2009 A6 with uncommon TPMS problem
Pete09
C?ID=271518
Hello Everyone,
I posted this problem on another popular Audi forum too and I am hoping some friendly folk will throw useful ideas to remedy my problem.
Please forgive me if I am making any errors in this post. My online search was so extensive that you could say I own the internets hehehe. I would greatly appreciate if anyone would help me find a solution to my problem.
Long story short, I replaced the headunit module with the one pulled out from 2007 model and now my indirect TPMS doesn't work from MMI menu.
See full explanation below;
I have 2009 audi a6 3.0T. It is one of the very last A6's with 2G MMI high and one of the very first with indirect TPMS (7k6). My car is bare stock with camera added.
Everything was working fine until I decided to retrofit back-up camera with 6C module. To do that I had to change the head unit (7) with the one that supports video. I must note that I bought used and working one
from 2007 A6 which had direct TPMS fitted. Then I had the component protection removed by the dealer and everything works fine except TPMS. I have this option in "Car" setting, but when I try to turn it on, it turns off after two seconds. It seems as if it was adapted for direct TPMS (7k3,7k4 or 7k5) as it has grayed out option to
show individual tire pressures. I believe the cars' TPMS works fine, because when I tempered with the abs module, I got ESP, ABS and TPMS lights on my dash. I was ready to pop my old head unit back in to copy all the adaptation values (currents' unit coding is the same and my channel 1 has TPMS on), but I fear it will be a wasted time and might trigger CP again. On top of this VCDS only allows for few channels to be changed in that module and it doesn't seem any of these are related except channel 01 which allows to turn on 7k3,7k4 and 7k5 system, but not 7k6.
VCDS in general doesnt support most of my modules.
Please let me know if you know of any solution to this or maybe advise me at least which direction should I take.
Should I get "7" module that was produced in 09 for my model or maybe dealer could code my head unit? Now new unit has the same HW(except "A" at he end for FBAS) and SW numbers as my original. All the numbers physically on the unit are identical to original unit except the serial and SW. Software on all modules is up to date too.
I want to keep the dealer out of this at least for now since their most common answer is to change the whole thing and charge 50% of the value of the car.
Let me know if additional details are needed. I could post pictures of tags on old and new "7" modules.
I tried;
- went through all available coding and long coding. ABS has no long coding and in coding only option available was "hitch added". 19 had also three bytes with litteraly 2 options. One byte had - "my 09> and my 09<". another was something about "standard". 4c had nothing.
- resetting relevant modules (3, 7, 19, 4c) by recoding them with the same value. Did this multiple times in different orders.
- did basic testing on ABS ch1. This couldnt be accomplished as the test never came back with "ok", but with error as if you were trying to access the channel without inputting security code. This followed with faults and warnings which disappeared after clearing the fault list.
- even disconnecting the battery for about 30min. This threw esp,abs and tpms warnings on the dash upon reconnect, which disappeared above 5mph.
-the only thing i didnt do was driving for more than 1hr, but i cant image this will make the menu in "car" appear properly.
Thanks in advance and I greatly appreciate any help!!!
VCDS scan;
Saturday,16,July,2016,14:15:25:60763
VCDS Version: 15.7.4.1
Data version: 20160216
Ross-Tech: Home
VIN: WAUSG74F39N017562 License Plate:
Mileage: 105790km-65734mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4C
4F 52 53 55 56 62 6C 72 77
VIN: WAUSG74F39N017562 Mileage: 105790km-65734miles
37-Navigation -- Status: Not registered 0001
6C-Back-up Cam. -- Status: Not registered 0011
Address 01: Engine (CCA) Labels: None
Part No SW: 4F1 910 551 A HW: 4F1 907 551
Component: 3.0l V6 TFSI 0030
Coding: 0105000A190F0120
Shop #: WSC 02325 785 00200
VCID: 21498CFAF824B13651-8074
Subsystem 1 - Part No: 4F1 910 551 A
No Faults Found
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 K HW: 09L 927 156 C
Component: AG6 09L 3,0TFSI USA 0040
Revision: --H04--- Serial number: 4492244
VCID: 2C576DCE8FE66C5EF2-8078
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AL HW: 4F0 614 517 BA
Component: ESP8 quattro H01 0060
Coding: 0020921
VCID: 6ED3A7C6797A5E4E9C-803A
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602601222254
Coding: 0000003
Shop #: WSC 02324 785 00200
VCID: 254198EAEC0C5D162D-8070
Subsystem 1 - Part No: 4F0 910 132 J
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 R HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 361IR067505481
Coding: 0000003
Shop #: WSC 02335 785 00200
VCID: 326B73B6ADC23AAEB8-8066
Subsystem 2 - Serial number: 00000001198453
Subsystem 3 - Serial number: 0113.10.080000000100010993
Subsystem 4 - Serial number: 010993
01327 - Control Module for Parking Aid (J446)
Reset counter: 155
Mileage: 105788 km
Date: 2016.07.16
Time: 13:49:46
Reset counter: 155
Mileage: 105788 km
Date: 2016.07.16
Time: 13:51:23
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000054 Serial number: 00000000580709
Coding: 0524326
VCID: 1C37BD0EDF469CDE82-8048
Part No SW: 4F0 910 279 N HW: 4F0 907 279
Component: ILM Fahrer H22 0320
Coding: 0013123
VCID: 346775AE57D6349EAA-8060
Subsystem 1 - Part No: 4F1 910 113 D Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00054547
Shop #: WSC 02335
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
VCID: 2B556ED24AE86B66FB-807E
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7H0434995
Coding: 0000100
VCID: 31697CBAA8C401B6C1-8064
Reset counter: 155
Mileage: 105778 km
Date: 2016.07.16
Time: 12:34:14
Address 15: Airbags (J234) Labels: None
Part No SW: 4F0 910 655 M HW: 4F0 959 655 F
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142373034303030314A55304C34463053
ROD: EV_Airba10AURB4.rod
VCID: 31697CBA60C401B6C1-8064
Subsystem 1 - Part No SW: 4F0 910 339 B HW: 4F0 959 339 B
Component: BF-Gewichtss. H03 0060
Serial number: 5810000R0000002UB5
Serial number: 3574SRB4000082588933
Serial number: 3584SRB40000822878FB
Serial number: 35152RB40317EMTAUKF.
Serial number: 35252RB40317EMTB4RJO
Serial number: 3554NRB4000047BA7B36
Serial number: 3564NRB4000047B9DFER
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90055082720042
Coding: 0002041
VCID: 275D92E296004F061F-8072
Component: E0221 H02 0030
Address 17: Instruments (J285) Labels: 4F0-920-xxx-17.clb
Part No SW: 4F0 920 951 D HW: 4F0 920 951 D
Component: KOMBIINSTR. H06 0133
Revision: 00200000 Serial number: 9IW28CGA8
Coding: 8B9F0A050300CF05020201
Shop #: WSC 02391 823 56573
VCID: 285F91DE5B1E407E16-807C
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 F HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0024
Revision: 4LA70021 Serial number: 2100L08A12862E
Coding: 000303
Shop #: WSC 54964 001 1048576
VCID: 326B73B66DC23AAEB8-8066
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0100
Reset counter: 155
Mileage: 105788 km
Date: 2016.07.16
Time: 13:50:38
Bin. Bits: 01111
Voltage: 12.50 V
Count: 7
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H47 0390
Revision: 00047003 Serial number: AUZ5ZBH8627785
VCID: 1A3BBB16D572E2EE90-804E
Part No SW: 4F0 959 760 C HW: 4F0 959 760 C
Component: MEM-FS H08 0062
Revision: AA000000 Serial number: 00001001165584
Coding: 00581300004011110000
VCID: 31697CBA68C401B6C1-8064
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H52 1100
Revision: 00000000 Serial number: 341LU087522563
Shop #: WSC 40832 444 85571
VCID: 387F419E4BBED0FE86-806C
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000100381955
Coding: 011F07204E40410001
VCID: 46833F66F14AB60E04-8012
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
Component: Komfortgeraet H28 0240
Revision: 02400028 Serial number: 01153730470000
Coding: 4618397
VCID: 356148AA5CAC2D969D-8060
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 910 223 M HW: 4F0 035 223 N
Component: Amp.-ASK-RD H07 0270
Revision: S1400000
Coding: 060000
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 A HW: 4F0 907 274
Component: J793 RKA+ H02 0100
Revision: 00000000 Serial number: 00008390030854
Coding: 0623301
Shop #: WSC 00477 128 36094
VCID: 224B83F6FD22AA2E48-8076
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000248535
Coding: 0002014
VCID: 5EB3F70689DACECE2C-800A
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000100406857
VCID: 4581386ACC4CBD160D-8010
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000222
Shop #: WSC 02145 785 00200
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Coding: 0000003
VCID: 3F8D2A826E90E7C647-806A
Part No SW: 4E0 910 541 T HW: 4F0 035 541 N
Revision: 00000000 Serial number: 379J5087539942
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000100376879
Coding: 010E07204040220001
VCID: 43852672C278832623-8016
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J752087
Coding: 1000404
VCID: 5DB1F00A84DCD5D635-8008
03006 - Back-up Camera System not calibrated
Reset counter: 155
Invalid
Invalid
Invalid
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000100376198
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005065854
Coding: 0010970
VCID: 285F91DE9B1E407E16-807C
End-------------------------(Elapsed Time: 04:08)------------------
I don't suppose you have a scan from before you swapped head units so people can compare before and after?
I do not think indirect TPMS was an option in 2007, so the older unit may simply not support it.
Pete09
C?ID=271518
Thanks for reply. I thought the same thing, but then I read posts of converting from direct to indirect and they made me wonder.
I actually do. See below:
Monday,04,July,2016,12:04:10:60763
Mileage: 105730km-65697mi   Repair Order:
          4F 52 53 55 56 62 72 77
VIN: WAUSG74F39N017562   Mileage: 105730km-65697miles
   Revision: --H02---    Serial number:
   Coding: 0020921
   Coding: 0000003
01176 - Key
                    Reset counter: 177
                    Mileage: 104916 km
                    Date: 2016.06.12
                    Time: 11:42:11
   Part No SW: 4F0 910 732 Q    HW: 4E0 035 729
   Revision: 00000000    Serial number: 303JZ087565358
   Coding: 0000003
   Coding: 0524326
   Coding: 0013123
   Coding: 00054547
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
                    Fault Status: 00111010
                    Fault Frequency: 10
                    Reset counter: 158
                    Mileage: 103472 km
                    Date: 2016.04.23
                    Time: 13:07:00
   Revision: 00000000
   Coding: 0000100
                    Reset counter: 143
                    Mileage: 105249 km
                    Date: 2016.06.19
                    Time: 19:10:19
   Coding: 0002041
   Coding: 000303
   Coding: 4618397
   Revision: S1400000
   Coding: 060000
            000 -  -  - Intermittent
                    Reset counter: 99
                    Mileage: 69821 km
                    Date: 2014.05.20
                    Time: 12:29:19
                    Voltage: 12.00 V
                    Temperature: 41.0C
                    Bin. Bits: 00000011
   Coding: 0623301
   Coding: 0002014
   Revision: --H05---
   Coding: 0000222
   Coding: 0000003
   Coding: 0010970
End-------------------------(Elapsed Time: 03:45)--------------------------
Dana
Western PA, USA
Thanks for the original scan.
I might have good news. According to the information I located 7K6 (via Adaptation channel 013) is only supported on modules 4F0 910 732 C and up. For that reason 4F0 910 732 R should support it but this is going to be experimental. Please create an Adaptation Function Control Module Map and post the result here wrapped in
 tags.
If you have time I would really like to see Adaptation and Measuring Block maps from 03 and Adaptation only from 15.  This is one of the rare cars with traditional 4F Bosch 8.0 ABS and the newer UDS protocol Airbags which use Adaptation channels that vary from our one and only Wiki page for the older units.  That info from this vehicle should enable me to make a new Airbag AU1042 page... or at the least fill in some of the unknowns the next time we have a support inquiry.
Dana
Western PA, USA
I don't want to leave you hanging over the weekend if I miss the map data.
1000 0000 0000 should represent with 7K6 in Adp 013. Please check me (I'm second guessing myself) but that should be Hex 0x800 or Dec 2048. I think you need to add 2048 to whatever the stored value is in channel 013. If in doubt, note the original value and change it to 2048 to make sure the module allows you to test/save.
Pete09
C?ID=271518
Thanks!
I will test that first thing I get home from work and update you guys!!!
I appreciate you helping me!!
Pete09
C?ID=271518
Dana... You are golden!!!!
That did the trick. I now have a request to store pressures upon entering TPMS in "Car" options just like original. ch.13 had 0 in it with options for +1 for acc and +2 for rvc. I simply added 2048.
I will map the whole ABS for you this weekend, I just need to find a moment when my wife is not around as she already is not talking to me for all the time spent on the research hehehe.
Thanks again!!!
Dana
Western PA, USA
Thanks for the feedback Peter! If you don't have time to map 03 and 15 this weekend please don't feel obligated. I had my Tiggy parked at the office window with a gap just large enough to fit a wire out the window and I think the office temp went up to 80F! Too damn hot out there. I'm going back into Netflix with air conditioning mode :)
Edit. Internal ref: FS#1150 - 4F0-910-7xx-07-H.lbl
Pete09
C?ID=271518
Yes it was too hot. Here in Edison NJ temps were hovering around 95, but that didnt stop my wife from dragging me out to the beach and having my back burnt... . AC was my friend for the remainder of the weekend :-D.
I will get to it one afternoon this week. I am glad i can help one way or another.
You can't REALLY be from NJ.
christopher-weyant-no-sweetie-we-don-t-go-to-the-beach-we-re-from-new-jersey-we-go-to-the.jpg
Pete09
C?ID=271518
Hahaha. Moved about 2 years ago so you are right on the money!!
Pete09
C?ID=271518
 tags.
Hi Dana,
Please see below. Is this what you were looking for? If not, let me know. I was not able to access Adaptation in 03 at all, even after I entered the security code. If there is a way to access it, then let me know and I will map it. Otherwise I checked every group/channel. I omitted a bunch of them because they were not available.
Let me know if you would like me to map anything else.
Thanks again:thumbs:
{03} Measuring block map:
Saturday,16,July,2016,13:18:46:60763
                Address 03: ABS Brakes  (4F0 910 517 AL)
13:56:29 Group 001: Wheel Speed
  0.0 km/h  Wheel Speed Front Left
  0.0 km/h  Wheel Speed Front Right
  0.0 km/h  Wheel Speed Rear Left
  0.0 km/h  Wheel Speed Rear Right
13:56:29 Group 002: Switches && Buttons
  0.0  Brake Test Switch
  0.0  Brake Light Switch
  Activated  Parking Brake Button
  0.0  ESP-Passive Button
13:56:29 Group 003: Engine Data
  0 /min  Engine Speed
  5.1 Nm  Engine Torque
  20.4 Nm  Engine Torque (loss)
  0.0 %  Throttle Valve Angle
13:56:40 Group 004: Standing Time && EDL-T Flag
  00:00  Standing Time
  OFF  EDL-T Flag
  N/A
  N/A
13:56:40 Group 005
  0.0°  Steering Angle Sensor (G85)
  0.00°/s  Turn Rate
  -0.33 bar  Brake Pressure
  0.00 m/s*2  Lateral Acceleration
13:56:40 Group 006
  11.54 V  Voltage Supply (Terminal 30)
  ON  Valve Relay
  OFF  Return Flow Pump Status
  02325  Workshop Code
13:56:48 Group 007: Installation Position
  Invalid  Install. Position Front Left
  Invalid  Install. Position Front Right
  Invalid  Install. Position Rear Left
  Invalid  Install. Position Rear Right
13:56:48 Group 008: Direction of Rotation
  Invalid  Direction Front Left
  Invalid  Direction Front Right
  Invalid  Direction Rear Left
  Invalid  Direction Rear Right
13:56:48 Group 009
  N/A
13:57:09 Group 014: Airbag Coding Info (not relevant)
  2  Error Code
  16  Error Code
  0  Error Code
  N/A
13:57:09 Group 015: Engine Coding Info (not relevant)
  0x0006  Hex Value
  0x0001  Hex Value
  0x000A  Hex Value
  0  Error Code
13:57:09 Group 016: Signals of Electro-Mechanical Parking Brake (not relevant)
  Valid
  0.00 m/s*2  Lateral Accel.
  0x0011  Hex Value
  0x0000  Hex Value
13:57:31 Group 020
  BB061009V 0502 0001 0000 CCA
13:57:31 Group 021
  Please use
  the first row
  for this
  data type
13:57:31 Group 022: Steering Angle Sensor Data (not relevant)
  0x0000  Hex Value
  8.92°  Steering Angle
  0x0000  Hex Value
  0x0000  Hex Value
13:57:40 Group 021: Data from ESP Sensor Unit -G419- (not relevant)
  4F0907637A__6261283W7HUY08R_010129-09-08
13:57:40 Group 021
  Please use
  the first row
  for this
  data type
13:57:40 Group 023: Variant Coding Data (not relevant)
   0001111  Bin. Bits
  N/A
  N/A
  N/A
13:58:21 Group 024
  01 00 00 00 01 00 00
13:58:21 Group 040
  Please use
  the first row
  for this
  data type
13:58:33 Group 040
  ICC: 21 FP: 24 FT: 01 aICC: 03
13:58:33 Group 040
  Please use
  the first row
  for this
  data type
13:58:50 Group 041
  ICC: 21 FP: 21 FT: 48 aICC: FD
13:58:50 Group 040
  Please use
  the first row
  for this
  data type
13:58:55 Group 042
  ICC: 21 FP: 21 FT: 49 aICC: FD
13:58:55 Group 040
  Please use
  the first row
  for this
  data type
13:58:58 Group 043
  ICC: 21 FP: 21 FT: 4B aICC: FD
13:58:58 Group 040
  Please use
  the first row
  for this
  data type
13:59:01 Group 044
  ICC: 21 FP: 21 FT: 50 aICC: FD
13:59:01 Group 040
  Please use
  the first row
  for this
  data type
13:59:04 Group 045
13:59:04 Group 040
  Please use
  the first row
  for this
  data type
14:00:10 Group 125: CAN-Databus Communication (Powertrain)
  Steer. ang. 1  Steering Angle Sensor
  Engine 1  Engine
  Transm. 1  Automatic Transmission
  Instruments 1  Instrument Cluster
14:00:10 Group 126: CAN-Databus Communication (Powertrain)
  Distance 1  Distance Regulation (ACC)
  Gateway 1  CAN-Gateway
  Park Brake 1  Electric Parking Brake (EPB)
  ESP Sens. 1  ESP Sensor Cluster
14:00:10 Group 127: CAN-Databus Communication (Powertrain)
  Level 0  Level Control
  Airbag 1  Airbag
  N/A
  N/A
14:01:22 Group 225
  0.0  (no units)
  0.0  (no units)
  0.0  (no units)
  0.0  (no units)
14:01:22 Group 226
  0.0  (no units)
  0.0  (no units)
  4.0  (no units)
  0.0  (no units)
14:01:22 Group 227
  255.0  (no units)
  0.0  (no units)
  N/A
  N/A
{15} Adaptation values:
Saturday,30,July,2016,14:02:38:60763
UDS Adaptation Channel: (1)-Airbag adaptations-Seat occupied recognition
Stored value activated
UDS Adaptation Channel: (2)-Airbag adaptations-Driver side active head restraint igniter
Stored value not defined
UDS Adaptation Channel: (3)-Airbag adaptations-Igniter for battery interrupt
UDS Adaptation Channel: (4)-Airbag adaptations-Key switch
Stored value Airbag deactivation key switch not parameterized
UDS Adaptation Channel: (5)-Airbag adaptations-Passenger side rear safety belt tension igniter
UDS Adaptation Channel: (6)-Airbag adaptations-Driver side rear safety belt tension igniter
UDS Adaptation Channel: (7)-Airbag adaptations-Center rear seat belt tensioner igniter
UDS Adaptation Channel: (8)-Airbag adaptations-Igniter for active head restraint on frt. passenger side
UDS Adaptation Channel: (9)-Airbag adaptations-Front passenger side seat belt tension igniter
UDS Adaptation Channel: (10)-Airbag adaptations-Driver side seat belt tension igniter
UDS Adaptation Channel: (11)-Airbag adaptations-Front passenger knee airbag igniter
UDS Adaptation Channel: (12)-Airbag adaptations-Driver knee airbag igniter
UDS Adaptation Channel: (13)-Airbag adaptations-Passenger side rear thorax airbag igniter
UDS Adaptation Channel: (14)-Airbag adaptations-Driver side rear thorax airbag igniter
UDS Adaptation Channel: (15)-Airbag adaptations-Front passenger head curtain airbag igniter
UDS Adaptation Channel: (16)-Airbag adaptations-Driver head curtain airbag igniter
UDS Adaptation Channel: (17)-Airbag adaptations-Passenger airbag igniter
UDS Adaptation Channel: (18)-Airbag adaptations-Driver airbag igniter
UDS Adaptation Channel: (19)-Airbag adaptations-Front passenger side airbag igniter
UDS Adaptation Channel: (20)-Airbag adaptations-Driver thorax airbag igniter
UDS Adaptation Channel: ESP coding information brakes
Stored value 10
UDS Adaptation Channel: ESP coding information drivetrain type
Stored value All Wheel Drive (AWD)
UDS Adaptation Channel: ESP coding information ESP1
Stored value 00
UDS Adaptation Channel: ESP coding information ESP2
Stored value 00
UDS Adaptation Channel: ESP coding information ESP3
Stored value 00
Stored value 00
UDS Adaptation Channel: ESP coding information vehicle variant
Stored value normal vehicle
UDS Adaptation Channel: GFA key
Stored value
UDS Adaptation Channel: IKA key
Stored value ERROR: Channel Not Available
Dana
Western PA, USA
Sorry I missed that post. I think that's all I needed - but I'll bump this back up if we need any additional info.
Thanks,
Dana
Dana
Western PA, USA
Hi Peter,
If you have the time I'd like to know if that 15-Airbag module will accept Security Access code: 20103. I believe the code in the pop-up balloon is incorrect and would like to test the alternative code if possible. A result such as Security Access Accepted would be a great sign and you'd want to exit the module at that point. I completely understand if you don't have the time.
Side note - Sebastian got the 7K6 TPMS Adp info added to that Control Head lbl file in the meanwhile so VCDS 16.8 contains the info we discussed above.
Pete09
C?ID=271518
Dana i will get that for you in about a week or so when i get back home from FL. Take care
Pete09
C?ID=271518
Hi Dana,
Sorry for delay. Code 20103 was accepted. Let me know of further tests.
I looked into 07... great that it's there. Might come handy to someone when replacing faulty head unit,
