Hello all,
Over the weekend I installed OEM Golf R headlights with OEM ballasts. In an attempt to disable the bulb longevity feature so that full voltage would reach the ballasts, I changed the long coding to the 09 Electrical module. Unfortunately, in my haste to leave for work, I changed the code and now the BCM is unresponsive. All of the lights now constantly flicker, the doors don't lock/unlock, alarm doesn't function, etc. I can no longer access 09-Cent Electrical to change the code back. I found that some others have had a similar problem, but I can't seem to find a solution. Does anyone know if anything can be done to fix this?
Any help would be great appreciated.
I'll post a full scan when I get home this evening.
Thank you,
Sean
Thank you,
Sean
