Mk70 abs Module mk70m retrofit
Adam87
C?ID=153293
Hoping someone can shed some light on this situation before I tackle this job, I currently have 1K0 907 379 P abs module (mk70) and want to swap it to 1K0 907 379 AF (mk70m) so that I can fit a newer style cluster, reason for the swap is that the older abs module won't talk properly to the newer instrument cluster.
There's not too much documented about doing that swap over so if anyone knows it's possible to do or what is needed to do it would be a good help.
Cheers
Dana
Western PA, USA
I don't know if this is going to be compatible Adam. I hope someone with Caddy specific experience is able to offer feedback but as far as I can tell that 1K0 907 379 P module supersedes directly to 1K0 907 375 P and that AD variant appears to fit 2009+ so you may encounter a number of issues.
