Abs coding help
Iobau998
Pirate
Walking the Plank
Romania
Good evening. I have a 2009 passat cc.
I upgraded the ABS pump software for ACC retrofit.
After upgrade, everything is working ok (including the ACC) but i lost the AutoHold function that i had it before
Deleted.   Data from illegally pirated copies of VCDS is not welcome here!
Scan after: (coding after was made from different combinations from internet)
Trade Member
C?ID=271231
I wonder if the code in the second scan should be the same as the code in the first scan?
You could keep a log of the codes and try it?
Iobau998
Pirate
Walking the Plank
Romania
I tried old code + ACC code but code rejected.
The code from new scan is from internet, is with Tpms and acc suport and was accepted.
I do not know what to add or minus from new code to activate back the autohold.
I do not know how to find out the Base code for new Abs
Trade Member
C?ID=271231
At the header of the forum you will see some tabs, wiki is one that might have some information to help you, happy reading. :)
Iobau998
Pirate
Walking the Plank
Romania
No luck with wiki, that is way i posted
golfi_vend
Tartu, Estonia
C?ID=195131
Start by posting correct autoscan.
But out of curiosity i would try [Edit: Not until he reforms]
