Results 1 to 10 of 14
Thread: Audi A4 petrol 3.2 CLCA 2009 non start
    Hi all please see attached scan
    we have a ~Fault codes P3053 starter returned message 50 short to ground
    P3088 stater relay electrical malfunction no signal communication
    There is no live data for engine ecu first in VCDS and also in snap on scanner
    We have checked starter, works fine through starter relay. (Both small starter relays J53 and J695 work fine) is not being earthed out by ecu through pin T94 77 .
    The ignition switch I Believe is working correctly as the warning light for press clutch pedal does not retun when pressed/operated correctly so im presuming ecu is recieving mesage that ignition switch wants to start
    I Am hoping someone has had this Problem or can see where im going wrong with testing this System
    Thanks Phillip Winkworth
    Friday,29,April,2016,13:11:21:27229
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    VIN: WAUZZZ8K49A083864   License Plate: BEN
    Mileage: 131080km-81449mi   Repair Order:
    Chassis Type: 8K (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 72
    VIN: WAUZZZ8K49A083864   Mileage: 131080km-81449miles
    Address 01: Engine (J623-CALA)       Labels: 06E-907-559-CAL.clb
       Part No SW: 8T0 907 559 E    HW: 8T0 907 559 A
       Component: 3.2 SIMOS8.2  H02 0001
       Revision: --------
       Coding: 01040003180F0119
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM32FSI8T0907559E A01001
       ROD: EV_ECM32FSI8T0907559E.rod
       VCID: 448CDEBCCFF1821E1A-8010
    7 Faults Found:
    6480 - Starter Control; Returned Message
              P3053 00 [228] - 50 Short to Ground
              MIL ON - Intermittent - Not Confirmed - Tested Since Memory Clear
                        Mileage: 131088 km
                        Date: 2016.04.20
                        Time: 19:26:05
    6484 - Starter Relay
              P3088 00 [228] - Electrical Malfunction
                        Mileage: 131088 km
                        Date: 2016.04.20
                        Time: 19:26:05
    6360 - Manifold Pressure Sensor (G71)
              P1156 00 [036] - Open/Short to Ground
                        Mileage: 1048574 km
                        Time: 00:00:00
    6473 - Camshaft Timing Adj. Bank1 (N205)
              P1528 00 [036] - Open Circuit
                        Mileage: 131088 km
                        Date: 2016.04.22
                        Time: 18:24:39
    6476 - Camshaft Timing Adj. Bank2 (N208)
              P1536 00 [036] - Open Circuit
                        Mileage: 131088 km
                        Date: 2016.04.22
                        Time: 18:24:39
    6467 - Bank1; Exhaust Cam Adjustment Valve 1 (N318)
              P1050 00 [036] - Open Circuit
                        Mileage: 131088 km
                        Date: 2016.04.22
                        Time: 18:24:39
    6470 - Bank2; Exhaust Cam Adjustment Valve 2 (N319)
              P1054 00 [036] - Open Circuit
                        Mileage: 131088 km
                        Date: 2016.04.22
                        Time: 18:24:39
    Readiness: 0110 0101
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 AD    HW: 8K0 907 379 AD
       Component: ESP8 quattro  H04 0060
       Coding: 0D0D00
       VCID: 7BFE6540FA8F3DE62B-802E
       Part No SW: 8K0 907 064 C    HW: 8K0 907 064 C
       Component: BCM2 1.1      H70 0134
       Coding: 031100
       VCID: 3064826C63490EBECE-8064
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: ELVAUDIB8  H36 0041
       Part No SW: 8T2 820 043 S    HW: 8T2 820 043 S
       Component: KLIMA 3 ZONEN H06 0140
       Revision: D0000000    Serial number: 0117.07.081049
       Coding: 46040000
       VCID: 4280D8A4DDE58C2E28-8016
       Part No SW: 8K0 907 063 A    HW: 8K0 907 063 A
       Component: BCM1 1.0      H22 0253
       Revision: 02022001    Serial number: 00000000183865
       Coding: 690040B10034A7010001000000005F5F0F1D020800000141000000
       VCID: 2D5A9B18747B6356E5-8078
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 110708  H05 0070
       Coding: 00FD11
       Component: RLS  H04 0003
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
       Component: AirbagVW-AU10 H26 0410
       Serial number: 0038JD17THLW
       Coding: 30363434363030303030554A3052384B3053
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 3C7CA65CB701FADE62-8068
       Serial number: 6334MSME3E36104BF
       Serial number: 6344MSME3E15480BK
       Serial number: 6352QSME78763A51O
       Serial number: 6362QSME6C597809Y
       Serial number: 63732SME7E7048354
       Serial number: 63832SME6B79266DH
       Component: Lenks.Modul   H13 0013
       Revision: --------    Serial number: 90304HGL0006K
       Coding: 000016
       VCID: 3D7AAB58A41BF3D655-8068
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 980     HW: 8K0 920 980
       Component: KOMBIINSTR.   H16 0221
       Revision: 00200000    Serial number: 99256NM78
       Coding: 2F04090003002600010000
       VCID: 6FE64110BEF7514697-803A
       Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0091
       Revision: GB102039    Serial number: 3900G08710813E
       Coding: 000303
       VCID: 4688C4B4F1CDB00E04-8012
       Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
       Component: J367-BDM  H04 0150
                000 -  -  - Intermittent
                        Fault Frequency: 21
                        Reset counter: 203
                        Mileage: 131088 km
                        Date: 2016.04.18
                        Time: 16:35:00
                        Reset counter: 203
                        Mileage: 131088 km
                        Date: 2016.04.22
                        Time: 18:03:53
    01312 - Powertrain Data Bus
                        Reset counter: 203
                        Mileage: 131088 km
                        Date: 2016.04.22
                        Time: 18:03:53
       Part No SW: 8K0 959 793 B    HW: 8K0 959 793
       Component: TSG FA        H10 0170
       Revision:             Serial number: 0000007437035
       Coding: 011C02205001410001
       VCID: 3F86D150AE17E1C647-806A
       Revision: 00002001    Serial number: 0112917544
       Coding: 011B0622003904C0003001
    01134 - Alarm Horn (H12)
                        Reset counter: 163
                        Mileage: 131088 km
                        Date: 2016.04.18
                        Time: 16:36:27
    02616 - Fuel Tank Cap; Unlock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 163
                        Mileage: 131088 km
                        Date: 2016.04.18
                        Time: 16:47:12
    02615 - Fuel Tank Cap; Lock
                        Reset counter: 163
                        Mileage: 131088 km
                        Date: 2016.04.18
                        Time: 16:56:13
    Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
       Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
       Component: DSP STD       H07 0220
       Revision: S1900000
       Coding: 0203010101
       VCID: 6ED85C14B9FD584E9C-803A
       Part No SW: 8K0 959 792 B    HW: 8K0 959 792
       Component: TSG BF        H10 0170
       Revision:             Serial number: 0000007486660
       VCID: 3E78AC54A91DE8CE4C-806A
       Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
       Component: EPB Audi B8   H05 0060
       Revision: 00000003    Serial number: 00000000180888
       VCID: 31628768684307B6C1-8064
    Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
       Part No SW: 8T2 035 195 H    HW: 8T2 035 195 H
       Component: Symphony3     H02 0210
       Revision: 00000004    Serial number: AUZ5Z4H1029303
       Coding: 0502008001010D004359070000
       Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
       Component: Display
       Part No SW: 8K0 959 795     HW: 8K0 959 795
       Component: TSG HL        H06 0170
       Revision:             Serial number: 0000007490103
       Coding: 010C02204001210001
       VCID: 7F069150EE9721C607-802A
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
       Part No SW: 8K0 959 794     HW: 8K0 959 795
       Component: TSG HR        H06 0170
       Revision:             Serial number: 0000007451427
       VCID: 7EF86C54E99D28CE0C-802A
    End-------------------------(Elapsed Time: 02:27)--------------------------
    16.4905 S, 151.7375 W
    ...we have a ~Fault codes P3053 starter returned message 50 short to ground
    - I would recommend to use the Factory wiring Diagrams and check the starter relay's connections,
    sounds like the ECM is not seeing the return message(positive voltage) from the (D97) circuit.
    - There is a lot of information about the starter in the ECM's Advanced Measuring Value Blocks, when using VCDS.
    Simply use the 'filter' filed box in the Advanced Measuring Values
    - You should see these values (and more), when you enter the key word "Starter" ...
    277 = Starter control; clutch switch
    278 = Starter control; interlock switch
    279 = Starter; measure-back wire term. 50 R
    280 = Starter; start relay 1
    281 = Starter; start relay 2
    282 = Starter; starter request terminal 50
    - If the other codes [Open Circuit] do not clear check the SB7 fuse.
    For more information about checking these types of fault codes, please see this Ross-Tech forum page.
    Testing - Open Circuits, Short to Ground or Positive, etc
    Hope this helps,
    drpeter
    I don't suppose the Starter Relay, the Manifold Pressure Sensor, and the Cam Adjusting Solenoids all have a common source of power?
  5. Likes Jack@European_Parts liked this post
  6. #4
    I'd probably have a quick look at J329 ( Terminal 15 Relay ) via WD with all shared on its tracks, and after all respective fuses were FIRST verified.
    Be careful:
    The WD has specific criteria related to date of production for this vehicle for line changes.
    You marked the engine code incorrectly in your title, however, VCDS saves the day.
    Audi A4 petrol 3.2 CLCA <<<<<<<<2009 non start
    Address 01: Engine (J623-CALA) <<<<<<<<< Labels: 06E-907-559-CAL.clb
    Revision: --------
    Another reason for the consistency check with JPPSG.
    Note to OP:
    If you find you would not like me to help in this thread, kindly ask me not to, and I will stay away.
    Above Magic!
    Hi...
    - I was thinking that too at first, then looking at the diagram I see:
    Positive battery power from Battery to the SA2 Fuse
    - Fuse SA2 provides 30-power to the J757
    - The SB7 fuse is powered by the J757-ECM relay
    - SB7 provides power to the [G71, N205, N208, etc...]
    Also...
    - Fuse SA2 also provides 30-power to the J329-Terminal 15 power
    - The J329 then provides power (terminal-50) to the Starter relays J53 and J695.
    - So I would imagine there would be no 15-power if we lost the common power source, SA2 Fuse... \
    I would like to add that I would verify the starter relays have power on the [86-terminal] and then to see if there is ground/[85-terminal] coming from the ECM.
    - Use a good wiring diagram...
    drpeter
  8. Likes Jack@European_Parts, Uwe liked this post
  9. #6
    It might be a good idea to know why this exists.
    Fault Frequency: 21
    Reset counter: 203
    Mileage: 131088 km
    Date: 2016.04.18
    Time: 16:35:00
    Reset counter: 203
    Mileage: 131088 km
    Date: 2016.04.22
    Time: 18:03:53
    Reset counter: 203
    Mileage: 131088 km
    Date: 2016.04.22
    Time: 18:03:53
    or these
    Reset counter: 163
    Mileage: 131088 km
    Date: 2016.04.18
    Time: 16:36:27
    Reset counter: 163
    Mileage: 131088 km
    Date: 2016.04.18
    Time: 16:47:12
    Reset counter: 163
    Mileage: 131088 km
    Date: 2016.04.18
    Time: 16:56:13
    Above Magic!
  10. Likes DrPeter, Uwe liked this post
  11. #7
    VCDS Super-User
    Mar 2014
    Check TSB 2022649 (about the P3053 ) - Maybe affected by bad ECU
  12. Likes NEtech, Uwe, DrPeter, Jack@European_Parts liked this post
  13. #8
    - I did not see your statement above.
    You will NOT see the ECM grounding the T94/77 pin at the ECM, this is a monitoring circuit, to watch the starter signal, 50-power. When the starter gets 50-power the ECM need to know, this is how it knows. Sorry about that..
    Any way, the ECM will be grounding the two relays from ECM Pins T94/8 and T94/30 to deliver the 50-power to the starter. Check these two terminals...
    also. . . .
    Quote Originally Posted by vagtuning View Post
    Hi...
    I saw the above mentioned TPI:2022649/3 earlier when doing a little research too, Date: 24-Aug-2010 and it does state the following:
    "Engine does not start in automatic start. If the ignition key is held, the engine starts without problems."
    - So it is a good document to reference, I would not condemn the ECM, yet ...
    drpeter
  14. Likes Uwe, Jack@European_Parts liked this post
  15. #9
    Well I'm glad I'm not the only one who misreads a post or makes a mistake.
    OP....... Peter just made me think of something.
    Is it possible someone installed an aftermarket starter lock out device for FOD?
    Above Magic!
  16. Likes DrPeter liked this post
  17. #10
    First of all Thank you for all your excellent replies
    we decided to save and clear codes and see what came back, the fault codes for camshaft and manifold were caused by us swapping around two of the same relays one for engine managment, the reason for this is erwins layout of this fuse box in scuttle for both left and right hand drive are different to this cars, it does not show both the small starter relays (which id already swapped around all same part numbers) while iv been off even though the two relays tested fine two new relays were fitted
    Drpeters reply for advanced measurng blocks was nice didnt know it existed, when key pressed and held all start blocks selected turned from zeros to 1 exept Starter; measure-back wire term. 50 R, not only did it not switch also starter relay two direct feed to starter motor only switched very briefly, we soldered a wire into old relay 2 for earth which goes rightly to pin 94/30 ecu, when starer switch operated this remained 12volts We decided to earth pin through wire when key pushed in, this operated starter motor and started, so all other systems work fine exept this one
    However as is so often the case the good or bad news is i removed this relay unsoldered wire refitted and its been starting fine since and even with the new relay so tomorrow im going to have a looked at the connection on the rear of relay holder to see if theres a bad connection
    I had already test this wire back to ecu for continuatey it was good tomorrow i I will isolate it and load test it
    I Will get back to you with results if there anything you can see i need to do please let me Know
    Thanks again Phillip Winkworth
  18. Likes Jack@European_Parts, Uwe liked this post
