Bought a 2002 Audi A4 1.8t (AMB) Quattro with tiptronic. Head was warped and breather hoses/vacuum lines were a mess.
Rebuilt head and straightened out all the vacuum lines, check valves etc.
After everything was straightened out, had 2 codes coming back consistently.
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Control Module Part Number: 8E0 909 518 F HW: 8E0 909 018
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 0016751
Work Shop Code: WSC 63351 000 00000
VCID: 336E048F518479A6B3-515A
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 001 - System too Lean - Intermittent - MIL ON
16804 - Catalyst System; Bank 1
P0420 - 002 - Efficiency Below Threshold
Readiness: 0000 1101
ABS controller was out getting rebuilt and has since been reinstalled and cleared.
Group 32 was showing +25% on Adaptation (Partial) and a run to reline showed the MAF not getting more than 90g.
Replaced MAF with Bosch unit part # 0280218063 which matches unit in car originally.
Code 17536 is now gone.
Now only remaining code is 16804
I have a screen shot of Measuring blocks but cannot figure out how to paste here
Info from engine group on screen shot is as follows:
Group MB1 MB2 MB3 MB4
032 0.0% 9.4%
034 800/min 485C 1.632 B1-S1 OK
043 800/min 555C 0.245 V B1-S2 OK
I monitored these for an hour today and the Adaptation (Partial) would float between 9.4% - 15% and the Catalyst temp between 555C and 645C
I did look at the catalyst through the front O2 sensor hole and it looked intact. The front O2 had a white coating that looked like powder. Similar to a spark plug when running lean. I cleaned off what I could.
Just trying to determine what step to take next. Don't mind replacing parts, just want to replace the right ones.
032 0.0% 9.4%
