Hi Guys,
This is the second time this error pops up, first time was at 591kms. I don't know where to start to troubleshoot the problem, since I've no idea when it will happen or what is like when it happen. Could you please shed some light on this? Thank you.
Monday,25,April,2016,21:16:03:64490
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWLF7AU9GW193259 License Plate:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 52 55
5F A5 A9
VIN: WVWLF7AU9GW193259 Mileage: 1882km-1169miles
Address 01: Engine (J623-CYFB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 H HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00122466000E3004
Shop #: WSC 53117 001 1048576
ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
ROD: EV_ECM20TFS0208V0906259H_VW37.rod
VCID: 45810E88C45A0C160D-8010
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4904
Revision: 06253104 Serial number: TFK01511102308
ROD: EV_TCMDQ250021_AU37.rod
VCID: 53A520D03A0EA2A693-8006
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 63165000002032
Coding: 01FA6BA15429096F0579030541CC6980D62A90A0C08296B7184050D8C288
VCID: 7AFBAD74FD24B3EE30-802E
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0385962962
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A7B6D74BDA473EE70-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020004200100010105000000101002
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 6ADB9D348D84036EC0-803E
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 085 AJ HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number: 01061531301159
Coding: 00011A46C041A2F149E44000091C07201800000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 0109DA9890F2E03671-8054
Slave 1:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 151017 043 0551
Serial number: 151102233844
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y15M11D24H15M03S25
Coding: 96A8DD
919560 - Light Switch
B126A 29 [008] - Signal Implausible
Reset counter: 100
Mileage: 1327 km
Date: 2016.04.11
Time: 18:40:27
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391531808594
Coding: 0071155011
ROD: EV_EPHVA18AU3700000_SK48.rod
VCID: 43851090CA6E322623-8016
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 28101503214139
Coding: 01045700FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
ROD: EV_ACCMRRBoschVW372_AU37.rod
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 03111541350247
ROD: EV_DRCONTITEMIC.rod
VCID: 377D74408EB66E868F-8062
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM02CTDY
VCID: 51A92AD80012D0B6A1-8004
Seat occupant detection; front passenger side:
Component: BF-Gewichtss. H11 0021
Serial number: IBH0000J150003JS6E0C
Coding: 30324E
Subsystem 2 - Part No SW: ----------- HW: 480 002 011 15
Serial number: 3570000000045671971C
Subsystem 3 - Part No SW: ----------- HW: 480 002 111 15
Serial number: 358000000004338DD71P
Subsystem 4 - Part No SW: ----------- HW: 480 401 611 15
Serial number: 35100029B1DBD6223354
Subsystem 5 - Part No SW: ----------- HW: 480 401 311 15
Serial number: 3520002B11DBD62061E5
Subsystem 6 - Part No SW: ----------- HW: 480 401 311 15
Serial number: 3550002A91DBD62561CI
Subsystem 7 - Part No SW: ----------- HW: 480 401 311 15
Serial number: 3560002AD1DBD624928M
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 24101504401899
Coding: 0C10
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 0919C2B8A8C2A87629-805C
Part No SW: 5G1 920 758 A HW: 5G1 920 758 A
Component: KOMBI 302 6420
Coding: 0BAD081A7F88880902886A0B5400000000000000
VCID: 2D5156287CEAD456E5-8078
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 17111510803078
Coding: 0101000838085900FB00023A9C0F00000001050000000000000000000000
ROD: EV_GatewConti.rod
VCID: 79F9B278F822B8F639-802C
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S
Component: E221__MFL-DC1 H11 0040
Serial number: 29150002033500085415
Coding: 35FFFF
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00009.10.15
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_AU21.rod
VCID: 4A9B3DB4ED44E36EE0-801E
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000246023006
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 3467434C9FC0859EAA-8060
Address 3C: Lane Change (J1086) Labels: None
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0385972139
Coding: 02011103
ROD: EV_HREntryHella_SK37.rod
VCID: 3C776B6CB7904DDE62-8068
Lane Change Assistant 2:
Component: TSG FS 020 0041
Serial number: 290915BIT02124
Coding: 003E13208000040000000000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000008170659
Coding: 111000
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 9102
ROD: EV_SteerAssisMQB.rod
VCID: 39797278B8A278F679-806C
Component: TSG BFS 020 0041
Serial number: 021015BJ202635
Coding: 003E13208C00040000800000
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 428B1594D5743B2E28-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000008057158
Coding: 091000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 022202010B010400
ROD: EV_HeadlRegulVWAFS_SE26.rod
VCID: 408F1F9CDB78293E3E-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 3G0 035 047 A HW: 3G0 035 047
Component: MU-H-NS-US H42 0344
Serial number: A296J0FB000895
Coding: 027300020000000051220002001828001F0207F401200105DE
ROD: EV_MUHig4CGen2HBAS_BY63.rod
VCID: 1E3381E4014C3FCE6C-804A
Media Player Position 1:
Radio Tuner - Digital:
Subsystem 2 - Part No SW: 5G0 919 606 B HW: 5G0 919 606 B
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU90032Q
Engine Control Module 2:
Subsystem 3 - Part No SW: ----------- HW: -----------
Component: ------------- --- ----
Seat Adjustment Driver Side:
Subsystem 4 - Part No SW: V03 959 802 NL HW: -----------
Component: NAR 2016 --- 0048
Air Conditioning Compressor:
Diesel Pump Control Unit:
Door Electronics Driver Side:
Subsystem 7 - Part No SW: ----------- HW: -----------
Brake Assistance:
Subsystem 8 - Part No SW: ----------- HW: -----------
Interior Monitoring:
Subsystem 9 - Part No SW: ----------- HW: -----------
Sound System:
Door Electronics Rear Left:
Subsystem 12 - Part No SW: ----------- HW: -----------
Subsystem 13 - Part No SW: ----------- HW: -----------
Subsystem 14 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 3007
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000459159
Coding: 0100000000020308000400010100000100
ROD: EV_MFKBoschAU370_AU37.rod
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 150826200215
VCID: 2F6D4C2076E6A646D7-807A
End-------------------------(Elapsed Time: 05:17)--------------------------
