Monday,04,April,2016,18:49:04:22573
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Workshop Code: 444 00001 012345
VIN: WAUZZZ8V6FA018259 License Plate:
Mileage: 14957km-9293mi Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WAUZZZ8V6FA018259 Mileage: 14957km-9293miles
Address 01: Engine (J623-CZEA) Labels: None
Part No HW: 04E 907 309 AB
Component: 1.4l R4 TSI H21 8139
Revision: R6H21---
Coding: 02190012230401082000
Shop #: WSC 29156 001 1048576
ASAM Dataset: EV_ECM14TFS01104E906027BL 001006
ROD: EV_ECM14TFS01104E906027BL_AU37.rod
VCID: 55A1E97E34597B967D-8000
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 61654000000178
Coding: 12F16AA224212A740179060541CC294856245480608294F2002100788608
Shop #: WSC 06314 790 00021
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 4581393EC4F9CB160D-8010
Address 08: Auto HVAC (E87) Labels: 8V0-820-047.clb
Part No SW: 8V0 820 047 D HW: 8V0 820 047 D
Component: AC Manuell el H11 0052
Revision: 20021000 Serial number: 00000000072633
Coding: 03000004000000001000000000000000
ASAM Dataset: EV_AirCondiFrontManAU37X 008018
ROD: EV_AirCondiFrontManAU37X.rod
VCID: 377D43F68E15A9868F-8062
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 AF HW: 5Q0 937 084 AF
Component: BCM MQBAB B H18 0134
Serial number: 01011415500511
Coding: 04040842C241005543D44004000407080000000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 7CF79CDAF7B34ADE22-8028
Slave 1:
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 140604 042 0580
Serial number: 140607015551
Coding: 0A47F7
Slave 3:
Subsystem 2 - Part No SW: 8V0 941 531 M HW: 8V0 941 531 M
Component: E1 - LDS MQB H05 0032
Serial number: 11 04 2014 00000370
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R0765WI
Coding: 98CCC0000C0000005C540000004800000065
VCID: 4B950F06E29D3D66DB-801E
Subsystem 1 - Part No SW: ----------- HW: 480 001 306 14
Serial number: 35767000000327A4201E
Subsystem 2 - Part No SW: ----------- HW: 480 001 306 14
Serial number: 35867000000D07A4201N
Subsystem 3 - Part No SW: ----------- HW: 480 401 206 14
Serial number: 3516502B5156E9E122CI
Subsystem 4 - Part No SW: ----------- HW: 480 401 206 14
Serial number: 3526502B9156E9E4F1F+
Subsystem 5 - Part No SW: ----------- HW: 480 401 505 14
Serial number: 3556502AF157E9E3C20W
Pedestrian protection crash sensor; driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 400 306 14
Component: PedP_Sensor_D 001 6149
Serial number: 2286502B515F3C310285
Pedestrian protection crash sensor; front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 400 306 14
Component: PedP_Sensor_P 001 6149
Serial number: 2296502C915C42126374
Center pedestrian protection crash sensor:
Subsystem 8 - Part No SW: ----------- HW: 480 400 306 14
Component: PedP_Sensor_C 001 6149
Serial number: 23065029915C4216421V
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 BM HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 16061404220825
Coding: 8408
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 0603FE32B97F000E44-8052
Part No SW: 8V0 920 860 G HW: 8V0 920 860 G
Component: KOMBI H01 4291
Coding: 0780090023800008000028001000000000000000
VCID: 3E7356D2A12F98CE4C-806A
Part No SW: 5Q0 907 530 R HW: 5Q0 907 530 D
Component: GW MQB Low 126 1188
Revision: -------- Serial number: 0001993884
Coding: 030000042F0857005B000248080000000001010000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear.rod
VCID: 408F282ADBDBEE3E3E-8014
Subsystem 2 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 2030053603
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 29051403110329
Coding: 00100F204100040000001002
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000002946764
Coding: 110000
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 0103
ROD: EV_SteerAssisMQB.rod
VCID: 41892D2ED0D1E73631-8014
Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
Component: TSG BFS 020 0025
Serial number: 02061401100335
Coding: 001007204100040000001002
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 3D7151DEAC2983D655-8068
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000002930174
Coding: 090000
Address 5F: Information Electr. (J794) Labels: 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 840 B HW: 8V0 035 840 B
Component: MU-S--ER 041 0420
Serial number: A3E01406142628
Coding: 01730300FF00000011110001000A00002F0001040100010000
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_AU37.rod
VCID: 346774FA9F63429EAA-8060
Seat Adjustment Driver Side:
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0013
Serial number: AUZ8Z9EY3044ES
Sound System:
Subsystem 2 - Part No SW: 8V0 919 614 P HW: 8V0 919 614 P
Component: ControlUnit_B H41 0054
Serial number: C1000008051400010210
End-------------------------(Elapsed Time: 02:46)--------------------------
