Wednesday,09,March,2016,16:13:02:49480
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: TMBJB9NEXG0190603 License Plate:
Mileage: 101km-62mi Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F 6D A5
VIN: TMBJB9NEXG0190603 Mileage: 101km-62miles
Address 01: Engine (J623-CYVB) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 GR HW: 04E 907 309 BL
Component: R4 1.2l TFS H23 2394
Revision: R4H23---
Coding: 01190072232419080000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM12TFS01104E906027GR 001005
ROD: EV_ECM12TFS01104E906027GP_SK37.rod
VCID: 7AF0EA33FD1E11EE30-802E
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 50186000002117
Coding: 1C076A911429296C007D060041C6243856289400608224F210230070C002
Shop #: WSC 73430 031 00063
ROD: EV_Brake1UDSContiMK100ESP_SK37.rod
VCID: 4B9E7FF7E2045866DB-801E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5E0 907 044 T HW: 5E0 907 044 T
Component: Climatronic H04 1002
Revision: 00001K07
Coding: 02010004000100011005000100101000
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 36683E038986358E94-8062
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Revision: -------- Serial number: 865827011601WR
Coding: 0C000966424702FB4FE44004001C17080000000000000000000000000000
Shop #: WSC 73430 790 00000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 030E97D78AD4502663-8056
Slave 1:
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 160109 041 0570
Serial number: 160122211328
Coding: 065DDD
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S2Y16M02D01H05M26S53
Coding: 028877
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391602508809
Coding: 0031051041
Shop #: WSC 73430 790 00063
ROD: EV_EPHVA18AU3700000_SK37.rod
VCID: 438E57D7CA54902623-8016
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 12011603271151
Coding: 00000400FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001016
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 3A702A33BD9ED1EE70-806E
Part No SW: 3Q0 959 655 AQ HW: 3Q0 959 655 AQ
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SNP10LUNP
Coding: 98FCC000000000005C5400CC000800000065
ROD: EV_AirbaVW20TS6VW48X_SK37.rod
VCID: 0D1AB1EFDC90165605-8058
Seat belt tensioner; left:
Component: BeltPretRevFL H36 0350
Serial number: 34169593B31011650114
Coding: 333135
Seat belt tensioner; right:
Component: BeltPretRevFR H36 0350
Serial number: 34169592B02021690339
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 454 001 201 16
Serial number: 3576U000000D0470091%
Subsystem 4 - Part No SW: ----------- HW: 454 001 301 16
Serial number: 3586U00000020650091W
Subsystem 5 - Part No SW: ----------- HW: 454 802 312 15
Component: SideSensor_Dr 301 0148
Serial number: 3516RF00877090000002
Subsystem 6 - Part No SW: ----------- HW: 454 801 812 15
Component: SideSensor_Pr 301 0148
Serial number: 3526R5FE87D09000000S
Subsystem 7 - Part No SW: ----------- HW: 454 801 512 15
Component: FrontSensor_D 304 0149
Serial number: 3556V87EA8709000000R
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 M HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160202501318
Coding: 1400
ROD: EV_SMLSVALEOMQB.rod
VCID: 3C7C2C2BB7AAEFDE62-8068
Part No SW: 5E0 920 750 B HW: 5E0 920 750 B
Component: KOMBI 325 6422
Coding: 07A40A006180000801886A031000000000000000
VCID: 234EF7572A14B02643-8076
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 F
Component: GW MQB High 128 1244
Revision: -------- Serial number: 0004450738
Coding: 030100047F085700EB00024C080F00010001050000000000000000000000
ROD: EV_GatewLear.rod
VCID: 79F2F53FF8181AF639-802C
Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000D1597250116
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185704001601212150
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 0000184101889
Coding: 00150920D000048000001100
ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
VCID: 479643C7FE6CBC06FF-8012
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000008759673
Coding: 010200
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 1103
ROD: EV_SteerAssisMQB.rod
VCID: 448C54CBCF5A971E1A-8010
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000184002559
Coding: 00150120D000048000001100
ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
VCID: 46884EC3F966A50E04-8012
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000008766521
Coding: 190200
Address 5F: Information Electr. (J794) Labels: 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 864 A HW: 5Q0 035 864 A
Component: MU-S-N-ER H24 0245
Serial number: SKZAZ2S8217100
Coding: 037302010000000011110002000800002F0200E401200100C6
ROD: EV_MUStd4CTSAT_SE25.rod
VCID: 31620D1F60E812B6C1-8064
Media Player Position 1:
Subsystem 1 - Part No SW: 5E0 919 605 J HW: 5E0 919 605 J
Component: ABT_Std-2_Nav H41 1028
Serial number: SKZ8Z9SBT01P02
Engine Control Module 2:
Subsystem 2 - Part No SW: 5L0 051 236 H HW: -----------
Component: ECE 2016 --- 0521
Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
Part No SW: 5E0 959 107 A HW: 5E0 959 107
Component: HDSG-Modul H01 0746
Revision: 42001001 Serial number: 006600643
Coding: 1233074002
ASAM Dataset: EV_HDSGSk462 301136
ROD: EV_HDSGSk462_SK37.rod
VCID: 2A501A734D3E616E00-807E
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000493200
Coding: 0100010001030306000000000100000100
ROD: EV_MFKBoschAU370_AU37.rod
