- Joined
- Jan 29, 2014
- Messages
- 21,923
- Reaction score
- 9,308
- Location
- Montgomery, NY, USA
- VCDS Serial number
- C?ID=57337
BY THE POWER OF VCDS ... not a Generator and SMOG machine installed @ rear of TDI TP!
Related threads:
http://forums.ross-tech.com/showthread.php?3147-What-is-Jack-talking-about-0x01-08-000
http://forums.ross-tech.com/showthr...smelly-Garbage-can-dumped-on-Motorsports!-WTF
http://forums.ross-tech.com/showthread.php?4111-cheaters-recalls-discuss
http://forums.ross-tech.com/showthread.php?805-Clean-Diesel-Readiness-Status
Okay here is why I take issue with the University in WVA..........as if they did something miraculous, by adding a generator, and SMOG machine tail pipe sniffer to go measure NOX down the road for output.
This is nothing special....... nor was it needed!
I guess for theatrics it gets an A+ for a hot news story, verse using the OBD2 port to log the data, you know....."boring" from the actual sensors that are already in the car!
FACT: Not one state within the USA uses a SMOG machine on a car TDI/diesel TP, because the OBD was considered sufficient.
I guess people are just not using the tools they have right in front of them.
Realize that VCDS and data logging are a powerful tool, further the significance of the MIL, and the systems ability to be its own SMOG "mobile" inspection station.
If you become proficient at logging data, you can determine if a car has had its diagnostic stack tampered.
This would include what VAG did, and what the aftermarket tuners do when they modify or even delete SMOG devices.
Quick example:
Most understand the quick test that techs do at dealers/shops, to see things like requested boost, verse actual 0x01-08-115 fields 3 and 4 or even an OBD2 checksum.
Just because an MIL isn't ON, and a car is stating it's ready by means of "Readiness completed" with no DTC's....doesn't mean it's clean or ready.
I encourage you to pay attention to the VCDS label caption files with specifications co0ntained and compare them to actual values on the road tests.
I have built some fun testing methods to log a "Modified controller", verse a "Stock" one.
You can try it too!
This is done by adding a dual controller, via piggy backing the units, to further observe the outputs as they are reported to different software versions.
This is done to see the OEM and the Aftermarket programming differences by versions to hardware.
Good old compare and contrast..........
Than log with twin VCDS cables to each controller, and set the clocks to sync the outputs to compare the data on the DCY.
See what your differences are with actual readiness tests, and where the basic settings show the final value.
You should be splendidly surprised what you observe.
He could of just logged the DPF pile up and OXS values with VCDS!
My ash was sky high when in the nefarious mode, because the ABS couldn't be recoded at the time.........the EPA was deaf when informed!
I often wonder why a state or EPA just doesn't implement a roller routine, to further log the data on a road test via OBD and spit out the numbers reported, or just send the customer out with a OBD2 port monitor once every 2 years to take a picture.
No TP sniffer needed, nor dyno........... and 4x4 could be done this way too............CHEAP!
The insurance companies have been exploiting this already..... for driving habits to underwrite risk.
NostraJackAss Has Spoken!
Related threads:
Quick example:
You can try it too!
