unable to code used ABS module on 2010 vw jetta
asselen
New Member
India
HC839933
I have replaced an abs module with a used abs module,tried coding with vcds but the system refuses to accept:confused:
Can anybody throw some light pleeeeasee..
Following is a copy of an auto scan :
VIN: WVWL091K5AA550307   License Plate: 123
Mileage: 95250km-59185mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWL091K5AA550307   Mileage: 95250km-59185miles
Address 01: Engine        Labels: None
   Part No SW: 03G 906 056 AC    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000AG  5415
   Revision: --H11---    Serial number:
   Coding: 0000078
   Shop #: WSC 73430 790 00000
   VCID: 68DFEB5E5BC5857ED6-803C
   Part No SW: 02E 300 051 S    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1909
   Revision: 04844002    Serial number: 00000908281307
   Shop #: WSC 44551 111 44551
   VCID: 2345BC72E263A62643-8076
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Revision: 00H30001
   Shop #: WSC 73430 790 00051
   VCID: 7AFBA116F56907EE30-802E
                    Reset counter: 204
                    Mileage: 95253 km
                    Date: 2011.01.28
                    Time: 07:49:50
                    Count: 16391
                    Count: 12
                    Count: 8192
                    Count: 195
                    Count: 43520
                    Count: 512
                    Fault Status: 01100101
                    Reset counter: 204
                    Mileage: 95253 km
                    Date: 2011.01.28
                    Time: 07:49:31
                    Count: 3
                    Count: 12
                    Count: 12288
                    Count: 279
                    Count: 43520
                    Count: 512
                    Reset counter: 204
                    Mileage: 95253 km
                    Date: 2011.01.28
                    Time: 07:49:31
                    Count: 3
                    Count: 12
                    Count: 12288
                    Count: 295
                    Count: 43520
                    Count: 512
                    Reset counter: 204
                    Mileage: 95253 km
                    Date: 2011.01.28
                    Time: 07:49:31
                    Count: 3
                    Count: 12
                    Count: 12288
                    Count: 270
                    Count: 43520
                    Count: 512
                    Reset counter: 204
                    Mileage: 95253 km
                    Date: 2011.01.28
                    Time: 07:49:52
                    Count: 7
                    Count: 12
                    Count: 12288
                    Count: 107
                    Count: 43520
                    Count: 512
   Part No SW: 5K0 907 044 BR    HW: 5K0 907 044 BR
   Component: Climatronic   H14 0609
   Revision: 00003001
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   VCID: 7CF7A70EF75D39DE22-8028
   Part No SW: 5K0 937 086     HW: 5K0 937 086
   Component: BCM PQ35 M    008 0019
   Revision: BC008001
   Coding: 40000A3A982DE1E0440800800400012001702388512085605C8000000000
   VCID: 71E9863AA81F44B681-8024
   Component: Wischer 07070  21  0501
   Coding: 009795
   Component: RLS 230708 05  54  0402
   Coding: 0330AD
   Subsystem 4 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
   Subsystem 5 - Part No: 1K8 951 171
                    Reset counter: 244
                        Term 15 Off
                    Voltage: 9.35 V
   Part No SW: 1K0 909 605 AC    HW: 1K0 909 605 AC
   Component: 27 AIRBAG VW8R  038 8600
   Revision: 07038000    Serial number: 003E7M08WG9P
   Coding: 0012855
   VCID: 6DD19A4A7427A056A5-8038
   Subsystem 1 - Serial number: 6332MSME4A132D3FM
   Subsystem 2 - Serial number: 6342MSME49450F27I
   Subsystem 3 - Serial number: 6351HSME1D2D5F2CU
   Subsystem 4 - Serial number: 6361HSME1D3406724
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           056 0111
   Coding: 0001631
   VCID: 76E3B5260171638E54-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000131
   Part No SW: 5M0 920 870 C    HW: 5M0 920 870 C
   Component: KOMBI         H04 0207
   Coding: 171B00
   VCID: 2F6D404276AB1246D7-807A
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 070709F1000767
   Coding: ED807F06000202001003
   VCID: 66C3E56651D1930EE4-8032
   Component: IMMO          H04 0207
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1520
   Revision: 71009005    Serial number: 00000500398714
   Coding: 0004790
   VCID: 71E9863A681F44B681-8024
   Part No: 1K0 909 144 C
   Revision: 00H15000
   VCID: 2A5B51568549776E00-807E
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 8.7 V
                        PD
                    Temperature: 28.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1520
   Revision: 71009005    Serial number: 00000540588829
   Coding: 0005046
   VCID: 72EB89366D197FAE78-8026
00097 - Front Passengers Central Locking (Safe) Motor (V162)
                    Reset counter: 204
                    Mileage: 94719 km
                    Date: 2011.01.15
                    Time: 18:35:18
                    Fault Frequency: 96
                    Reset counter: 244
                    Mileage: 94719 km
                    Date: 2011.01.15
                    Time: 18:35:18
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  039 0144
   Revision: 00000001    Serial number: VWZ1Z3I5393790
   Coding: 0500040004
   VCID: 65C1E26A6CD79816ED-8030
03138 - Input AUX IN
                    Reset counter: 190
                    Mileage: 94719 km
                    Date: 2011.01.15
                    Time: 18:33:03
   Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R
   Revision: 11006001    Serial number: 00000004086875
   Coding: 0000144
   VCID: 75E1B22A1C7768965D-8020
   Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R
   Revision: 11006001    Serial number: 00000004057546
   Coding: 0000144
00099 - Rear Right Central Locking (Safe) Motor (V164)
                    Reset counter: 204
                    Mileage: 94719 km
                    Date: 2011.01.15
                    Time: 18:35:18
                    Fault Frequency: 96
                    Reset counter: 244
                    Mileage: 94719 km
                    Date: 2011.01.15
                    Time: 18:35:18
End-------------------------(Elapsed Time: 02:18)--------------------------
What coding value are you trying to enter?
Have you done the various basic settings in the same session as the coding?
Then there's that Hydraulic Pump DTC. It's possible that fault has to be fixed before the module can be coded.
From the other thread you posted this question in:
i noted the coding on the original abs module before replacing and tried typing in the original coding on the replaced used abs module.
Typing a hexadecimal string this long is rather error-prone. Please use Copy & Paste.
Please post your archived auto-scan from the old module.
What was wrong with the old module?
PR-Code tag?
Brake sizes?
Booster part #?
India origin
JPPSG ?
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
WVWL091K5AA550307
Part No SW: 03G 906 056 AC HW: 03G 906 021 AN 1.9 TDI
Part No SW: 02E 300 051 S HW: 02E 927 770 AJ Automatic
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ ABS module & type
Revision: 00H30001
Coding: 114B000C092700FA880E00E490200000000000 Base VIN string left hand drive stripped.
