Yet another MKV with a ABS problem
8 months ago the problem started with loosing traction and wheel hop on a hard launch.
every light on the dash came on and 3 beeps no MPH gauge of fuel gauge.
Had the ABS module rebuilt and all was good for about 6 months
The other day the dash lit up and will not rev past 4k no boost etc
3 beeps all lights on dash ESP ABS air bags no fuel level or speed gauge.
Sent module in for warranty got it back no change and now no communication with ABS module.
I checked voltage and ground at the module all is good as far as I can tell
Checked grounds under battery and other locations
Replaced batter,alternator and MAF sensor
I believe the fault to be in the ignition possibly but just don't want to throw parts at this car. If someone can look at my file I posted and make some suggestions that would be great. Hopefully I posted enough info.
Everything else on the car works great.
right now. 3 beeps,only 4k,no boost, CEL,ABS,ESP,no fuel or speedo working.
Thank you. BTW first time posting so I probably did something wrong. lol
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRJ71K39xxxxxxx Mileage: 201290km-125075miles
03-ABS Brakes -- Status: Cannot be reached 1100
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AE HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH03--- Serial number: VWX7Z0H62410KP
Coding: 0403010A18070160
VCID: 69F747DF40450B76C9-803C
053285 - Please Check Fault Codes in Control Module for HVAC (J301)
U1025 - 000 -
Mileage: 201299 km
Time: 00:38:09
Temperature: 29.0°C
Temperature: 21.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.557 V
049441 - No Communication with ABS Brake Control Module
U0121 - 000 - - MIL ON
Fault Status: 11100000
Mileage: 201299 km
Time: 00:38:09
Temperature: 29.0°C
Temperature: 21.0°C
Voltage: 11.557 V
Readiness: 0110 0100
Address 03: ABS Brakes
Part No SW: 1K0 820 047 HS HW: 1K0 820 047 HS
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 7CD90E8B3FD78EDE22-8028
009 - Open or Short to Ground
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Revision: 00H54000 Serial number: 00000001006682
Coding: 14058E234004150007140000001400000008730B5C000120000000000000
VCID: 6FC329C77EA1E54697-803A
Component: Wischer 100708 021 0501
Coding: 00038805
Shop #: WSC 00066
Reset counter: 175
Mileage: 201299 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 9.15 V
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0357742
Coding: 0000100
VCID: 334BE5B7520981A6B3-8066
00532 - Supply Voltage B+
Reset counter: 175
Mileage: 201299 km
Time: 22:03:55
Voltage: 8.40 V
Reset counter: 175
Mileage: 201299 km
Time: 22:10:14
Voltage: 7.40 V
Reset counter: 225
Mileage: 144688 km
Time: 05:09:08
01304 - Radio
Fault Frequency: 78
Reset counter: 174
Mileage: 201299 km
Time: 07:16:29
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M05W6BA
Coding: 0013889
VCID: 6CF93ECB4FB71E5EB2-8038
Subsystem 1 - Part No: 000 000 000 000
Component: BF-Gewichtsens. 000 0000
Subsystem 2 - Serial number: 6332MSME290365084
Subsystem 3 - Serial number: 6342MSME2D25561CI
Subsystem 4 - Serial number: 6351HSME163F013EA
Subsystem 5 - Serial number: 6361HSME164F5729H
Subsystem 6 - Serial number: 63727SME157E1133
Subsystem 7 - Serial number: 63827SME160E5F44A
02511 - Control Module for Seat Occupied Recognition (J706)
012 - Electrical Fault in Circuit - MIL ON
Part No SW: 1K0 953 549 BR HW: 1K0 953 549 BR
Component: J0527 051 0101
Coding: 0000021
VCID: 032B75774229F12663-8056
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Part No SW: 1K0 920 954 R HW: 1K0 920 954 R
Component: KOMBIINSTRUMENT 3HL 1222
Revision: V0003000 Serial number: VWX7Z0H62410KP
Coding: 0023203
VCID: 3B5BCD977A5949E66B-806E
Reset counter: 136
Mileage: 201298 km
Time: 04:51:50
Reset counter: 157
Mileage: 201299 km
Time: 23:08:28
Reset counter: 165
Mileage: 201299 km
Time: 06:00:57
00771 - Fuel Level Sensor (G)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 136
Mileage: 198831 km
Time: 06:24:41
Fault Frequency: 9
Reset counter: 175
Mileage: 201299 km
Time: 05:59:59
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 260508F1001366
Coding: E9807F070003021002
VCID: 354FDBAF5C7D9F969D-8060
Fault Status: 00110100
Reset counter: 157
Mileage: 201299 km
Time: 23:08:29
Reset counter: 64
Mileage: 201298 km
Time: 20:40:29
01304 - Radio
Reset counter: 174
Mileage: 178756 km
Time: 11:01:53
Reset counter: 175
Mileage: 201299 km
Time: 06:00:58
Component: IMMO 3HL 1222
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000313888630
Coding: 0001205
Reset counter: 166
Fault Status: 01100101
Reset counter: 136
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
VCID: 2A75F8D385C3C06E00-807E
Reset counter: 64
Mileage: 201298 km
Time: 04:51:53
Voltage: 14.13 V
DU
Temperature: 18.0°C
RPM: 1107 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
Reset counter: 167
Mileage: 201299 km
Time: 23:08:29
Voltage: 12.00 V
DU
Temperature: 36.0°C
RPM: 1498 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DCA0
VCID: 0429766B4727F61E5A-8050
Fault Frequency: 11
Reset counter: 175
Mileage: 201299 km
Time: 06:00:57
00625 - Vehicle Speed Signal
Reset counter: 136
Mileage: 201299 km
Time: 00:25:22
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 00000006688630
Coding: 0001204
VCID: 70C12ABB639FFABE8E-8024
Reset counter: 166
Reset counter: 136
Mileage: 201299 km
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7H2214118
Coding: 0010400
VCID: 297707DF80C5CB7609-807C
00003 - Control Module
014 - Defective
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003281352
Coding: 0001168
VCID: 76CD1CA301FBD48E54-8022
00934 - Electric Window Motor; Rear Left (V26)
Fault Status: 00100101
Reset counter: 158
02071 - Local Databus
Reset counter: 175
Component: RDK 0450
Coding: 0100101
Fault Status: 01111000
Fault Frequency: 255
Reset counter: 135
Mileage: 201299 km
Time: 22:10:21
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003247444
Coding: 0001168
VCID: 77D311A706F1AD864F-8022
Reset counter: 175
End-------------------------(Elapsed Time: 01:19)--------------------------
