ok update,
We tried a replacement , still no communication to module 95, tried a replavement LT3 Central Elec module- (address B4) this removed the 90B2 - Control module: Faulty error, but gave us 2 new ones
90EE - bus: Timeout
Test Complete - Active/Stored
90ED - bus: Error
still no connection to address 95,
I checked and get 2 x 12v and 2 x ground at the plug to the , not sure how to test CAN lines, any ideas?
I unplugged plug and scanned with and engine module threw up no communication errors so the must be alive to some extent
the
I think his leads me back to the module having a fault,
I'm thinking next step send pump away to get tested, any recommendations where to send it
or any other things to try feel free to suggest,
we still have , ESP and 1 other error light on and MOT due!!
Tuesday,09,August,2016,19:30:37:05805
VCDS Version: 16.8.0.1
Data version: 20160801 DS254
VIN: WV1ZZZ2EZC6032361 License Plate: EBAY MODULE
Chassis Type: 2E (2E - VW Crafter (LT3 / 2006 >))
B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (J623-CKTB) Labels: 03L-906-012-CKT.clb
Part No SW: 03L 906 012 Q HW: 03L 906 012 A
Component: R4 2,0L EDC H23 1860
Revision: 72H23--- Serial number: VWXDZ0L1001387
Coding: 0119401020040C080000
Shop #: WSC 00000 555 00117
ASAM Dataset: EV_ECM20TDI01103L906012Q 001011
ROD: EV_ECM20TDI01103L906012Q.rod
VCID: 326F53586539CCD264-8066
Readiness: 0 1 0 0 0
Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
Part No SW: 2E0 909 052 HG HW: 906 900 200 0
Component: IMMO 0805 1006
Revision: 00805000 Serial number: VWXDZ0L1001387
VCID: 6FE99A2C7E8BA13A4B-803A
Address 94: LT3 Airbag Labels: None
Part No HW: 9069014700
Shop #: WSC 00117 555 00000
ASAM Dataset: 3 3332
ROD: CRFT_AB_3_3332.rod (*)
VCID: 55A5C8C43417FBEAA1-8000
Address 96: LT3 Instruments Labels: None
Part No SW: 9069021601 HW: 9069019800
ASAM Dataset: 32 790
ROD: CRFT_KOMBI_32_790.rod (*)
VCID: 020FC3989519BC52B4-8056
Address 99: LT3 Ign. Switch Labels: None
Part No HW: 9069002000
ASAM Dataset: 67 257
ROD: CRFT_EZS_67_257.rod (*)
900F - ABS Control Module (J104): Emergency opening canceled
Test Complete - Stored
900E - ABS Control Module (J104): Emergency opening performed
900D - ABS Control Module (J104): Emergency opening detected
Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb
Component: HF-FFB 0805 1006
Revision: 00805000 Serial number: 12345678901234
Shop #: WSC 00117 555 186459
00171 - Key 1 not learned
Address 9B: LT3 Driver Door Labels: None
Part No HW: 9068204126
ASAM Dataset: 33 773
ROD: CRFT_FTUHR_33_773.rod (*)
9023 - Central locking; emergency opening activated: msg from elect. Ign./starter switch
Address B0: LT3 Roof Display Labels: None
Part No SW: 9069021000 HW: 9069010900
ASAM Dataset: 21 3
ROD: CRFT_DBE_21_3.rod (*)
VCID: 7BF1BE7CF2F3CD9AF7-802E
Address B4: LT3 Central Elec. Labels: None
Part No SW: 9069021901 HW: 9069011500
ASAM Dataset: 33 804
ROD: CRFT_EZE_33_804.rod (*)
VCID: 0505D88484378B6A91-8050
90EE - LIN bus: Timeout
90ED - LIN bus: Error
Address B6: LT3 Steering Wheel Labels: None
Part No SW: 9065402345 HW: 9065402345
ASAM Dataset: 72 257
ROD: CRFT_SML_72_257.rod (*)
VCID: 0607DF88B931807298-8052
End-------------------------(Elapsed Time: 03:14)--------------------------
I can clear all errors but they come back when the ignition is off and back on, the central locking tries to open the doors and this stores all the door emergency open errors
best regards
Andy
