I think the factory condition Auto-Scan (or most recent scan with the MIB1 installed) would help.
Sunday,15,January,2017,17:07:53:05573
VCDS Version: 17.1.1.0
Data version: 20170106 DS267.0
VIN: WVWZZZAUZFW****** License Plate:
Mileage: 51034km-31711mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 3C 42 44 47 52 55
5F 65 A5 A9 C0
VIN: WVWZZZAUZFW****** Mileage: 51034km-31711miles
Address 01: Engine (J623-CUNA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 EQ HW: 04L 907 309 A
Component: R4 2,0L EDC H22 8360
Revision: 81H22---
Coding: 091D0032036405083000
ASAM Dataset: EV_ECM20TDI01104L906021EQ 002011
ROD: EV_ECM20TDI01104L906021ER.rod
VCID: 78F42609C3C68E81ED-802C
Part No SW: 0D9 300 041 Q HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4504
Revision: 05853104 Serial number: TFK01504011518
ROD: EV_TCMDQ250021.rod
VCID: 2648387159F2C8718F-8072
Part No SW: 3Q0 907 379 R HW: 3Q0 907 379 G
Component: ESC H42 0711
Revision: 00000000 Serial number: 60935000002968
Coding: 01FA6BA13423096F077A0608C1C8A980D62C90E0608395F51862508A4289
VCID: 499293CDE8ACC70942-801C
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0365830359
Coding: 030C0C
VCID: 3A70FC01BD4A5C91DB-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020114202400011105000200101000
VCID: 6AD00C418D6A2C116B-803E
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011510602060
Coding: 00111E66C24122FB0BA44080B11C07281800000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 00044EE99B16C641D5-8054
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150403 043 0551
Serial number: 150410040138
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S3Y15M04D20H00M25S18
Coding: 1EA8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150750Y1C
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000062141643
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.403 H03 0004
Serial number: 0000FST0008DFNN00000
Coding: 181901
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 F HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0047
Revision: -------- Serial number: 39431510500062
Coding: 0031165051
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: 428084E1D59A145183-8016
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 24031503273603
Coding: 001C1700FE0739
VCID: 3874E60983464E812D-806C
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 HW: 5Q0 907 376
Component: DAEMPFUNGS-SG H16 0115
Serial number: 24031541350375
ROD: EV_DRCONTITEMIC.rod
VCID: 76E82831C9D2F8F1FF-8022
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR0DSP8I
VCID: 7F06CD15E6E8B9B9AC-802A
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34169667B19041510022
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34169668B17041570842
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 204 15
Serial number: 35767000000007B8B31Q
Subsystem 4 - Part No SW: ----------- HW: 480 001 304 15
Serial number: 35867000000AAB70141U
Subsystem 5 - Part No SW: ----------- HW: 480 400 904 15
Serial number: 3516502AD1A87850B26H
Subsystem 6 - Part No SW: ----------- HW: 480 400 904 15
Serial number: 3526502AB1A878517117
Subsystem 7 - Part No SW: ----------- HW: 480 400 904 15
Serial number: 3556502C9194131463A3
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 EC HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 15041504400949
Coding: 0C10
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 7BFE3905F2F0A59980-802E
Part No SW: 5G1 920 757 HW: 5G1 920 757
Component: KOMBI 301 4310
Coding: 07AD09987E9C000804887E0F5400000000000000
VCID: 6BDE09458290351910-803E
16777014 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Reset counter: 104
Mileage: 50823 km
Date: 2017.01.14
Time: 15:41:09
16776989 - Databus
Reset counter: 104
Mileage: 50823 km
Date: 2017.01.14
Time: 15:41:10
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 F
Component: GW MQB High 128 1204
Revision: -------- Serial number: 0003390353
Coding: 030100040F087300FF00027E9D0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011020
ROD: EV_GatewLear_011.rod
VCID: 72E01421A5BAE4D1D3-8026
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0040
Serial number: 29150000730720045153
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 2520616303
131595 - Tire Pressure Monitoring Module
U0127 00 [008] - No Communications
Reset counter: 104
Mileage: 50823 km
Date: 2017.01.14
Time: 15:41:07
Supply voltage: Terminal 30: 14.7 V
Terminal 15: On
65798 - Extended CAN in One-Wire Mode
U0054 00 [008] - -
Fault Frequency: 73
Reset counter: 104
Mileage: 50823 km
Date: 2017.01.14
Time: 15:41:10
Terminal 15: On
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000091730001
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_SK25.rod
VCID: 346CD2399F2EAAE101-8060
Address 3C: Lane Change (J1086) Labels: None
Part No SW: 5Q0 907 686 A HW: 5Q0 907 686 A
Component: HRE_Master H11 0066
Serial number: 0364164866
Coding: 02011103
ASAM Dataset: EV_HREntryHella 001024
ROD: EV_HREntryHella.rod
VCID: 3B7EF905B2706599C0-806E
Lane Change Assistant 2:
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 230315BCM00796
Coding: 003F1220D000048000001000
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000005805248
Coding: 110000
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 9303
ROD: EV_SteerAssisMQB_VW31.rod
VCID: 3776E5358E5841F924-8062
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H30 0150
Revision: 00000001 Serial number: VWZ8Z1GBA02AEXN
Coding: 120000008AAA008A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001002
ROD: EV_AMPMst11CGen2ALPI.rod
VCID: 6DDA075DBC843B290E-8038
0522 - Center speaker
B1069 13 [009] - Open Circuit
Reset counter: 65
Mileage: 50764 km
Date: 2017.01.12
Time: 06:39:33
Voltage terminal 30: 11.4 V
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 020415BD205411
Coding: 003F1020DE00048000801000
VCID: 41828BEDD09C0F499A-8014
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000005921294
Coding: 090000
B1487 54 [009] - Missing Calibration / Basic Setting
Reset counter: 63
Mileage: 50764 km
Date: 2017.01.12
Time: 06:41:20
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 029203104F010200
VCID: 40848EE9DB96064195-8014
Subsystem 1 - Part No SW: 3D0 941 329 D HW: 3D0 941 329 D Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 900000
Subsystem 2 - Part No SW: 3D0 941 329 D HW: 3D0 941 329 D Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 900000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-HGH1.clb
Part No SW: 5G0 035 021 C HW: 5G0 035 021 B
Component: MU-H-TND-EU H44 0376
Serial number: A330D0F7520223
Coding: 027300010000000011111202000800101F0202F4010001009F
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_VW37.rod
VCID: 1A301C811D8A7C913B-804E
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU301E7E
Subsystem 2 - Part No SW: V03 959 801 DG HW: -----------
Component: ECE 2016/2017 --- 0153
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 1010
B201A 00 [009] - -
Reset counter: 63
Mileage: 50764 km
Date: 2017.01.11
Time: 18:44:00
Voltage terminal 30: 14.9 V
Status_Software_Version_Management-SW_VersMgtInfo: MMIBLite/MIBLite
6919 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 106
Mileage: 50823 km
Date: 2017.01.14
Time: 15:41:09
Voltage terminal 30: 15.2 V
7175 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 106
Mileage: 50824 km
Date: 2017.01.14
Time: 15:41:32
BAP-BAP_Function_ID: 02
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000019474
ROD: EV_RDKBERU30_006.rod
12652550 - invalid data record
B2005 00 [009] - -
Reset counter: 63
Mileage: 50764 km
Date: 2017.01.11
Time: 18:18:59
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 F HW: 5Q0 980 653
Component: MQB_MFK H06 0052
Serial number: 10000341309
Coding: 0101020001020303020400010100000100
ROD: EV_MFKBoschAU370.rod
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 150311200428
ROD: EV_SoundActuaGen2AU64X_VW26.rod
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 5G0 907 160 HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0006
Serial number: 150324201384
ROD: EV_ActuaForExterNoiseUDS_VW12.rod
VCID: 63CE61656A407D59A8-8036
End-------------------------(Elapsed Time: 06:08)--------------------------
Do you need more autoscan @DV52?
2016 Golf Estate, 1.8T CXBB
Component: MIB2_lite_amp H20 0130
Revision: 00000001 Serial number: VWZ8Z1FBA01355K
Coding: 2200000000AAAAAA000000000000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: ED9DCAE33C790554F4-80B8
2016 Golf R, 2.0T CYFB, manual transmission
Revision: 00000001 Serial number: VWZ8Z1FBA0197N3
2015 GTI 6MT
Part No SW: 5G0 035 456 HW: 5G0 035 456
Component: MIB_lite_amp H30 0042
Serial number: VWZ8Z1EC40128KV
Coding: 22000000AAAAAA0000
ASAM Dataset: EV_AMPMst11CALPI 001005
ROD: EV_AMPMst11CALPI.rod
VCID: 63EB4B376AD8C75ADD-8036
Ok, I did try coding
with mib2 cracked installed and wait activation coding.....
When I re-write mib1's amplifier coding string, radio was mute equally
After some minutes with car turn off, audio was ok with central subwoofer error....
Does anyone here know if I am able to transplant Dynaudio speakers off an MKVI Golf to upgrade my MKVII Golf Fender speakers? Should be plug-n-play no? Tweeters in A-pillars and rear doors have two wire set ups for both MKVI Dynaudio & MKVII Fender. Front and rear mids have two wires in MKVI Dynaudio and 4 wires in MKVII Fender.
I've been following this thread closely to also hopefully re-code my MIBII into a Dynaudio unit and transplant speakers.
quailallstar,
where you ever able to get this to work. i just converted from a 2011 Golf TDI with Dynaudio/RCD510 to a new 2017 Golf SEL with Fender/Discover Media. i have only had it a week but already find myself missing Dynaudio sound quality. i did not keep my mk6 speakers but would be willing to buy the mk7 ones from some of the euro links or eBay, if it is adaptable to the MIBII unit and amp.
