Surface Pro Communication fix, Alter the Power settings.
Santos
We've had a few reports of HEX-NET users having coms issues with the Surface Pro tablet. We've found a fix requiring a registry tweak, and a power management setting. By default, the surface pro will only have balanced power settings with very little control over the management. The following instructions will re-enable the individual settings.
Registry Modification: Script:
Right Click, Save As
Then run the file and reboot.
Come back to this thread and see "Disable wireless Adapter power savings"
If you are not comfortable running a registry script, follow the instructions below.
Registry Modification Manual Instructions:
Step 1: Open Regedit.exe (search from start menu is the fastest way to get to it)
Step 2: navigate down the registry tree:
HKEY_local_Machine -> System -> ControlSet001 -> Control -> Power
Double Click CsEnabled and change the stored value to 0. Then press ok.
Step 3: reboot
Santos
Disable wireless Adapter power savings:
Step 1: right click on the window start menu, and select power options
Step2: to the right of the Balanced (recommended) profile, Click on Change plan settings.
Step 3: click on the Changed Advanced Power settings link
Step 4: click on + next to Wireless Adapter Settings. Click on + next to Power Saving Mode:
Change the On battery profile to Maximum Performance.
Click ok.
Reboot, and rescan!
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Santos, screen-shot above You make on Win 10? :) I ask because i don't want W10 on my PC, even Win8 but i have to know when customer come with another machine & OS... My screen on W7:
Santos
Hi Bojan, Yes, it was taken with win 10. Win 8 should look very similar as well.
