2008 VW JETTA SEL PRNDS issues
johnpaulluna
C?ID=282120
///Quick Backstory///
Had issue with motor that controls A/C flap "erratic sound at startup near glovebox". got replacement part from junk yard in doing so had to disconnect battery. after replacing part-which works fine now. Had a ton of indicator lights. the most apparent was that I am no longer able to disengage the gear selector and the PRNDS is not visible on the MFD. I read where I could remove the boot from the gear selector and bypass the solenoid I put car in (D)rive and steering wheel indicator went away. The only ones that are still visible is the MIL, Light (I have a light out) stability control system.
Things I have done so far:
1. Verified all fuses
2. I tried a different Transmission Control Module (TCM) from a 2009 Jetta-no display of PRNDS
3. waited for my lucky star to appear at night so I wish upon it...maybe they are punishing me
Any assistance would be greatly appreciated.
VCDS Version: Release 15.7.4 Running on Windows 10 x86
Data version: 20160216
Saturday,09,July,2016,18:01:52:51409
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 56 62 65
72
VIN: 3VWRM71K68M147580 Mileage: 291940km-181403miles
02-Auto Trans -- Status: Cannot be reached 1100
Address 01: Engine (CBT) Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 BJ HW: 07K 906 032 Q
Component: 2,5l R5/4V G 1862
Revision: 1NH03--- Serial number: VWX7Z0H124C09S
Coding: 0000003
VCID: 72C527A36D67F0AE78-8026
049409 - No Communication with Transmission Control Module
U0101 - 008 -
Mileage: 291943 km
Time: 01:33:04
RPM: 765 /min
Load: 26.3 %
Temperature: 47.0°C
Temperature: 32.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.097 V
Readiness: 0110 1101
Address 02: Auto Trans
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0021122
VCID: 73CB22A7127DF9A673-8026
Part No SW: 1K0 820 047 HJ HW: 1K0 820 047 HJ
Component: Climatic PQ35 141 1010
Revision: 00141028 Serial number: 00000000000000
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Revision: 00H54000 Serial number: 00000007404611
Coding: 14058E234004150007140000001400000008730B5C000100000000000000
VCID: 71C728AF6861CBB681-8024
Component: Wischer 050308 021 0501
Coding: 00038805
Shop #: WSC 00066
Reset counter: 234
Mileage: 291943 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.95 V
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0278647
Coding: 0000000
VCID: 334BE2A752FDB9A6B3-8066
Reset counter: 233
Mileage: 291943 km
Time: 16:37:27
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M04JFZT
Coding: 0013889
VCID: 6CF939DB4F43265EB2-8038
Subsystem 2 - Serial number: 6332MSME2D1045488
Subsystem 3 - Serial number: 6342MSME35536E76L
Subsystem 4 - Serial number: 6351HSME1336190A0
Subsystem 5 - Serial number: 6361HSME13162F501
Subsystem 6 - Serial number: 63727SME124D2925+
Subsystem 7 - Serial number: 63827SME125B2B33%
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 051 0100
Coding: 0012021
VCID: 78D1158B0B1B9AFE46-802C
Component: E0221 002 0010
00002 - Transmission Control Unit
Part No SW: 1K0 920 974 J HW: 1K0 920 974 J
Component: KOMBIINSTRUMENT 3HL 2216
Revision: V0002000 Serial number: VWX7Z0H124C09S
Coding: 0023203
Shop #: WSC 00066 067 57207
VCID: 354FDCBF5C89A7969D-8060
Reset counter: 234
Mileage: 291943 km
Time: 01:33:18
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 220108F2001486
Coding: ED807F071013021002
VCID: 3041EDABA3EB82BECE-8064
Reset counter: 234
Mileage: 291943 km
Time: 16:45:18
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0004
Revision: 00005000 Serial number: 1293324T2X8P04
Coding: 0000003
VCID: 3957D08F709143F679-806C
015 - Cannot Be Tested at this Time - Intermittent - MIL ON
Fault Status: 10111111
Fault Frequency: 255
Reset counter: 95
Time Indication: 15
Reset counter: 55
Reset counter: 16
Time Indication: 15
Component: IMMO 3HL 2216
Shop #: WSC 58402 001 1048576
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1133
Revision: 32008001 Serial number: 00000088088110
Coding: 0001205
VCID: 3B5BCA877AAD71E66B-806E
Fault Status: 00100101
Reset counter: 17
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.070 H08 1901
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DC00
VCID: 0429717B47D3CE1E5A-8050
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No SW: 1K6 035 456 B HW: 1K6 035 456 B
Component: 08K Audioverst. 0006
Revision: 00004000 Serial number: 00000008140024
VCID: 2B7BFAC78ACDE166FB-807E
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1133
Revision: 32008001 Serial number: 00000040188221
Coding: 0001204
VCID: 3C59C99B7FA376DE62-8068
Reset counter: 17
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7H2188153
Coding: 0010400
VCID: 297700CF8031F37609-807C
00003 - Control Module
014 - Defective
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1120
Revision: 12006001 Serial number: 00000002785209
Coding: 0001168
VCID: 3E5DC39369BF64CE4C-806A
00934 - Electric Window Motor; Rear Left (V26)
Reset counter: 17
Component: RDK 0450
Coding: 0100101
Shop #: WSC 92724 999 796063
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1120
Revision: 12006001 Serial number: 00000002793391
Coding: 0001168
VCID: 3FA3BE976EB56DC647-806A
End-------------------------(Elapsed Time: 01:30)--------------------------
Lucky star.....
Did you check the TCU for power and grounds at module?
What part number module is in the car currently?
I
johnpaulluna
C?ID=282120
Lucky star.....
I
I believe the part # is 09G 927 750 HE. Regarding your first comment, how exactly do I check power at the module? Do you mean check the pins with the TCM removed?
Yup.......
Time to get a repair manual and trace via WD.
Learn how to use a meter and test light by searching YouTube videos.
johnpaulluna
C?ID=282120
Yup.......
If a wire is fried so to speak, do you feel that one of the fuses might have gone out in the process?
