Page 11 of 13 FirstFirst ... 910111213 LastLast
Results 101 to 110 of 123
Thread: Testbench setup?
  1. #101
    Quote Originally Posted by Eric View Post
    I do need it! I'm merely interested in a permanent terminal 15 solution so other modules can power up and talk to VCDS.
    Eric: Here you go_
    I'm not sure if you "Yanks" get taught these diagrams the same as us Southerners, but I hope the table is self explanatory
    I've shown the way the Key-switch connector locks into the body of the steering module in the lower LHS to indicate the relative position of pin#1
    Lastly, I suspect that you probably know having hooked-up the steering module to your test-bench, but the PC board into which the key-switch connector fits is double-sided. So the Pins make contact on both sides of the board as shown in the lower LHS picture
    VW Golf MkVII (103TSI) my13
  2. Likes Eric, Uwe, jyoung8607, Jack@European_Parts liked this post
  3. #102
    I have a little set up like this for use on BT, RNS, gateway and window modules. i'm having a small issue that I can't get round hoping someone can help.
    so with regard to the window wiring i'm mainly connecting gen 3 units so + power on 20 and 18, - on 19, can on 8 and 9, so I wanted to talk to a gen 2 unit the other day the only difference being pin 18 is now pin 12 for gen 2, but for the life of me it will not connect to the unit, elsa tell me can connections are the same going to convenience pins on the gateway. power all tested and all ok, one gen 2 unit is vw the other two are seat, so I even changed the vehicle manufacturer between vw and seat in the gateway but still won't talk to the modules.
    any idea please.
    thanks
  4. #103
    Eric: Here you go_
    Victory! Your table matches perfectly the old MQB diagram we found after I came begging for your assistance:
    however I hadn't bothered connecting pins T16r/7-14-16 to their mates on 09, because, who needs that, right? Seriously, why can't 16 determine the switch status on its own!?
    Anyway, now the measuring values show terminal 15 going to ON when I short 3-5-6. Thanks Don, you gave me the determination to look further than just the switch connection, once I knew we had it right
    Bonus video produced and directed by Andy:
  5. Likes Andy, DrPeter, DV52, Dana, Uwe and 3 others liked this post
  6. #104
    Administrator Andy's Avatar
    Bonus:
  7. Likes DV52, DrPeter, Dana, Uwe, jyoung8607 and 3 others liked this post
  8. #105
    Eric: No offense, but that's the weirdest American accent I've ever heard!!!
    Well done- it took me a long time to get to the stage that you're at with your test bench - but then, I didn't have Andy, or a nifty "Sperry" multi-meter as aids!!!
    Just a minor point about "connecting pin3 to pin 5 and pin 6" (as your say in the video), my experience has been that some of the modules in my test bench (i.e. the BCM occasionally, but more frequently, the instrument module - and others) get cranky if the steering module doesn't also see pin 4 connected. Makes sense (IMO) - because in a real car the "S" contact is closed before, and during the period of ignition-on and engine-on (because of the act of inserting the key shaft into the key-switch). Something to consider!
  9. Likes Eric, Dana, Andy, Uwe, Jack@European_Parts liked this post
  10. #106
    Feb 2017
    I've looked at the current flow diagram for a 2014 e-Golf and in the fitting location section/ connector view and there are two pins labelled as Terminal 15. These are 16 and 14. Below shows how they connect to the J519 module :
    Module J519 T73a/47 goes to module J527 T16r/16 which appears in the cruise control section.
    Module J519 T73a/44 goes to module J527 T16r/14 which appears in the turn signal switch, horn plate and airbag section.
    Not sure if this is any use???
  11. #107
    OBD is wierd!!
    So, more questions about stuff that I probably should know - but don't
    When I wired-up the OBD port on my test bench I connected the CAN and power supply pins thinking that that's all that was needed. I'm now contemplating adding an airbag module (for no other reason than I can get one gratis). However, a quick glance at the WD has me puzzled:
    Yes, pin #15 on the OBD port apparently does stuff on a mk7- go figure!!
    If I look at the standard pin-out on and OBD port, I find:
    So- question: Does the VCDS dongle read (write?) from the L-line pin?
  12. #108
    Yes. ISO specified pin 15 as the L-line, but that use has been deprecated for roughly 20 years now and VW/Audi used it as a second K-line for a while (~2001-2008) when they had some cars (primarily Audi A4 and A6) that had too much stuff to hang on one K-line.
    I'm somewhat surprised to see this in an Mk.7...
    However, there was also a Polo back in 2008 that gave us fits due to a mystery wire to pin 15...
  13. #109
    Uwe: thanks (also thanks for not making me feel so foolish in asking the question) - so does a HEX-NET actually connect to this pin? And what was L-line used for in the earlier models (resetting the airbag module -perhaps)?
  14. #110
    Yes, a HEX-NET will connect to a K-line module on pin 15.
    Of course, whether an Mk.7 Airbag module actually responds in the way that older K-line modules did is another question. This connection might be intended for some (even more) proprietary tool to read out crash data when the all the CAN stuff in the car is toast due to a crash? I'm not sure.
    On really old cars, the L-line was a unidirectional signal from the scan tool to the car on which the normal 5 bps initialization sequence was duplicated. I suppose it went to a separate UART in the some control modules that did nothing but listen for init sequences?
  15. Likes Eric, DV52 liked this post
