Page 4 of 4 FirstFirst ... 234
Results 31 to 40 of 40
Thread: Acronyms
  1. #31
    Oct 2015
    Following on from the post Andyvee made in the MIB2 thread here is a list from 5f that is not in the main "common acronyms" list. Any ideas??
    VPS
    SWA
    ENI
    HCA (from LDW_HCA)
    VPS
  2. Likes Eric, Uwe, andyvee liked this post
  3. #32
    From MLB gateway coding:
    IVB, KL, HSP, AV, RWB, eBKV
    AGK, VAQ, PreCrash
    SAK, MO_StSt, AMB, AGA
    Freilauf, MO, GE, ALR, MO_BZS, DR
    AEB, FCWO, FCWP, QS, SCU, HAL, NR, MXB
    I have a vague idea what Freilauf and Precrash might do, but the others
  4. Likes Uwe, andyvee liked this post
  5. #33
    Verified VCDS User andyvee's Avatar
    Rossendale, Lancashire, UK
    SWA Spurwechselassistent - Lane Change Assist
  6. Likes Eric, Uwe, Dana, SBC Auto liked this post
  7. #34
    Magdeburg, Germany
    Freilauf = DSG's disengage the clutch when free-wheeling to save fuel
    Won't add that one to the WIKI as it's not an actual Acronym. You should find LDW/HCA, SWA/LCA, eBKV and a few other documented now. MXB is likely written MxB? If so, it's the combination of MQB & MLB platform.
  8. Likes andyvee liked this post
  9. #35
    Perhaps a link to the Acronym WIKI page would be good
    http://wiki.ross-tech.com/wiki/index...ommon_Acronyms
  10. Likes Eric, Uwe, cbx750p liked this post
  11. #36
    Jun 2017
    Anyone on FCWP?
  12. #37
    Maybe: "Forward Collision Warning Pedestrian"
  13. Likes hadez16 liked this post
  14. #38
    Jun 2017
    Could make sense...thanks
  15. #39
    Jun 2017
    (A)STA???
    Camera coding: STA
    Towing unit: ASTA
    Whats that?
  16. #40
    I'm not sure but in 69-Trailer the Selective Output Test shows ASTA_sensor_function_test as if that's a sensor.
    Similar RODs show Adv MVBs such as:
    [*IDE12009-IDE09554*] Anhängelast- und Stützlasterkennung: Werte - Spannungsversorgung [ASTA Trailer weight nose weight detection value - ASTA-Spannungversorgung]
    [*IDE12009-MAS01561*] Anhängelast- und Stützlasterkennung: Werte - Einheit [ASTA Trailer weight nose weight detection value - Einheit]
    Kilogramm (kg)
    Pfund (lbs)
    Fehler
    nicht codiert / nicht verbaut
    Messwert nicht verfügbar
    Do newer models have an optional trailer tongue weight sensor (or strategy built into the chassis control module that allows evaluation of the trailer load based on on the rear axle height and sensors)?
  17. Likes Uwe, PetrolDave liked this post
