- Joined
- Apr 9, 2014
- Messages
- 2,303
- Reaction score
- 2,250
- Location
- Tartu, Estonia
- VCDS Serial number
- C?ID=195131
Hi
Does anyone know what is the Sec.Acces for this module(18)? I know i have unlocked one of these before and taken the code from some other module, but i can't remember where. I tried searching for a hour, but gave up and used ODIS instead which was able to unlock it.
I have scans from 2 octavias which had the same fault. Second one was the one today i used ODIS on and first one i was able to unlock with VCDS.
1)
2)
PS! It does accept code 20103, but i guess this is only for adaption.
1)
Sunday,17,July,2016,14:06:21:36026
VCDS Version: 16.7.0.1 (x64) HEX-NET CB: 0.4321.4
Data version: 20160602 DS251
Dealer/Shop Name:
Workshop Code: 324 23454 056743
VIN: TMBAJ7NE9F0 License Plate:
Chassis Type: NE (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 20 2B 42 44 52 55 5F
69
VIN: TMBAJ7NE9F0 Mileage: 81643km-50730miles
Address 01: Engine (J623-CKFC) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 7545
Revision: 83H22---
Coding: 111D001A047401091000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM20TDI01104L906021DT 002007
ROD: EV_ECM20TDI01104L906021DT.rod
VCID: FAB8B9A47D536392F0-80AE
Part No SW: 0D9 300 041 P HW: 02E 927 770 AQ
Component: DQ250-6F MQB H52 4507
Revision: 05852204 Serial number: TFK01406020399
ROD: EV_TCMDQ250021.rod
VCID: A502BAD8A46D3C6AED-80F0
Part No SW: 5Q0 907 379 M HW: 5Q0 907 379 H
Component: ESC H31 0571
Revision: 00000000 Serial number: 61564000000475
Coding: 1A07629124230971007E060841CA245846249000608224F0F661F070C002
Shop #: WSC 73430 031 00063
ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
VCID: C6C01D54792BD772C4-8092
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 84
Mileage: 81574 km
Date: 2016.04.06
Time: 18:54:02
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0336697236
Coding: 030C0C
Shop #: WSC 73430 790 00000
ROD: EV_KessyHellaMQBAB_VW37.rod
VCID: BA3879A43DD3A392B0-80EE
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5E0 907 044 P HW: 5E0 907 044 P
Component: Climatronic H03 0907
Revision: 00001K06
Coding: 01010104004101011005000100101000
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: B2285184E5A35BD278-80E6
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0134
Serial number: 01011416400731
Coding: 0C031B76424722FB47E04000001807080C00000000000000000000000000
ROD: EV_BCMBOSCH_SK37.rod
VCID: 804CCB4C1B8F3942BE-80D4
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 140611 041 0570
Serial number: 140620092406
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y14M06D24H21M28S18
Coding: 00885D
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 D HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0048
Revision: -------- Serial number: 60831417101399
Coding: 0001050111
ROD: EV_EPHVA14AU3700000_SK25.rod
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 03061403210494
Coding: 00081800FE0739
VCID: B83C63AC03DFB18246-80EC
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P4PB8NV23
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: FF4E48B0667146BAC7-80AA
Subsystem 1 - Part No SW: ----------- HW: 454 000 806 14
Serial number: 3576U000000B59581015
Subsystem 2 - Part No SW: ----------- HW: 454 000 806 14
Serial number: 3586U000000FC078101A
Subsystem 3 - Part No SW: ----------- HW: 454 801 406 14
Component: SideSensor_Dr 111 0148
Serial number: 3516RFF80EF03000000Q
Subsystem 4 - Part No SW: ----------- HW: 454 801 406 14
Component: SideSensor_Pr 111 0148
Serial number: 3526RB91DE803000000G
Subsystem 5 - Part No SW: ----------- HW: 454 801 905 14
Component: FrontSensor_D 114 0149
Serial number: 3556V6F519F03000000I
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 DT HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 26051408491130
Coding: 6810
ROD: EV_SMLSKLOMQB_SK37.rod
VCID: 8B56EC6022C96A1ADB-80DE
Part No SW: 5E0 920 751 HW: 5E0 920 751
Component: KOMBI 304 4270
Coding: 07AC02182D80000801882A011000000000000000
Shop #: WSC 73430 031 12345
ROD: EV_DashBoardVDDMQBAB_SK37.rod
VCID: E288E1C4F5C38B52C8-80B6
Address 18: Aux. Heat (J364) Labels: 5Q0-963-272.clb
Part No SW: 5Q0 963 272 C HW: 5Q0 963 272 C
Component: STH-MQB 006 0069
Coding: 9309
VCID: B6206D9409CB47F254-80E2
Subsystem 1 - Part No SW: 5Q0 963 513 HW: 5Q0 963 513
Component: R149 T91-LIN 003 0301
Serial number: 00000000000000878105
0035 - Crash Signal
B1073 00 [009] - -
Reset counter: 39
Mileage: 81525 km
Date: 2016.02.01
Time: 16:51:29
Operating condition of parking heater: OFF
71
Coolant temperature of parking heater: 52 °C
Coolant temperature: 51 °C
Engine running status: detected
Fuel level: 34 l
Heater output: 0 W
Trying Address 19
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
Component: GW MQB High 128 1188
Revision: -------- Serial number: 0002170571
Coding: 030100340F087300EF00025A1C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear.rod
VCID: C2C801445503EB52E8-8096
Subsystem 2 - Part No SW: 5E0 919 719 A HW: 5E0 919 719 A
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000C0449080614
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 3254143703
Address 20: High Beam Assist. (J844) Labels: 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511
Component: FLA H04 0002
Revision: AA001001
Coding: 02018F6B74745D545420363E01
VCID: AB164CE0C2890A1A3B-80FE
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000139848004
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_VW37.rod
VCID: B424579C1FB755E26A-80E0
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000107406934
Coding: 00150120D000040000001100
VCID: C4C4075C4F17E562DA-8090
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000003032557
Coding: 010200
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 0102
VCID: C1CA0E485005F04AF1-8094
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000107749163
VCID: C3C604404A19E25AE3-8096
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000003013735
Coding: 190200
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 03CA02003F000000
Shop #: WSC 73430 790 00063
VCID: C0CC0B4C5B0FF942FE-8094
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Address 5F: Information Electr. (J794) Labels: 5E0-035-MIB-STD1.clb
Part No SW: 5E0 035 840 A HW: 5E0 035 840 A
Component: MU-S--ER 041 0435
Serial number: S3E02006141250
Coding: 03730100FF00000011110001000800002F0000840100010002
ROD: EV_MUStd4CPASE_AU37.rod
VCID: 9F0EA8308631E6BAA7-80CA
Subsystem 1 - Part No SW: 5E0 919 605 B HW: 5E0 919 605 B
Component: ABT_Std_Plus H50 0022
Serial number: SKZ8Z9PK6018DH
Address 69: Trailer (J345) Labels: 5Q0-907-383.clb
Part No SW: 5Q0 907 383 E HW: 5Q0 907 383 B
Component: Anhaenger H14 0137
Revision: 8C001001 Serial number: 0338296893
Coding: 0100000202000000
VCID: B93A66A838D5A88AB9-80EC
End-------------------------(Elapsed Time: 01:45)--------------------------
Sunday,31,July,2016,21:59:29:36026
VCDS Version: 16.7.0.14 (x64) HEX-NET CB: 0.4323.4
Data version: 20160726 DS254
Dealer/Shop Name:
VIN: TMBAJ7NE5F0 License Plate:
69
VIN: TMBAJ7NE5F0 Mileage: 53816km-33439miles
Revision: 83H22---
Coding: 111D001A043401091000
Shop #: WSC 73430 031 00104
VCID: FAB8B9A47D5363FB0B1-80AE
Revision: 05852204 Serial number: TFK01406020685
VCID: A502BAD8A46D3C03163-80F0
P1734 00 [002] - -
Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
Component: ESC H31 0371
Revision: 00000000 Serial number: 61674000000453
Coding: 1A076291242309710080060741CB245846249000608224F2F0610070C006
Shop #: WSC 23454 324 56743
ROD: EV_Brake1UDSContiMK100ESP_SK37.rod
VCID: C4C4075C4F17E50B21D-8090
Revision: 00021000 Serial number: 0336697846
Coding: 030C0C
Shop #: WSC 73430 790 00104
VCID: BA3879A43DD3A3FB4B1-80EE
Part No SW: 5E0 907 044 M HW: 5E0 907 044 M
Revision: 00001K06
Coding: 01010104004101011005000000101000
VCID: AF2E58F0F6917653ECF-80FA
Serial number: 01011416301019
Coding: 0C031B46424722FB47E04000001807280C00000000000000000000000000
VCID: 804CCB4C1B8F392B455-80D4
Serial number: 140620090914
Coding: 065DDD
Serial number: S4Y14M06D24H20M29S01
Coding: 00885D
Revision: -------- Serial number: 60831417101416
Coding: 0001050111
Serial number: 03061403210496
Coding: 00001A00FE0739
VCID: B83C63AC03DFB1EBBD5-80EC
Revision: -------- Serial number: 003P4PBDTXHV
VCID: FF4E48B0667146D33CF-80AA
Serial number: 3576U000000E54581013
Serial number: 3586U000000DD358101A
Serial number: 3516R8C8BEF03000000R
Serial number: 3526R4704E803000000/
Serial number: 3556V2D6BA603000000F
Part No SW: 5Q0 953 507 DR HW: 5Q0 953 549 C
Revision: -------- Serial number: 18061404221244
Coding: 1010
VCID: 895AD66828B5786312B-80DC
Coding: 07A402182980000801886A011000000000000000
VCID: E288E1C4F5C38B3B331-80B6
Address 18: Aux. Heat (J364) Labels: 5Q0-963-272.lbl
Coding: 9309
VCID: B6206D9409CB479BAF9-80E2
Serial number: 00000000000000878280
Revision: -------- Serial number: 0002172754
Coding: 030100340F087300EF00024A1C0F00010001050000000000000000000000
VCID: C2C801445503EB3B131-8096
Serial number: 000000000B1529120614
Serial number: 6132183703
Revision: AA001001
Coding: 02018F6B76765D525220343E01
VCID: AB164CE0C2890A73C07-80FE
Revision: 00000000 Serial number: 14000140189003
VCID: B424579C1FB7558B91D-80E0
Serial number: 0000107427369
Serial number: 00000000000003032351
Coding: 010200
Coding: 8102
VCID: C1CA0E485005F0230AB-8094
Serial number: 0000107752573
VCID: C3C604404A19E233187-8096
Serial number: 00000000000003002460
Coding: 190200
VCID: C0CC0B4C5B0FF92B055-8094
Coding: 3E0000
Coding: 3E0000
Part No SW: 5E0 035 864 A HW: 5E0 035 864 A
Component: MU-S-N-ER 041 0435
Serial number: S3F01306140697
Coding: 03730101FF00000011110001000800002F0000840100010046
Subsystem 1 - Part No SW: 5E0 919 605 D HW: 5E0 919 605 D
Component: ABT_Std_Nav H60 0030
Serial number: SKZ8Z9PT3002YA
Revision: 8C001001 Serial number: 0338294004
VCID: B93A66A838D5A8E342B-80EC
End----------(Elapsed Time: 02:10, VBatt start/end: 11.7V/11.7V)-----------
