Page 1 of 10 123 ... LastLast
Results 1 to 10 of 96
Thread: 2016 A3 - Disable Parking Lights - US Spec?
    Feb 2016
    CT
    Hi all
    Has anyone done the digging around to figure out how to disable the corner lights on North American cars? I'd obviously still want them to blink when I put them on for turning but hate how they look on!
    I would imagine it's in that 09 Central Elec Adaption list, it seems like all light controls are in there, but can't figure it out.
    Thanks,
    Jun 2014
    Disabling the cornering lights is very easy under the adaptation channels.
    It's probably under channel 8FL and 9FL, best thing is post a full adaptation map up and we can then advise.
    Also can you clarify, you want the cornering fogs to blink?
  3. Likes AudiSportB5S4 liked this post
    Feb 2016
    CT
    Quote Originally Posted by Xpower View Post
    Nice! Figured.. Just so many things in there. When you say post a full adaption map, what do you mean? I have posted a full auto scan in a separate thread in the proper forum, is that the same thing? If not, how can I post a full adaption map? Thanks for your help!
    To be clear.. Looking to turn off the TURN SIGNALS.. I shouldn't have said cornering lights..
    Hmm.... I'm by no means an expert on A3s (NAR, or RoW vehicles), but on my MQB platform vehicle, it really depends on what type of corning light system is installed in the car. My understanding is that there are currently three versions of "cornering lights" used on MQB platform vehicles:
    1. on the bog-standard incandescent headlight assemblies, there is a form of cornering light where the steering wheel angle operates the fog-light. The settings for this arrangement are indeed controlled by Leuchte programming within the BCM adaptation channels (the Leuchte command is Abbiegelicht links, or Abbiegelicht rechts)
    2. then there is the static cornering light system that uses a halogen lamp and an additional reflector which is behind the turn signal light, inside the Xenon headlight assemblies
    3. lastly, there is the more sophisticated dynamic cornering light system that swivels the Xenon lamp assembly horizontally to provide cornering light functionality
    I don't believe that systems (2) and (3) above are controlled by the BCM. Rather I remember reading somewhere (might have been a SSP) that cornering light control happens via the headlight range control unit (J745) and a special CAN bus that is specifically designed for lighting (can't remember its name, but I can remember being surprised to read that it was a stand alone CAN bus totally unrelated and unconnected to the activities of J533 - I think). This means that disabling the cornering lights on (2) and (3) systems above is probably done via coding/adaptation channels in J745 (not the BCM). I've had a look at the admap for the headlight range control module (address Hex55) on a couple of mk7s in my database and they have a very small suite of adaptation channels - nothing vaguely suggestive of "cornering lights". Might be worth looking at the Long Coding helper for this module (I don't have any info on this)
    Happy to be corrected - and to learn more!
    PS: When referring to "a full Adaptation map" I think that Xpower meant this
    VW Golf MkVII (103TSI) my13
    Feb 2016
    CT
    Ah okay thanks! If that's what he needs I have to do that when I am home later on.
    BTW, just to be clear, I'm talking about turn signals, not fog lights. I know the word cornering light can easily be confused with the function that when you turn your wheel the fog light on that side if equipped will illuminate while the steering wheel is moved in either direction.
    My goal is to turn off the amber side markers that are on in the US market while the headlights are on.. My goal is to have them run like the EU cars where those are only on when turn signal activated.
    Jun 2014
    Ah ok, DoN is correct on the ad map front and we need this to go any further.
    Do you have seperate amber running lights or is it just the front indicator lit dimly?
    Feb 2016
    CT
    Alright I feel like this has to help me achieve what I am looking for!
    I linked the CSV file on my Dropbox for now.. Is there a better way for me to attach this?
    Again, looking to deactivate the "parking lights" which are illuminated with the headlights being on and double as the turn signals when activated. I want to keep the turn signals functioning, but the lights off otherwise.
    https://www.dropbox.com/s/8gmvclnv1b...3_Map.CSV?dl=0
  9. #8
    Feb 2016
    CT
    For what it's worth - I tried changing "Driving light and parking light - Parklicht uever LSS aktiviert as the value that was stored was "Parklichtfunktion USA and Kanada" thinking this could be it but it was not.. I forget what I changed it to but whatever it was didn't work.
  10. #9
    Quote Originally Posted by AudiSportB5S4 View Post
    AudiSportB5S4: Given that I don't have an A3, I'm extrapolating the nomenclature on a mk7. But I hope the following observations are useful:
    First I must apologise, because your original post mentions "corner lights" which I understood to mean "cornering lights". But your clarification above confirms that you are referring to the multipurpose parking lights/turn signal (and I suspect two more functions- see later explanation) in the headlight assembly.It's good therefore that you made an admap of the BCM.
    There is much common between your A3 and my mk7 where exterior lighting control is concerned - they both use "Leuchte" programming. I've had a look at your admap for lamps that function both as parking lights and as turn signals in an attempt to locate the correct Leuchte-sets on your A3. The only two Leuchte-sets that satisfy this criteria in your admap are Leuchte2SL VLB10 (left-side lamp) and Leuchte3SL VRB21 (right-side lamp). The complete listing for each Leuchte-set from your admap is shown below
    I've also identified in the table, the "cluster" of adaption channels that perform the various functions in the Leuchte-set and I have included commentary on what each Leuchte command does. If my identification of the Leuchte-sets is correct, the lamps in question perform the following four functions:
    1. Parking Lights - Illumination level 30%
    2. Coming Home/Leaving Home - illumination 30%
    3. DRL function - level 100%
    4. Turn Signal - does this function blink counter to the front turn signals?
    Is this correct for your car? If so, then I believe that the easiest way to "disable" the parking light function is to alter the associated dimming level to 0%. This is done as follows:
    1. Change the setting of (6)-Leuchte2SL VLB10-Dimmwert AB 2 from 30 to 0
    2. Change the setting of (6)-Leuchte3SL VRB21-Dimmwert AB 3 from 30 to 0
    PS: with the changes suggested, the lamps will still function as DRLs, CH/LH and Turn Signals
  11. Likes AudiSportB5S4, Uwe liked this post
  12. #10
    Feb 2016
    CT
    Thanks DV52! Appreciate the effort.. I will give that a shot and report back.
    I have to be in front of it to confirm, there are so many things so when I'm at work I have no clue . I'll try that tomorrow when I have the chance and see if that turns them off.
    Side note - can an admin update the thread title to read "Disable US Parking Lights"?.. Much more accurate.
