2015 VW Polo Blue GT ( UK)
Phil
C?ID=122638
I have a Blue GT with powered folding mirrors & rvc.Is it possible to activate passenger mirror tilt when in reverse gear?BCM PQ26 Hi4R H0 7 0065.
Any advice would be appreciated.
Please post an Auto-Scan so people can see how the car is equipped and configured.
Phil
C?ID=122638
Polo Blue GT mirror tilt
VCDS Version: Release 15.7.4 (x64) Running on Windows 10 x64
Data version: 20160216
Thursday,28,April,2016,13:12:41:29196
Chassis Type: 6R (6C0)
Scan: 01 03 08 09 10 15 17 19 44 5F
VIN: WVWZZZ6RZFY214019 Mileage: 3991km-2479miles
Address 01: Engine Labels:
Part No SW: 04E 906 027 AT HW: 04E 907 309 AB
Component: 1.4l R4 TSI H21 8236
Coding: 01190032232419080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM14TFS01104E906027AT 001008
ROD: N/A
VCID: 76E66B2BC9B5318E54-8022
mattylondon
United Kingdom
C?ID=219022
On Audi's you move the adjustment dial from its centre position to the passenger side, see if that's the same on VW's.
Phil
C?ID=122638
Thanks have tried that but I can't tell if the hardware/software is in place to allow me to perform this function.
I doubt anyone else can either since your Auto-Scan stops after 01-Engine. ;)
RS4_ollie
C?ID=277460
I though you had to have memory seats for this to work. I could have made that up though :)
Phil
C?ID=122638
Sorry about the scan seems i now have a problem with windows 10 notebook will try & sort it.
Phil
C?ID=122638
Friday,29,April,2016,12:09:02:29196
Address 01: Engine (J623-CZEA)       Labels: None
   Part No HW: 04E 907 309 AB
   Revision: R6H21---
   ROD: EV_ECM14TFS01104E906027AT_VW26.rod
   VCID: 55A40CA734735A967D-8000
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: 08502194141115
   Coding: 23DD48858B2433C40914106A005AC412D1CC9008000ACB098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   VCID: 3360923F9A4764A6B3-8066
Address 08: Auto HVAC (J255)       Labels: 6C0-907-044.clb
   Part No SW: 6C0 907 044 A    HW: 6C0 907 044 A
   Component: Climatronic   H02 0105
   Serial number:  1412022A-0685
   Coding: 200000001001000001
   ASAM Dataset: EV_ACClimaValeoPQ26 003001
   ROD: EV_ACClimaValeoPQ26_SK25.rod
   VCID: 224E677B35BDFD2E48-8076
Address 09: Cent. Elect. (J519)       Labels: 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 B    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H07 0065
   Serial number: 009738007777
   Coding: 0310085042130AFB0B244080B12F07C800005B0257010000000000000000
   ASAM Dataset: EV_BCMA0 004008
   ROD: EV_BCMA0_SE25.rod
   VCID: 2F689E4F766F4046D7-807A
   Slave 2:
   Subsystem 1 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S5Y14M11D26H05M32S27
   Coding: 0038DD
   Subsystem 2 - Part No SW: 6R0 959 802 CK    HW: 6R0 959 802 CK  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 9620
   Serial number: KU0KU025061441768311
   Coding: 1400A1
   Subsystem 3 - Part No SW: 6R0 959 801 CH    HW: 6R0 959 801 CH
   Component: J387__TSG_BT  003 9620
   Serial number: KU0KU025061441766399
   Coding: 0400A1
   Subsystem 4 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY141903G1H
   Serial number: 00000000000060653223
   Subsystem 6 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS72.403  H02 0003
   Serial number: 0000FST0000L6MD00000
   Coding: 181001
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331431700132
   Coding: 0031151001
   ROD: EV_EPHVA18AU3700000_AU37.rod
   VCID: 3D74B407AC03A2D655-8068
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
   Component: VW20Airbag010 001 0330
   Revision: --------    Serial number: 003LM006YMR6
   Coding: 88C0C000000000005C000000008800000000
   ROD: EV_AirbaVW20BPAVW26X_SE25.rod
   VCID: 316C9837605B56B6C1-8064
   Subsystem 1 - Part No SW: -----------    HW: 410 821 011 14
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00A916D1962B3BX
   Subsystem 2 - Part No SW: -----------    HW: 410 820 811 14
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H009D16B6B82F3D7
   Subsystem 3 - Part No SW: -----------    HW: 442 152 811 14
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00BF17352719304
   Subsystem 4 - Part No SW: -----------    HW: 442 152 811 14
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00BF1735271F3CN
   Part No SW: 6C0 920 940 A    HW: 6C0 920 940 A
   Component: KOMBI         211 0290
   Coding: 272401002180260001082A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_VW26.rod
Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H07 0065
   Revision: --------    Serial number: 009738007777
   Coding: 030100047F0A560071000000000000010001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_SE26.rod
   VCID: 65C43C676413CA16ED-8030
   Subsystem 1 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H03 0102
   Serial number: 27140002546400054415
   Coding: 30FFFF
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 61331054142821154475
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 M    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3211
   Serial number: CEBE0914
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_VW26.rod
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 842     HW: 3Q0 035 842
   Component: MU-S-D-ER     H10 0135
   Serial number: VWZAZ2P4636136
   Coding: 02620000BE00000011111201000808001F0100D60120010000
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 6ADE4F5B8D0DE56EC0-803E
   Media Player Position 1:
   Subsystem 1 - Part No SW: 6C0 919 603 B    HW: 6C0 919 603 B
   Component: ABTm_Std2  H43 1017
   Serial number: VWZ8Z9PH10035V
End-------------------------(Elapsed Time: 02:29)--------------------------
DV52
C?ID=194404
Phil: what a very good question to ask -thankyou for doing so!
I also have a Polo 6R (as well as a Golf with titling mirror) and I was sufficiently intrigued by your question to do some research. According to the WD, the door equipment on a Polo is connected to the BCM whereas the Golf, which has reverse mirror tilt, has its own separate door control modules (which are only connected to the BCM via messages on the convenience CAN bus). This is confirmed by your autoscan which has a complete absence of any specific control modules related to the doors.
I guess that unlike the situation in a Golf, the BCM in a Polo could have added smarts for reverse mirror tilt, but I somehow doubt it.
Happy to be proven wrong
Phil
C?ID=122638
Don,
Thanks for your research I to had the Golf & Scirocco with mirror tilt & looking at their scans I can now see your analysis.The 6C uses a totally diff.system but who knows someone out there may know away to activate the tilt but it does look doubtful.
Thanks for your help Phil.
EduardJS
Romania
C?ID=307521
Hei Phil ... I know this is very old but I'm actively ( more like desperately ) looking for a owner of a BlueGT ( with factory Xenons installed ).
Please ping me if you're by any chance, still active here.
MasterTommy
Amsterdam
C?ID=295586
Well, even after activating you sometimes still have to set the mirror position when dipped. If you never did that it wont move.
Lets assume it is supported:
- Start engine
- Put in reverse gear
- Turn mirror dial to 'R'
- Adjust the mirror downwards
Now, if you drive away and hit the door-lock threshold speed or you turn the dial back to anything else but 'R', the mirror should move back to its starting position. If it doesnt, well yeah... :)
iichel
Netherlands, eastern part
C?ID=284912
no the Polo door control modules don't support this feature.
