #: WSC 31414 790 00001
   VCID: 2B5505CD8AD8991A2D-807E
009529 - Low Pressure Fuel Sensor (G410)
               P2539 - 001 - Open Circuit - MIL ON
                    Fault Status: 11100001
                    Mileage: 119516 km
                    Date: 2007.05.27
                    Time: 07:20:40
                    Load: 0.0 %
                    Temperature: 38.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 950.0 mbar
                    Voltage: 12.319 V
005161 - Circuit for Brake Vacuum Pump
               P1429 - 004 - Open Circuit
                    Mileage: 119516 km
                    Date: 2007.05.29
                    Time: 12:33:14
                    RPM: 823 /min
                    Load: 72.5 %
                    Temperature: 38.0°C
                    Temperature: 36.0°C
                    Voltage: 11.811 V
001393 - Brake Switch (F)
               P0571 - 008 - Implausible Signal
                    Fault Status: 01101000
                    Mileage: 119516 km
                    Date: 2007.05.29
                    Time: 16:36:42
                    RPM: 2539 /min
                    Load: 69.0 %
                    Speed: 65.0 km/h
                    Temperature: 88.0°C
                    Temperature: 33.0°C
                    Voltage: 13.716 V
Readiness: 0010 0101
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4L0 910 156 A    HW: 0AT 927 156
   Component: AG6 0AT 3,6 FSI USA 0040
   Revision: --H01---    Serial number:        4007027
   VCID: 275DF9FD9630BD7AC9-8072
               P0571 - 000 - Implausible Signal - Intermittent
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 04:51:15
                    RPM: 896 /min
                    RPM: 352 /min
                    RPM: 64 /min
                    (no units): 1.0
                    (no units): 42.0
                    Temperature: 42.0°C
                    T.B. Angle: 27.4°
Address 03: ABS Brakes        Labels: 4L0-910-517-V1.clb
   Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
   Component: ESP ALLRAD MK25E1   0130
   Revision: 00H21001
   Coding: 0017425
   VCID: 285FFAC19B2EB202C0-807C
                    Reset counter: 145
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:43:02
                    Count: 14337
                    Count: 128
                    Count: 31488
            000 -  -  - Intermittent
                    Reset counter: 145
                    Mileage: 119518 km
                    Count: 192
                    Count: 15105
                    Count: 297
                    Count: 32256
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601100556624
   Coding: 0000131
   VCID: 63C5ADEDA288115AD5-8036
   Subsystem 1 - Part No: 4F0 910 131 J
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H01 0040
00230 - Transmission Park Selector Switch (F305)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 105
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:37:56
00532 - Supply Voltage B+
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:44:07
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:43:05
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L0 910 729 Q    HW: 4E0 035 729
   Component: Interfacebox    H43 2740
   Revision: 00000000    Serial number: 308I.067507839
   Coding: 0002003
   VCID: 3D713B9564AC07AA83-8068
   Subsystem 1 - Part No: 4L0 910 609
   Component: E0380 BedienteilH01 0060
   Subsystem 2 - Serial number: 00000001231804
   Subsystem 3 - Serial number: 0121.11.080000000100010301ÿ
   Subsystem 4 - Serial number: 010301ÿ
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:43:18
   Part No SW: 4L0 910 043     HW: 4L0 820 043 F
   Component: KLIMABETAETIGUNGH05 0060
   Revision: 00---010    Serial number: 00000030004999
   Coding: 0786470
   VCID: 61C9A7E5B894034AC7-8034
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:42:41
                    Bin. Bits:    01111
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:43:18
                    Voltage: 9.00 V
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H17 0240
   Coding: 0014123
   VCID: 316917A5A8F4F3CA17-8064
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H12 0080
   Coding: 00064792
   Shop #: WSC 31414
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 144
                    Mileage: 119516 km
                    Date: 2007.06.02
                    Time: 16:02:00
                    Reset counter: 144
                    Mileage: 119516 km
                    Date: 2007.06.02
                    Time: 16:02:00
   Part No SW: 4L0 910 111 A    HW: 4L0 035 111
   Component: CD-Changer      H41 0100
   Revision: 00000000    Serial number: AUZ5ZBF3044471
   VCID: 1E33DC19C96A7CB2BA-804A
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 16:09:59
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:44:22
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH39 0210
   Revision: 03H39000    Serial number: 0038QD039SKO
   Coding: 0014131
   Subsystem 1 - Part No: 4L0 910 339
   Component: BF-Gewichtsens. H02 0020
   Subsystem 2 - Serial number: 6332QSME14170C73A
   Subsystem 3 - Serial number: 6342QSME105251774
   Subsystem 4 - Serial number: 6352QSME134441352
   Subsystem 5 - Serial number: 6362QSME14194815B
   Subsystem 6 - Serial number: 63734SME15323A49
   Subsystem 7 - Serial number: 63834SME15247745.
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H08 0230
   Revision: 00H08000    Serial number: 90026062640544
   Coding: 0002022
   VCID: 66C3B4F951BA647232-8032
   Component: Lenkradmodul    H07 0090
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:43:28
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:44:23
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 C    HW: 4L0 920 950 B
   Component: KOMBIINSTR. M73 H11 0240
   Revision: 00400000    Serial number: 4ZS75Z2A6
   Coding: 0531263
   Shop #: WSC 06158 444 67030
   VCID: 204FE2E1F31E4A4288-8074
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:43:03
Address 19: CAN Gateway        Labels: 4L0-910-468.clb
   Part No SW: 4L0 910 468     HW: 4L0 907 468
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0900B069198017
   Coding: E5779E77300202
   Shop #: WSC 06158 444 54724
   VCID: 6CD7C6D14F565E2264-8038
            000 -  -
                    Reset counter: 106
                    Mileage: 119526 km
                    Date: 2007.05.20
                    Time: 08:47:40
Address 28: HVAC, Rear        Labels: None
   Part No SW: 4L0 910 158     HW: 4L0 919 158 D
   Revision: 00---009    Serial number: 00000030118185
   Coding: 0000006
   VCID: 68DFBAC15BAE720200-803C
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:43:15
                    Voltage: 9.10 V
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 104
                    Mileage: 119517 km
                    Date: 2007.05.16
                    Time: 12:02:30
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 D
   Component: MNS US          H48 1100
   Revision: 00000000    Serial number: 381J 067506749
   VCID: 387F2A814B8E228250-806C
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:43:06
                    Hex Value: 0x4661
                    Hex Value: 0x9584
                    Hex Value: 0x0054
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0130
   Revision: 00000000    Serial number: Fr
   Coding: 0035403
   VCID: 2F6D11DDBEC0E53A01-807A
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:44:20
Address 46: Central Conv.        Labels: 4L0-910-289.lbl
   Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
   Component: Komfortgeraet   H05 0020
   Revision: 0020 ---    Serial number: 01020822680000
   Coding: 4487197
02957 - Lamp in Trunk/Hatch Lid; Right
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 106
                    Mileage: 83901 km
                    Date: 2012.10.03
                    Time: 06:35:53
                    Bin. Bits:  000 010
02956 - Lamp in Trunk/Hatch Lid; Left
                    Reset counter: 106
                    Mileage: 85361 km
                    Date: 2012.11.06
                    Time: 07:02:16
                    Bin. Bits:  000 001
01503 - Bulb for 3rd Brake Light (M25)
                    Fault Frequency: 7
                    Reset counter: 106
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:46:39
01403 - Glass-Break Sensors; Rear
                    Fault Status: 01101011
                    Reset counter: 106
                    Mileage: 119513 km
                    Date: 2007.05.16
                    Time: 12:00:00
Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
   Part No SW: 4L0 910 223 D    HW: 4L0 035 223 A
   Component: DSP-High AU716  H02 0110
   Revision: PROD_01     Serial number: 00000000018269
   Coding: 0000016
   VCID: 2541F3F5EC3CAF6AFB-8070
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 16:04:46
                    Voltage: 8.40 V
                    Fault Frequency: 7
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:43:13
                    Voltage: 6.90 V
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000042711
   Coding: 0012001
   VCID: 5EB39C1989EA3CB2FA-800A
                    Fault Status: 00110010
                    Reset counter: 144
                    Mileage: 119516 km
                    Date: 2007.06.02
                    Time: 15:44:00
                    Voltage: 6.800 V
                    Temperature: 38.0°C
                    Reset counter: 144
                    Mileage: 119516 km
                    Date: 2007.06.02
                    Time: 15:43:00
                    Voltage: 7.700 V
                    Temperature: 38.0°C
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0130
   Revision: 00000000    Serial number: "#
   Coding: 0035403
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:44:20
   Part No: 8P0 907 357 F
   Component: Dynamische LWR  H02 0010
   Coding: 0000007
                    Fault Frequency: 0
                    Reset counter: 144
                    Mileage: 119512 km
                    Date: 2000.01.01
                    Time: 12:00:00
   Part No SW: 4E0 910 541 M    HW: 4E0 035 541 P
   Component: TUNER EU/US/RDW H42 0570
   Revision: 00000000    Serial number: 388I+067556732
   VCID: 2A5B00C985228012D6-807E
                    Reset counter: 145
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 16:02:43
                    Fault Frequency: 251
                    Reset counter: 145
00856 - Radio Antenna
                    Reset counter: 104
                    Mileage: 119513 km
                    Date: 2007.05.16
                    Time: 12:04:30
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4L0 910 181     HW: 4L0 915 181
   Component: J0644 BEM       H12 0530
   Revision: --------    Serial number: 00000000048984
   Shop #: WSC 06133 444 52622
   VCID: 64C7AEF1A78616622C-8030
   Component: von TU3  0538800465
   Coding: 344630393135313035442054553330353338383030343635
                    Reset counter: 144
                    Mileage: 119516 km
                    Date: 2007.05.26
                    Time: 10:12:04
                    Fault Frequency: 37
                    Mileage: 119516 km
                    Date: 2007.05.26
                    Time: 15:38:08
02256 - Quiescent Current
                    Fault Status: 00100001
                    Fault Frequency: 7
                    Reset counter: 145
                    Mileage: 119516 km
                    Date: 2007.05.26
                    Time: 23:05:41
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Component: TSG HL          H21 0050
   Coding: 0035338
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 16:10:01
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273 B    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000900031970
   Coding: 0062424
   VCID: 224BE8E9FD1258529E-8076
02214 - Tire Pressure Warning
            000 -  -
                    Fault Frequency: 40
                    Reset counter: 0
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:39:19
                    (no units): 0.0
                    Temperature: 37.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 6F: Centr. Conv. II        Labels: 4L0-910-290.lbl
   Component: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Serial number: 002010187-----
   Coding: 0003595
   VCID: 2643F4F9913AA472F2-8072
   Subsystem 1 - Part No: 4L0 910 591
   Component: J_245_EE15_SKB09H10 0180
   Subsystem 2 - Part No: 4L0 910 591
   Component: J_394_EE15_SKB09H10 0180
   Subsystem 3 - Part No: 4L0 910 591
   Component: J_392_EE15_SKB09H10 0180
02914 - Sensor 1 for Trunk/Hatch Closed (G525)
                    Fault Status: 00101010
                    Reset counter: 143
                    Mileage: 119516 km
                    Date: 2007.05.26
                    Time: 11:21:36
02915 - Sensor 2 for Trunk/Hatch Closed (G526)
                    Reset counter: 143
                    Mileage: 119516 km
                    Date: 2007.05.26
                    Time: 11:21:36
                    Fault Frequency: 7
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:44:07
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Component: TSG HR          H21 0050
   Coding: 0035338
                    Reset counter: 144
                    Mileage: 119518 km
                    Date: 2007.06.02
                    Time: 15:44:20
End-------------------------(Elapsed Time: 02:45)--------------------------
Please ignore all of the voltage codes as I re-coded my battery after this Auto Scan.
